RTEMS 5.2-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions
#include <limits.h>
#include <inttypes.h>
#include <pthread.h>
#include <rtems/error.h>
#include <rtems/thread.h>
#include "rtems/bdbuf.h"
struct  rtems_bdbuf_swapout_transfer
struct  rtems_bdbuf_swapout_worker
struct  rtems_bdbuf_waiters
struct  rtems_bdbuf_cache
#define RTEMS_BDBUF_TRACE   0
#define BDBUF_INVALID_DEV   NULL
#define bdbuf_config   rtems_bdbuf_configuration
#define RTEMS_BDBUF_SWAPOUT_SYNC   RTEMS_EVENT_2
#define RTEMS_BDBUF_READ_AHEAD_WAKE_UP   RTEMS_EVENT_1
#define rtems_bdbuf_tracer   (0)
#define rtems_bdbuf_show_usage()   ((void) 0)
#define rtems_bdbuf_show_users(_w, _b)   ((void) 0)
#define RTEMS_BDBUF_AVL_MAX_HEIGHT   (32)
#define bdbuf_alloc(size)   __builtin_alloca (size)
typedef struct rtems_bdbuf_swapout_transfer rtems_bdbuf_swapout_transfer
typedef struct rtems_bdbuf_swapout_worker rtems_bdbuf_swapout_worker
typedef struct rtems_bdbuf_waiters rtems_bdbuf_waiters
typedef struct rtems_bdbuf_cache rtems_bdbuf_cache
enum  rtems_bdbuf_fatal_code {
  RTEMS_BDBUF_FATAL_CACHE_WAIT_2 , RTEMS_BDBUF_FATAL_CACHE_WAIT_TO , RTEMS_BDBUF_FATAL_CACHE_WAKE , RTEMS_BDBUF_FATAL_PREEMPT_DIS ,
  RTEMS_BDBUF_FATAL_PREEMPT_RST , RTEMS_BDBUF_FATAL_RA_WAKE_UP , RTEMS_BDBUF_FATAL_RECYCLE , RTEMS_BDBUF_FATAL_SO_WAKE_1 ,
  RTEMS_BDBUF_FATAL_SO_WAKE_2 , RTEMS_BDBUF_FATAL_STATE_0 , RTEMS_BDBUF_FATAL_STATE_2 , RTEMS_BDBUF_FATAL_STATE_4 ,
  RTEMS_BDBUF_FATAL_STATE_5 , RTEMS_BDBUF_FATAL_STATE_6 , RTEMS_BDBUF_FATAL_STATE_7 , RTEMS_BDBUF_FATAL_STATE_8 ,
  RTEMS_BDBUF_FATAL_STATE_9 , RTEMS_BDBUF_FATAL_STATE_10 , RTEMS_BDBUF_FATAL_STATE_11 , RTEMS_BDBUF_FATAL_SWAPOUT_RE ,
  RTEMS_BDBUF_FATAL_TREE_RM , RTEMS_BDBUF_FATAL_WAIT_EVNT , RTEMS_BDBUF_FATAL_WAIT_TRANS_EVNT
rtems_status_code rtems_bdbuf_init (void)
rtems_status_code rtems_bdbuf_get (rtems_disk_device *dd, rtems_blkdev_bnum block, rtems_bdbuf_buffer **bd_ptr)
rtems_status_code rtems_bdbuf_read (rtems_disk_device *dd, rtems_blkdev_bnum block, rtems_bdbuf_buffer **bd_ptr)
rtems_status_code rtems_bdbuf_release (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_release_modified (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_sync (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_syncdev (rtems_disk_device *dd)
void rtems_bdbuf_purge_dev (rtems_disk_device *dd)
 Purges all buffers corresponding to the disk device dd. More...
rtems_status_code rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size, bool sync)
 Sets the block size of a disk device. More...
void rtems_bdbuf_get_device_stats (const rtems_disk_device *dd, rtems_blkdev_stats *stats)
 Returns the block device statistics.
void rtems_bdbuf_reset_device_stats (rtems_disk_device *dd)
 Resets the block device statistics.
Block device buffer management.
◆ RTEMS_BDBUF_AVL_MAX_HEIGHT
The default maximum height of 32 allows for AVL trees having between 5,704,880 and 4,294,967,295 nodes, depending on order of insertion. You may change this compile-time constant as you wish.
◆ RTEMS_BDBUF_SWAPOUT_SYNC
The events used in this code. These should be system events rather than application events.
◆ RTEMS_BDBUF_TRACE
Set to 1 to enable debug tracing.
Typedef Documentation
◆ rtems_bdbuf_cache
The BD buffer cache.
◆ rtems_bdbuf_swapout_transfer
A swapout transfer transaction data. This data is passed to a worked thread to handle the write phase of the transfer.
◆ rtems_bdbuf_swapout_worker
Swapout worker thread. These are available to take processing from the main swapout thread and handle the I/O operation.
◆ rtems_bdbuf_waiters
Buffer waiters synchronization.
