RTEMS 5.2-rc1
alt_clkmgr.h
1
7/*******************************************************************************
8* *
9* Copyright 2013 Altera Corporation. All Rights Reserved. *
10* *
11* Redistribution and use in source and binary forms, with or without *
12* modification, are permitted provided that the following conditions are met: *
13* *
14* 1. Redistributions of source code must retain the above copyright notice, *
15* this list of conditions and the following disclaimer. *
16* *
17* 2. Redistributions in binary form must reproduce the above copyright notice, *
18* this list of conditions and the following disclaimer in the documentation *
19* and/or other materials provided with the distribution. *
20* *
21* 3. The name of the author may not be used to endorse or promote products *
22* derived from this software without specific prior written permission. *
23* *
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34* *
35*******************************************************************************/
36
37/* Altera - ALT_CLKMGR */
38
39#ifndef __ALTERA_ALT_CLKMGR_H__
40#define __ALTERA_ALT_CLKMGR_H__
41
42#ifdef __cplusplus
43extern "C"
44{
45#endif /* __cplusplus */
46
47/*
48 * Component : Clock Manager Module - ALT_CLKMGR
49 * Clock Manager Module
50 *
51 * Registers in the Clock Manager module
52 *
53 */
54/*
55 * Register : Control Register - ctrl
56 *
57 * Contains fields that control the entire Clock Manager.
58 *
59 * Register Layout
60 *
61 * Bits | Access | Reset | Description
62 * :-------|:-------|:------|:------------------------------
63 * [0] | RW | 0x1 | Safe Mode
64 * [1] | ??? | 0x0 | *UNDEFINED*
65 * [2] | RW | 0x1 | Enable SafeMode on Warm Reset
66 * [31:3] | ??? | 0x0 | *UNDEFINED*
67 *
68 */
69/*
70 * Field : Safe Mode - safemode
71 *
72 * When set the Clock Manager is in Safe Mode.
73 *
74 * In Safe Mode Clock Manager register settings defining clock behavior are ignored
75 * and clocks are set to a Safe Mode state.In Safe Mode all clocks with the
76 * optional exception of debug clocks, are directly generated from the EOSC1 clock
77 * input, all PLLs are bypassed, all programmable dividers are set to 1 and all
78 * clocks are enabled.
79 *
80 * This bit should only be cleared when clocks have been correctly configured
81 *
82 * This field is set on a cold reset and optionally on a warm reset and may not be
83 * set by SW.
84 *
85 * Field Access Macros:
86 *
87 */
88/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_CTL_SAFEMOD register field. */
89#define ALT_CLKMGR_CTL_SAFEMOD_LSB 0
90/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_CTL_SAFEMOD register field. */
91#define ALT_CLKMGR_CTL_SAFEMOD_MSB 0
92/* The width in bits of the ALT_CLKMGR_CTL_SAFEMOD register field. */
93#define ALT_CLKMGR_CTL_SAFEMOD_WIDTH 1
94/* The mask used to set the ALT_CLKMGR_CTL_SAFEMOD register field value. */
95#define ALT_CLKMGR_CTL_SAFEMOD_SET_MSK 0x00000001
96/* The mask used to clear the ALT_CLKMGR_CTL_SAFEMOD register field value. */
97#define ALT_CLKMGR_CTL_SAFEMOD_CLR_MSK 0xfffffffe
98/* The reset value of the ALT_CLKMGR_CTL_SAFEMOD register field. */
99#define ALT_CLKMGR_CTL_SAFEMOD_RESET 0x1
100/* Extracts the ALT_CLKMGR_CTL_SAFEMOD field value from a register. */
101#define ALT_CLKMGR_CTL_SAFEMOD_GET(value) (((value) & 0x00000001) >> 0)
102/* Produces a ALT_CLKMGR_CTL_SAFEMOD register field value suitable for setting the register. */
103#define ALT_CLKMGR_CTL_SAFEMOD_SET(value) (((value) << 0) & 0x00000001)
104
105/*
106 * Field : Enable SafeMode on Warm Reset - ensfmdwr
107 *
108 * When set the Clock Manager will respond to a Safe Mode request from the Reset
109 * Manager on a warm reset by setting the Safe Mode bit. When clear the clock
110 * manager will not set the the Safe Mode bit on a warm reset This bit is cleared
111 * on a cold reset. Warm reset has no affect on this bit.
112 *
113 * Field Access Macros:
114 *
115 */
116/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
117#define ALT_CLKMGR_CTL_ENSFMDWR_LSB 2
118/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
119#define ALT_CLKMGR_CTL_ENSFMDWR_MSB 2
120/* The width in bits of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
121#define ALT_CLKMGR_CTL_ENSFMDWR_WIDTH 1
122/* The mask used to set the ALT_CLKMGR_CTL_ENSFMDWR register field value. */
123#define ALT_CLKMGR_CTL_ENSFMDWR_SET_MSK 0x00000004
124/* The mask used to clear the ALT_CLKMGR_CTL_ENSFMDWR register field value. */
125#define ALT_CLKMGR_CTL_ENSFMDWR_CLR_MSK 0xfffffffb
126/* The reset value of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
127#define ALT_CLKMGR_CTL_ENSFMDWR_RESET 0x1
128/* Extracts the ALT_CLKMGR_CTL_ENSFMDWR field value from a register. */
129#define ALT_CLKMGR_CTL_ENSFMDWR_GET(value) (((value) & 0x00000004) >> 2)
130/* Produces a ALT_CLKMGR_CTL_ENSFMDWR register field value suitable for setting the register. */
131#define ALT_CLKMGR_CTL_ENSFMDWR_SET(value) (((value) << 2) & 0x00000004)
132
133#ifndef __ASSEMBLY__
134/*
135 * WARNING: The C register and register group struct declarations are provided for
136 * convenience and illustrative purposes. They should, however, be used with
137 * caution as the C language standard provides no guarantees about the alignment or
138 * atomicity of device memory accesses. The recommended practice for writing
139 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
140 * alt_write_word() functions.
141 *
142 * The struct declaration for register ALT_CLKMGR_CTL.
143 */
145{
146 uint32_t safemode : 1; /* Safe Mode */
147 uint32_t : 1; /* *UNDEFINED* */
148 uint32_t ensfmdwr : 1; /* Enable SafeMode on Warm Reset */
149 uint32_t : 29; /* *UNDEFINED* */
150};
151
152/* The typedef declaration for register ALT_CLKMGR_CTL. */
153typedef volatile struct ALT_CLKMGR_CTL_s ALT_CLKMGR_CTL_t;
154#endif /* __ASSEMBLY__ */
155
156/* The byte offset of the ALT_CLKMGR_CTL register from the beginning of the component. */
157#define ALT_CLKMGR_CTL_OFST 0x0
158
159/*
160 * Register : PLL Bypass Register - bypass
161 *
162 * Contains fields that control bypassing each PLL.
163 *
164 * Register Layout
165 *
166 * Bits | Access | Reset | Description
167 * :-------|:-------|:------|:-----------------------------
168 * [0] | RW | 0x1 | Main PLL Bypass
169 * [1] | RW | 0x1 | SDRAM PLL Bypass
170 * [2] | RW | 0x0 | SDRAM PLL Bypass Source
171 * [3] | RW | 0x1 | Peripheral PLL Bypass
172 * [4] | RW | 0x0 | Peripheral PLL Bypass Source
173 * [31:5] | ??? | 0x0 | *UNDEFINED*
174 *
175 */
176/*
177 * Field : Main PLL Bypass - mainpll
178 *
179 * When set, causes the Main PLL VCO and counters to be bypassed so that all clocks
180 * generated by the Main PLL are directly driven from the Main PLL input clock. The
181 * bypass source for Main PLL is the external eosc1_clk.
182 *
183 * The reset value for this bit is applied on a cold reset. Warm reset has no
184 * affect on this bit.
185 *
186 * Field Access Macros:
187 *
188 */
189/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
190#define ALT_CLKMGR_BYPASS_MAINPLL_LSB 0
191/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
192#define ALT_CLKMGR_BYPASS_MAINPLL_MSB 0
193/* The width in bits of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
194#define ALT_CLKMGR_BYPASS_MAINPLL_WIDTH 1
195/* The mask used to set the ALT_CLKMGR_BYPASS_MAINPLL register field value. */
196#define ALT_CLKMGR_BYPASS_MAINPLL_SET_MSK 0x00000001
197/* The mask used to clear the ALT_CLKMGR_BYPASS_MAINPLL register field value. */
198#define ALT_CLKMGR_BYPASS_MAINPLL_CLR_MSK 0xfffffffe
199/* The reset value of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
200#define ALT_CLKMGR_BYPASS_MAINPLL_RESET 0x1
201/* Extracts the ALT_CLKMGR_BYPASS_MAINPLL field value from a register. */
202#define ALT_CLKMGR_BYPASS_MAINPLL_GET(value) (((value) & 0x00000001) >> 0)
203/* Produces a ALT_CLKMGR_BYPASS_MAINPLL register field value suitable for setting the register. */
204#define ALT_CLKMGR_BYPASS_MAINPLL_SET(value) (((value) << 0) & 0x00000001)
205
206/*
207 * Field : SDRAM PLL Bypass - sdrpll
208 *
209 * When set, causes the SDRAM PLL VCO and counters to be bypassed so that all
210 * clocks generated by the SDRAM PLL are directly driven from either eosc1_clk or
211 * the SDRAM PLL input clock.
212 *
213 * The bypass clock source for SDRAM PLL is determined by the SDRAM PLL Bypass
214 * Source Register bit.
215 *
216 * The reset value for this bit is applied on a cold reset. Warm reset has no
217 * affect on this bit.
218 *
219 * Field Access Macros:
220 *
221 */
222/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
223#define ALT_CLKMGR_BYPASS_SDRPLL_LSB 1
224/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
225#define ALT_CLKMGR_BYPASS_SDRPLL_MSB 1
226/* The width in bits of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
227#define ALT_CLKMGR_BYPASS_SDRPLL_WIDTH 1
228/* The mask used to set the ALT_CLKMGR_BYPASS_SDRPLL register field value. */
229#define ALT_CLKMGR_BYPASS_SDRPLL_SET_MSK 0x00000002
230/* The mask used to clear the ALT_CLKMGR_BYPASS_SDRPLL register field value. */
231#define ALT_CLKMGR_BYPASS_SDRPLL_CLR_MSK 0xfffffffd
232/* The reset value of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
233#define ALT_CLKMGR_BYPASS_SDRPLL_RESET 0x1
234/* Extracts the ALT_CLKMGR_BYPASS_SDRPLL field value from a register. */
235#define ALT_CLKMGR_BYPASS_SDRPLL_GET(value) (((value) & 0x00000002) >> 1)
236/* Produces a ALT_CLKMGR_BYPASS_SDRPLL register field value suitable for setting the register. */
237#define ALT_CLKMGR_BYPASS_SDRPLL_SET(value) (((value) << 1) & 0x00000002)
238
239/*
240 * Field : SDRAM PLL Bypass Source - sdrpllsrc
241 *
242 * This bit defines the bypass source forSDRAM PLL.
243 *
244 * When changing fields that affect VCO lock the PLL must be bypassed and this bit
245 * must be set to OSC1_CLK.
246 *
247 * The reset value for this bit is applied on a cold reset. Warm reset has no
248 * affect on this bit.
249 *
250 * Field Enumeration Values:
251 *
252 * Enum | Value | Description
253 * :-----------------------------------------------|:------|:---------------------
254 * ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1 | 0x0 | Select EOSC1
255 * ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX | 0x1 | Select PLL Input Mux
256 *
257 * Field Access Macros:
258 *
259 */
260/*
261 * Enumerated value for register field ALT_CLKMGR_BYPASS_SDRPLLSRC
262 *
263 * Select EOSC1
264 */
265#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1 0x0
266/*
267 * Enumerated value for register field ALT_CLKMGR_BYPASS_SDRPLLSRC
268 *
269 * Select PLL Input Mux
270 */
271#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX 0x1
272
273/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
274#define ALT_CLKMGR_BYPASS_SDRPLLSRC_LSB 2
275/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
276#define ALT_CLKMGR_BYPASS_SDRPLLSRC_MSB 2
277/* The width in bits of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
278#define ALT_CLKMGR_BYPASS_SDRPLLSRC_WIDTH 1
279/* The mask used to set the ALT_CLKMGR_BYPASS_SDRPLLSRC register field value. */
280#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET_MSK 0x00000004
281/* The mask used to clear the ALT_CLKMGR_BYPASS_SDRPLLSRC register field value. */
282#define ALT_CLKMGR_BYPASS_SDRPLLSRC_CLR_MSK 0xfffffffb
283/* The reset value of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
284#define ALT_CLKMGR_BYPASS_SDRPLLSRC_RESET 0x0
285/* Extracts the ALT_CLKMGR_BYPASS_SDRPLLSRC field value from a register. */
286#define ALT_CLKMGR_BYPASS_SDRPLLSRC_GET(value) (((value) & 0x00000004) >> 2)
287/* Produces a ALT_CLKMGR_BYPASS_SDRPLLSRC register field value suitable for setting the register. */
288#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET(value) (((value) << 2) & 0x00000004)
289
290/*
291 * Field : Peripheral PLL Bypass - perpll
292 *
293 * When set, causes the Peripheral PLL VCO and counters to be bypassed so that all
294 * clocks generated by the Peripheral PLL are directly driven from either eosc1_clk
295 * or the Peripheral PLL input clock.
296 *
297 * The bypass clock source for Peripheral PLL is determined by the Peripheral PLL
298 * Bypass Source Register bit.
299 *
300 * The reset value for this bit is applied on a cold reset. Warm reset has no
301 * affect on this bit.
302 *
303 * Field Access Macros:
304 *
305 */
306/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_PERPLL register field. */
307#define ALT_CLKMGR_BYPASS_PERPLL_LSB 3
308/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_PERPLL register field. */
309#define ALT_CLKMGR_BYPASS_PERPLL_MSB 3
310/* The width in bits of the ALT_CLKMGR_BYPASS_PERPLL register field. */
311#define ALT_CLKMGR_BYPASS_PERPLL_WIDTH 1
312/* The mask used to set the ALT_CLKMGR_BYPASS_PERPLL register field value. */
313#define ALT_CLKMGR_BYPASS_PERPLL_SET_MSK 0x00000008
314/* The mask used to clear the ALT_CLKMGR_BYPASS_PERPLL register field value. */
315#define ALT_CLKMGR_BYPASS_PERPLL_CLR_MSK 0xfffffff7
316/* The reset value of the ALT_CLKMGR_BYPASS_PERPLL register field. */
317#define ALT_CLKMGR_BYPASS_PERPLL_RESET 0x1
318/* Extracts the ALT_CLKMGR_BYPASS_PERPLL field value from a register. */
319#define ALT_CLKMGR_BYPASS_PERPLL_GET(value) (((value) & 0x00000008) >> 3)
320/* Produces a ALT_CLKMGR_BYPASS_PERPLL register field value suitable for setting the register. */
321#define ALT_CLKMGR_BYPASS_PERPLL_SET(value) (((value) << 3) & 0x00000008)
322
323/*
324 * Field : Peripheral PLL Bypass Source - perpllsrc
325 *
326 * This bit defines the bypass source forPeripheral PLL.
327 *
328 * When changing fields that affect VCO lock the PLL must be bypassed and this bit
329 * must be set to OSC1_CLK.
330 *
331 * The reset value for this bit is applied on a cold reset. Warm reset has no
332 * affect on this bit.
333 *
334 * Field Enumeration Values:
335 *
336 * Enum | Value | Description
337 * :-----------------------------------------------|:------|:---------------------
338 * ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1 | 0x0 | Select EOSC1
339 * ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX | 0x1 | Select PLL Input Mux
340 *
341 * Field Access Macros:
342 *
343 */
344/*
345 * Enumerated value for register field ALT_CLKMGR_BYPASS_PERPLLSRC
346 *
347 * Select EOSC1
348 */
349#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1 0x0
350/*
351 * Enumerated value for register field ALT_CLKMGR_BYPASS_PERPLLSRC
352 *
353 * Select PLL Input Mux
354 */
355#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX 0x1
356
357/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
358#define ALT_CLKMGR_BYPASS_PERPLLSRC_LSB 4
359/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
360#define ALT_CLKMGR_BYPASS_PERPLLSRC_MSB 4
361/* The width in bits of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
362#define ALT_CLKMGR_BYPASS_PERPLLSRC_WIDTH 1
363/* The mask used to set the ALT_CLKMGR_BYPASS_PERPLLSRC register field value. */
364#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET_MSK 0x00000010
365/* The mask used to clear the ALT_CLKMGR_BYPASS_PERPLLSRC register field value. */
366#define ALT_CLKMGR_BYPASS_PERPLLSRC_CLR_MSK 0xffffffef
367/* The reset value of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
368#define ALT_CLKMGR_BYPASS_PERPLLSRC_RESET 0x0
369/* Extracts the ALT_CLKMGR_BYPASS_PERPLLSRC field value from a register. */
370#define ALT_CLKMGR_BYPASS_PERPLLSRC_GET(value) (((value) & 0x00000010) >> 4)
371/* Produces a ALT_CLKMGR_BYPASS_PERPLLSRC register field value suitable for setting the register. */
372#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET(value) (((value) << 4) & 0x00000010)
373
374#ifndef __ASSEMBLY__
375/*
376 * WARNING: The C register and register group struct declarations are provided for
377 * convenience and illustrative purposes. They should, however, be used with
378 * caution as the C language standard provides no guarantees about the alignment or
379 * atomicity of device memory accesses. The recommended practice for writing
380 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
381 * alt_write_word() functions.
382 *
383 * The struct declaration for register ALT_CLKMGR_BYPASS.
384 */
386{
387 uint32_t mainpll : 1; /* Main PLL Bypass */
388 uint32_t sdrpll : 1; /* SDRAM PLL Bypass */
389 uint32_t sdrpllsrc : 1; /* SDRAM PLL Bypass Source */
390 uint32_t perpll : 1; /* Peripheral PLL Bypass */
391 uint32_t perpllsrc : 1; /* Peripheral PLL Bypass Source */
392 uint32_t : 27; /* *UNDEFINED* */
393};
394
395/* The typedef declaration for register ALT_CLKMGR_BYPASS. */
396typedef volatile struct ALT_CLKMGR_BYPASS_s ALT_CLKMGR_BYPASS_t;
397#endif /* __ASSEMBLY__ */
398
399/* The byte offset of the ALT_CLKMGR_BYPASS register from the beginning of the component. */
400#define ALT_CLKMGR_BYPASS_OFST 0x4
401
402/*
403 * Register : Interrupt Status Register - inter
404 *
405 * Contains fields that indicate the PLL lock status.
406 *
407 * Fields are only reset by a cold reset.
408 *
409 * Register Layout
410 *
411 * Bits | Access | Reset | Description
412 * :-------|:-------|:--------|:-----------------------------------
413 * [0] | RW | 0x0 | Main PLL Achieved Lock
414 * [1] | RW | 0x0 | Peripheral PLL Achieved Lock
415 * [2] | RW | 0x0 | SDRAM PLL Achieved Lock
416 * [3] | RW | 0x0 | Main PLL Lost Lock
417 * [4] | RW | 0x0 | Peripheral PLL Lost Lock
418 * [5] | RW | 0x0 | SDRAM PLL Lost Lock
419 * [6] | R | Unknown | Main PLL Current Lock Status
420 * [7] | R | Unknown | Peripheral PLL Current Lock Status
421 * [8] | R | Unknown | SDRAM PLL Current Lock Status
422 * [31:9] | ??? | 0x0 | *UNDEFINED*
423 *
424 */
425/*
426 * Field : Main PLL Achieved Lock - mainpllachieved
427 *
428 * If 1, the Main PLL has achieved lock at least once since this bit was cleared.
429 * If 0, the Main PLL has not achieved lock since this bit was cleared.
430 *
431 * Field Access Macros:
432 *
433 */
434/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
435#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_LSB 0
436/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
437#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_MSB 0
438/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
439#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_WIDTH 1
440/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value. */
441#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET_MSK 0x00000001
442/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value. */
443#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_CLR_MSK 0xfffffffe
444/* The reset value of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
445#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_RESET 0x0
446/* Extracts the ALT_CLKMGR_INTER_MAINPLLACHIEVED field value from a register. */
447#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
448/* Produces a ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value suitable for setting the register. */
449#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
450
451/*
452 * Field : Peripheral PLL Achieved Lock - perpllachieved
453 *
454 * If 1, the Peripheral PLL has achieved lock at least once since this bit was
455 * cleared. If 0, the Peripheral PLL has not achieved lock since this bit was
456 * cleared.
457 *
458 * Field Access Macros:
459 *
460 */
461/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
462#define ALT_CLKMGR_INTER_PERPLLACHIEVED_LSB 1
463/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
464#define ALT_CLKMGR_INTER_PERPLLACHIEVED_MSB 1
465/* The width in bits of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
466#define ALT_CLKMGR_INTER_PERPLLACHIEVED_WIDTH 1
467/* The mask used to set the ALT_CLKMGR_INTER_PERPLLACHIEVED register field value. */
468#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET_MSK 0x00000002
469/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLACHIEVED register field value. */
470#define ALT_CLKMGR_INTER_PERPLLACHIEVED_CLR_MSK 0xfffffffd
471/* The reset value of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
472#define ALT_CLKMGR_INTER_PERPLLACHIEVED_RESET 0x0
473/* Extracts the ALT_CLKMGR_INTER_PERPLLACHIEVED field value from a register. */
474#define ALT_CLKMGR_INTER_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
475/* Produces a ALT_CLKMGR_INTER_PERPLLACHIEVED register field value suitable for setting the register. */
476#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
477
478/*
479 * Field : SDRAM PLL Achieved Lock - sdrpllachieved
480 *
481 * If 1, the SDRAM PLL has achieved lock at least once since this bit was cleared.
482 * If 0, the SDRAM PLL has not achieved lock since this bit was cleared.
483 *
484 * Field Access Macros:
485 *
486 */
487/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
488#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_LSB 2
489/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
490#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_MSB 2
491/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
492#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_WIDTH 1
493/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value. */
494#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET_MSK 0x00000004
495/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value. */
496#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_CLR_MSK 0xfffffffb
497/* The reset value of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
498#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_RESET 0x0
499/* Extracts the ALT_CLKMGR_INTER_SDRPLLACHIEVED field value from a register. */
500#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
501/* Produces a ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value suitable for setting the register. */
502#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
503
504/*
505 * Field : Main PLL Lost Lock - mainplllost
506 *
507 * If 1, the Main PLL has lost lock at least once since this bit was cleared. If 0,
508 * the Main PLL has not lost lock since this bit was cleared.
