RTEMS 5.2-rc1
diskdevs.h
1
9/*
10 * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
11 * Author: Victor V. Vengerov <vvv@oktet.ru>
12 */
13
14#ifndef _RTEMS_DISKDEVS_H
15#define _RTEMS_DISKDEVS_H
16
17#include <rtems.h>
18#include <rtems/libio.h>
19#include <rtems/chain.h>
20
21#ifdef __cplusplus
22extern "C" {
23#endif
24
26
45typedef uint32_t rtems_blkdev_bnum;
46
52 uint32_t req,
53 void *argp
54);
55
59#define RTEMS_DISK_READ_AHEAD_NO_TRIGGER ((rtems_blkdev_bnum) -1)
60
64typedef struct {
69
77
86
92typedef struct {
99 uint32_t read_hits;
100
108 uint32_t read_misses;
109
116
120 uint32_t read_blocks;
121
127 uint32_t read_errors;
128
135
139 uint32_t write_blocks;
140
146 uint32_t write_errors;
148
161 dev_t dev;
162
168
172 uint32_t capabilities;
173
177 char *name;
178
184 unsigned uses;
185
193
198
205
214 uint32_t block_size;
215
222
229
240
247
252
257
263
268
273};
274
280/* Use fstat() instead */
281RTEMS_DEPRECATED static inline dev_t rtems_disk_get_device_identifier(
282 const rtems_disk_device *dd
283)
284{
285 return dd->dev;
286}
287
288/* Use fstat() instead */
289RTEMS_DEPRECATED static inline rtems_device_major_number rtems_disk_get_major_number(
290 const rtems_disk_device *dd
291)
292{
293 return rtems_filesystem_dev_major_t(dd->dev);
294}
295
296/* Use fstat() instead */
297RTEMS_DEPRECATED static inline rtems_device_minor_number rtems_disk_get_minor_number(
298 const rtems_disk_device *dd
299)
300{
301 return rtems_filesystem_dev_minor_t(dd->dev);
302}
303
304static inline void *rtems_disk_get_driver_data(
305 const rtems_disk_device *dd
306)
307{
308 return dd->driver_data;
309}
310
311static inline uint32_t rtems_disk_get_media_block_size(
312 const rtems_disk_device *dd
313)
314{
315 return dd->media_block_size;
316}
317
318static inline uint32_t rtems_disk_get_block_size(
319 const rtems_disk_device *dd
320)
321{
322 return dd->block_size;
323}
324
325static inline rtems_blkdev_bnum rtems_disk_get_block_begin(
326 const rtems_disk_device *dd
327)
328{
329 return dd->start;
330}
331
332static inline rtems_blkdev_bnum rtems_disk_get_block_count(
333 const rtems_disk_device *dd
334)
335{
336 return dd->size;
337}
338
346/* Use rtems_blkdev_create() instead */
347RTEMS_DEPRECATED rtems_status_code rtems_disk_create_phys(
348 dev_t dev,
349 uint32_t block_size,
350 rtems_blkdev_bnum block_count,
352 void *driver_data,
353 const char *name
354);
355
356/* Use rtems_blkdev_create_partition() instead */
357RTEMS_DEPRECATED rtems_status_code rtems_disk_create_log(
358 dev_t dev,
359 dev_t phys,
360 rtems_blkdev_bnum block_begin,
361 rtems_blkdev_bnum block_count,
362 const char *name
363);
364
365/*
366 * Use rtems_blkdev_create() or rtems_blkdev_create_partition and unlink()
367 * instead.
368 */
369RTEMS_DEPRECATED rtems_status_code rtems_disk_delete(dev_t dev);
370
371/*
372 * Use rtems_blkdev_create() or rtems_blkdev_create_partition and open()
373 * instead.
374 */
375RTEMS_DEPRECATED rtems_disk_device *rtems_disk_obtain(dev_t dev);
376
377/*
378 * Use rtems_blkdev_create() or rtems_blkdev_create_partition and close()
379 * instead.
