RTEMS 5.2-rc1
#include <rtems/score/basedefs.h>Go to the source code of this file.
| #define | RTEMS_DEFAULT_ATTRIBUTES 0x00000000 |
| #define | RTEMS_LOCAL 0x00000000 |
| #define | RTEMS_GLOBAL 0x00000002 |
| #define | RTEMS_FIFO 0x00000000 |
| #define | RTEMS_PRIORITY 0x00000004 |
| #define | RTEMS_NO_FLOATING_POINT 0x00000000 |
| #define | RTEMS_FLOATING_POINT 0x00000001 |
| #define | RTEMS_SEMAPHORE_CLASS 0x00000030 |
| #define | RTEMS_COUNTING_SEMAPHORE 0x00000000 |
| #define | RTEMS_BINARY_SEMAPHORE 0x00000010 |
| #define | RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020 |
| #define | RTEMS_NO_INHERIT_PRIORITY 0x00000000 |
| #define | RTEMS_INHERIT_PRIORITY 0x00000040 |
| #define | RTEMS_NO_PRIORITY_CEILING 0x00000000 |
| #define | RTEMS_PRIORITY_CEILING 0x00000080 |
| #define | RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000 |
| #define | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100 |
| #define | RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000010 |
| #define | RTEMS_BARRIER_MANUAL_RELEASE 0x00000000 |
| #define | RTEMS_APPLICATION_TASK 0x00000000 |
| #define | RTEMS_SYSTEM_TASK 0x00008000 |
Typedefs | |
| typedef uint32_t | rtems_attribute |
This include file contains all information about the Object Attributes Handler.