509 *
510 * Field Access Macros:
511 *
512 */
513/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
514#define ALT_CLKMGR_INTER_MAINPLLLOST_LSB 3
515/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
516#define ALT_CLKMGR_INTER_MAINPLLLOST_MSB 3
517/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
518#define ALT_CLKMGR_INTER_MAINPLLLOST_WIDTH 1
519/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLLOST register field value. */
520#define ALT_CLKMGR_INTER_MAINPLLLOST_SET_MSK 0x00000008
521/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLLOST register field value. */
522#define ALT_CLKMGR_INTER_MAINPLLLOST_CLR_MSK 0xfffffff7
523/* The reset value of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
524#define ALT_CLKMGR_INTER_MAINPLLLOST_RESET 0x0
525/* Extracts the ALT_CLKMGR_INTER_MAINPLLLOST field value from a register. */
526#define ALT_CLKMGR_INTER_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
527/* Produces a ALT_CLKMGR_INTER_MAINPLLLOST register field value suitable for setting the register. */
528#define ALT_CLKMGR_INTER_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
529
530/*
531 * Field : Peripheral PLL Lost Lock - perplllost
532 *
533 * If 1, the Peripheral PLL has lost lock at least once since this bit was cleared.
534 * If 0, the Peripheral PLL has not lost lock since this bit was cleared.
535 *
536 * Field Access Macros:
537 *
538 */
539/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
540#define ALT_CLKMGR_INTER_PERPLLLOST_LSB 4
541/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
542#define ALT_CLKMGR_INTER_PERPLLLOST_MSB 4
543/* The width in bits of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
544#define ALT_CLKMGR_INTER_PERPLLLOST_WIDTH 1
545/* The mask used to set the ALT_CLKMGR_INTER_PERPLLLOST register field value. */
546#define ALT_CLKMGR_INTER_PERPLLLOST_SET_MSK 0x00000010
547/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLLOST register field value. */
548#define ALT_CLKMGR_INTER_PERPLLLOST_CLR_MSK 0xffffffef
549/* The reset value of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
550#define ALT_CLKMGR_INTER_PERPLLLOST_RESET 0x0
551/* Extracts the ALT_CLKMGR_INTER_PERPLLLOST field value from a register. */
552#define ALT_CLKMGR_INTER_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
553/* Produces a ALT_CLKMGR_INTER_PERPLLLOST register field value suitable for setting the register. */
554#define ALT_CLKMGR_INTER_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
555
556/*
557 * Field : SDRAM PLL Lost Lock - sdrplllost
558 *
559 * If 1, the SDRAM PLL has lost lock at least once since this bit was cleared. If
560 * 0, the SDRAM PLL has not lost lock since this bit was cleared.
561 *
562 * Field Access Macros:
563 *
564 */
565/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
566#define ALT_CLKMGR_INTER_SDRPLLLOST_LSB 5
567/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
568#define ALT_CLKMGR_INTER_SDRPLLLOST_MSB 5
569/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
570#define ALT_CLKMGR_INTER_SDRPLLLOST_WIDTH 1
571/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLLOST register field value. */
572#define ALT_CLKMGR_INTER_SDRPLLLOST_SET_MSK 0x00000020
573/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLLOST register field value. */
574#define ALT_CLKMGR_INTER_SDRPLLLOST_CLR_MSK 0xffffffdf
575/* The reset value of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
576#define ALT_CLKMGR_INTER_SDRPLLLOST_RESET 0x0
577/* Extracts the ALT_CLKMGR_INTER_SDRPLLLOST field value from a register. */
578#define ALT_CLKMGR_INTER_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
579/* Produces a ALT_CLKMGR_INTER_SDRPLLLOST register field value suitable for setting the register. */
580#define ALT_CLKMGR_INTER_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
581
582/*
583 * Field : Main PLL Current Lock Status - mainplllocked
584 *
585 * If 1, the Main PLL is currently locked. If 0, the Main PLL is currently not
586 * locked.
587 *
588 * Field Access Macros:
589 *
590 */
591/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
592#define ALT_CLKMGR_INTER_MAINPLLLOCKED_LSB 6
593/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
594#define ALT_CLKMGR_INTER_MAINPLLLOCKED_MSB 6
595/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
596#define ALT_CLKMGR_INTER_MAINPLLLOCKED_WIDTH 1
597/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLLOCKED register field value. */
598#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET_MSK 0x00000040
599/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLLOCKED register field value. */
600#define ALT_CLKMGR_INTER_MAINPLLLOCKED_CLR_MSK 0xffffffbf
601/* The reset value of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field is UNKNOWN. */
602#define ALT_CLKMGR_INTER_MAINPLLLOCKED_RESET 0x0
603/* Extracts the ALT_CLKMGR_INTER_MAINPLLLOCKED field value from a register. */
604#define ALT_CLKMGR_INTER_MAINPLLLOCKED_GET(value) (((value) & 0x00000040) >> 6)
605/* Produces a ALT_CLKMGR_INTER_MAINPLLLOCKED register field value suitable for setting the register. */
606#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET(value) (((value) << 6) & 0x00000040)
607
608/*
609 * Field : Peripheral PLL Current Lock Status - perplllocked
610 *
611 * If 1, the Peripheral PLL is currently locked. If 0, the Peripheral PLL is
612 * currently not locked.
613 *
614 * Field Access Macros:
615 *
616 */
617/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
618#define ALT_CLKMGR_INTER_PERPLLLOCKED_LSB 7
619/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
620#define ALT_CLKMGR_INTER_PERPLLLOCKED_MSB 7
621/* The width in bits of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
622#define ALT_CLKMGR_INTER_PERPLLLOCKED_WIDTH 1
623/* The mask used to set the ALT_CLKMGR_INTER_PERPLLLOCKED register field value. */
624#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET_MSK 0x00000080
625/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLLOCKED register field value. */
626#define ALT_CLKMGR_INTER_PERPLLLOCKED_CLR_MSK 0xffffff7f
627/* The reset value of the ALT_CLKMGR_INTER_PERPLLLOCKED register field is UNKNOWN. */
628#define ALT_CLKMGR_INTER_PERPLLLOCKED_RESET 0x0
629/* Extracts the ALT_CLKMGR_INTER_PERPLLLOCKED field value from a register. */
630#define ALT_CLKMGR_INTER_PERPLLLOCKED_GET(value) (((value) & 0x00000080) >> 7)
631/* Produces a ALT_CLKMGR_INTER_PERPLLLOCKED register field value suitable for setting the register. */
632#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET(value) (((value) << 7) & 0x00000080)
633
634/*
635 * Field : SDRAM PLL Current Lock Status - sdrplllocked
636 *
637 * If 1, the SDRAM PLL is currently locked. If 0, the SDRAM PLL is currently not
638 * locked.
639 *
640 * Field Access Macros:
641 *
642 */
643/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
644#define ALT_CLKMGR_INTER_SDRPLLLOCKED_LSB 8
645/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
646#define ALT_CLKMGR_INTER_SDRPLLLOCKED_MSB 8
647/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
648#define ALT_CLKMGR_INTER_SDRPLLLOCKED_WIDTH 1
649/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLLOCKED register field value. */
650#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET_MSK 0x00000100
651/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLLOCKED register field value. */
652#define ALT_CLKMGR_INTER_SDRPLLLOCKED_CLR_MSK 0xfffffeff
653/* The reset value of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field is UNKNOWN. */
654#define ALT_CLKMGR_INTER_SDRPLLLOCKED_RESET 0x0
655/* Extracts the ALT_CLKMGR_INTER_SDRPLLLOCKED field value from a register. */
656#define ALT_CLKMGR_INTER_SDRPLLLOCKED_GET(value) (((value) & 0x00000100) >> 8)
657/* Produces a ALT_CLKMGR_INTER_SDRPLLLOCKED register field value suitable for setting the register. */
658#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET(value) (((value) << 8) & 0x00000100)
659
660#ifndef __ASSEMBLY__
661/*
662 * WARNING: The C register and register group struct declarations are provided for
663 * convenience and illustrative purposes. They should, however, be used with
664 * caution as the C language standard provides no guarantees about the alignment or
665 * atomicity of device memory accesses. The recommended practice for writing
666 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
667 * alt_write_word() functions.
668 *
669 * The struct declaration for register ALT_CLKMGR_INTER.
670 */
672{
673 uint32_t mainpllachieved : 1; /* Main PLL Achieved Lock */
674 uint32_t perpllachieved : 1; /* Peripheral PLL Achieved Lock */
675 uint32_t sdrpllachieved : 1; /* SDRAM PLL Achieved Lock */
676 uint32_t mainplllost : 1; /* Main PLL Lost Lock */
677 uint32_t perplllost : 1; /* Peripheral PLL Lost Lock */
678 uint32_t sdrplllost : 1; /* SDRAM PLL Lost Lock */
679 const uint32_t mainplllocked : 1; /* Main PLL Current Lock Status */
680 const uint32_t perplllocked : 1; /* Peripheral PLL Current Lock Status */
681 const uint32_t sdrplllocked : 1; /* SDRAM PLL Current Lock Status */
682 uint32_t : 23; /* *UNDEFINED* */
683};
684
685/* The typedef declaration for register ALT_CLKMGR_INTER. */
686typedef volatile struct ALT_CLKMGR_INTER_s ALT_CLKMGR_INTER_t;
687#endif /* __ASSEMBLY__ */
688
689/* The byte offset of the ALT_CLKMGR_INTER register from the beginning of the component. */
690#define ALT_CLKMGR_INTER_OFST 0x8
691
692/*
693 * Register : Interrupt Enable Register - intren
694 *
695 * Contain fields that enable the interrupt.
696 *
697 * Fields are only reset by a cold reset.
698 *
699 * Register Layout
700 *
701 * Bits | Access | Reset | Description
702 * :-------|:-------|:------|:----------------------------------------------
703 * [0] | RW | 0x0 | Main PLL Achieved Lock Interrupt Enable
704 * [1] | RW | 0x0 | Peripheral PLL Achieved Lock Interrupt Enable
705 * [2] | RW | 0x0 | SDRAM PLL Achieved Lock Interrupt Enable
706 * [3] | RW | 0x0 | Main PLL Achieved Lock Interrupt Enable
707 * [4] | RW | 0x0 | Peripheral PLL Achieved Lock Interrupt Enable
708 * [5] | RW | 0x0 | SDRAM PLL Achieved Lock Interrupt Enable
709 * [31:6] | ??? | 0x0 | *UNDEFINED*
710 *
711 */
712/*
713 * Field : Main PLL Achieved Lock Interrupt Enable - mainpllachieved
714 *
715 * When set to 1, the Main PLL achieved lock bit is ORed into the Clock Manager
716 * interrupt output. When set to 0 the Main PLL achieved lock bit is not ORed into
717 * the Clock Manager interrupt output.
718 *
719 * Field Access Macros:
720 *
721 */
722/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
723#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_LSB 0
724/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
725#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_MSB 0
726/* The width in bits of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
727#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_WIDTH 1
728/* The mask used to set the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value. */
729#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET_MSK 0x00000001
730/* The mask used to clear the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value. */
731#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_CLR_MSK 0xfffffffe
732/* The reset value of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
733#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_RESET 0x0
734/* Extracts the ALT_CLKMGR_INTREN_MAINPLLACHIEVED field value from a register. */
735#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
736/* Produces a ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value suitable for setting the register. */
737#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
738
739/*
740 * Field : Peripheral PLL Achieved Lock Interrupt Enable - perpllachieved
741 *
742 * When set to 1, the Peripheral PLL achieved lock bit is ORed into the Clock
743 * Manager interrupt output. When set to 0 the Peripheral PLL achieved lock bit is
744 * not ORed into the Clock Manager interrupt output.
745 *
746 * Field Access Macros:
747 *
748 */
749/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
750#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_LSB 1
751/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
752#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_MSB 1
753/* The width in bits of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
754#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_WIDTH 1
755/* The mask used to set the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value. */
756#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET_MSK 0x00000002
757/* The mask used to clear the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value. */
758#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_CLR_MSK 0xfffffffd
759/* The reset value of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
760#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_RESET 0x0
761/* Extracts the ALT_CLKMGR_INTREN_PERPLLACHIEVED field value from a register. */
762#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
763/* Produces a ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value suitable for setting the register. */
764#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
765
766/*
767 * Field : SDRAM PLL Achieved Lock Interrupt Enable - sdrpllachieved
768 *
769 * When set to 1, the SDRAM PLL achieved lock bit is ORed into the Clock Manager
770 * interrupt output. When set to 0 the SDRAM PLL achieved lock bit is not ORed
771 * into the Clock Manager interrupt output.
772 *
773 * Field Access Macros:
774 *
775 */
776/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
777#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_LSB 2
778/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
779#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_MSB 2
780/* The width in bits of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
781#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_WIDTH 1
782/* The mask used to set the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value. */
783#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET_MSK 0x00000004
784/* The mask used to clear the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value. */
785#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_CLR_MSK 0xfffffffb
786/* The reset value of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
787#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_RESET 0x0
788/* Extracts the ALT_CLKMGR_INTREN_SDRPLLACHIEVED field value from a register. */
789#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
790/* Produces a ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value suitable for setting the register. */
791#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
792
793/*
794 * Field : Main PLL Achieved Lock Interrupt Enable - mainplllost
795 *
796 * When set to 1, the Main PLL lost lock bit is ORed into the Clock Manager
797 * interrupt output. When set to 0 the Main PLL lost lock bit is not ORed into the
798 * Clock Manager interrupt output.
799 *
800 * Field Access Macros:
801 *
802 */
803/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
804#define ALT_CLKMGR_INTREN_MAINPLLLOST_LSB 3
805/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
806#define ALT_CLKMGR_INTREN_MAINPLLLOST_MSB 3
807/* The width in bits of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
808#define ALT_CLKMGR_INTREN_MAINPLLLOST_WIDTH 1
809/* The mask used to set the ALT_CLKMGR_INTREN_MAINPLLLOST register field value. */
810#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET_MSK 0x00000008
811/* The mask used to clear the ALT_CLKMGR_INTREN_MAINPLLLOST register field value. */
812#define ALT_CLKMGR_INTREN_MAINPLLLOST_CLR_MSK 0xfffffff7
813/* The reset value of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
814#define ALT_CLKMGR_INTREN_MAINPLLLOST_RESET 0x0
815/* Extracts the ALT_CLKMGR_INTREN_MAINPLLLOST field value from a register. */
816#define ALT_CLKMGR_INTREN_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
817/* Produces a ALT_CLKMGR_INTREN_MAINPLLLOST register field value suitable for setting the register. */
818#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
819
820/*
821 * Field : Peripheral PLL Achieved Lock Interrupt Enable - perplllost
822 *
823 * When set to 1, the Peripheral PLL lost lock bit is ORed into the Clock Manager
824 * interrupt output. When set to 0 the Peripheral PLL lost lock bit is not ORed
825 * into the Clock Manager interrupt output.
826 *
827 * Field Access Macros:
828 *
829 */
830/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
831#define ALT_CLKMGR_INTREN_PERPLLLOST_LSB 4
832/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
833#define ALT_CLKMGR_INTREN_PERPLLLOST_MSB 4
834/* The width in bits of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
835#define ALT_CLKMGR_INTREN_PERPLLLOST_WIDTH 1
836/* The mask used to set the ALT_CLKMGR_INTREN_PERPLLLOST register field value. */
837#define ALT_CLKMGR_INTREN_PERPLLLOST_SET_MSK 0x00000010
838/* The mask used to clear the ALT_CLKMGR_INTREN_PERPLLLOST register field value. */
839#define ALT_CLKMGR_INTREN_PERPLLLOST_CLR_MSK 0xffffffef
840/* The reset value of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
841#define ALT_CLKMGR_INTREN_PERPLLLOST_RESET 0x0
842/* Extracts the ALT_CLKMGR_INTREN_PERPLLLOST field value from a register. */
843#define ALT_CLKMGR_INTREN_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
844/* Produces a ALT_CLKMGR_INTREN_PERPLLLOST register field value suitable for setting the register. */
845#define ALT_CLKMGR_INTREN_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
846
847/*
848 * Field : SDRAM PLL Achieved Lock Interrupt Enable - sdrplllost
849 *
850 * When set to 1, the SDRAM PLL lost lock bit is ORed into the Clock Manager
851 * interrupt output. When set to 0 the SDRAM PLL lost lock bit is not ORed into
852 * the Clock Manager interrupt output.
853 *
854 * Field Access Macros:
855 *
856 */
857/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
858#define ALT_CLKMGR_INTREN_SDRPLLLOST_LSB 5
859/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
860#define ALT_CLKMGR_INTREN_SDRPLLLOST_MSB 5
861/* The width in bits of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
862#define ALT_CLKMGR_INTREN_SDRPLLLOST_WIDTH 1
863/* The mask used to set the ALT_CLKMGR_INTREN_SDRPLLLOST register field value. */
864#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET_MSK 0x00000020
865/* The mask used to clear the ALT_CLKMGR_INTREN_SDRPLLLOST register field value. */
866#define ALT_CLKMGR_INTREN_SDRPLLLOST_CLR_MSK 0xffffffdf
867/* The reset value of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
868#define ALT_CLKMGR_INTREN_SDRPLLLOST_RESET 0x0
869/* Extracts the ALT_CLKMGR_INTREN_SDRPLLLOST field value from a register. */
870#define ALT_CLKMGR_INTREN_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
871/* Produces a ALT_CLKMGR_INTREN_SDRPLLLOST register field value suitable for setting the register. */
872#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
873
874#ifndef __ASSEMBLY__
875/*
876 * WARNING: The C register and register group struct declarations are provided for
877 * convenience and illustrative purposes. They should, however, be used with
878 * caution as the C language standard provides no guarantees about the alignment or
879 * atomicity of device memory accesses. The recommended practice for writing
880 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
881 * alt_write_word() functions.
882 *
883 * The struct declaration for register ALT_CLKMGR_INTREN.
884 */
886{
887 uint32_t mainpllachieved : 1; /* Main PLL Achieved Lock Interrupt Enable */
888 uint32_t perpllachieved : 1; /* Peripheral PLL Achieved Lock Interrupt Enable */
889 uint32_t sdrpllachieved : 1; /* SDRAM PLL Achieved Lock Interrupt Enable */
890 uint32_t mainplllost : 1; /* Main PLL Achieved Lock Interrupt Enable */
891 uint32_t perplllost : 1; /* Peripheral PLL Achieved Lock Interrupt Enable */
892 uint32_t sdrplllost : 1; /* SDRAM PLL Achieved Lock Interrupt Enable */
893 uint32_t : 26; /* *UNDEFINED* */
894};
895
896/* The typedef declaration for register ALT_CLKMGR_INTREN. */
897typedef volatile struct ALT_CLKMGR_INTREN_s ALT_CLKMGR_INTREN_t;
898#endif /* __ASSEMBLY__ */
899
900/* The byte offset of the ALT_CLKMGR_INTREN register from the beginning of the component. */
901#define ALT_CLKMGR_INTREN_OFST 0xc
902
903/*
904 * Register : Debug clock Control Register - dbctrl
905 *
906 * Contains fields that control the debug clocks.
907 *
908 * Register Layout
909 *
910 * Bits | Access | Reset | Description
911 * :-------|:-------|:------|:-------------------------------
912 * [0] | RW | 0x1 | Debug Clocks Stay on EOSC1_CLK
913 * [1] | RW | 0x1 | Debug Clocks Enable Safe Mode
914 * [31:2] | ??? | 0x0 | *UNDEFINED*
915 *
916 */
917/*
918 * Field : Debug Clocks Stay on EOSC1_CLK - stayosc1
919 *
920 * When this bit is set the debug root clock (Main PLL C2 output) will always be
921 * bypassed to the EOSC1_clk independent of any other clock manager settings.
922 * When clear the debug source will be a function of register settings in the clock
923 * manager. Clocks affected by this bit are dbg_at_clk, dbg_clk, dbg_trace_clk,
924 * and dbg_timer_clk.
925 *
926 * The reset value for this bit is applied on a cold reset. Warm reset has no
927 * affect on this bit.
928 *
929 * Field Access Macros:
930 *
931 */
932/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
933#define ALT_CLKMGR_DBCTL_STAYOSC1_LSB 0
934/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
935#define ALT_CLKMGR_DBCTL_STAYOSC1_MSB 0
936/* The width in bits of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
937#define ALT_CLKMGR_DBCTL_STAYOSC1_WIDTH 1
938/* The mask used to set the ALT_CLKMGR_DBCTL_STAYOSC1 register field value. */
939#define ALT_CLKMGR_DBCTL_STAYOSC1_SET_MSK 0x00000001
940/* The mask used to clear the ALT_CLKMGR_DBCTL_STAYOSC1 register field value. */
941#define ALT_CLKMGR_DBCTL_STAYOSC1_CLR_MSK 0xfffffffe
942/* The reset value of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
943#define ALT_CLKMGR_DBCTL_STAYOSC1_RESET 0x1
944/* Extracts the ALT_CLKMGR_DBCTL_STAYOSC1 field value from a register. */
945#define ALT_CLKMGR_DBCTL_STAYOSC1_GET(value) (((value) & 0x00000001) >> 0)
946/* Produces a ALT_CLKMGR_DBCTL_STAYOSC1 register field value suitable for setting the register. */
947#define ALT_CLKMGR_DBCTL_STAYOSC1_SET(value) (((value) << 0) & 0x00000001)
948
949/*
950 * Field : Debug Clocks Enable Safe Mode - ensfmdwr
951 *
952 * When this bit is set the debug clocks will be affected by the assertion of Safe
953 * Mode on a warm reset if Stay OSC1 is not set.
954 *
955 * When this bit is clear the debug clocks will not be affected by the assertion of
956 * Safe Mode on a warm reset.
957 *
958 * If Debug Clocks are in Safe Mode they are taken out of Safe Mode when the Safe
959 * Mode bit is cleared independent of this bit.The reset value of this bit is
960 * applied on a cold reset; warm reset has no affect on this bit.