380 */
381RTEMS_DEPRECATED rtems_status_code rtems_disk_release(rtems_disk_device *dd);
382
390/* Just remove calls to this function */
391RTEMS_DEPRECATED rtems_status_code rtems_disk_io_initialize(void);
392
393/* Just remove calls to this function */
394RTEMS_DEPRECATED rtems_status_code rtems_disk_io_done(void);
395
400/*
401 * This functionality no longer available. There is no global registration for
402 * disk devices.
403 */
404RTEMS_DEPRECATED rtems_disk_device *rtems_disk_next(dev_t dev);
405
406/* Internal function, do not use */
407rtems_status_code rtems_disk_init_phys(
409 uint32_t block_size,
410 rtems_blkdev_bnum block_count,
412 void *driver_data
413);
414
415/* Internal function, do not use */
416rtems_status_code rtems_disk_init_log(
418 rtems_disk_device *phys_dd,
419 rtems_blkdev_bnum block_begin,
420 rtems_blkdev_bnum block_count
421);
422
423#ifdef __cplusplus
424}
425#endif
426
427#endif
Chain API.
rtems_status_code
Classic API Status.
Definition: status.h:43
Block device block index type.
Definition: diskdevs.h:45
int(* rtems_block_device_ioctl)(rtems_disk_device *dd, uint32_t req, void *argp)
Block device IO control handler type.
Definition: diskdevs.h:50
Basic IO API.
Definition: chain.h:68
Block device read-ahead control.
Definition: diskdevs.h:64
rtems_chain_node node
Chain node for the read-ahead request queue of the read-ahead task.
Definition: diskdevs.h:68
rtems_blkdev_bnum next
Start block for the next read-ahead request.
Definition: diskdevs.h:84
rtems_blkdev_bnum trigger
Block value to trigger the read-ahead request.
Definition: diskdevs.h:76
Block device statistics.
Definition: diskdevs.h:92
uint32_t read_ahead_transfers
Read-ahead transfer count.
Definition: diskdevs.h:115
Count of blocks transfered from the device.
Definition: diskdevs.h:120
Read error count.
Definition: diskdevs.h:127
Write error count.
Definition: diskdevs.h:146
Count of blocks transfered to the device.
Definition: diskdevs.h:139
Read miss count.
Definition: diskdevs.h:108
uint32_t write_transfers
Write transfer count.
Definition: diskdevs.h:134
uint32_t read_hits
Read hit count.
Definition: diskdevs.h:99
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:157
uint32_t media_block_size
Media block size in bytes.
Definition: diskdevs.h:204
rtems_block_device_ioctl ioctl
IO control handler for this disk.
Definition: diskdevs.h:251
void * driver_data
Private data for the disk driver.
Definition: diskdevs.h:256
dev_t dev
Device identifier (concatenation of major and minor number).
Definition: diskdevs.h:161
size_t bds_per_group
Buffer descriptors per group count.
Definition: diskdevs.h:246
rtems_blkdev_stats stats
Device statistics for this disk.
Definition: diskdevs.h:267
Driver capabilities.
Definition: diskdevs.h:172
unsigned uses
Usage counter.
Definition: diskdevs.h:184
rtems_blkdev_bnum start
Start media block number.
Definition: diskdevs.h:192
rtems_blkdev_read_ahead read_ahead
Read-ahead control for this disk.
Definition: diskdevs.h:272
rtems_disk_device * phys_dev
Physical device identifier (equals the dev entry if it specifies a physical device).
Definition: diskdevs.h:167
rtems_blkdev_bnum size
Size of the physical or logical disk in media blocks.
Definition: diskdevs.h:197
bool deleted
Indicates that this disk should be deleted as soon as the last user releases this disk.
Definition: diskdevs.h:262
uint32_t block_size
Block size in bytes.
Definition: diskdevs.h:214
uint32_t media_blocks_per_block
Media blocks per device blocks.
Definition: diskdevs.h:228
char * name
Disk device name.
Definition: diskdevs.h:177
int block_to_media_block_shift
Block to media block shift.
Definition: diskdevs.h:239
Block count.
Definition: diskdevs.h:221
