RTEMS 5.2-rc1
Block Device Buffer Management. More...
#include <rtems.h>#include <rtems/libio.h>#include <rtems/chain.h>#include <rtems/blkdev.h>#include <rtems/diskdevs.h>Go to the source code of this file.
| struct | rtems_bdbuf_buffer |
| struct | rtems_bdbuf_buffer::rtems_bdbuf_avl_node |
| struct | rtems_bdbuf_group |
| struct | rtems_bdbuf_config |
| #define | RTEMS_BDBUF_MAX_READ_AHEAD_BLOCKS_DEFAULT 0 |
| #define | RTEMS_BDBUF_MAX_WRITE_BLOCKS_DEFAULT 16 |
| #define | RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT 15 |
| #define | RTEMS_BDBUF_SWAPOUT_TASK_SWAP_PERIOD_DEFAULT 250 |
| #define | RTEMS_BDBUF_SWAPOUT_TASK_BLOCK_HOLD_DEFAULT 1000 |
| #define | RTEMS_BDBUF_SWAPOUT_WORKER_TASKS_DEFAULT 0 |
| #define | RTEMS_BDBUF_SWAPOUT_WORKER_TASK_PRIORITY_DEFAULT RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT |
| #define | RTEMS_BDBUF_READ_AHEAD_TASK_PRIORITY_DEFAULT RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT |
| #define | RTEMS_BDBUF_TASK_STACK_SIZE_DEFAULT RTEMS_MINIMUM_STACK_SIZE |
| #define | RTEMS_BDBUF_CACHE_MEMORY_SIZE_DEFAULT (64 * 512) |
| #define | RTEMS_BDBUF_BUFFER_MIN_SIZE_DEFAULT (512) |
| #define | RTEMS_BDBUF_BUFFER_MAX_SIZE_DEFAULT (4096) |
Typedefs | |
| typedef struct rtems_bdbuf_group | rtems_bdbuf_group |
| typedef struct rtems_bdbuf_buffer | rtems_bdbuf_buffer |
| typedef struct rtems_bdbuf_config | rtems_bdbuf_config |
Enumerations | |
| enum | rtems_bdbuf_buf_state { RTEMS_BDBUF_STATE_FREE = 0 , RTEMS_BDBUF_STATE_EMPTY , RTEMS_BDBUF_STATE_CACHED , RTEMS_BDBUF_STATE_ACCESS_CACHED , RTEMS_BDBUF_STATE_ACCESS_MODIFIED , RTEMS_BDBUF_STATE_ACCESS_EMPTY , RTEMS_BDBUF_STATE_ACCESS_PURGED , RTEMS_BDBUF_STATE_MODIFIED , RTEMS_BDBUF_STATE_SYNC , RTEMS_BDBUF_STATE_TRANSFER , RTEMS_BDBUF_STATE_TRANSFER_PURGED } |
| State of a buffer of the cache. More... | |
| const rtems_bdbuf_config | rtems_bdbuf_configuration |