961 *
962 * Field Access Macros:
963 *
964 */
965/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
966#define ALT_CLKMGR_DBCTL_ENSFMDWR_LSB 1
967/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
968#define ALT_CLKMGR_DBCTL_ENSFMDWR_MSB 1
969/* The width in bits of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
970#define ALT_CLKMGR_DBCTL_ENSFMDWR_WIDTH 1
971/* The mask used to set the ALT_CLKMGR_DBCTL_ENSFMDWR register field value. */
972#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET_MSK 0x00000002
973/* The mask used to clear the ALT_CLKMGR_DBCTL_ENSFMDWR register field value. */
974#define ALT_CLKMGR_DBCTL_ENSFMDWR_CLR_MSK 0xfffffffd
975/* The reset value of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
976#define ALT_CLKMGR_DBCTL_ENSFMDWR_RESET 0x1
977/* Extracts the ALT_CLKMGR_DBCTL_ENSFMDWR field value from a register. */
978#define ALT_CLKMGR_DBCTL_ENSFMDWR_GET(value) (((value) & 0x00000002) >> 1)
979/* Produces a ALT_CLKMGR_DBCTL_ENSFMDWR register field value suitable for setting the register. */
980#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET(value) (((value) << 1) & 0x00000002)
981
982#ifndef __ASSEMBLY__
983/*
984 * WARNING: The C register and register group struct declarations are provided for
985 * convenience and illustrative purposes. They should, however, be used with
986 * caution as the C language standard provides no guarantees about the alignment or
987 * atomicity of device memory accesses. The recommended practice for writing
988 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
989 * alt_write_word() functions.
990 *
991 * The struct declaration for register ALT_CLKMGR_DBCTL.
992 */
994{
995 uint32_t stayosc1 : 1; /* Debug Clocks Stay on EOSC1_CLK */
996 uint32_t ensfmdwr : 1; /* Debug Clocks Enable Safe Mode */
997 uint32_t : 30; /* *UNDEFINED* */
998};
999
1000/* The typedef declaration for register ALT_CLKMGR_DBCTL. */
1001typedef volatile struct ALT_CLKMGR_DBCTL_s ALT_CLKMGR_DBCTL_t;
1002#endif /* __ASSEMBLY__ */
1003
1004/* The byte offset of the ALT_CLKMGR_DBCTL register from the beginning of the component. */
1005#define ALT_CLKMGR_DBCTL_OFST 0x10
1006
1007/*
1008 * Register : Status Register - stat
1009 *
1010 * Provides status of Hardware Managed Clock transition State Machine.
1011 *
1012 * Register Layout
1013 *
1014 * Bits | Access | Reset | Description
1015 * :-------|:-------|:------|:-----------------------
1016 * [0] | R | 0x0 | HW Managed Clocks BUSY
1017 * [31:1] | ??? | 0x0 | *UNDEFINED*
1018 *
1019 */
1020/*
1021 * Field : HW Managed Clocks BUSY - busy
1022 *
1023 * This read only bit indicates that the Hardware Managed clock's state machine is
1024 * active. If the state machine is active, then the clocks are in transition.
1025 * Software should poll this bit after changing the source of internal clocks when
1026 * writing to the BYPASS, CTRL or DBCTRL registers. Immediately following writes
1027 * to any of these registers, SW should wait until this bit is IDLE before
1028 * proceeding with any other register writes in the Clock Manager.
1029 *
1030 * The reset value of this bit is applied on a cold reset; warm reset has no affect
1031 * on this bit.
1032 *
1033 * Field Enumeration Values:
1034 *
1035 * Enum | Value | Description
1036 * :----------------------------|:------|:---------------------
1037 * ALT_CLKMGR_STAT_BUSY_E_IDLE | 0x0 | Clocks stable
1038 * ALT_CLKMGR_STAT_BUSY_E_BUSY | 0x1 | Clocks in transition
1039 *
1040 * Field Access Macros:
1041 *
1042 */
1043/*
1044 * Enumerated value for register field ALT_CLKMGR_STAT_BUSY
1045 *
1046 * Clocks stable
1047 */
1048#define ALT_CLKMGR_STAT_BUSY_E_IDLE 0x0
1049/*
1050 * Enumerated value for register field ALT_CLKMGR_STAT_BUSY
1051 *
1052 * Clocks in transition
1053 */
1054#define ALT_CLKMGR_STAT_BUSY_E_BUSY 0x1
1055
1056/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_STAT_BUSY register field. */
1057#define ALT_CLKMGR_STAT_BUSY_LSB 0
1058/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_STAT_BUSY register field. */
1059#define ALT_CLKMGR_STAT_BUSY_MSB 0
1060/* The width in bits of the ALT_CLKMGR_STAT_BUSY register field. */
1061#define ALT_CLKMGR_STAT_BUSY_WIDTH 1
1062/* The mask used to set the ALT_CLKMGR_STAT_BUSY register field value. */
1063#define ALT_CLKMGR_STAT_BUSY_SET_MSK 0x00000001
1064/* The mask used to clear the ALT_CLKMGR_STAT_BUSY register field value. */
1065#define ALT_CLKMGR_STAT_BUSY_CLR_MSK 0xfffffffe
1066/* The reset value of the ALT_CLKMGR_STAT_BUSY register field. */
1067#define ALT_CLKMGR_STAT_BUSY_RESET 0x0
1068/* Extracts the ALT_CLKMGR_STAT_BUSY field value from a register. */
1069#define ALT_CLKMGR_STAT_BUSY_GET(value) (((value) & 0x00000001) >> 0)
1070/* Produces a ALT_CLKMGR_STAT_BUSY register field value suitable for setting the register. */
1071#define ALT_CLKMGR_STAT_BUSY_SET(value) (((value) << 0) & 0x00000001)
1072
1073#ifndef __ASSEMBLY__
1074/*
1075 * WARNING: The C register and register group struct declarations are provided for
1076 * convenience and illustrative purposes. They should, however, be used with
1077 * caution as the C language standard provides no guarantees about the alignment or
1078 * atomicity of device memory accesses. The recommended practice for writing
1079 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1080 * alt_write_word() functions.
1081 *
1082 * The struct declaration for register ALT_CLKMGR_STAT.
1083 */
1085{
1086 const uint32_t busy : 1; /* HW Managed Clocks BUSY */
1087 uint32_t : 31; /* *UNDEFINED* */
1088};
1089
1090/* The typedef declaration for register ALT_CLKMGR_STAT. */
1091typedef volatile struct ALT_CLKMGR_STAT_s ALT_CLKMGR_STAT_t;
1092#endif /* __ASSEMBLY__ */
1093
1094/* The byte offset of the ALT_CLKMGR_STAT register from the beginning of the component. */
1095#define ALT_CLKMGR_STAT_OFST 0x14
1096
1097/*
1098 * Register Group : Main PLL Group - ALT_CLKMGR_MAINPLL
1099 * Main PLL Group
1100 *
1101 * Contains registers with settings for the Main PLL.
1102 *
1103 */
1104/*
1105 * Register : Main PLL VCO Control Register - vco
1106 *
1107 * Contains settings that control the Main PLL VCO. The VCO output frequency is the
1108 * input frequency multiplied by the numerator (M+1) and divided by the denominator
1109 * (N+1). The VCO input clock source is always eosc1_clk.
1110 *
1111 * Fields are only reset by a cold reset.
1112 *
1113 * Register Layout
1114 *
1115 * Bits | Access | Reset | Description
1116 * :--------|:-------|:------|:--------------------------------
1117 * [0] | RW | 0x1 | BG PWRDN
1118 * [1] | RW | 0x0 | Enable
1119 * [2] | RW | 0x1 | Power down
1120 * [15:3] | RW | 0x1 | Numerator (M)
1121 * [21:16] | RW | 0x1 | Denominator (N)
1122 * [23:22] | ??? | 0x0 | *UNDEFINED*
1123 * [24] | RW | 0x0 | All Output Counter Reset
1124 * [30:25] | RW | 0x0 | Output Counter Reset
1125 * [31] | RW | 0x1 | External Regulator Input Select
1126 *
1127 */
1128/*
1129 * Field : BG PWRDN - bgpwrdn
1130 *
1131 * If '1', powers down bandgap. If '0', bandgap is not power down.
1132 *
1133 * Field Access Macros:
1134 *
1135 */
1136/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
1137#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_LSB 0
1138/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
1139#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_MSB 0
1140/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
1141#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_WIDTH 1
1142/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value. */
1143#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET_MSK 0x00000001
1144/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value. */
1145#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
1146/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
1147#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_RESET 0x1
1148/* Extracts the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN field value from a register. */
1149#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
1150/* Produces a ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value suitable for setting the register. */
1151#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
1152
1153/*
1154 * Field : Enable - en
1155 *
1156 * If '1', VCO is enabled. If '0', VCO is in reset.
1157 *
1158 * Field Access Macros:
1159 *
1160 */
1161/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
1162#define ALT_CLKMGR_MAINPLL_VCO_EN_LSB 1
1163/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
1164#define ALT_CLKMGR_MAINPLL_VCO_EN_MSB 1
1165/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
1166#define ALT_CLKMGR_MAINPLL_VCO_EN_WIDTH 1
1167/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_EN register field value. */
1168#define ALT_CLKMGR_MAINPLL_VCO_EN_SET_MSK 0x00000002
1169/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_EN register field value. */
1170#define ALT_CLKMGR_MAINPLL_VCO_EN_CLR_MSK 0xfffffffd
1171/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
1172#define ALT_CLKMGR_MAINPLL_VCO_EN_RESET 0x0
1173/* Extracts the ALT_CLKMGR_MAINPLL_VCO_EN field value from a register. */
1174#define ALT_CLKMGR_MAINPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
1175/* Produces a ALT_CLKMGR_MAINPLL_VCO_EN register field value suitable for setting the register. */
1176#define ALT_CLKMGR_MAINPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
1177
1178/*
1179 * Field : Power down - pwrdn
1180 *
1181 * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
1182 *
1183 * Field Access Macros:
1184 *
1185 */
1186/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
1187#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_LSB 2
1188/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
1189#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_MSB 2
1190/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
1191#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_WIDTH 1
1192/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value. */
1193#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET_MSK 0x00000004
1194/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value. */
1195#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
1196/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
1197#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_RESET 0x1
1198/* Extracts the ALT_CLKMGR_MAINPLL_VCO_PWRDN field value from a register. */
1199#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
1200/* Produces a ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value suitable for setting the register. */
1201#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
1202
1203/*
1204 * Field : Numerator (M) - numer
1205 *
1206 * Numerator in VCO output frequency equation. For incremental frequency change, if
1207 * the new value lead to less than 20% of the frequency change, this value can be
1208 * changed without resetting the PLL. The Numerator and Denominator can not be
1209 * changed at the same time for incremental frequency changed.
1210 *
1211 * Field Access Macros:
1212 *
1213 */
1214/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
1215#define ALT_CLKMGR_MAINPLL_VCO_NUMER_LSB 3
1216/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
1217#define ALT_CLKMGR_MAINPLL_VCO_NUMER_MSB 15
1218/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
1219#define ALT_CLKMGR_MAINPLL_VCO_NUMER_WIDTH 13
1220/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_NUMER register field value. */
1221#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET_MSK 0x0000fff8
1222/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_NUMER register field value. */
1223#define ALT_CLKMGR_MAINPLL_VCO_NUMER_CLR_MSK 0xffff0007
1224/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
1225#define ALT_CLKMGR_MAINPLL_VCO_NUMER_RESET 0x1
1226/* Extracts the ALT_CLKMGR_MAINPLL_VCO_NUMER field value from a register. */
1227#define ALT_CLKMGR_MAINPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
1228/* Produces a ALT_CLKMGR_MAINPLL_VCO_NUMER register field value suitable for setting the register. */
1229#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
1230
1231/*
1232 * Field : Denominator (N) - denom
1233 *
1234 * Denominator in VCO output frequency equation. For incremental frequency change,
1235 * if the new value lead to less than 20% of the frequency change, this value can
1236 * be changed without resetting the PLL. The Numerator and Denominator can not be
1237 * changed at the same time for incremental frequency changed.
1238 *
1239 * Field Access Macros:
1240 *
1241 */
1242/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
1243#define ALT_CLKMGR_MAINPLL_VCO_DENOM_LSB 16
1244/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
1245#define ALT_CLKMGR_MAINPLL_VCO_DENOM_MSB 21
1246/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
1247#define ALT_CLKMGR_MAINPLL_VCO_DENOM_WIDTH 6
1248/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_DENOM register field value. */
1249#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET_MSK 0x003f0000
1250/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_DENOM register field value. */
1251#define ALT_CLKMGR_MAINPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
1252/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
1253#define ALT_CLKMGR_MAINPLL_VCO_DENOM_RESET 0x1
1254/* Extracts the ALT_CLKMGR_MAINPLL_VCO_DENOM field value from a register. */
1255#define ALT_CLKMGR_MAINPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
1256/* Produces a ALT_CLKMGR_MAINPLL_VCO_DENOM register field value suitable for setting the register. */
1257#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
1258
1259/*
1260 * Field : All Output Counter Reset - outresetall
1261 *
1262 * Before releasing Bypass, All Output Counter Reset must be set and cleared by
1263 * software for correct clock operation.
1264 *
1265 * If '1', Reset phase multiplexer and all output counter state. So that after the
1266 * assertion all the clocks output are start from rising edge align.
1267 *
1268 * If '0', phase multiplexer and output counter state not reset and no change to
1269 * the phase of the clock outputs.
1270 *
1271 * Field Access Macros:
1272 *
1273 */
1274/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
1275#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_LSB 24
1276/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
1277#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_MSB 24
1278/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
1279#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_WIDTH 1
1280/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value. */
1281#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
1282/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value. */
1283#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
1284/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
1285#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_RESET 0x0
1286/* Extracts the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL field value from a register. */
1287#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
1288/* Produces a ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
1289#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
1290
1291/*
1292 * Field : Output Counter Reset - outreset
1293 *
1294 * Resets the individual PLL output counter.
1295 *
1296 * For software to change the PLL output counter without producing glitches on the
1297 * respective clock, SW must set the VCO register respective Output Counter Reset
1298 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
1299 * the Output Counter Reset Ack Status Register. Software then writes the
1300 * appropriate counter register, and then clears the respective VCO register Output
1301 * Counter Reset bit.
1302 *
1303 * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
1304 *
1305 * If set to '1', reset output divider, no clock output from counter.
1306 *
1307 * If set to '0', counter is not reset.
1308 *
1309 * The reset value of this bit is applied on a cold reset; warm reset has no affect
1310 * on this bit.
1311 *
1312 * Field Access Macros:
1313 *
1314 */
1315/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
1316#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_LSB 25
1317/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
1318#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_MSB 30
1319/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
1320#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_WIDTH 6
1321/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value. */
1322#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET_MSK 0x7e000000
1323/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value. */
1324#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
1325/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
1326#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_RESET 0x0
1327/* Extracts the ALT_CLKMGR_MAINPLL_VCO_OUTRST field value from a register. */
1328#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
1329/* Produces a ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value suitable for setting the register. */
1330#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
1331
1332/*
1333 * Field : External Regulator Input Select - regextsel
1334 *
1335 * If set to '1', the external regulator is selected for the PLL.
1336 *
1337 * If set to '0', the internal regulator is slected.
1338 *
1339 * It is strongly recommended to select the external regulator while the PLL is not
1340 * enabled (in reset), and then disable the external regulater once the PLL
1341 * becomes enabled. Software should simulateously update the 'Enable' bit and the
1342 * 'External Regulator Input Select' in the same write access to the VCO register.
1343 * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
1344 * set, and vice versa.
1345 *
1346 * The reset value of this bit is applied on a cold reset; warm reset has no affect
1347 * on this bit.
1348 *
1349 * Field Access Macros:
1350 *
1351 */
1352/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
1353#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_LSB 31
1354/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
1355#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_MSB 31
1356/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
1357#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_WIDTH 1
1358/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value. */
1359#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
1360/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value. */
1361#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
1362/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
1363#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_RESET 0x1
1364/* Extracts the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL field value from a register. */
1365#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
1366/* Produces a ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
1367#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
1368
1369#ifndef __ASSEMBLY__
1370/*
1371 * WARNING: The C register and register group struct declarations are provided for
1372 * convenience and illustrative purposes. They should, however, be used with
1373 * caution as the C language standard provides no guarantees about the alignment or
1374 * atomicity of device memory accesses. The recommended practice for writing
1375 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1376 * alt_write_word() functions.
1377 *
1378 * The struct declaration for register ALT_CLKMGR_MAINPLL_VCO.
1379 */
1381{
1382 uint32_t bgpwrdn : 1; /* BG PWRDN */
1383 uint32_t en : 1; /* Enable */
1384 uint32_t pwrdn : 1; /* Power down */
1385 uint32_t numer : 13; /* Numerator (M) */
1386 uint32_t denom : 6; /* Denominator (N) */
1387 uint32_t : 2; /* *UNDEFINED* */
1388 uint32_t outresetall : 1; /* All Output Counter Reset */
1389 uint32_t outreset : 6; /* Output Counter Reset */
1390 uint32_t regextsel : 1; /* External Regulator Input Select */
1391};
1392
1393/* The typedef declaration for register ALT_CLKMGR_MAINPLL_VCO. */
1395#endif /* __ASSEMBLY__ */
1396
1397/* The byte offset of the ALT_CLKMGR_MAINPLL_VCO register from the beginning of the component. */
1398#define ALT_CLKMGR_MAINPLL_VCO_OFST 0x0
1399
1400/*
1401 * Register : Main PLL VCO Advanced Control Register - misc
1402 *
1403 * Contains VCO control signals and other PLL control signals need to be
1404 * controllable through register.
1405 *
1406 * Fields are only reset by a cold reset.
1407 *
1408 * Register Layout
1409 *
1410 * Bits | Access | Reset | Description
1411 * :--------|:-------|:------|:------------------------------
1412 * [0] | RW | 0x0 | Loop Bandwidth Adjust Enabled
1413 * [12:1] | RW | 0x1 | Loop Bandwidth Adjust
1414 * [13] | RW | 0x0 | Fast Locking Enable
1415 * [14] | RW | 0x1 | Saturation Enable
1416 * [31:15] | ??? | 0x0 | *UNDEFINED*
1417 *
1418 */
1419/*
1420 * Field : Loop Bandwidth Adjust Enabled - bwadjen
1421 *
1422 * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
1423 * Adjust field.
1424 *
1425 * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
1426 * value of the VCO Control Register. The M divided by 2 is the upper 12 bits
1427 * (12:1) of the M field in the VCO register.
1428 *
1429 * Field Access Macros:
1430 *
1431 */
1432/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
1433#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_LSB 0
1434/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
1435#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_MSB 0
1436/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
1437#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_WIDTH 1
1438/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value. */
1439#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET_MSK 0x00000001
1440/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value. */
1441#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_CLR_MSK 0xfffffffe
1442/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
1443#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_RESET 0x0
1444/* Extracts the ALT_CLKMGR_MAINPLL_MISC_BWADJEN field value from a register. */
1445#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
1446/* Produces a ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value suitable for setting the register. */
1447#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
1448
1449/*
1450 * Field : Loop Bandwidth Adjust - bwadj
1451 *
1452 * Provides Loop Bandwidth Adjust value.
1453 *
1454 * Field Access Macros:
1455 *
1456 */
1457/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
1458#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_LSB 1
1459/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
1460#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_MSB 12
1461/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
1462#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_WIDTH 12
1463/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value. */
1464#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET_MSK 0x00001ffe
1465/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value. */
1466#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_CLR_MSK 0xffffe001
1467/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
1468#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_RESET 0x1
1469/* Extracts the ALT_CLKMGR_MAINPLL_MISC_BWADJ field value from a register. */
1470#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
1471/* Produces a ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value suitable for setting the register. */
1472#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
1473
1474/*
1475 * Field : Fast Locking Enable - fasten
1476 *
1477 * Enables fast locking circuit.
1478 *
1479 * Field Access Macros:
1480 *
1481 */
1482/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
1483#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_LSB 13
1484/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
1485#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_MSB 13
1486/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
1487#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_WIDTH 1
1488/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value. */
1489#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET_MSK 0x00002000
1490/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value. */
1491#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_CLR_MSK 0xffffdfff
1492/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
1493#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_RESET 0x0
1494/* Extracts the ALT_CLKMGR_MAINPLL_MISC_FASTEN field value from a register. */
1495#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
1496/* Produces a ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value suitable for setting the register. */
1497#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
1498
1499/*
1500 * Field : Saturation Enable - saten
1501 *
1502 * Enables saturation behavior.
1503 *
1504 * Field Access Macros:
1505 *
1506 */
1507/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
1508#define ALT_CLKMGR_MAINPLL_MISC_SATEN_LSB 14
1509/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
1510#define ALT_CLKMGR_MAINPLL_MISC_SATEN_MSB 14
1511/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
1512#define ALT_CLKMGR_MAINPLL_MISC_SATEN_WIDTH 1
1513/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_SATEN register field value. */
1514#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET_MSK 0x00004000
1515/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_SATEN register field value. */
1516#define ALT_CLKMGR_MAINPLL_MISC_SATEN_CLR_MSK 0xffffbfff
1517/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
1518#define ALT_CLKMGR_MAINPLL_MISC_SATEN_RESET 0x1
1519/* Extracts the ALT_CLKMGR_MAINPLL_MISC_SATEN field value from a register. */
1520#define ALT_CLKMGR_MAINPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
1521/* Produces a ALT_CLKMGR_MAINPLL_MISC_SATEN register field value suitable for setting the register. */
1522#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
1523
1524#ifndef __ASSEMBLY__
1525/*
1526 * WARNING: The C register and register group struct declarations are provided for
1527 * convenience and illustrative purposes. They should, however, be used with
1528 * caution as the C language standard provides no guarantees about the alignment or
1529 * atomicity of device memory accesses. The recommended practice for writing
1530 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1531 * alt_write_word() functions.
1532 *
1533 * The struct declaration for register ALT_CLKMGR_MAINPLL_MISC.
1534 */
1536{
1537 uint32_t bwadjen : 1; /* Loop Bandwidth Adjust Enabled */
1538 uint32_t bwadj : 12; /* Loop Bandwidth Adjust */
1539 uint32_t fasten : 1; /* Fast Locking Enable */
1540 uint32_t saten : 1; /* Saturation Enable */
1541 uint32_t : 17; /* *UNDEFINED* */
1542};
1543
1544/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MISC. */
1546#endif /* __ASSEMBLY__ */
1547
1548/* The byte offset of the ALT_CLKMGR_MAINPLL_MISC register from the beginning of the component. */
1549#define ALT_CLKMGR_MAINPLL_MISC_OFST 0x4
1550
1551/*
1552 * Register : Main PLL C0 Control Register for Clock mpu_clk - mpuclk
1553 *
1554 * Contains settings that control clock mpu_clk generated from the C0 output of the
1555 * Main PLL.
1556 *
1557 * Only reset by a cold reset.
1558 *
1559 * Register Layout
1560 *
1561 * Bits | Access | Reset | Description
1562 * :-------|:-------|:------|:------------
1563 * [8:0] | RW | 0x0 | Counter
1564 * [31:9] | ??? | 0x0 | *UNDEFINED*
1565 *
1566 */
1567/*
1568 * Field : Counter - cnt
1569 *
1570 * Divides the VCO/2 frequency by the value+1 in this field.
