RTEMS 5.2-rc1
#include "board.h"Go to the source code of this file.
| #define | CS2100_SLAVE_ADDRESS 0x4E |
| #define | CS2100_REG_ID 0x01 |
| #define | CS2100_REG_CTRL 0x02 |
| #define | CS2100_REG_DEV_CFG1 0x03 |
| #define | CS2100_REG_CFG 0x05 |
| #define | CS2100_REG_32_BIT_RATIO_1 0x06 |
| #define | CS2100_REG_32_BIT_RATIO_2 0x07 |
| #define | CS2100_REG_32_BIT_RATIO_3 0x08 |
| #define | CS2100_REG_32_BIT_RATIO_4 0x09 |
| #define | CS2100_REG_FUNC_CFG1 0x16 |
| #define | CS2100_REG_FUNC_CFG2 0x17 |
| #define | CS2100_REG_FUNC_CFG3 0x1E |
| uint16_t | CS2100_Read (Twid *pTwid, uint32_t device, uint32_t regAddr) |
| void | CS2100_Write (Twid *pTwid, uint32_t device, uint32_t regAddr, uint16_t data) |
| uint8_t | CS2100_Init (Twid *pTwid, uint32_t device, uint32_t PCK) |
Implementation WM8904 driver.
| #define CS2100_REG_32_BIT_RATIO_1 0x06 |
Power management control 0 register
| #define CS2100_REG_32_BIT_RATIO_2 0x07 |
| #define CS2100_REG_32_BIT_RATIO_3 0x08 |
| #define CS2100_REG_32_BIT_RATIO_4 0x09 |
| #define CS2100_REG_CFG 0x05 |
Bias control 1 register
| #define CS2100_REG_CTRL 0x02 |
VMID control 0 register
| #define CS2100_REG_DEV_CFG1 0x03 |
MIC Bias control 0 register
| #define CS2100_REG_FUNC_CFG1 0x16 |
Power management control 2 register
| #define CS2100_REG_FUNC_CFG2 0x17 |
Power management control 3 register
| #define CS2100_REG_FUNC_CFG3 0x1E |
| #define CS2100_REG_ID 0x01 |
ID and Rev register
