RTEMS 5.2-rc1
38#ifndef __ALT_MPUSCU_H__
39#define __ALT_MPUSCU_H__
57#define ALT_HPS_ADDR 0x00
63#define GLOBALTMR_BASE (ALT_MPUSCU_OFST + GLOBALTMR_MODULE_BASE_OFFSET)
64#define CPU_WDTGPT_TMR_BASE (ALT_MPUSCU_OFST + WDOG_TIMER_MODULE_BASE_OFFSET)
65#define CPU_PRIVATE_TMR_BASE (ALT_MPUSCU_OFST + CPU_PRIV_TIMER_MODULE_BASE_OFFSET)
66#define CPU_INT_CTRL_BASE (ALT_MPUSCU_OFST + INT_CONTROLLER_MODULE_BASE_OFFSET)
67#define CPU_INT_DIST_BASE (ALT_MPUSCU_OFST + INT_DISTRIBUTOR_MODULE_BASE_OFFSET)
72#define GLOBALTMR_MODULE_BASE_OFFSET 0x00000200
73#define GLOBALTMR_CNTR_LO_REG_OFFSET 0x00000000
74#define GLOBALTMR_CNTR_HI_REG_OFFSET 0x00000004
75#define GLOBALTMR_CTRL_REG_OFFSET 0x00000008
76#define GLOBALTMR_INT_STAT_REG_OFFSET 0x0000000C
77#define GLOBALTMR_COMP_LO_REG_OFFSET 0x00000010
78#define GLOBALTMR_COMP_HI_REG_OFFSET 0x00000014
79#define GLOBALTMR_AUTOINC_REG_OFFSET 0x00000018
82#define GLOBALTMR_ENABLE_BIT 0x00000001
83#define GLOBALTMR_COMP_ENABLE_BIT 0x00000002
84#define GLOBALTMR_INT_ENABLE_BIT 0x00000004
85#define GLOBALTMR_AUTOINC_ENABLE_BIT 0x00000008
86#define GLOBALTMR_PS_MASK 0x0000FF00
87#define GLOBALTMR_PS_SHIFT 8
88#define GLOBALTMR_INT_STATUS_BIT 0x00000001
91#define GLOBALTMR_MAX 0xFFFFFFFF
92#define GLOBALTMR_PS_MAX 0x000000FF
96#define CPU_PRIV_TIMER_MODULE_BASE_OFFSET 0x00000600
97#define CPU_PRIV_TMR_LOAD_REG_OFFSET 0x00000000
98#define CPU_PRIV_TMR_CNTR_REG_OFFSET 0x00000004
99#define CPU_PRIV_TMR_CTRL_REG_OFFSET 0x00000008
100#define CPU_PRIV_TMR_INT_STATUS_REG_OFFSET 0x0000000C
103#define CPU_PRIV_TMR_ENABLE 0x00000001
104#define CPU_PRIV_TMR_AUTO_RELOAD 0x00000002
105#define CPU_PRIV_TMR_INT_EN 0x00000004
106#define CPU_PRIV_TMR_PS_MASK 0x0000FF00
107#define CPU_PRIV_TMR_PS_SHIFT 8
108#define CPU_PRIV_TMR_INT_STATUS 0x00000001
111#define CPU_PRIV_TMR_MAX 0xFFFFFFFF
112#define CPU_PRIV_TMR_PS_MAX 0x000000FF
117#define WDOG_TIMER_MODULE_BASE_OFFSET 0x00000620
118#define WDOG_LOAD_REG_OFFSET 0x00000000
119#define WDOG_CNTR_REG_OFFSET 0x00000004
120#define WDOG_CTRL_REG_OFFSET 0x00000008
121#define WDOG_INTSTAT_REG_OFFSET 0x0000000C
122#define WDOG_RSTSTAT_REG_OFFSET 0x00000010
123#define WDOG_DISABLE_REG_OFFSET 0x00000014
127#define WDOG_TMR_ENABLE 0x00000001
128#define WDOG_AUTO_RELOAD 0x00000002
129#define WDOG_INT_EN 0x00000004
130#define WDOG_WDT_MODE 0x00000008
131#define WDOG_PS_MASK 0x0000FF00
132#define WDOG_PS_SHIFT 8
134#define WDOG_INT_STAT_BIT 0x00000001
136#define WDOG_RST_STAT_BIT 0x00000001
139#define WDOG_TMR_MAX UINT32_MAX
140#define WDOG_PS_MAX UINT8_MAX
141#define WDOG_DISABLE_VAL0 0x12345678
142#define WDOG_DISABLE_VAL1 0x87654321
148#define INT_CONTROLLER_MODULE_BASE_OFFSET 0x00000100
149#define INT_DISTRIBUTOR_MODULE_BASE_OFFSET 0x00001000
150#define INT_DIST_TYPE_REG 0x00000004
154#define MPUSCU_MAX 0x00001FFF