1571 *
1572 * Field Access Macros:
1573 *
1574 */
1575/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
1576#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_LSB 0
1577/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
1578#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_MSB 8
1579/* The width in bits of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
1580#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_WIDTH 9
1581/* The mask used to set the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value. */
1582#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET_MSK 0x000001ff
1583/* The mask used to clear the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value. */
1584#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_CLR_MSK 0xfffffe00
1585/* The reset value of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
1586#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_RESET 0x0
1587/* Extracts the ALT_CLKMGR_MAINPLL_MPUCLK_CNT field value from a register. */
1588#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1589/* Produces a ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value suitable for setting the register. */
1590#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1591
1592#ifndef __ASSEMBLY__
1593/*
1594 * WARNING: The C register and register group struct declarations are provided for
1595 * convenience and illustrative purposes. They should, however, be used with
1596 * caution as the C language standard provides no guarantees about the alignment or
1597 * atomicity of device memory accesses. The recommended practice for writing
1598 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1599 * alt_write_word() functions.
1600 *
1601 * The struct declaration for register ALT_CLKMGR_MAINPLL_MPUCLK.
1602 */
1604{
1605 uint32_t cnt : 9; /* Counter */
1606 uint32_t : 23; /* *UNDEFINED* */
1607};
1608
1609/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MPUCLK. */
1611#endif /* __ASSEMBLY__ */
1612
1613/* The byte offset of the ALT_CLKMGR_MAINPLL_MPUCLK register from the beginning of the component. */
1614#define ALT_CLKMGR_MAINPLL_MPUCLK_OFST 0x8
1615
1616/*
1617 * Register : Main PLL C1 Control Register for Clock main_clk - mainclk
1618 *
1619 * Contains settings that control clock main_clk generated from the C1 output of
1620 * the Main PLL.
1621 *
1622 * Only reset by a cold reset.
1623 *
1624 * Register Layout
1625 *
1626 * Bits | Access | Reset | Description
1627 * :-------|:-------|:------|:------------
1628 * [8:0] | RW | 0x0 | Counter
1629 * [31:9] | ??? | 0x0 | *UNDEFINED*
1630 *
1631 */
1632/*
1633 * Field : Counter - cnt
1634 *
1635 * Divides the VCO/4 frequency by the value+1 in this field.
1636 *
1637 * Field Access Macros:
1638 *
1639 */
1640/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
1641#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_LSB 0
1642/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
1643#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_MSB 8
1644/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
1645#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_WIDTH 9
1646/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value. */
1647#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET_MSK 0x000001ff
1648/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value. */
1649#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_CLR_MSK 0xfffffe00
1650/* The reset value of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
1651#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_RESET 0x0
1652/* Extracts the ALT_CLKMGR_MAINPLL_MAINCLK_CNT field value from a register. */
1653#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1654/* Produces a ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value suitable for setting the register. */
1655#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1656
1657#ifndef __ASSEMBLY__
1658/*
1659 * WARNING: The C register and register group struct declarations are provided for
1660 * convenience and illustrative purposes. They should, however, be used with
1661 * caution as the C language standard provides no guarantees about the alignment or
1662 * atomicity of device memory accesses. The recommended practice for writing
1663 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1664 * alt_write_word() functions.
1665 *
1666 * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINCLK.
1667 */
1669{
1670 uint32_t cnt : 9; /* Counter */
1671 uint32_t : 23; /* *UNDEFINED* */
1672};
1673
1674/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINCLK. */
1676#endif /* __ASSEMBLY__ */
1677
1678/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINCLK register from the beginning of the component. */
1679#define ALT_CLKMGR_MAINPLL_MAINCLK_OFST 0xc
1680
1681/*
1682 * Register : Main PLL C2 Control Register for Clock dbg_base_clk - dbgatclk
1683 *
1684 * Contains settings that control clock dbg_base_clk generated from the C2 output
1685 * of the Main PLL.
1686 *
1687 * Only reset by a cold reset.
1688 *
1689 * Register Layout
1690 *
1691 * Bits | Access | Reset | Description
1692 * :-------|:-------|:------|:------------
1693 * [8:0] | RW | 0x0 | Counter
1694 * [31:9] | ??? | 0x0 | *UNDEFINED*
1695 *
1696 */
1697/*
1698 * Field : Counter - cnt
1699 *
1700 * Divides the VCO/4 frequency by the value+1 in this field.
1701 *
1702 * Field Access Macros:
1703 *
1704 */
1705/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
1706#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_LSB 0
1707/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
1708#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_MSB 8
1709/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
1710#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_WIDTH 9
1711/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value. */
1712#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET_MSK 0x000001ff
1713/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value. */
1714#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_CLR_MSK 0xfffffe00
1715/* The reset value of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
1716#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_RESET 0x0
1717/* Extracts the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT field value from a register. */
1718#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1719/* Produces a ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value suitable for setting the register. */
1720#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1721
1722#ifndef __ASSEMBLY__
1723/*
1724 * WARNING: The C register and register group struct declarations are provided for
1725 * convenience and illustrative purposes. They should, however, be used with
1726 * caution as the C language standard provides no guarantees about the alignment or
1727 * atomicity of device memory accesses. The recommended practice for writing
1728 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1729 * alt_write_word() functions.
1730 *
1731 * The struct declaration for register ALT_CLKMGR_MAINPLL_DBGATCLK.
1732 */
1734{
1735 uint32_t cnt : 9; /* Counter */
1736 uint32_t : 23; /* *UNDEFINED* */
1737};
1738
1739/* The typedef declaration for register ALT_CLKMGR_MAINPLL_DBGATCLK. */
1741#endif /* __ASSEMBLY__ */
1742
1743/* The byte offset of the ALT_CLKMGR_MAINPLL_DBGATCLK register from the beginning of the component. */
1744#define ALT_CLKMGR_MAINPLL_DBGATCLK_OFST 0x10
1745
1746/*
1747 * Register : Main PLL C3 Control Register for Clock main_qspi_clk - mainqspiclk
1748 *
1749 * Contains settings that control clock main_qspi_clk generated from the C3 output
1750 * of the Main PLL.
1751 *
1752 * Only reset by a cold reset.
1753 *
1754 * Register Layout
1755 *
1756 * Bits | Access | Reset | Description
1757 * :-------|:-------|:------|:------------
1758 * [8:0] | RW | 0x3 | Counter
1759 * [31:9] | ??? | 0x0 | *UNDEFINED*
1760 *
1761 */
1762/*
1763 * Field : Counter - cnt
1764 *
1765 * Divides the VCO frequency by the value+1 in this field.
1766 *
1767 * Field Access Macros:
1768 *
1769 */
1770/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
1771#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_LSB 0
1772/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
1773#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_MSB 8
1774/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
1775#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_WIDTH 9
1776/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value. */
1777#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET_MSK 0x000001ff
1778/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value. */
1779#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_CLR_MSK 0xfffffe00
1780/* The reset value of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
1781#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_RESET 0x3
1782/* Extracts the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT field value from a register. */
1783#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1784/* Produces a ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value suitable for setting the register. */
1785#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1786
1787#ifndef __ASSEMBLY__
1788/*
1789 * WARNING: The C register and register group struct declarations are provided for
1790 * convenience and illustrative purposes. They should, however, be used with
1791 * caution as the C language standard provides no guarantees about the alignment or
1792 * atomicity of device memory accesses. The recommended practice for writing
1793 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1794 * alt_write_word() functions.
1795 *
1796 * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINQSPICLK.
1797 */
1799{
1800 uint32_t cnt : 9; /* Counter */
1801 uint32_t : 23; /* *UNDEFINED* */
1802};
1803
1804/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINQSPICLK. */
1806#endif /* __ASSEMBLY__ */
1807
1808/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINQSPICLK register from the beginning of the component. */
1809#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST 0x14
1810
1811/*
1812 * Register : Main PLL C4 Control Register for Clock main_nand_sdmmc_clk - mainnandsdmmcclk
1813 *
1814 * Contains settings that control clock main_nand_sdmmc_clk generated from the C4
1815 * output of the Main PLL.
1816 *
1817 * Only reset by a cold reset.
1818 *
1819 * Register Layout
1820 *
1821 * Bits | Access | Reset | Description
1822 * :-------|:-------|:------|:------------
1823 * [8:0] | RW | 0x3 | Counter
1824 * [31:9] | ??? | 0x0 | *UNDEFINED*
1825 *
1826 */
1827/*
1828 * Field : Counter - cnt
1829 *
1830 * Divides the VCO frequency by the value+1 in this field.
1831 *
1832 * Field Access Macros:
1833 *
1834 */
1835/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
1836#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_LSB 0
1837/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
1838#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_MSB 8
1839/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
1840#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_WIDTH 9
1841/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value. */
1842#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET_MSK 0x000001ff
1843/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value. */
1844#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_CLR_MSK 0xfffffe00
1845/* The reset value of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
1846#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_RESET 0x3
1847/* Extracts the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT field value from a register. */
1848#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1849/* Produces a ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value suitable for setting the register. */
1850#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1851
1852#ifndef __ASSEMBLY__
1853/*
1854 * WARNING: The C register and register group struct declarations are provided for
1855 * convenience and illustrative purposes. They should, however, be used with
1856 * caution as the C language standard provides no guarantees about the alignment or
1857 * atomicity of device memory accesses. The recommended practice for writing
1858 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1859 * alt_write_word() functions.
1860 *
1861 * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK.
1862 */
1864{
1865 uint32_t cnt : 9; /* Counter */
1866 uint32_t : 23; /* *UNDEFINED* */
1867};
1868
1869/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK. */
1871#endif /* __ASSEMBLY__ */
1872
1873/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK register from the beginning of the component. */
1874#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST 0x18
1875
1876/*
1877 * Register : Main PLL C5 Control Register for Clock cfg_s2f_user0_clk - cfgs2fuser0clk
1878 *
1879 * Contains settings that control clock cfg_s2f_user0_clk generated from the C5
1880 * output of the Main PLL.
1881 *
1882 * Qsys and user documenation refer to cfg_s2f_user0_clk as cfg_h2f_user0_clk.
1883 *
1884 * Only reset by a cold reset.
1885 *
1886 * Register Layout
1887 *
1888 * Bits | Access | Reset | Description
1889 * :-------|:-------|:------|:------------
1890 * [8:0] | RW | 0xf | Counter
1891 * [31:9] | ??? | 0x0 | *UNDEFINED*
1892 *
1893 */
1894/*
1895 * Field : Counter - cnt
1896 *
1897 * Divides the VCO frequency by the value+1 in this field.
1898 *
1899 * Field Access Macros:
1900 *
1901 */
1902/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
1903#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_LSB 0
1904/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
1905#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_MSB 8
1906/* The width in bits of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
1907#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_WIDTH 9
1908/* The mask used to set the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value. */
1909#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET_MSK 0x000001ff
1910/* The mask used to clear the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value. */
1911#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_CLR_MSK 0xfffffe00
1912/* The reset value of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
1913#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_RESET 0xf
1914/* Extracts the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT field value from a register. */
1915#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1916/* Produces a ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value suitable for setting the register. */
1917#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1918
1919#ifndef __ASSEMBLY__
1920/*
1921 * WARNING: The C register and register group struct declarations are provided for
1922 * convenience and illustrative purposes. They should, however, be used with
1923 * caution as the C language standard provides no guarantees about the alignment or
1924 * atomicity of device memory accesses. The recommended practice for writing
1925 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1926 * alt_write_word() functions.
1927 *
1928 * The struct declaration for register ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK.
1929 */
1931{
1932 uint32_t cnt : 9; /* Counter */
1933 uint32_t : 23; /* *UNDEFINED* */
1934};
1935
1936/* The typedef declaration for register ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK. */
1938#endif /* __ASSEMBLY__ */
1939
1940/* The byte offset of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK register from the beginning of the component. */
1941#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST 0x1c
1942
1943/*
1944 * Register : Enable Register - en
1945 *
1946 * Contains fields that control clock enables for clocks derived from the Main PLL.
1947 *
1948 * 1: The clock is enabled.
1949 *
1950 * 0: The clock is disabled.
1951 *
1952 * Fields are only reset by a cold reset.
1953 *
1954 * Register Layout
1955 *
1956 * Bits | Access | Reset | Description
1957 * :--------|:-------|:------|:---------------------
1958 * [0] | RW | 0x1 | l4_main_clk Enable
1959 * [1] | RW | 0x1 | l3_mp_clk Enable
1960 * [2] | RW | 0x1 | l4_mp_clk Enable
1961 * [3] | RW | 0x1 | l4_sp_clk Enable
1962 * [4] | RW | 0x1 | dbg_at_clk Enable
1963 * [5] | RW | 0x1 | dbg_clk Enable
1964 * [6] | RW | 0x1 | dbg_trace_clk Enable
1965 * [7] | RW | 0x1 | dbg_timer_clk Enable
1966 * [8] | RW | 0x1 | cfg_clk Enable
1967 * [9] | RW | 0x1 | s2f_user0_clk Enable
1968 * [31:10] | ??? | 0x0 | *UNDEFINED*
1969 *
1970 */
1971/*
1972 * Field : l4_main_clk Enable - l4mainclk
1973 *
1974 * Enables clock l4_main_clk output
1975 *
1976 * Field Access Macros:
1977 *
1978 */
1979/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
1980#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_LSB 0
1981/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
1982#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_MSB 0
1983/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
1984#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_WIDTH 1
1985/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value. */
1986#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET_MSK 0x00000001
1987/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value. */
1988#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_CLR_MSK 0xfffffffe
1989/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
1990#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_RESET 0x1
1991/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK field value from a register. */
1992#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_GET(value) (((value) & 0x00000001) >> 0)
1993/* Produces a ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value suitable for setting the register. */
1994#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET(value) (((value) << 0) & 0x00000001)
1995
1996/*
1997 * Field : l3_mp_clk Enable - l3mpclk
1998 *
1999 * Enables clock l3_mp_clk output
2000 *
2001 * Field Access Macros:
2002 *
2003 */
2004/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
2005#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_LSB 1
2006/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
2007#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_MSB 1
2008/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
2009#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_WIDTH 1
2010/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value. */
2011#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET_MSK 0x00000002
2012/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value. */
2013#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_CLR_MSK 0xfffffffd
2014/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
2015#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_RESET 0x1
2016/* Extracts the ALT_CLKMGR_MAINPLL_EN_L3MPCLK field value from a register. */
2017#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_GET(value) (((value) & 0x00000002) >> 1)
2018/* Produces a ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value suitable for setting the register. */
2019#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET(value) (((value) << 1) & 0x00000002)
2020
2021/*
2022 * Field : l4_mp_clk Enable - l4mpclk
2023 *
2024 * Enables clock l4_mp_clk output
2025 *
2026 * Field Access Macros:
2027 *
2028 */
2029/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
2030#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_LSB 2
2031/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
2032#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_MSB 2
2033/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
2034#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_WIDTH 1
2035/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value. */
2036#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET_MSK 0x00000004
2037/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value. */
2038#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_CLR_MSK 0xfffffffb
2039/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
2040#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_RESET 0x1
2041/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4MPCLK field value from a register. */
2042#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_GET(value) (((value) & 0x00000004) >> 2)
2043/* Produces a ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value suitable for setting the register. */
2044#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET(value) (((value) << 2) & 0x00000004)
2045
2046/*
2047 * Field : l4_sp_clk Enable - l4spclk
2048 *
2049 * Enables clock l4_sp_clk output
2050 *
2051 * Field Access Macros:
2052 *
2053 */
2054/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
2055#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_LSB 3
2056/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
2057#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_MSB 3
2058/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
2059#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_WIDTH 1
2060/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value. */
2061#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET_MSK 0x00000008
2062/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value. */
2063#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_CLR_MSK 0xfffffff7
2064/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
2065#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_RESET 0x1
2066/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4SPCLK field value from a register. */
2067#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_GET(value) (((value) & 0x00000008) >> 3)
2068/* Produces a ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value suitable for setting the register. */
2069#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET(value) (((value) << 3) & 0x00000008)
2070
2071/*
2072 * Field : dbg_at_clk Enable - dbgatclk
2073 *
2074 * Enables clock dbg_at_clk output
2075 *
2076 * Field Access Macros:
2077 *
2078 */
2079/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
2080#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_LSB 4
2081/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
2082#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_MSB 4
2083/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
2084#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_WIDTH 1
2085/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value. */
2086#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET_MSK 0x00000010
2087/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value. */
2088#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_CLR_MSK 0xffffffef
2089/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
2090#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_RESET 0x1
2091/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGATCLK field value from a register. */
2092#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_GET(value) (((value) & 0x00000010) >> 4)
2093/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value suitable for setting the register. */
2094#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET(value) (((value) << 4) & 0x00000010)
2095
2096/*
2097 * Field : dbg_clk Enable - dbgclk
2098 *
2099 * Enables clock dbg_clk output
2100 *
2101 * Field Access Macros:
2102 *
2103 */
2104/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
2105#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_LSB 5
2106/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
2107#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_MSB 5
2108/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
2109#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_WIDTH 1
2110/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value. */
2111#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET_MSK 0x00000020
2112/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value. */
2113#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_CLR_MSK 0xffffffdf
2114/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
2115#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_RESET 0x1
2116/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGCLK field value from a register. */
2117#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_GET(value) (((value) & 0x00000020) >> 5)
2118/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value suitable for setting the register. */
2119#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET(value) (((value) << 5) & 0x00000020)
2120
2121/*
2122 * Field : dbg_trace_clk Enable - dbgtraceclk
2123 *
2124 * Enables clock dbg_trace_clk output
2125 *
2126 * Field Access Macros:
2127 *
2128 */
2129/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
2130#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_LSB 6
2131/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
2132#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_MSB 6
2133/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
2134#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_WIDTH 1
2135/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value. */
2136#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET_MSK 0x00000040
2137/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value. */
2138#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_CLR_MSK 0xffffffbf
2139/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
2140#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_RESET 0x1
2141/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK field value from a register. */
2142#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_GET(value) (((value) & 0x00000040) >> 6)
2143/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value suitable for setting the register. */
2144#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET(value) (((value) << 6) & 0x00000040)
2145
2146/*
2147 * Field : dbg_timer_clk Enable - dbgtimerclk
2148 *
2149 * Enables clock dbg_timer_clk output
2150 *
2151 * Field Access Macros:
2152 *
2153 */
2154/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
2155#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_LSB 7
2156/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
2157#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_MSB 7
2158/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
2159#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_WIDTH 1
2160/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value. */
2161#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET_MSK 0x00000080
2162/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value. */
2163#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_CLR_MSK 0xffffff7f
2164/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
2165#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_RESET 0x1
2166/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK field value from a register. */
2167#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_GET(value) (((value) & 0x00000080) >> 7)
2168/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value suitable for setting the register. */
2169#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET(value) (((value) << 7) & 0x00000080)
2170
2171/*
2172 * Field : cfg_clk Enable - cfgclk
2173 *
2174 * Enables clock cfg_clk output
2175 *
2176 * Field Access Macros:
2177 *
2178 */
2179/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
2180#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_LSB 8
2181/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
2182#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_MSB 8
2183/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
2184#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_WIDTH 1
2185/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value. */
2186#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET_MSK 0x00000100
2187/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value. */
2188#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_CLR_MSK 0xfffffeff
2189/* The reset value of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
2190#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_RESET 0x1
2191/* Extracts the ALT_CLKMGR_MAINPLL_EN_CFGCLK field value from a register. */
2192#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_GET(value) (((value) & 0x00000100) >> 8)
2193/* Produces a ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value suitable for setting the register. */
2194#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET(value) (((value) << 8) & 0x00000100)
2195
2196/*
2197 * Field : s2f_user0_clk Enable - s2fuser0clk
2198 *
2199 * Enables clock s2f_user0_clk output.
2200 *
2201 * Qsys and user documenation refer to s2f_user0_clk as h2f_user0_clk.
2202 *
2203 * Field Access Macros:
2204 *
2205 */
2206/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
2207#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_LSB 9
2208/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
2209#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_MSB 9
2210/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
2211#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_WIDTH 1
2212/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value. */
2213#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET_MSK 0x00000200
2214/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value. */
2215#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_CLR_MSK 0xfffffdff
2216/* The reset value of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
2217#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_RESET 0x1
2218/* Extracts the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK field value from a register. */
2219#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_GET(value) (((value) & 0x00000200) >> 9)
2220/* Produces a ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value suitable for setting the register. */
2221#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET(value) (((value) << 9) & 0x00000200)
2222
2223#ifndef __ASSEMBLY__
2224/*
2225 * WARNING: The C register and register group struct declarations are provided for
2226 * convenience and illustrative purposes. They should, however, be used with
2227 * caution as the C language standard provides no guarantees about the alignment or
2228 * atomicity of device memory accesses. The recommended practice for writing
2229 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2230 * alt_write_word() functions.
2231 *
2232 * The struct declaration for register ALT_CLKMGR_MAINPLL_EN.
2233 */
2235{
2236 uint32_t l4mainclk : 1; /* l4_main_clk Enable */
2237 uint32_t l3mpclk : 1; /* l3_mp_clk Enable */
2238 uint32_t l4mpclk : 1; /* l4_mp_clk Enable */
2239 uint32_t l4spclk : 1; /* l4_sp_clk Enable */
2240 uint32_t dbgatclk : 1; /* dbg_at_clk Enable */
2241 uint32_t dbgclk : 1; /* dbg_clk Enable */
2242 uint32_t dbgtraceclk : 1; /* dbg_trace_clk Enable */
2243 uint32_t dbgtimerclk : 1; /* dbg_timer_clk Enable */
2244 uint32_t cfgclk : 1; /* cfg_clk Enable */
2245 uint32_t s2fuser0clk : 1; /* s2f_user0_clk Enable */
2246 uint32_t : 22; /* *UNDEFINED* */
2247};
2248
2249/* The typedef declaration for register ALT_CLKMGR_MAINPLL_EN. */
2250typedef volatile struct ALT_CLKMGR_MAINPLL_EN_s ALT_CLKMGR_MAINPLL_EN_t;
2251#endif /* __ASSEMBLY__ */
2252
2253/* The byte offset of the ALT_CLKMGR_MAINPLL_EN register from the beginning of the component. */
2254#define ALT_CLKMGR_MAINPLL_EN_OFST 0x20
2255
2256/*
2257 * Register : Main Divide Register - maindiv
2258 *
2259 * Contains fields that control clock dividers for main clocks derived from the
2260 * Main PLL
2261 *
2262 * Fields are only reset by a cold reset.
