RTEMS 5.2-rc1
alt_mpu_registers.h File Reference
#define ALT_HPS_ADDR   0x00
#define GLOBALTMR_BASE   (ALT_MPUSCU_OFST + GLOBALTMR_MODULE_BASE_OFFSET)
#define CPU_WDTGPT_TMR_BASE   (ALT_MPUSCU_OFST + WDOG_TIMER_MODULE_BASE_OFFSET)
#define CPU_PRIVATE_TMR_BASE   (ALT_MPUSCU_OFST + CPU_PRIV_TIMER_MODULE_BASE_OFFSET)
#define CPU_INT_CTRL_BASE   (ALT_MPUSCU_OFST + INT_CONTROLLER_MODULE_BASE_OFFSET)
#define CPU_INT_DIST_BASE   (ALT_MPUSCU_OFST + INT_DISTRIBUTOR_MODULE_BASE_OFFSET)
#define GLOBALTMR_MODULE_BASE_OFFSET   0x00000200
#define GLOBALTMR_CNTR_LO_REG_OFFSET   0x00000000
#define GLOBALTMR_CNTR_HI_REG_OFFSET   0x00000004
#define GLOBALTMR_CTRL_REG_OFFSET   0x00000008
#define GLOBALTMR_INT_STAT_REG_OFFSET   0x0000000C
#define GLOBALTMR_COMP_LO_REG_OFFSET   0x00000010
#define GLOBALTMR_COMP_HI_REG_OFFSET   0x00000014
#define GLOBALTMR_AUTOINC_REG_OFFSET   0x00000018
#define GLOBALTMR_ENABLE_BIT   0x00000001
#define GLOBALTMR_COMP_ENABLE_BIT   0x00000002
#define GLOBALTMR_INT_ENABLE_BIT   0x00000004
#define GLOBALTMR_AUTOINC_ENABLE_BIT   0x00000008
#define GLOBALTMR_PS_MASK   0x0000FF00
#define GLOBALTMR_PS_SHIFT   8
#define GLOBALTMR_INT_STATUS_BIT   0x00000001
#define GLOBALTMR_MAX   0xFFFFFFFF
#define GLOBALTMR_PS_MAX   0x000000FF
#define CPU_PRIV_TIMER_MODULE_BASE_OFFSET   0x00000600
#define CPU_PRIV_TMR_LOAD_REG_OFFSET   0x00000000
#define CPU_PRIV_TMR_CNTR_REG_OFFSET   0x00000004
#define CPU_PRIV_TMR_CTRL_REG_OFFSET   0x00000008
#define CPU_PRIV_TMR_INT_STATUS_REG_OFFSET   0x0000000C
#define CPU_PRIV_TMR_ENABLE   0x00000001
#define CPU_PRIV_TMR_AUTO_RELOAD   0x00000002
#define CPU_PRIV_TMR_INT_EN   0x00000004
#define CPU_PRIV_TMR_PS_MASK   0x0000FF00
#define CPU_PRIV_TMR_PS_SHIFT   8
#define CPU_PRIV_TMR_INT_STATUS   0x00000001
#define CPU_PRIV_TMR_MAX   0xFFFFFFFF
#define CPU_PRIV_TMR_PS_MAX   0x000000FF
#define WDOG_TIMER_MODULE_BASE_OFFSET   0x00000620
#define WDOG_LOAD_REG_OFFSET   0x00000000
#define WDOG_CNTR_REG_OFFSET   0x00000004
#define WDOG_CTRL_REG_OFFSET   0x00000008
#define WDOG_INTSTAT_REG_OFFSET   0x0000000C
#define WDOG_RSTSTAT_REG_OFFSET   0x00000010
#define WDOG_DISABLE_REG_OFFSET   0x00000014
#define WDOG_TMR_ENABLE   0x00000001
#define WDOG_AUTO_RELOAD   0x00000002
#define WDOG_INT_EN   0x00000004
#define WDOG_WDT_MODE   0x00000008
#define WDOG_PS_MASK   0x0000FF00
#define WDOG_PS_SHIFT   8
#define WDOG_INT_STAT_BIT   0x00000001
#define WDOG_RST_STAT_BIT   0x00000001
#define WDOG_TMR_MAX   UINT32_MAX
#define WDOG_PS_MAX   UINT8_MAX
#define WDOG_DISABLE_VAL0   0x12345678
#define WDOG_DISABLE_VAL1   0x87654321
#define INT_CONTROLLER_MODULE_BASE_OFFSET   0x00000100
#define INT_DISTRIBUTOR_MODULE_BASE_OFFSET   0x00001000
#define INT_DIST_TYPE_REG   0x00000004
#define MPUSCU_MAX   0x00001FFF
