RTEMS 5.2-rc1
Block device disk management implementation. More...
#include <stdlib.h>#include <unistd.h>#include <string.h>#include <rtems.h>#include <rtems/libio.h>#include <rtems/diskdevs.h>#include <rtems/blkdev.h>#include <rtems/bdbuf.h>#include <rtems/thread.h>Data Structures | |
| struct | rtems_disk_device_table |
| #define | DISKTAB_INITIAL_SIZE 8 |
Typedefs | |
| typedef struct rtems_disk_device_table | rtems_disk_device_table |
| rtems_status_code | rtems_disk_create_phys (dev_t dev, uint32_t block_size, rtems_blkdev_bnum block_count, rtems_block_device_ioctl handler, void *driver_data, const char *name) |
| rtems_status_code | rtems_disk_create_log (dev_t dev, dev_t phys, rtems_blkdev_bnum block_begin, rtems_blkdev_bnum block_count, const char *name) |
| rtems_status_code | rtems_disk_delete (dev_t dev) |
| rtems_disk_device * | rtems_disk_obtain (dev_t dev) |
| rtems_status_code | rtems_disk_release (rtems_disk_device *dd) |
| rtems_disk_device * | rtems_disk_next (dev_t dev) |
| rtems_status_code | rtems_disk_io_initialize (void) |
| rtems_status_code | rtems_disk_io_done (void) |