2263 *
2264 * Register Layout
2265 *
2266 * Bits | Access | Reset | Description
2267 * :--------|:-------|:------|:--------------------
2268 * [1:0] | RW | 0x0 | L3 MP Clock Divider
2269 * [3:2] | RW | 0x0 | L3 SP Clock Divider
2270 * [6:4] | RW | 0x0 | L4 MP Clock Divider
2271 * [9:7] | RW | 0x0 | L4 SP Clock Divider
2272 * [31:10] | ??? | 0x0 | *UNDEFINED*
2273 *
2274 */
2275/*
2276 * Field : L3 MP Clock Divider - l3mpclk
2277 *
2278 * The l3_mp_clk is divided down from the l3_main_clk by the value specified in
2279 * this field.
2280 *
2281 * Field Enumeration Values:
2282 *
2283 * Enum | Value | Description
2284 * :------------------------------------------|:------|:------------
2285 * ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1 | 0x0 | Divide by 1
2286 * ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2 | 0x1 | Divide by 2
2287 *
2288 * Field Access Macros:
2289 *
2290 */
2291/*
2292 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK
2293 *
2294 * Divide by 1
2295 */
2296#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1 0x0
2297/*
2298 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK
2299 *
2300 * Divide by 2
2301 */
2302#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2 0x1
2303
2304/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
2305#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_LSB 0
2306/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
2307#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_MSB 1
2308/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
2309#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_WIDTH 2
2310/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value. */
2311#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET_MSK 0x00000003
2312/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value. */
2313#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_CLR_MSK 0xfffffffc
2314/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
2315#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_RESET 0x0
2316/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK field value from a register. */
2317#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_GET(value) (((value) & 0x00000003) >> 0)
2318/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value suitable for setting the register. */
2319#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET(value) (((value) << 0) & 0x00000003)
2320
2321/*
2322 * Field : L3 SP Clock Divider - l3spclk
2323 *
2324 * The l3_sp_clk is divided down from the l3_mp_clk by the value specified in this
2325 * field.
2326 *
2327 * Field Enumeration Values:
2328 *
2329 * Enum | Value | Description
2330 * :------------------------------------------|:------|:------------
2331 * ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1 | 0x0 | Divide by 1
2332 * ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2 | 0x1 | Divide by 2
2333 *
2334 * Field Access Macros:
2335 *
2336 */
2337/*
2338 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK
2339 *
2340 * Divide by 1
2341 */
2342#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1 0x0
2343/*
2344 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK
2345 *
2346 * Divide by 2
2347 */
2348#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2 0x1
2349
2350/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
2351#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_LSB 2
2352/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
2353#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_MSB 3
2354/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
2355#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_WIDTH 2
2356/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value. */
2357#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET_MSK 0x0000000c
2358/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value. */
2359#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_CLR_MSK 0xfffffff3
2360/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
2361#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_RESET 0x0
2362/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK field value from a register. */
2363#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_GET(value) (((value) & 0x0000000c) >> 2)
2364/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value suitable for setting the register. */
2365#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET(value) (((value) << 2) & 0x0000000c)
2366
2367/*
2368 * Field : L4 MP Clock Divider - l4mpclk
2369 *
2370 * The l4_mp_clk is divided down from the periph_base_clk by the value specified in
2371 * this field.
2372 *
2373 * Field Enumeration Values:
2374 *
2375 * Enum | Value | Description
2376 * :--------------------------------------------|:------|:-------------
2377 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1 | 0x0 | Divide By 1
2378 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2 | 0x1 | Divide By 2
2379 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4 | 0x2 | Divide By 4
2380 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8 | 0x3 | Divide By 8
2381 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16 | 0x4 | Divide By 16
2382 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1 | 0x5 | Reserved
2383 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2 | 0x6 | Reserved
2384 * ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3 | 0x7 | Reserved
2385 *
2386 * Field Access Macros:
2387 *
2388 */
2389/*
2390 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2391 *
2392 * Divide By 1
2393 */
2394#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1 0x0
2395/*
2396 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2397 *
2398 * Divide By 2
2399 */
2400#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2 0x1
2401/*
2402 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2403 *
2404 * Divide By 4
2405 */
2406#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4 0x2
2407/*
2408 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2409 *
2410 * Divide By 8
2411 */
2412#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8 0x3
2413/*
2414 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2415 *
2416 * Divide By 16
2417 */
2418#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16 0x4
2419/*
2420 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2421 *
2422 * Reserved
2423 */
2424#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1 0x5
2425/*
2426 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2427 *
2428 * Reserved
2429 */
2430#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2 0x6
2431/*
2432 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
2433 *
2434 * Reserved
2435 */
2436#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3 0x7
2437
2438/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
2439#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_LSB 4
2440/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
2441#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_MSB 6
2442/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
2443#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_WIDTH 3
2444/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value. */
2445#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET_MSK 0x00000070
2446/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value. */
2447#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_CLR_MSK 0xffffff8f
2448/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
2449#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_RESET 0x0
2450/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK field value from a register. */
2451#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_GET(value) (((value) & 0x00000070) >> 4)
2452/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value suitable for setting the register. */
2453#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET(value) (((value) << 4) & 0x00000070)
2454
2455/*
2456 * Field : L4 SP Clock Divider - l4spclk
2457 *
2458 * The l4_sp_clk is divided down from the periph_base_clk by the value specified in
2459 * this field.
2460 *
2461 * Field Enumeration Values:
2462 *
2463 * Enum | Value | Description
2464 * :--------------------------------------------|:------|:-------------
2465 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1 | 0x0 | Divide By 1
2466 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2 | 0x1 | Divide By 2
2467 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4 | 0x2 | Divide By 4
2468 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8 | 0x3 | Divide By 8
2469 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16 | 0x4 | Divide By 16
2470 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1 | 0x5 | Reserved
2471 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2 | 0x6 | Reserved
2472 * ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3 | 0x7 | Reserved
2473 *
2474 * Field Access Macros:
2475 *
2476 */
2477/*
2478 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2479 *
2480 * Divide By 1
2481 */
2482#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1 0x0
2483/*
2484 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2485 *
2486 * Divide By 2
2487 */
2488#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2 0x1
2489/*
2490 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2491 *
2492 * Divide By 4
2493 */
2494#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4 0x2
2495/*
2496 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2497 *
2498 * Divide By 8
2499 */
2500#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8 0x3
2501/*
2502 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2503 *
2504 * Divide By 16
2505 */
2506#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16 0x4
2507/*
2508 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2509 *
2510 * Reserved
2511 */
2512#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1 0x5
2513/*
2514 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2515 *
2516 * Reserved
2517 */
2518#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2 0x6
2519/*
2520 * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
2521 *
2522 * Reserved
2523 */
2524#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3 0x7
2525
2526/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
2527#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_LSB 7
2528/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
2529#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_MSB 9
2530/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
2531#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_WIDTH 3
2532/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value. */
2533#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET_MSK 0x00000380
2534/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value. */
2535#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_CLR_MSK 0xfffffc7f
2536/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
2537#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_RESET 0x0
2538/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK field value from a register. */
2539#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_GET(value) (((value) & 0x00000380) >> 7)
2540/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value suitable for setting the register. */
2541#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET(value) (((value) << 7) & 0x00000380)
2542
2543#ifndef __ASSEMBLY__
2544/*
2545 * WARNING: The C register and register group struct declarations are provided for
2546 * convenience and illustrative purposes. They should, however, be used with
2547 * caution as the C language standard provides no guarantees about the alignment or
2548 * atomicity of device memory accesses. The recommended practice for writing
2549 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2550 * alt_write_word() functions.
2551 *
2552 * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINDIV.
2553 */
2555{
2556 uint32_t l3mpclk : 2; /* L3 MP Clock Divider */
2557 uint32_t l3spclk : 2; /* L3 SP Clock Divider */
2558 uint32_t l4mpclk : 3; /* L4 MP Clock Divider */
2559 uint32_t l4spclk : 3; /* L4 SP Clock Divider */
2560 uint32_t : 22; /* *UNDEFINED* */
2561};
2562
2563/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINDIV. */
2565#endif /* __ASSEMBLY__ */
2566
2567/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINDIV register from the beginning of the component. */
2568#define ALT_CLKMGR_MAINPLL_MAINDIV_OFST 0x24
2569
2570/*
2571 * Register : Debug Divide Register - dbgdiv
2572 *
2573 * Contains fields that control clock dividers for debug clocks derived from the
2574 * Main PLL
2575 *
2576 * Fields are only reset by a cold reset.
2577 *
2578 * Register Layout
2579 *
2580 * Bits | Access | Reset | Description
2581 * :-------|:-------|:------|:-----------------------
2582 * [1:0] | RW | 0x0 | Debug AT Clock Divider
2583 * [3:2] | RW | 0x1 | Debug Clock Divider
2584 * [31:4] | ??? | 0x0 | *UNDEFINED*
2585 *
2586 */
2587/*
2588 * Field : Debug AT Clock Divider - dbgatclk
2589 *
2590 * The dbg_at_clk is divided down from the C2 output of the Main PLL by the value
2591 * specified in this field.
2592 *
2593 * Field Enumeration Values:
2594 *
2595 * Enum | Value | Description
2596 * :------------------------------------------|:------|:------------
2597 * ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1 | 0x0 | Divide by 1
2598 * ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2 | 0x1 | Divide by 2
2599 * ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4 | 0x2 | Divide by 4
2600 *
2601 * Field Access Macros:
2602 *
2603 */
2604/*
2605 * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK
2606 *
2607 * Divide by 1
2608 */
2609#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1 0x0
2610/*
2611 * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK
2612 *
2613 * Divide by 2
2614 */
2615#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2 0x1
2616/*
2617 * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK
2618 *
2619 * Divide by 4
2620 */
2621#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4 0x2
2622
2623/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
2624#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_LSB 0
2625/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
2626#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_MSB 1
2627/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
2628#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_WIDTH 2
2629/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value. */
2630#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET_MSK 0x00000003
2631/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value. */
2632#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_CLR_MSK 0xfffffffc
2633/* The reset value of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
2634#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_RESET 0x0
2635/* Extracts the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK field value from a register. */
2636#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_GET(value) (((value) & 0x00000003) >> 0)
2637/* Produces a ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value suitable for setting the register. */
2638#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET(value) (((value) << 0) & 0x00000003)
2639
2640/*
2641 * Field : Debug Clock Divider - dbgclk
2642 *
2643 * The dbg_clk is divided down from the dbg_at_clk by the value specified in this
2644 * field.
2645 *
2646 * Field Enumeration Values:
2647 *
2648 * Enum | Value | Description
2649 * :----------------------------------------|:------|:------------
2650 * ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2 | 0x1 | Divide by 2
2651 * ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4 | 0x2 | Divide by 4
2652 *
2653 * Field Access Macros:
2654 *
2655 */
2656/*
2657 * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK
2658 *
2659 * Divide by 2
2660 */
2661#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2 0x1
2662/*
2663 * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK
2664 *
2665 * Divide by 4
2666 */
2667#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4 0x2
2668
2669/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
2670#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_LSB 2
2671/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
2672#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_MSB 3
2673/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
2674#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_WIDTH 2
2675/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value. */
2676#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET_MSK 0x0000000c
2677/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value. */
2678#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_CLR_MSK 0xfffffff3
2679/* The reset value of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
2680#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_RESET 0x1
2681/* Extracts the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK field value from a register. */
2682#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_GET(value) (((value) & 0x0000000c) >> 2)
2683/* Produces a ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value suitable for setting the register. */
2684#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET(value) (((value) << 2) & 0x0000000c)
2685
2686#ifndef __ASSEMBLY__
2687/*
2688 * WARNING: The C register and register group struct declarations are provided for
2689 * convenience and illustrative purposes. They should, however, be used with
2690 * caution as the C language standard provides no guarantees about the alignment or
2691 * atomicity of device memory accesses. The recommended practice for writing
2692 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2693 * alt_write_word() functions.
2694 *
2695 * The struct declaration for register ALT_CLKMGR_MAINPLL_DBGDIV.
2696 */
2698{
2699 uint32_t dbgatclk : 2; /* Debug AT Clock Divider */
2700 uint32_t dbgclk : 2; /* Debug Clock Divider */
2701 uint32_t : 28; /* *UNDEFINED* */
2702};
2703
2704/* The typedef declaration for register ALT_CLKMGR_MAINPLL_DBGDIV. */
2706#endif /* __ASSEMBLY__ */
2707
2708/* The byte offset of the ALT_CLKMGR_MAINPLL_DBGDIV register from the beginning of the component. */
2709#define ALT_CLKMGR_MAINPLL_DBGDIV_OFST 0x28
2710
2711/*
2712 * Register : Debug Trace Divide Register - tracediv
2713 *
2714 * Contains a field that controls the clock divider for the debug trace clock
2715 * derived from the Main PLL
2716 *
2717 * Only reset by a cold reset.
2718 *
2719 * Register Layout
2720 *
2721 * Bits | Access | Reset | Description
2722 * :-------|:-------|:------|:--------------------------
2723 * [2:0] | RW | 0x0 | Debug Trace Clock Divider
2724 * [31:3] | ??? | 0x0 | *UNDEFINED*
2725 *
2726 */
2727/*
2728 * Field : Debug Trace Clock Divider - traceclk
2729 *
2730 * The dbg_trace_clk is divided down from the C2 output of the Main PLL by the
2731 * value specified in this field.
2732 *
2733 * Field Enumeration Values:
2734 *
2735 * Enum | Value | Description
2736 * :----------------------------------------------|:------|:-------------
2737 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1 | 0x0 | Divide By 1
2738 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2 | 0x1 | Divide By 2
2739 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4 | 0x2 | Divide By 4
2740 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8 | 0x3 | Divide By 8
2741 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16 | 0x4 | Divide By 16
2742 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1 | 0x5 | Reserved
2743 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2 | 0x6 | Reserved
2744 * ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3 | 0x7 | Reserved
2745 *
2746 * Field Access Macros:
2747 *
2748 */
2749/*
2750 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2751 *
2752 * Divide By 1
2753 */
2754#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1 0x0
2755/*
2756 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2757 *
2758 * Divide By 2
2759 */
2760#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2 0x1
2761/*
2762 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2763 *
2764 * Divide By 4
2765 */
2766#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4 0x2
2767/*
2768 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2769 *
2770 * Divide By 8
2771 */
2772#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8 0x3
2773/*
2774 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2775 *
2776 * Divide By 16
2777 */
2778#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16 0x4
2779/*
2780 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2781 *
2782 * Reserved
2783 */
2784#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1 0x5
2785/*
2786 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2787 *
2788 * Reserved
2789 */
2790#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2 0x6
2791/*
2792 * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
2793 *
2794 * Reserved
2795 */
2796#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3 0x7
2797
2798/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
2799#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_LSB 0
2800/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
2801#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_MSB 2
2802/* The width in bits of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
2803#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_WIDTH 3
2804/* The mask used to set the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value. */
2805#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET_MSK 0x00000007
2806/* The mask used to clear the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value. */
2807#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_CLR_MSK 0xfffffff8
2808/* The reset value of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
2809#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_RESET 0x0
2810/* Extracts the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK field value from a register. */
2811#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_GET(value) (((value) & 0x00000007) >> 0)
2812/* Produces a ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value suitable for setting the register. */
2813#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET(value) (((value) << 0) & 0x00000007)
2814
2815#ifndef __ASSEMBLY__
2816/*
2817 * WARNING: The C register and register group struct declarations are provided for
2818 * convenience and illustrative purposes. They should, however, be used with
2819 * caution as the C language standard provides no guarantees about the alignment or
2820 * atomicity of device memory accesses. The recommended practice for writing
2821 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2822 * alt_write_word() functions.
2823 *
2824 * The struct declaration for register ALT_CLKMGR_MAINPLL_TRACEDIV.
2825 */
2827{
2828 uint32_t traceclk : 3; /* Debug Trace Clock Divider */
2829 uint32_t : 29; /* *UNDEFINED* */
2830};
2831
2832/* The typedef declaration for register ALT_CLKMGR_MAINPLL_TRACEDIV. */
2834#endif /* __ASSEMBLY__ */
2835
2836/* The byte offset of the ALT_CLKMGR_MAINPLL_TRACEDIV register from the beginning of the component. */
2837#define ALT_CLKMGR_MAINPLL_TRACEDIV_OFST 0x2c
2838
2839/*
2840 * Register : L4 MP SP APB Clock Source - l4src
2841 *
2842 * Contains fields that select the clock source for L4 MP and SP APB interconnect
2843 *
2844 * Fields are only reset by a cold reset.
2845 *
2846 * Register Layout
2847 *
2848 * Bits | Access | Reset | Description
2849 * :-------|:-------|:------|:-----------------
2850 * [0] | RW | 0x0 | l4_mp_clk Source
2851 * [1] | RW | 0x0 | l4_sp_clk Source
2852 * [31:2] | ??? | 0x0 | *UNDEFINED*
2853 *
2854 */
2855/*
2856 * Field : l4_mp_clk Source - l4mp
2857 *
2858 * Selects the source for l4_mp_clk
2859 *
2860 * Field Enumeration Values:
2861 *
2862 * Enum | Value | Description
2863 * :------------------------------------------|:------|:----------------
2864 * ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL | 0x0 | main_clk
2865 * ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL | 0x1 | periph_base_clk
2866 *
2867 * Field Access Macros:
2868 *
2869 */
2870/*
2871 * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4MP
2872 *
2873 * main_clk
2874 */
2875#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL 0x0
2876/*
2877 * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4MP
2878 *
2879 * periph_base_clk
2880 */
2881#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL 0x1
2882
2883/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
2884#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_LSB 0
2885/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
2886#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_MSB 0
2887/* The width in bits of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
2888#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_WIDTH 1
2889/* The mask used to set the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value. */
2890#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET_MSK 0x00000001
2891/* The mask used to clear the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value. */
2892#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_CLR_MSK 0xfffffffe
2893/* The reset value of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
2894#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_RESET 0x0
2895/* Extracts the ALT_CLKMGR_MAINPLL_L4SRC_L4MP field value from a register. */
2896#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_GET(value) (((value) & 0x00000001) >> 0)
2897/* Produces a ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value suitable for setting the register. */
2898#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET(value) (((value) << 0) & 0x00000001)
2899
2900/*
2901 * Field : l4_sp_clk Source - l4sp
2902 *
2903 * Selects the source for l4_sp_clk
2904 *
2905 * Field Enumeration Values:
2906 *
2907 * Enum | Value | Description
2908 * :------------------------------------------|:------|:----------------
2909 * ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL | 0x0 | main_clk
2910 * ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL | 0x1 | periph_base_clk
2911 *
2912 * Field Access Macros:
2913 *
2914 */
2915/*
2916 * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4SP
2917 *
2918 * main_clk
2919 */
2920#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL 0x0
2921/*
2922 * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4SP
2923 *
2924 * periph_base_clk
2925 */
2926#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL 0x1
2927
2928/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
2929#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_LSB 1
2930/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
2931#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_MSB 1
2932/* The width in bits of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
2933#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_WIDTH 1
2934/* The mask used to set the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value. */
2935#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET_MSK 0x00000002
2936/* The mask used to clear the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value. */
2937#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_CLR_MSK 0xfffffffd
2938/* The reset value of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
2939#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_RESET 0x0
2940/* Extracts the ALT_CLKMGR_MAINPLL_L4SRC_L4SP field value from a register. */
2941#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_GET(value) (((value) & 0x00000002) >> 1)
2942/* Produces a ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value suitable for setting the register. */
2943#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET(value) (((value) << 1) & 0x00000002)
2944
2945#ifndef __ASSEMBLY__
2946/*
2947 * WARNING: The C register and register group struct declarations are provided for
2948 * convenience and illustrative purposes. They should, however, be used with
2949 * caution as the C language standard provides no guarantees about the alignment or
2950 * atomicity of device memory accesses. The recommended practice for writing
2951 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2952 * alt_write_word() functions.
2953 *
2954 * The struct declaration for register ALT_CLKMGR_MAINPLL_L4SRC.
2955 */
2957{
2958 uint32_t l4mp : 1; /* l4_mp_clk Source */
2959 uint32_t l4sp : 1; /* l4_sp_clk Source */
2960 uint32_t : 30; /* *UNDEFINED* */
2961};
2962
2963/* The typedef declaration for register ALT_CLKMGR_MAINPLL_L4SRC. */
2965#endif /* __ASSEMBLY__ */
2966
2967/* The byte offset of the ALT_CLKMGR_MAINPLL_L4SRC register from the beginning of the component. */
2968#define ALT_CLKMGR_MAINPLL_L4SRC_OFST 0x30
2969
2970/*
2971 * Register : Main PLL Output Counter Reset Ack Status Register - stat
2972 *
2973 * Contains Output Clock Counter Reset acknowledge status.
2974 *
2975 * Register Layout
2976 *
2977 * Bits | Access | Reset | Description
2978 * :-------|:-------|:------|:---------------------------------
2979 * [5:0] | R | 0x0 | Output Counter Reset Acknowledge
2980 * [31:6] | ??? | 0x0 | *UNDEFINED*
2981 *
2982 */
2983/*
2984 * Field : Output Counter Reset Acknowledge - outresetack
2985 *
2986 * These read only bits per PLL output indicate that the PLL has received the
2987 * Output Reset Counter request and has gracefully stopped the respective PLL
2988 * output clock.
2989 *
2990 * For software to change the PLL output counter without producing glitches on the
2991 * respective clock, SW must set the VCO register respective Output Counter Reset
2992 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
2993 * the Output Counter Reset Ack Status Register. Software then writes the
2994 * appropriate counter register, and then clears the respective VCO register Output
2995 * Counter Reset bit.
2996 *
2997 * The reset value of this bit is applied on a cold reset; warm reset has no affect
2998 * on this bit.
2999 *
3000 * Field Enumeration Values:
3001 *
3002 * Enum | Value | Description
3003 * :--------------------------------------------|:------|:-------------------------------------
3004 * ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE | 0x0 | Idle
3005 * ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1 | Output Counter Acknowledge received.
3006 *
3007 * Field Access Macros:
3008 *
3009 */
3010/*
3011 * Enumerated value for register field ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK
3012 *
3013 * Idle
3014 */
3015#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE 0x0
3016/*
3017 * Enumerated value for register field ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK
3018 *
3019 * Output Counter Acknowledge received.
