RTEMS 5.2-rc1
attr.h
1
10/* COPYRIGHT (c) 1989-2008.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_RTEMS_ATTR_H
19#define _RTEMS_RTEMS_ATTR_H
20
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
41typedef uint32_t rtems_attribute;
42
45#define RTEMS_DEFAULT_ATTRIBUTES 0x00000000
46
50#define RTEMS_LOCAL 0x00000000
51
55#define RTEMS_GLOBAL 0x00000002
56
61#define RTEMS_FIFO 0x00000000
62
67#define RTEMS_PRIORITY 0x00000004
68
69/******************** RTEMS Task Specific Attributes *********************/
70
76#define RTEMS_NO_FLOATING_POINT 0x00000000
77
83#define RTEMS_FLOATING_POINT 0x00000001
84
85/***************** RTEMS Semaphore Specific Attributes ********************/
86
91#define RTEMS_SEMAPHORE_CLASS 0x00000030
92
97#define RTEMS_COUNTING_SEMAPHORE 0x00000000
98
103#define RTEMS_BINARY_SEMAPHORE 0x00000010
104
109#define RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020
110
115#define RTEMS_NO_INHERIT_PRIORITY 0x00000000
116
123#define RTEMS_INHERIT_PRIORITY 0x00000040
124
129#define RTEMS_NO_PRIORITY_CEILING 0x00000000
130
137#define RTEMS_PRIORITY_CEILING 0x00000080
138
143#define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000
144
151#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
152
153/******************** RTEMS Barrier Specific Attributes ********************/
154
159#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000010
160
165#define RTEMS_BARRIER_MANUAL_RELEASE 0x00000000
166
167/**************** RTEMS Internal Task Specific Attributes ****************/
168
173#define RTEMS_APPLICATION_TASK 0x00000000
174
179#define RTEMS_SYSTEM_TASK 0x00008000
180
183#ifdef __cplusplus
184}
185#endif
186
187#endif
188/* end of include file */
Basic Definitions.
Definition: attr.h:41