3020 */
3021#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
3022
3023/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
3024#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_LSB 0
3025/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
3026#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_MSB 5
3027/* The width in bits of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
3028#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_WIDTH 6
3029/* The mask used to set the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value. */
3030#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
3031/* The mask used to clear the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value. */
3032#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
3033/* The reset value of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
3034#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_RESET 0x0
3035/* Extracts the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK field value from a register. */
3036#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
3037/* Produces a ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
3038#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
3039
3040#ifndef __ASSEMBLY__
3041/*
3042 * WARNING: The C register and register group struct declarations are provided for
3043 * convenience and illustrative purposes. They should, however, be used with
3044 * caution as the C language standard provides no guarantees about the alignment or
3045 * atomicity of device memory accesses. The recommended practice for writing
3046 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3047 * alt_write_word() functions.
3048 *
3049 * The struct declaration for register ALT_CLKMGR_MAINPLL_STAT.
3050 */
3052{
3053 const uint32_t outresetack : 6; /* Output Counter Reset Acknowledge */
3054 uint32_t : 26; /* *UNDEFINED* */
3055};
3056
3057/* The typedef declaration for register ALT_CLKMGR_MAINPLL_STAT. */
3059#endif /* __ASSEMBLY__ */
3060
3061/* The byte offset of the ALT_CLKMGR_MAINPLL_STAT register from the beginning of the component. */
3062#define ALT_CLKMGR_MAINPLL_STAT_OFST 0x34
3063
3064#ifndef __ASSEMBLY__
3065/*
3066 * WARNING: The C register and register group struct declarations are provided for
3067 * convenience and illustrative purposes. They should, however, be used with
3068 * caution as the C language standard provides no guarantees about the alignment or
3069 * atomicity of device memory accesses. The recommended practice for writing
3070 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3071 * alt_write_word() functions.
3072 *
3073 * The struct declaration for register group ALT_CLKMGR_MAINPLL.
3074 */
3076{
3077 volatile ALT_CLKMGR_MAINPLL_VCO_t vco; /* ALT_CLKMGR_MAINPLL_VCO */
3078 volatile ALT_CLKMGR_MAINPLL_MISC_t misc; /* ALT_CLKMGR_MAINPLL_MISC */
3079 volatile ALT_CLKMGR_MAINPLL_MPUCLK_t mpuclk; /* ALT_CLKMGR_MAINPLL_MPUCLK */
3080 volatile ALT_CLKMGR_MAINPLL_MAINCLK_t mainclk; /* ALT_CLKMGR_MAINPLL_MAINCLK */
3081 volatile ALT_CLKMGR_MAINPLL_DBGATCLK_t dbgatclk; /* ALT_CLKMGR_MAINPLL_DBGATCLK */
3082 volatile ALT_CLKMGR_MAINPLL_MAINQSPICLK_t mainqspiclk; /* ALT_CLKMGR_MAINPLL_MAINQSPICLK */
3083 volatile ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_t mainnandsdmmcclk; /* ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK */
3084 volatile ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_t cfgs2fuser0clk; /* ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK */
3085 volatile ALT_CLKMGR_MAINPLL_EN_t en; /* ALT_CLKMGR_MAINPLL_EN */
3086 volatile ALT_CLKMGR_MAINPLL_MAINDIV_t maindiv; /* ALT_CLKMGR_MAINPLL_MAINDIV */
3087 volatile ALT_CLKMGR_MAINPLL_DBGDIV_t dbgdiv; /* ALT_CLKMGR_MAINPLL_DBGDIV */
3088 volatile ALT_CLKMGR_MAINPLL_TRACEDIV_t tracediv; /* ALT_CLKMGR_MAINPLL_TRACEDIV */
3089 volatile ALT_CLKMGR_MAINPLL_L4SRC_t l4src; /* ALT_CLKMGR_MAINPLL_L4SRC */
3090 volatile ALT_CLKMGR_MAINPLL_STAT_t stat; /* ALT_CLKMGR_MAINPLL_STAT */
3091 volatile uint32_t _pad_0x38_0x40[2]; /* *UNDEFINED* */
3092};
3093
3094/* The typedef declaration for register group ALT_CLKMGR_MAINPLL. */
3095typedef volatile struct ALT_CLKMGR_MAINPLL_s ALT_CLKMGR_MAINPLL_t;
3096/* The struct declaration for the raw register contents of register group ALT_CLKMGR_MAINPLL. */
3098{
3099 volatile uint32_t vco; /* ALT_CLKMGR_MAINPLL_VCO */
3100 volatile uint32_t misc; /* ALT_CLKMGR_MAINPLL_MISC */
3101 volatile uint32_t mpuclk; /* ALT_CLKMGR_MAINPLL_MPUCLK */
3102 volatile uint32_t mainclk; /* ALT_CLKMGR_MAINPLL_MAINCLK */
3103 volatile uint32_t dbgatclk; /* ALT_CLKMGR_MAINPLL_DBGATCLK */
3104 volatile uint32_t mainqspiclk; /* ALT_CLKMGR_MAINPLL_MAINQSPICLK */
3105 volatile uint32_t mainnandsdmmcclk; /* ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK */
3106 volatile uint32_t cfgs2fuser0clk; /* ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK */
3107 volatile uint32_t en; /* ALT_CLKMGR_MAINPLL_EN */
3108 volatile uint32_t maindiv; /* ALT_CLKMGR_MAINPLL_MAINDIV */
3109 volatile uint32_t dbgdiv; /* ALT_CLKMGR_MAINPLL_DBGDIV */
3110 volatile uint32_t tracediv; /* ALT_CLKMGR_MAINPLL_TRACEDIV */
3111 volatile uint32_t l4src; /* ALT_CLKMGR_MAINPLL_L4SRC */
3112 volatile uint32_t stat; /* ALT_CLKMGR_MAINPLL_STAT */
3113 volatile uint32_t _pad_0x38_0x40[2]; /* *UNDEFINED* */
3114};
3115
3116/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_MAINPLL. */
3118#endif /* __ASSEMBLY__ */
3119
3120
3121/*
3122 * Register Group : Peripheral PLL Group - ALT_CLKMGR_PERPLL
3123 * Peripheral PLL Group
3124 *
3125 * Contains registers with settings for the Peripheral PLL.
3126 *
3127 */
3128/*
3129 * Register : Peripheral PLL VCO Control Register - vco
3130 *
3131 * Contains settings that control the Peripheral PLL VCO. The VCO output frequency
3132 * is the input frequency multiplied by the numerator (M+1) and divided by the
3133 * denominator (N+1).
3134 *
3135 * Fields are only reset by a cold reset.
3136 *
3137 * Register Layout
3138 *
3139 * Bits | Access | Reset | Description
3140 * :--------|:-------|:------|:--------------------------------
3141 * [0] | RW | 0x1 | BG PWRDN
3142 * [1] | RW | 0x0 | Enable
3143 * [2] | RW | 0x1 | Power down
3144 * [15:3] | RW | 0x1 | Numerator (M)
3145 * [21:16] | RW | 0x1 | Denominator (N)
3146 * [23:22] | RW | 0x0 | Clock Source
3147 * [24] | RW | 0x0 | All Output Counter Reset
3148 * [30:25] | RW | 0x0 | Output Counter Reset
3149 * [31] | RW | 0x1 | External Regulator Input Select
3150 *
3151 */
3152/*
3153 * Field : BG PWRDN - bgpwrdn
3154 *
3155 * If '1', powers down bandgap. If '0', bandgap is not power down.
3156 *
3157 * Field Access Macros:
3158 *
3159 */
3160/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
3161#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_LSB 0
3162/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
3163#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_MSB 0
3164/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
3165#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_WIDTH 1
3166/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value. */
3167#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET_MSK 0x00000001
3168/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value. */
3169#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
3170/* The reset value of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
3171#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_RESET 0x1
3172/* Extracts the ALT_CLKMGR_PERPLL_VCO_BGPWRDN field value from a register. */
3173#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
3174/* Produces a ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value suitable for setting the register. */
3175#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
3176
3177/*
3178 * Field : Enable - en
3179 *
3180 * If '1', VCO is enabled. If '0', VCO is in reset.
3181 *
3182 * Field Access Macros:
3183 *
3184 */
3185/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
3186#define ALT_CLKMGR_PERPLL_VCO_EN_LSB 1
3187/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
3188#define ALT_CLKMGR_PERPLL_VCO_EN_MSB 1
3189/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
3190#define ALT_CLKMGR_PERPLL_VCO_EN_WIDTH 1
3191/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_EN register field value. */
3192#define ALT_CLKMGR_PERPLL_VCO_EN_SET_MSK 0x00000002
3193/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_EN register field value. */
3194#define ALT_CLKMGR_PERPLL_VCO_EN_CLR_MSK 0xfffffffd
3195/* The reset value of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
3196#define ALT_CLKMGR_PERPLL_VCO_EN_RESET 0x0
3197/* Extracts the ALT_CLKMGR_PERPLL_VCO_EN field value from a register. */
3198#define ALT_CLKMGR_PERPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
3199/* Produces a ALT_CLKMGR_PERPLL_VCO_EN register field value suitable for setting the register. */
3200#define ALT_CLKMGR_PERPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
3201
3202/*
3203 * Field : Power down - pwrdn
3204 *
3205 * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
3206 *
3207 * Field Access Macros:
3208 *
3209 */
3210/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
3211#define ALT_CLKMGR_PERPLL_VCO_PWRDN_LSB 2
3212/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
3213#define ALT_CLKMGR_PERPLL_VCO_PWRDN_MSB 2
3214/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
3215#define ALT_CLKMGR_PERPLL_VCO_PWRDN_WIDTH 1
3216/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_PWRDN register field value. */
3217#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET_MSK 0x00000004
3218/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_PWRDN register field value. */
3219#define ALT_CLKMGR_PERPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
3220/* The reset value of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
3221#define ALT_CLKMGR_PERPLL_VCO_PWRDN_RESET 0x1
3222/* Extracts the ALT_CLKMGR_PERPLL_VCO_PWRDN field value from a register. */
3223#define ALT_CLKMGR_PERPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
3224/* Produces a ALT_CLKMGR_PERPLL_VCO_PWRDN register field value suitable for setting the register. */
3225#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
3226
3227/*
3228 * Field : Numerator (M) - numer
3229 *
3230 * Numerator in VCO output frequency equation. For incremental frequency change, if
3231 * the new value lead to less than 20% of the frequency change, this value can be
3232 * changed without resetting the PLL. The Numerator and Denominator can not be
3233 * changed at the same time for incremental frequency changed.
3234 *
3235 * Field Access Macros:
3236 *
3237 */
3238/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
3239#define ALT_CLKMGR_PERPLL_VCO_NUMER_LSB 3
3240/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
3241#define ALT_CLKMGR_PERPLL_VCO_NUMER_MSB 15
3242/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
3243#define ALT_CLKMGR_PERPLL_VCO_NUMER_WIDTH 13
3244/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_NUMER register field value. */
3245#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET_MSK 0x0000fff8
3246/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_NUMER register field value. */
3247#define ALT_CLKMGR_PERPLL_VCO_NUMER_CLR_MSK 0xffff0007
3248/* The reset value of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
3249#define ALT_CLKMGR_PERPLL_VCO_NUMER_RESET 0x1
3250/* Extracts the ALT_CLKMGR_PERPLL_VCO_NUMER field value from a register. */
3251#define ALT_CLKMGR_PERPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
3252/* Produces a ALT_CLKMGR_PERPLL_VCO_NUMER register field value suitable for setting the register. */
3253#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
3254
3255/*
3256 * Field : Denominator (N) - denom
3257 *
3258 * Denominator in VCO output frequency equation. For incremental frequency change,
3259 * if the new value lead to less than 20% of the frequency change, this value can
3260 * be changed without resetting the PLL. The Numerator and Denominator can not be
3261 * changed at the same time for incremental frequency changed.
3262 *
3263 * Field Access Macros:
3264 *
3265 */
3266/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
3267#define ALT_CLKMGR_PERPLL_VCO_DENOM_LSB 16
3268/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
3269#define ALT_CLKMGR_PERPLL_VCO_DENOM_MSB 21
3270/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
3271#define ALT_CLKMGR_PERPLL_VCO_DENOM_WIDTH 6
3272/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_DENOM register field value. */
3273#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET_MSK 0x003f0000
3274/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_DENOM register field value. */
3275#define ALT_CLKMGR_PERPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
3276/* The reset value of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
3277#define ALT_CLKMGR_PERPLL_VCO_DENOM_RESET 0x1
3278/* Extracts the ALT_CLKMGR_PERPLL_VCO_DENOM field value from a register. */
3279#define ALT_CLKMGR_PERPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
3280/* Produces a ALT_CLKMGR_PERPLL_VCO_DENOM register field value suitable for setting the register. */
3281#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
3282
3283/*
3284 * Field : Clock Source - psrc
3285 *
3286 * Controls the VCO input clock source.
3287 *
3288 * Qsys and user documenation refer to f2s_periph_ref_clk as f2h_periph_ref_clk.
3289 *
3290 * Field Enumeration Values:
3291 *
3292 * Enum | Value | Description
3293 * :--------------------------------------------|:------|:-------------------
3294 * ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1 | 0x0 | eosc1_clk
3295 * ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2 | 0x1 | eosc2_clk
3296 * ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF | 0x2 | f2s_periph_ref_clk
3297 *
3298 * Field Access Macros:
3299 *
3300 */
3301/*
3302 * Enumerated value for register field ALT_CLKMGR_PERPLL_VCO_PSRC
3303 *
3304 * eosc1_clk
3305 */
3306#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1 0x0
3307/*
3308 * Enumerated value for register field ALT_CLKMGR_PERPLL_VCO_PSRC
3309 *
3310 * eosc2_clk
3311 */
3312#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2 0x1
3313/*
3314 * Enumerated value for register field ALT_CLKMGR_PERPLL_VCO_PSRC
3315 *
3316 * f2s_periph_ref_clk
3317 */
3318#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF 0x2
3319
3320/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
3321#define ALT_CLKMGR_PERPLL_VCO_PSRC_LSB 22
3322/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
3323#define ALT_CLKMGR_PERPLL_VCO_PSRC_MSB 23
3324/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
3325#define ALT_CLKMGR_PERPLL_VCO_PSRC_WIDTH 2
3326/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_PSRC register field value. */
3327#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET_MSK 0x00c00000
3328/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_PSRC register field value. */
3329#define ALT_CLKMGR_PERPLL_VCO_PSRC_CLR_MSK 0xff3fffff
3330/* The reset value of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
3331#define ALT_CLKMGR_PERPLL_VCO_PSRC_RESET 0x0
3332/* Extracts the ALT_CLKMGR_PERPLL_VCO_PSRC field value from a register. */
3333#define ALT_CLKMGR_PERPLL_VCO_PSRC_GET(value) (((value) & 0x00c00000) >> 22)
3334/* Produces a ALT_CLKMGR_PERPLL_VCO_PSRC register field value suitable for setting the register. */
3335#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET(value) (((value) << 22) & 0x00c00000)
3336
3337/*
3338 * Field : All Output Counter Reset - outresetall
3339 *
3340 * Before releasing Bypass, All Output Counter Reset must be set and cleared by
3341 * software for correct clock operation.
3342 *
3343 * If '1', Reset phase multiplexer and all output counter state. So that after the
3344 * assertion all the clocks output are start from rising edge align.
3345 *
3346 * If '0', phase multiplexer and output counter state not reset and no change to
3347 * the phase of the clock outputs.
3348 *
3349 * Field Access Macros:
3350 *
3351 */
3352/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
3353#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_LSB 24
3354/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
3355#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_MSB 24
3356/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
3357#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_WIDTH 1
3358/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value. */
3359#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
3360/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value. */
3361#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
3362/* The reset value of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
3363#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_RESET 0x0
3364/* Extracts the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL field value from a register. */
3365#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
3366/* Produces a ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
3367#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
3368
3369/*
3370 * Field : Output Counter Reset - outreset
3371 *
3372 * Resets the individual PLL output counter.
3373 *
3374 * For software to change the PLL output counter without producing glitches on the
3375 * respective clock, SW must set the VCO register respective Output Counter Reset
3376 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
3377 * the Output Counter Reset Ack Status Register. Software then writes the
3378 * appropriate counter register, and then clears the respective VCO register Output
3379 * Counter Reset bit.
3380 *
3381 * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
3382 *
3383 * If set to '1', reset output divider, no clock output from counter.
3384 *
3385 * If set to '0', counter is not reset.
3386 *
3387 * The reset value of this bit is applied on a cold reset; warm reset has no affect
3388 * on this bit.
3389 *
3390 * Field Access Macros:
3391 *
3392 */
3393/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
3394#define ALT_CLKMGR_PERPLL_VCO_OUTRST_LSB 25
3395/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
3396#define ALT_CLKMGR_PERPLL_VCO_OUTRST_MSB 30
3397/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
3398#define ALT_CLKMGR_PERPLL_VCO_OUTRST_WIDTH 6
3399/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_OUTRST register field value. */
3400#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET_MSK 0x7e000000
3401/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_OUTRST register field value. */
3402#define ALT_CLKMGR_PERPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
3403/* The reset value of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
3404#define ALT_CLKMGR_PERPLL_VCO_OUTRST_RESET 0x0
3405/* Extracts the ALT_CLKMGR_PERPLL_VCO_OUTRST field value from a register. */
3406#define ALT_CLKMGR_PERPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
3407/* Produces a ALT_CLKMGR_PERPLL_VCO_OUTRST register field value suitable for setting the register. */
3408#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
3409
3410/*
3411 * Field : External Regulator Input Select - regextsel
3412 *
3413 * If set to '1', the external regulator is selected for the PLL.
3414 *
3415 * If set to '0', the internal regulator is slected.
3416 *
3417 * It is strongly recommended to select the external regulator while the PLL is not
3418 * enabled (in reset), and then disable the external regulater once the PLL
3419 * becomes enabled. Software should simulateously update the 'Enable' bit and the
3420 * 'External Regulator Input Select' in the same write access to the VCO register.
3421 * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
3422 * set, and vice versa.
3423 *
3424 * The reset value of this bit is applied on a cold reset; warm reset has no affect
3425 * on this bit.
3426 *
3427 * Field Access Macros:
3428 *
3429 */
3430/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
3431#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_LSB 31
3432/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
3433#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_MSB 31
3434/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
3435#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_WIDTH 1
3436/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value. */
3437#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
3438/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value. */
3439#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
3440/* The reset value of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
3441#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_RESET 0x1
3442/* Extracts the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL field value from a register. */
3443#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
3444/* Produces a ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
3445#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
3446
3447#ifndef __ASSEMBLY__
3448/*
3449 * WARNING: The C register and register group struct declarations are provided for
3450 * convenience and illustrative purposes. They should, however, be used with
3451 * caution as the C language standard provides no guarantees about the alignment or
3452 * atomicity of device memory accesses. The recommended practice for writing
3453 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3454 * alt_write_word() functions.
3455 *
3456 * The struct declaration for register ALT_CLKMGR_PERPLL_VCO.
3457 */
3459{
3460 uint32_t bgpwrdn : 1; /* BG PWRDN */
3461 uint32_t en : 1; /* Enable */
3462 uint32_t pwrdn : 1; /* Power down */
3463 uint32_t numer : 13; /* Numerator (M) */
3464 uint32_t denom : 6; /* Denominator (N) */
3465 uint32_t psrc : 2; /* Clock Source */
3466 uint32_t outresetall : 1; /* All Output Counter Reset */
3467 uint32_t outreset : 6; /* Output Counter Reset */
3468 uint32_t regextsel : 1; /* External Regulator Input Select */
3469};
3470
3471/* The typedef declaration for register ALT_CLKMGR_PERPLL_VCO. */
3472typedef volatile struct ALT_CLKMGR_PERPLL_VCO_s ALT_CLKMGR_PERPLL_VCO_t;
3473#endif /* __ASSEMBLY__ */
3474
3475/* The byte offset of the ALT_CLKMGR_PERPLL_VCO register from the beginning of the component. */
3476#define ALT_CLKMGR_PERPLL_VCO_OFST 0x0
3477
3478/*
3479 * Register : Peripheral PLL VCO Advanced Control Register - misc
3480 *
3481 * Contains VCO control signals and other PLL control signals need to be
3482 * controllable through register.
3483 *
3484 * Fields are only reset by a cold reset.
3485 *
3486 * Register Layout
3487 *
3488 * Bits | Access | Reset | Description
3489 * :--------|:-------|:------|:------------------------------
3490 * [0] | RW | 0x0 | Loop Bandwidth Adjust Enabled
3491 * [12:1] | RW | 0x1 | Loop Bandwidth Adjust
3492 * [13] | RW | 0x0 | Fast Locking Enable
3493 * [14] | RW | 0x1 | Saturation Enable
3494 * [31:15] | ??? | 0x0 | *UNDEFINED*
3495 *
3496 */
3497/*
3498 * Field : Loop Bandwidth Adjust Enabled - bwadjen
3499 *
3500 * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
3501 * Adjust field.
3502 *
3503 * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
3504 * value of the VCO Control Register. The M divided by 2 is the upper 12 bits
3505 * (12:1) of the M field in the VCO register.
3506 *
3507 * Field Access Macros:
3508 *
3509 */
3510/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
3511#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_LSB 0
3512/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
3513#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_MSB 0
3514/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
3515#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_WIDTH 1
3516/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value. */
3517#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET_MSK 0x00000001
3518/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value. */
3519#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_CLR_MSK 0xfffffffe
3520/* The reset value of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
3521#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_RESET 0x0
3522/* Extracts the ALT_CLKMGR_PERPLL_MISC_BWADJEN field value from a register. */
3523#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
3524/* Produces a ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value suitable for setting the register. */
3525#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
3526
3527/*
3528 * Field : Loop Bandwidth Adjust - bwadj
3529 *
3530 * Provides Loop Bandwidth Adjust value.
3531 *
3532 * Field Access Macros:
3533 *
3534 */
3535/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
3536#define ALT_CLKMGR_PERPLL_MISC_BWADJ_LSB 1
3537/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
3538#define ALT_CLKMGR_PERPLL_MISC_BWADJ_MSB 12
3539/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
3540#define ALT_CLKMGR_PERPLL_MISC_BWADJ_WIDTH 12
3541/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_BWADJ register field value. */
3542#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET_MSK 0x00001ffe
3543/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_BWADJ register field value. */
3544#define ALT_CLKMGR_PERPLL_MISC_BWADJ_CLR_MSK 0xffffe001
3545/* The reset value of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
3546#define ALT_CLKMGR_PERPLL_MISC_BWADJ_RESET 0x1
3547/* Extracts the ALT_CLKMGR_PERPLL_MISC_BWADJ field value from a register. */
3548#define ALT_CLKMGR_PERPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
3549/* Produces a ALT_CLKMGR_PERPLL_MISC_BWADJ register field value suitable for setting the register. */
3550#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
3551
3552/*
3553 * Field : Fast Locking Enable - fasten
3554 *
3555 * Enables fast locking circuit.
3556 *
3557 * Field Access Macros:
3558 *
3559 */
3560/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
3561#define ALT_CLKMGR_PERPLL_MISC_FASTEN_LSB 13
3562/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
3563#define ALT_CLKMGR_PERPLL_MISC_FASTEN_MSB 13
3564/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
3565#define ALT_CLKMGR_PERPLL_MISC_FASTEN_WIDTH 1
3566/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_FASTEN register field value. */
3567#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET_MSK 0x00002000
3568/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_FASTEN register field value. */
3569#define ALT_CLKMGR_PERPLL_MISC_FASTEN_CLR_MSK 0xffffdfff
3570/* The reset value of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
3571#define ALT_CLKMGR_PERPLL_MISC_FASTEN_RESET 0x0
3572/* Extracts the ALT_CLKMGR_PERPLL_MISC_FASTEN field value from a register. */
3573#define ALT_CLKMGR_PERPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
3574/* Produces a ALT_CLKMGR_PERPLL_MISC_FASTEN register field value suitable for setting the register. */
3575#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
3576
3577/*
3578 * Field : Saturation Enable - saten
3579 *
3580 * Enables saturation behavior.
3581 *
3582 * Field Access Macros:
3583 *
3584 */
3585/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
3586#define ALT_CLKMGR_PERPLL_MISC_SATEN_LSB 14
3587/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
3588#define ALT_CLKMGR_PERPLL_MISC_SATEN_MSB 14
3589/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
3590#define ALT_CLKMGR_PERPLL_MISC_SATEN_WIDTH 1
3591/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_SATEN register field value. */
3592#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET_MSK 0x00004000
3593/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_SATEN register field value. */
3594#define ALT_CLKMGR_PERPLL_MISC_SATEN_CLR_MSK 0xffffbfff
3595/* The reset value of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
3596#define ALT_CLKMGR_PERPLL_MISC_SATEN_RESET 0x1
3597/* Extracts the ALT_CLKMGR_PERPLL_MISC_SATEN field value from a register. */
3598#define ALT_CLKMGR_PERPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
3599/* Produces a ALT_CLKMGR_PERPLL_MISC_SATEN register field value suitable for setting the register. */
3600#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
3601
3602#ifndef __ASSEMBLY__
3603/*
3604 * WARNING: The C register and register group struct declarations are provided for
3605 * convenience and illustrative purposes. They should, however, be used with
3606 * caution as the C language standard provides no guarantees about the alignment or
3607 * atomicity of device memory accesses. The recommended practice for writing
3608 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3609 * alt_write_word() functions.
3610 *
3611 * The struct declaration for register ALT_CLKMGR_PERPLL_MISC.
3612 */
3614{
3615 uint32_t bwadjen : 1; /* Loop Bandwidth Adjust Enabled */
3616 uint32_t bwadj : 12; /* Loop Bandwidth Adjust */
3617 uint32_t fasten : 1; /* Fast Locking Enable */
3618 uint32_t saten : 1; /* Saturation Enable */
3619 uint32_t : 17; /* *UNDEFINED* */
3620};
3621
3622/* The typedef declaration for register ALT_CLKMGR_PERPLL_MISC. */
3624#endif /* __ASSEMBLY__ */
3625
3626/* The byte offset of the ALT_CLKMGR_PERPLL_MISC register from the beginning of the component. */
3627#define ALT_CLKMGR_PERPLL_MISC_OFST 0x4
3628
3629/*
3630 * Register : Peripheral PLL C0 Control Register for Clock emac0_clk - emac0clk
3631 *
3632 * Contains settings that control clock emac0_clk generated from the C0 output of
3633 * the Peripheral PLL.
3634 *
3635 * Only reset by a cold reset.
3636 *
3637 * Register Layout
3638 *
3639 * Bits | Access | Reset | Description
3640 * :-------|:-------|:------|:------------
3641 * [8:0] | RW | 0x1 | Counter
3642 * [31:9] | ??? | 0x0 | *UNDEFINED*
3643 *
3644 */
3645/*
3646 * Field : Counter - cnt
3647 *
3648 * Divides the VCO frequency by the value+1 in this field.
3649 *
3650 * Field Access Macros:
3651 *
3652 */
3653/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
3654#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_LSB 0
3655/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
3656#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_MSB 8
3657/* The width in bits of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
3658#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_WIDTH 9
3659/* The mask used to set the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value. */
3660#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET_MSK 0x000001ff
3661/* The mask used to clear the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value. */
3662#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_CLR_MSK 0xfffffe00
3663/* The reset value of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
3664#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_RESET 0x1
3665/* Extracts the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT field value from a register. */
3666#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3667/* Produces a ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value suitable for setting the register. */
3668#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3669
3670#ifndef __ASSEMBLY__
3671/*
3672 * WARNING: The C register and register group struct declarations are provided for
3673 * convenience and illustrative purposes. They should, however, be used with
3674 * caution as the C language standard provides no guarantees about the alignment or
3675 * atomicity of device memory accesses. The recommended practice for writing
3676 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3677 * alt_write_word() functions.
3678 *
3679 * The struct declaration for register ALT_CLKMGR_PERPLL_EMAC0CLK.
3680 */
3682{
3683 uint32_t cnt : 9; /* Counter */
3684 uint32_t : 23; /* *UNDEFINED* */
3685};
3686
3687/* The typedef declaration for register ALT_CLKMGR_PERPLL_EMAC0CLK. */
3689#endif /* __ASSEMBLY__ */
3690
3691/* The byte offset of the ALT_CLKMGR_PERPLL_EMAC0CLK register from the beginning of the component. */
3692#define ALT_CLKMGR_PERPLL_EMAC0CLK_OFST 0x8
3693
3694/*
3695 * Register : Peripheral PLL C1 Control Register for Clock emac1_clk - emac1clk
3696 *
3697 * Contains settings that control clock emac1_clk generated from the C1 output of
3698 * the Peripheral PLL.
3699 *
3700 * Only reset by a cold reset.
3701 *
3702 * Register Layout
3703 *
3704 * Bits | Access | Reset | Description
3705 * :-------|:-------|:------|:------------
3706 * [8:0] | RW | 0x1 | Counter
3707 * [31:9] | ??? | 0x0 | *UNDEFINED*
3708 *
3709 */
3710/*
3711 * Field : Counter - cnt
3712 *
3713 * Divides the VCO frequency by the value+1 in this field.
3714 *
3715 * Field Access Macros:
3716 *
3717 */
3718/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
3719#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_LSB 0
3720/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
3721#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_MSB 8
3722/* The width in bits of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
3723#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_WIDTH 9
3724/* The mask used to set the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value. */
3725#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET_MSK 0x000001ff
3726/* The mask used to clear the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value. */
3727#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_CLR_MSK 0xfffffe00
3728/* The reset value of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
3729#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_RESET 0x1
3730/* Extracts the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT field value from a register. */
3731#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3732/* Produces a ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value suitable for setting the register. */
3733#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3734
3735#ifndef __ASSEMBLY__
3736/*
3737 * WARNING: The C register and register group struct declarations are provided for
3738 * convenience and illustrative purposes. They should, however, be used with
3739 * caution as the C language standard provides no guarantees about the alignment or
3740 * atomicity of device memory accesses. The recommended practice for writing
3741 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3742 * alt_write_word() functions.
3743 *
3744 * The struct declaration for register ALT_CLKMGR_PERPLL_EMAC1CLK.
3745 */
3747{
3748 uint32_t cnt : 9; /* Counter */
3749 uint32_t : 23; /* *UNDEFINED* */
3750};
3751
3752/* The typedef declaration for register ALT_CLKMGR_PERPLL_EMAC1CLK. */
3754#endif /* __ASSEMBLY__ */
3755
3756/* The byte offset of the ALT_CLKMGR_PERPLL_EMAC1CLK register from the beginning of the component. */
3757#define ALT_CLKMGR_PERPLL_EMAC1CLK_OFST 0xc
3758
3759/*
3760 * Register : Peripheral PLL C2 Control Register for Clock periph_qspi_clk - perqspiclk
3761 *
3762 * Contains settings that control clock periph_qspi_clk generated from the C2
3763 * output of the Peripheral PLL.
3764 *
3765 * Only reset by a cold reset.
3766 *
3767 * Register Layout
3768 *
3769 * Bits | Access | Reset | Description
3770 * :-------|:-------|:------|:------------
3771 * [8:0] | RW | 0x1 | Counter
3772 * [31:9] | ??? | 0x0 | *UNDEFINED*
3773 *
3774 */
3775/*
3776 * Field : Counter - cnt
3777 *
3778 * Divides the VCO frequency by the value+1 in this field.
3779 *
3780 * Field Access Macros:
3781 *
3782 */
3783/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
3784#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_LSB 0
3785/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
3786#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_MSB 8
3787/* The width in bits of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
3788#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_WIDTH 9
3789/* The mask used to set the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value. */
3790#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET_MSK 0x000001ff
3791/* The mask used to clear the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value. */
3792#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_CLR_MSK 0xfffffe00
3793/* The reset value of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
3794#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_RESET 0x1
3795/* Extracts the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT field value from a register. */
3796#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3797/* Produces a ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value suitable for setting the register. */
3798#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3799
3800#ifndef __ASSEMBLY__
3801/*
3802 * WARNING: The C register and register group struct declarations are provided for
3803 * convenience and illustrative purposes. They should, however, be used with
3804 * caution as the C language standard provides no guarantees about the alignment or
3805 * atomicity of device memory accesses. The recommended practice for writing
3806 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3807 * alt_write_word() functions.
3808 *
3809 * The struct declaration for register ALT_CLKMGR_PERPLL_PERQSPICLK.
3810 */
3812{
3813 uint32_t cnt : 9; /* Counter */
3814 uint32_t : 23; /* *UNDEFINED* */
3815};
3816
3817/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERQSPICLK. */
3819#endif /* __ASSEMBLY__ */
3820
3821/* The byte offset of the ALT_CLKMGR_PERPLL_PERQSPICLK register from the beginning of the component. */
3822#define ALT_CLKMGR_PERPLL_PERQSPICLK_OFST 0x10
3823
3824/*
3825 * Register : Peripheral PLL C3 Control Register for Clock periph_nand_sdmmc_clk - pernandsdmmcclk
3826 *
3827 * Contains settings that control clock periph_nand_sdmmc_clk generated from the C3
3828 * output of the Peripheral PLL.
3829 *
3830 * Only reset by a cold reset.
3831 *
3832 * Register Layout
3833 *
3834 * Bits | Access | Reset | Description
3835 * :-------|:-------|:------|:------------
3836 * [8:0] | RW | 0x1 | Counter
3837 * [31:9] | ??? | 0x0 | *UNDEFINED*
3838 *
3839 */
3840/*
3841 * Field : Counter - cnt
3842 *
3843 * Divides the VCO frequency by the value+1 in this field.
3844 *
3845 * Field Access Macros:
3846 *
3847 */
3848/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
3849#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_LSB 0
3850/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
3851#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_MSB 8
3852/* The width in bits of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
3853#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_WIDTH 9
3854/* The mask used to set the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value. */
3855#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET_MSK 0x000001ff
3856/* The mask used to clear the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value. */
3857#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_CLR_MSK 0xfffffe00
3858/* The reset value of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
3859#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_RESET 0x1
3860/* Extracts the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT field value from a register. */
3861#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3862/* Produces a ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value suitable for setting the register. */
3863#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3864
3865#ifndef __ASSEMBLY__
3866/*
3867 * WARNING: The C register and register group struct declarations are provided for
3868 * convenience and illustrative purposes. They should, however, be used with
3869 * caution as the C language standard provides no guarantees about the alignment or
3870 * atomicity of device memory accesses. The recommended practice for writing
3871 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3872 * alt_write_word() functions.
3873 *
3874 * The struct declaration for register ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK.
3875 */
3877{
3878 uint32_t cnt : 9; /* Counter */
3879 uint32_t : 23; /* *UNDEFINED* */
3880};
3881
3882/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK. */
3884#endif /* __ASSEMBLY__ */
3885
3886/* The byte offset of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK register from the beginning of the component. */
3887#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST 0x14
3888
3889/*
3890 * Register : Peripheral PLL C4 Control Register for Clock periph_base_clk - perbaseclk
3891 *
3892 * Contains settings that control clock periph_base_clk generated from the C4
3893 * output of the Peripheral PLL.
3894 *
3895 * Only reset by a cold reset.
3896 *
3897 * Register Layout
3898 *
3899 * Bits | Access | Reset | Description
3900 * :-------|:-------|:------|:------------
3901 * [8:0] | RW | 0x1 | Counter
3902 * [31:9] | ??? | 0x0 | *UNDEFINED*
3903 *
3904 */
3905/*
3906 * Field : Counter - cnt
3907 *
3908 * Divides the VCO frequency by the value+1 in this field.
3909 *
3910 * Field Access Macros:
3911 *
3912 */
3913/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
3914#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_LSB 0
3915/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
3916#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_MSB 8
3917/* The width in bits of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
3918#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_WIDTH 9
3919/* The mask used to set the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value. */
3920#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET_MSK 0x000001ff
3921/* The mask used to clear the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value. */
3922#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_CLR_MSK 0xfffffe00
3923/* The reset value of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
3924#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_RESET 0x1
3925/* Extracts the ALT_CLKMGR_PERPLL_PERBASECLK_CNT field value from a register. */
3926#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3927/* Produces a ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value suitable for setting the register. */
3928#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3929
3930#ifndef __ASSEMBLY__
3931/*
3932 * WARNING: The C register and register group struct declarations are provided for
3933 * convenience and illustrative purposes. They should, however, be used with
3934 * caution as the C language standard provides no guarantees about the alignment or
3935 * atomicity of device memory accesses. The recommended practice for writing
3936 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3937 * alt_write_word() functions.
3938 *
3939 * The struct declaration for register ALT_CLKMGR_PERPLL_PERBASECLK.
3940 */
3942{
3943 uint32_t cnt : 9; /* Counter */
3944 uint32_t : 23; /* *UNDEFINED* */
3945};
3946
3947/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERBASECLK. */
3949#endif /* __ASSEMBLY__ */
3950
3951/* The byte offset of the ALT_CLKMGR_PERPLL_PERBASECLK register from the beginning of the component. */
3952#define ALT_CLKMGR_PERPLL_PERBASECLK_OFST 0x18
3953
3954/*
3955 * Register : Peripheral PLL C5 Control Register for Clock s2f_user1_clk - s2fuser1clk
3956 *
3957 * Contains settings that control clock s2f_user1_clk generated from the C5 output
3958 * of the Peripheral PLL.
3959 *
3960 * Qsys and user documenation refer to s2f_user1_clk as h2f_user1_clk.
3961 *
3962 * Only reset by a cold reset.
3963 *
3964 * Register Layout
3965 *
3966 * Bits | Access | Reset | Description
3967 * :-------|:-------|:------|:------------
3968 * [8:0] | RW | 0x1 | Counter
3969 * [31:9] | ??? | 0x0 | *UNDEFINED*
3970 *
3971 */
3972/*
3973 * Field : Counter - cnt
3974 *
3975 * Divides the VCO frequency by the value+1 in this field.
3976 *
3977 * Field Access Macros:
3978 *
3979 */
3980/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
3981#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_LSB 0
3982/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
3983#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_MSB 8
3984/* The width in bits of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
3985#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_WIDTH 9
3986/* The mask used to set the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value. */
3987#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET_MSK 0x000001ff
3988/* The mask used to clear the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value. */
3989#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_CLR_MSK 0xfffffe00
3990/* The reset value of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
3991#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_RESET 0x1
3992/* Extracts the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT field value from a register. */
3993#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3994/* Produces a ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value suitable for setting the register. */
3995#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3996
3997#ifndef __ASSEMBLY__
3998/*
3999 * WARNING: The C register and register group struct declarations are provided for
4000 * convenience and illustrative purposes. They should, however, be used with
4001 * caution as the C language standard provides no guarantees about the alignment or
4002 * atomicity of device memory accesses. The recommended practice for writing
4003 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4004 * alt_write_word() functions.
4005 *
4006 * The struct declaration for register ALT_CLKMGR_PERPLL_S2FUSER1CLK.
4007 */
4009{
4010 uint32_t cnt : 9; /* Counter */
4011 uint32_t : 23; /* *UNDEFINED* */
4012};
4013
4014/* The typedef declaration for register ALT_CLKMGR_PERPLL_S2FUSER1CLK. */
4016#endif /* __ASSEMBLY__ */
4017
4018/* The byte offset of the ALT_CLKMGR_PERPLL_S2FUSER1CLK register from the beginning of the component. */
4019#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST 0x1c
4020
4021/*
4022 * Register : Enable Register - en
4023 *
4024 * Contains fields that control clock enables for clocks derived from the
4025 * Peripheral PLL
4026 *
4027 * 1: The clock is enabled.
4028 *
4029 * 0: The clock is disabled.
4030 *
4031 * Fields are only reset by a cold reset.
4032 *
4033 * Register Layout
4034 *
4035 * Bits | Access | Reset | Description
4036 * :--------|:-------|:------|:---------------------
4037 * [0] | RW | 0x1 | emac0_clk Enable
4038 * [1] | RW | 0x1 | emac1_clk Enable
4039 * [2] | RW | 0x1 | usb_mp_clk Enable
4040 * [3] | RW | 0x1 | spi_m_clk Enable
4041 * [4] | RW | 0x1 | can0_clk Enable
4042 * [5] | RW | 0x1 | can1_clk Enable
4043 * [6] | RW | 0x1 | gpio_clk Enable
4044 * [7] | RW | 0x1 | s2f_user1_clk Enable
4045 * [8] | RW | 0x1 | sdmmc_clk Enable
4046 * [9] | RW | 0x1 | nand_x_clk Enable
4047 * [10] | RW | 0x1 | nand_clk Enable
4048 * [11] | RW | 0x1 | qspi_clk Enable
4049 * [31:12] | ??? | 0x0 | *UNDEFINED*
4050 *
4051 */
4052/*
4053 * Field : emac0_clk Enable - emac0clk
4054 *
4055 * Enables clock emac0_clk output
4056 *
4057 * Field Access Macros:
4058 *
4059 */
4060/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
4061#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_LSB 0
4062/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
4063#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_MSB 0
4064/* The width in bits of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
4065#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_WIDTH 1
4066/* The mask used to set the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value. */
4067#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET_MSK 0x00000001
4068/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value. */
4069#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_CLR_MSK 0xfffffffe
4070/* The reset value of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
4071#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_RESET 0x1
4072/* Extracts the ALT_CLKMGR_PERPLL_EN_EMAC0CLK field value from a register. */
4073#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_GET(value) (((value) & 0x00000001) >> 0)
4074/* Produces a ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value suitable for setting the register. */
4075#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET(value) (((value) << 0) & 0x00000001)
4076
4077/*
4078 * Field : emac1_clk Enable - emac1clk
4079 *
4080 * Enables clock emac1_clk output
4081 *
4082 * Field Access Macros:
4083 *
4084 */
4085/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
4086#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_LSB 1
4087/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
4088#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_MSB 1
4089/* The width in bits of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
4090#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_WIDTH 1
4091/* The mask used to set the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value. */
4092#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET_MSK 0x00000002
4093/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value. */
4094#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_CLR_MSK 0xfffffffd
4095/* The reset value of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
4096#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_RESET 0x1
4097/* Extracts the ALT_CLKMGR_PERPLL_EN_EMAC1CLK field value from a register. */
4098#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_GET(value) (((value) & 0x00000002) >> 1)
4099/* Produces a ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value suitable for setting the register. */
4100#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET(value) (((value) << 1) & 0x00000002)
4101
4102/*
4103 * Field : usb_mp_clk Enable - usbclk
4104 *
4105 * Enables clock usb_mp_clk output
4106 *
4107 * Field Access Macros:
4108 *
4109 */
4110/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
4111#define ALT_CLKMGR_PERPLL_EN_USBCLK_LSB 2
4112/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
4113#define ALT_CLKMGR_PERPLL_EN_USBCLK_MSB 2
4114/* The width in bits of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
4115#define ALT_CLKMGR_PERPLL_EN_USBCLK_WIDTH 1
4116/* The mask used to set the ALT_CLKMGR_PERPLL_EN_USBCLK register field value. */
4117#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET_MSK 0x00000004
4118/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_USBCLK register field value. */
4119#define ALT_CLKMGR_PERPLL_EN_USBCLK_CLR_MSK 0xfffffffb
4120/* The reset value of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
4121#define ALT_CLKMGR_PERPLL_EN_USBCLK_RESET 0x1
4122/* Extracts the ALT_CLKMGR_PERPLL_EN_USBCLK field value from a register. */
4123#define ALT_CLKMGR_PERPLL_EN_USBCLK_GET(value) (((value) & 0x00000004) >> 2)
4124/* Produces a ALT_CLKMGR_PERPLL_EN_USBCLK register field value suitable for setting the register. */
4125#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET(value) (((value) << 2) & 0x00000004)
4126
4127/*
4128 * Field : spi_m_clk Enable - spimclk
4129 *
4130 * Enables clock spi_m_clk output
4131 *
4132 * Field Access Macros:
4133 *
4134 */
4135/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
4136#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_LSB 3
4137/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
4138#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_MSB 3
4139/* The width in bits of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
4140#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_WIDTH 1
4141/* The mask used to set the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value. */
4142#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET_MSK 0x00000008
4143/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value. */
4144#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_CLR_MSK 0xfffffff7
4145/* The reset value of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
4146#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_RESET 0x1
4147/* Extracts the ALT_CLKMGR_PERPLL_EN_SPIMCLK field value from a register. */
4148#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_GET(value) (((value) & 0x00000008) >> 3)
4149/* Produces a ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value suitable for setting the register. */
4150#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET(value) (((value) << 3) & 0x00000008)
4151
4152/*
4153 * Field : can0_clk Enable - can0clk
4154 *
4155 * Enables clock can0_clk output
4156 *
4157 * Field Access Macros:
4158 *
4159 */
4160/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
4161#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_LSB 4
4162/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
4163#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_MSB 4
4164/* The width in bits of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
4165#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_WIDTH 1
4166/* The mask used to set the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value. */
4167#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET_MSK 0x00000010
4168/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value. */
4169#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_CLR_MSK 0xffffffef
4170/* The reset value of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
4171#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_RESET 0x1
4172/* Extracts the ALT_CLKMGR_PERPLL_EN_CAN0CLK field value from a register. */
4173#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_GET(value) (((value) & 0x00000010) >> 4)
4174/* Produces a ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value suitable for setting the register. */
4175#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET(value) (((value) << 4) & 0x00000010)
4176
4177/*
4178 * Field : can1_clk Enable - can1clk
4179 *
4180 * Enables clock can1_clk output
4181 *
4182 * Field Access Macros:
4183 *
4184 */
4185/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
4186#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_LSB 5
4187/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
4188#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_MSB 5
4189/* The width in bits of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
4190#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_WIDTH 1
4191/* The mask used to set the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value. */
4192#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET_MSK 0x00000020
4193/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value. */
4194#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_CLR_MSK 0xffffffdf
4195/* The reset value of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
4196#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_RESET 0x1
4197/* Extracts the ALT_CLKMGR_PERPLL_EN_CAN1CLK field value from a register. */
4198#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_GET(value) (((value) & 0x00000020) >> 5)
4199/* Produces a ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value suitable for setting the register. */
4200#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET(value) (((value) << 5) & 0x00000020)
4201
4202/*
4203 * Field : gpio_clk Enable - gpioclk
4204 *
4205 * Enables clock gpio_clk output
4206 *
4207 * Field Access Macros:
4208 *
4209 */
4210/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
4211#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_LSB 6
4212/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
4213#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_MSB 6
4214/* The width in bits of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
4215#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_WIDTH 1
4216/* The mask used to set the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value. */
4217#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET_MSK 0x00000040
4218/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value. */
4219#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_CLR_MSK 0xffffffbf
4220/* The reset value of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
4221#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_RESET 0x1
4222/* Extracts the ALT_CLKMGR_PERPLL_EN_GPIOCLK field value from a register. */
4223#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_GET(value) (((value) & 0x00000040) >> 6)
4224/* Produces a ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value suitable for setting the register. */
4225#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET(value) (((value) << 6) & 0x00000040)
4226
4227/*
4228 * Field : s2f_user1_clk Enable - s2fuser1clk
4229 *
4230 * Enables clock s2f_user1_clk output.
4231 *
4232 * Qsys and user documenation refer to s2f_user1_clk as h2f_user1_clk.
4233 *
4234 * Field Access Macros:
4235 *
4236 */
4237/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
4238#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_LSB 7
4239/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
4240#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_MSB 7
4241/* The width in bits of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
4242#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_WIDTH 1
4243/* The mask used to set the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value. */
4244#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET_MSK 0x00000080
4245/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value. */
4246#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_CLR_MSK 0xffffff7f
4247/* The reset value of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
4248#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_RESET 0x1
4249/* Extracts the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK field value from a register. */
4250#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_GET(value) (((value) & 0x00000080) >> 7)
4251/* Produces a ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value suitable for setting the register. */
4252#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET(value) (((value) << 7) & 0x00000080)
4253
4254/*
4255 * Field : sdmmc_clk Enable - sdmmcclk
4256 *
4257 * Enables clock sdmmc_clk output
4258 *
4259 * Field Access Macros:
4260 *
4261 */
4262/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
4263#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_LSB 8
4264/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
4265#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_MSB 8
4266/* The width in bits of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
4267#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_WIDTH 1
4268/* The mask used to set the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value. */
4269#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET_MSK 0x00000100
4270/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value. */
4271#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_CLR_MSK 0xfffffeff
4272/* The reset value of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
4273#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_RESET 0x1
4274/* Extracts the ALT_CLKMGR_PERPLL_EN_SDMMCCLK field value from a register. */
4275#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_GET(value) (((value) & 0x00000100) >> 8)
4276/* Produces a ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value suitable for setting the register. */
4277#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET(value) (((value) << 8) & 0x00000100)
4278
4279/*
4280 * Field : nand_x_clk Enable - nandxclk
4281 *
4282 * Enables clock nand_x_clk output
4283 *
4284 * nand_clk Enable should always be de-asserted before the nand_x_clk Enable, and
4285 * the nand_x_clk Enable should always be asserted before the nand_clk Enable is
4286 * asserted. A brief delay is also required between switching the enables (8 *
4287 * nand_clk period).
4288 *
4289 * Field Access Macros:
4290 *
4291 */
4292/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
4293#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_LSB 9
4294/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
4295#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_MSB 9
4296/* The width in bits of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
4297#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_WIDTH 1
4298/* The mask used to set the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value. */
4299#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET_MSK 0x00000200
4300/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value. */
4301#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_CLR_MSK 0xfffffdff
4302/* The reset value of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
4303#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_RESET 0x1
4304/* Extracts the ALT_CLKMGR_PERPLL_EN_NANDXCLK field value from a register. */
4305#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_GET(value) (((value) & 0x00000200) >> 9)
4306/* Produces a ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value suitable for setting the register. */
4307#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET(value) (((value) << 9) & 0x00000200)
4308
4309/*
4310 * Field : nand_clk Enable - nandclk
4311 *
4312 * Enables clock nand_clk output
4313 *
4314 * nand_clk Enable should always be de-asserted before the nand_x_clk Enable, and
4315 * the nand_x_clk Enable should always be asserted before the nand_clk Enable is
4316 * asserted. A brief delay is also required between switching the enables (8 *
4317 * nand_clk period).
4318 *
4319 * Field Access Macros:
4320 *
4321 */
4322/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
4323#define ALT_CLKMGR_PERPLL_EN_NANDCLK_LSB 10
4324/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
4325#define ALT_CLKMGR_PERPLL_EN_NANDCLK_MSB 10
4326/* The width in bits of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
4327#define ALT_CLKMGR_PERPLL_EN_NANDCLK_WIDTH 1
4328/* The mask used to set the ALT_CLKMGR_PERPLL_EN_NANDCLK register field value. */
4329#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET_MSK 0x00000400
4330/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_NANDCLK register field value. */
4331#define ALT_CLKMGR_PERPLL_EN_NANDCLK_CLR_MSK 0xfffffbff
4332/* The reset value of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
4333#define ALT_CLKMGR_PERPLL_EN_NANDCLK_RESET 0x1
4334/* Extracts the ALT_CLKMGR_PERPLL_EN_NANDCLK field value from a register. */
4335#define ALT_CLKMGR_PERPLL_EN_NANDCLK_GET(value) (((value) & 0x00000400) >> 10)
4336/* Produces a ALT_CLKMGR_PERPLL_EN_NANDCLK register field value suitable for setting the register. */
4337#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET(value) (((value) << 10) & 0x00000400)
4338
4339/*
4340 * Field : qspi_clk Enable - qspiclk
4341 *
4342 * Enables clock qspi_clk output
4343 *
4344 * Field Access Macros:
4345 *
4346 */
4347/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
4348#define ALT_CLKMGR_PERPLL_EN_QSPICLK_LSB 11
4349/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
4350#define ALT_CLKMGR_PERPLL_EN_QSPICLK_MSB 11
4351/* The width in bits of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
4352#define ALT_CLKMGR_PERPLL_EN_QSPICLK_WIDTH 1
4353/* The mask used to set the ALT_CLKMGR_PERPLL_EN_QSPICLK register field value. */
4354#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET_MSK 0x00000800
4355/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_QSPICLK register field value. */
4356#define ALT_CLKMGR_PERPLL_EN_QSPICLK_CLR_MSK 0xfffff7ff
4357/* The reset value of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
4358#define ALT_CLKMGR_PERPLL_EN_QSPICLK_RESET 0x1
4359/* Extracts the ALT_CLKMGR_PERPLL_EN_QSPICLK field value from a register. */
4360#define ALT_CLKMGR_PERPLL_EN_QSPICLK_GET(value) (((value) & 0x00000800) >> 11)
4361/* Produces a ALT_CLKMGR_PERPLL_EN_QSPICLK register field value suitable for setting the register. */
4362#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET(value) (((value) << 11) & 0x00000800)
4363
4364#ifndef __ASSEMBLY__
4365/*
4366 * WARNING: The C register and register group struct declarations are provided for
4367 * convenience and illustrative purposes. They should, however, be used with
4368 * caution as the C language standard provides no guarantees about the alignment or
4369 * atomicity of device memory accesses. The recommended practice for writing
4370 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4371 * alt_write_word() functions.
4372 *
4373 * The struct declaration for register ALT_CLKMGR_PERPLL_EN.
4374 */
4376{
4377 uint32_t emac0clk : 1; /* emac0_clk Enable */
4378 uint32_t emac1clk : 1; /* emac1_clk Enable */
4379 uint32_t usbclk : 1; /* usb_mp_clk Enable */
4380 uint32_t spimclk : 1; /* spi_m_clk Enable */
4381 uint32_t can0clk : 1; /* can0_clk Enable */
4382 uint32_t can1clk : 1; /* can1_clk Enable */
4383 uint32_t gpioclk : 1; /* gpio_clk Enable */
4384 uint32_t s2fuser1clk : 1; /* s2f_user1_clk Enable */
4385 uint32_t sdmmcclk : 1; /* sdmmc_clk Enable */
4386 uint32_t nandxclk : 1; /* nand_x_clk Enable */
4387 uint32_t nandclk : 1; /* nand_clk Enable */
4388 uint32_t qspiclk : 1; /* qspi_clk Enable */
4389 uint32_t : 20; /* *UNDEFINED* */
4390};
4391
4392/* The typedef declaration for register ALT_CLKMGR_PERPLL_EN. */
4393typedef volatile struct ALT_CLKMGR_PERPLL_EN_s ALT_CLKMGR_PERPLL_EN_t;
4394#endif /* __ASSEMBLY__ */
4395
4396/* The byte offset of the ALT_CLKMGR_PERPLL_EN register from the beginning of the component. */
4397#define ALT_CLKMGR_PERPLL_EN_OFST 0x20
4398
4399/*
4400 * Register : Divide Register - div
4401 *
4402 * Contains fields that control clock dividers for clocks derived from the
4403 * Peripheral PLL
4404 *
4405 * Fields are only reset by a cold reset.
4406 *
4407 * Register Layout
4408 *
4409 * Bits | Access | Reset | Description
4410 * :--------|:-------|:------|:-------------------------
4411 * [2:0] | RW | 0x0 | USB Clock Divider
4412 * [5:3] | RW | 0x0 | SPI Master Clock Divider
4413 * [8:6] | RW | 0x0 | CAN0 Clock Divider
4414 * [11:9] | RW | 0x0 | CAN1 Clock Divider
4415 * [31:12] | ??? | 0x0 | *UNDEFINED*
4416 *
4417 */
4418/*
4419 * Field : USB Clock Divider - usbclk
4420 *
4421 * The usb_mp_clk is divided down from the periph_base_clk by the value specified
4422 * in this field.
4423 *
4424 * Field Enumeration Values:
4425 *
4426 * Enum | Value | Description
4427 * :--------------------------------------|:------|:-------------
4428 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1 | 0x0 | Divide By 1
4429 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2 | 0x1 | Divide By 2
4430 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4 | 0x2 | Divide By 4
4431 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8 | 0x3 | Divide By 8
4432 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16 | 0x4 | Divide By 16
4433 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1 | 0x5 | Reserved
4434 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2 | 0x6 | Reserved
4435 * ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3 | 0x7 | Reserved
4436 *
4437 * Field Access Macros:
4438 *
4439 */
4440/*
4441 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4442 *
4443 * Divide By 1
4444 */
4445#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1 0x0
4446/*
4447 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4448 *
4449 * Divide By 2
4450 */
4451#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2 0x1
4452/*
4453 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4454 *
4455 * Divide By 4
4456 */
4457#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4 0x2
4458/*
4459 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4460 *
4461 * Divide By 8
4462 */
4463#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8 0x3
4464/*
4465 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4466 *
4467 * Divide By 16
4468 */
4469#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16 0x4
4470/*
4471 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4472 *
4473 * Reserved
4474 */
4475#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1 0x5
4476/*
4477 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4478 *
4479 * Reserved
4480 */
4481#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2 0x6
4482/*
4483 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
4484 *
4485 * Reserved
4486 */
4487#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3 0x7
4488
4489/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
4490#define ALT_CLKMGR_PERPLL_DIV_USBCLK_LSB 0
4491/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
4492#define ALT_CLKMGR_PERPLL_DIV_USBCLK_MSB 2
4493/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
4494#define ALT_CLKMGR_PERPLL_DIV_USBCLK_WIDTH 3
4495/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_USBCLK register field value. */
4496#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET_MSK 0x00000007
4497/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_USBCLK register field value. */
4498#define ALT_CLKMGR_PERPLL_DIV_USBCLK_CLR_MSK 0xfffffff8
4499/* The reset value of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
4500#define ALT_CLKMGR_PERPLL_DIV_USBCLK_RESET 0x0
4501/* Extracts the ALT_CLKMGR_PERPLL_DIV_USBCLK field value from a register. */
4502#define ALT_CLKMGR_PERPLL_DIV_USBCLK_GET(value) (((value) & 0x00000007) >> 0)
4503/* Produces a ALT_CLKMGR_PERPLL_DIV_USBCLK register field value suitable for setting the register. */
4504#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET(value) (((value) << 0) & 0x00000007)
4505
4506/*
4507 * Field : SPI Master Clock Divider - spimclk
4508 *
4509 * The spi_m_clk is divided down from the periph_base_clk by the value specified in
4510 * this field.
4511 *
4512 * Field Enumeration Values:
4513 *
4514 * Enum | Value | Description
4515 * :---------------------------------------|:------|:-------------
4516 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1 | 0x0 | Divide By 1
4517 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2 | 0x1 | Divide By 2
4518 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4 | 0x2 | Divide By 4
4519 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8 | 0x3 | Divide By 8
4520 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16 | 0x4 | Divide By 16
4521 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1 | 0x5 | Reserved
4522 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2 | 0x6 | Reserved
4523 * ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3 | 0x7 | Reserved
4524 *
4525 * Field Access Macros:
4526 *
4527 */
4528/*
4529 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4530 *
4531 * Divide By 1
4532 */
4533#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1 0x0
4534/*
4535 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4536 *
4537 * Divide By 2
4538 */
4539#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2 0x1
4540/*
4541 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4542 *
4543 * Divide By 4
4544 */
4545#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4 0x2
4546/*
4547 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4548 *
4549 * Divide By 8
4550 */
4551#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8 0x3
4552/*
4553 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4554 *
4555 * Divide By 16
4556 */
4557#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16 0x4
4558/*
4559 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4560 *
4561 * Reserved
4562 */
4563#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1 0x5
4564/*
4565 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4566 *
4567 * Reserved
4568 */
4569#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2 0x6
4570/*
4571 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
4572 *
4573 * Reserved
4574 */
4575#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3 0x7
4576
4577/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
4578#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_LSB 3
4579/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
4580#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_MSB 5
4581/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
4582#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_WIDTH 3
4583/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value. */
4584#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET_MSK 0x00000038
4585/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value. */
4586#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_CLR_MSK 0xffffffc7
4587/* The reset value of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
4588#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_RESET 0x0
4589/* Extracts the ALT_CLKMGR_PERPLL_DIV_SPIMCLK field value from a register. */
4590#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_GET(value) (((value) & 0x00000038) >> 3)
4591/* Produces a ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value suitable for setting the register. */
4592#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET(value) (((value) << 3) & 0x00000038)
4593
4594/*
4595 * Field : CAN0 Clock Divider - can0clk
4596 *
4597 * The can0_clk is divided down from the periph_base_clk by the value specified in
4598 * this field.
4599 *
4600 * Field Enumeration Values:
4601 *
4602 * Enum | Value | Description
4603 * :---------------------------------------|:------|:-------------
4604 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1 | 0x0 | Divide By 1
4605 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2 | 0x1 | Divide By 2
4606 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4 | 0x2 | Divide By 4
4607 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8 | 0x3 | Divide By 8
4608 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16 | 0x4 | Divide By 16
4609 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1 | 0x5 | Reserved
4610 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2 | 0x6 | Reserved
4611 * ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3 | 0x7 | Reserved
4612 *
4613 * Field Access Macros:
4614 *
4615 */
4616/*
4617 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4618 *
4619 * Divide By 1
4620 */
4621#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1 0x0
4622/*
4623 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4624 *
4625 * Divide By 2
4626 */
4627#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2 0x1
4628/*
4629 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4630 *
4631 * Divide By 4
4632 */
4633#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4 0x2
4634/*
4635 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4636 *
4637 * Divide By 8
4638 */
4639#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8 0x3
4640/*
4641 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4642 *
4643 * Divide By 16
4644 */
4645#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16 0x4
4646/*
4647 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4648 *
4649 * Reserved
4650 */
4651#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1 0x5
4652/*
4653 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4654 *
4655 * Reserved
4656 */
4657#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2 0x6
4658/*
4659 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
4660 *
4661 * Reserved
4662 */
4663#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3 0x7
4664
4665/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
4666#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_LSB 6
4667/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
4668#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_MSB 8
4669/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
4670#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_WIDTH 3
4671/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value. */
4672#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET_MSK 0x000001c0
4673/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value. */
4674#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_CLR_MSK 0xfffffe3f
4675/* The reset value of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
4676#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_RESET 0x0
4677/* Extracts the ALT_CLKMGR_PERPLL_DIV_CAN0CLK field value from a register. */
4678#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_GET(value) (((value) & 0x000001c0) >> 6)
4679/* Produces a ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value suitable for setting the register. */
4680#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET(value) (((value) << 6) & 0x000001c0)
4681
4682/*
4683 * Field : CAN1 Clock Divider - can1clk
4684 *
4685 * The can1_clk is divided down from the periph_base_clk by the value specified in
4686 * this field.
4687 *
4688 * Field Enumeration Values:
4689 *
4690 * Enum | Value | Description
4691 * :---------------------------------------|:------|:-------------
4692 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1 | 0x0 | Divide By 1
4693 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2 | 0x1 | Divide By 2
4694 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4 | 0x2 | Divide By 4
4695 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8 | 0x3 | Divide By 8
4696 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16 | 0x4 | Divide By 16
4697 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1 | 0x5 | Reserved
4698 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2 | 0x6 | Reserved
4699 * ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3 | 0x7 | Reserved
4700 *
4701 * Field Access Macros:
4702 *
4703 */
4704/*
4705 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4706 *
4707 * Divide By 1
4708 */
4709#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1 0x0
4710/*
4711 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4712 *
4713 * Divide By 2
4714 */
4715#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2 0x1
4716/*
4717 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4718 *
4719 * Divide By 4
4720 */
4721#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4 0x2
4722/*
4723 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4724 *
4725 * Divide By 8
4726 */
4727#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8 0x3
4728/*
4729 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4730 *
4731 * Divide By 16
4732 */
4733#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16 0x4
4734/*
4735 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4736 *
4737 * Reserved
4738 */
4739#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1 0x5
4740/*
4741 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4742 *
4743 * Reserved
4744 */
4745#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2 0x6
4746/*
4747 * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
4748 *
4749 * Reserved
4750 */
4751#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3 0x7
4752
4753/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
4754#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_LSB 9
4755/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
4756#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_MSB 11
4757/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
4758#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_WIDTH 3
4759/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value. */
4760#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET_MSK 0x00000e00
4761/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value. */
4762#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_CLR_MSK 0xfffff1ff
4763/* The reset value of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
4764#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_RESET 0x0
4765/* Extracts the ALT_CLKMGR_PERPLL_DIV_CAN1CLK field value from a register. */
4766#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_GET(value) (((value) & 0x00000e00) >> 9)
4767/* Produces a ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value suitable for setting the register. */
4768#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET(value) (((value) << 9) & 0x00000e00)
4769
4770#ifndef __ASSEMBLY__
4771/*
4772 * WARNING: The C register and register group struct declarations are provided for
4773 * convenience and illustrative purposes. They should, however, be used with
4774 * caution as the C language standard provides no guarantees about the alignment or
4775 * atomicity of device memory accesses. The recommended practice for writing
4776 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4777 * alt_write_word() functions.
4778 *
4779 * The struct declaration for register ALT_CLKMGR_PERPLL_DIV.
4780 */
4782{
4783 uint32_t usbclk : 3; /* USB Clock Divider */
4784 uint32_t spimclk : 3; /* SPI Master Clock Divider */
4785 uint32_t can0clk : 3; /* CAN0 Clock Divider */
4786 uint32_t can1clk : 3; /* CAN1 Clock Divider */
4787 uint32_t : 20; /* *UNDEFINED* */
4788};
4789
4790/* The typedef declaration for register ALT_CLKMGR_PERPLL_DIV. */
4791typedef volatile struct ALT_CLKMGR_PERPLL_DIV_s ALT_CLKMGR_PERPLL_DIV_t;
4792#endif /* __ASSEMBLY__ */
4793
4794/* The byte offset of the ALT_CLKMGR_PERPLL_DIV register from the beginning of the component. */
4795#define ALT_CLKMGR_PERPLL_DIV_OFST 0x24
4796
4797/*
4798 * Register : GPIO Divide Register - gpiodiv
4799 *
4800 * Contains a field that controls the clock divider for the GPIO De-bounce clock.
4801 *
4802 * Only reset by a cold reset.
4803 *
4804 * Register Layout
4805 *
4806 * Bits | Access | Reset | Description
4807 * :--------|:-------|:------|:-----------------------------
4808 * [23:0] | RW | 0x1 | GPIO De-bounce Clock Divider
4809 * [31:24] | ??? | 0x0 | *UNDEFINED*
4810 *
4811 */
4812/*
4813 * Field : GPIO De-bounce Clock Divider - gpiodbclk
4814 *
4815 * The gpio_db_clk is divided down from the periph_base_clk by the value plus one
4816 * specified in this field. The value 0 (divide by 1) is illegal. A value of 1
4817 * indicates divide by 2, 2 divide by 3, etc.
4818 *
4819 * Field Access Macros:
4820 *
4821 */
4822/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
4823#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_LSB 0
4824/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
4825#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_MSB 23
4826/* The width in bits of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
4827#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_WIDTH 24
4828/* The mask used to set the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value. */
4829#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET_MSK 0x00ffffff
4830/* The mask used to clear the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value. */
4831#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_CLR_MSK 0xff000000
4832/* The reset value of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
4833#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_RESET 0x1
4834/* Extracts the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK field value from a register. */
4835#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_GET(value) (((value) & 0x00ffffff) >> 0)
4836/* Produces a ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value suitable for setting the register. */
4837#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET(value) (((value) << 0) & 0x00ffffff)
4838
4839#ifndef __ASSEMBLY__
4840/*
4841 * WARNING: The C register and register group struct declarations are provided for
4842 * convenience and illustrative purposes. They should, however, be used with
4843 * caution as the C language standard provides no guarantees about the alignment or
4844 * atomicity of device memory accesses. The recommended practice for writing
4845 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4846 * alt_write_word() functions.
4847 *
4848 * The struct declaration for register ALT_CLKMGR_PERPLL_GPIODIV.
4849 */
4851{
4852 uint32_t gpiodbclk : 24; /* GPIO De-bounce Clock Divider */
4853 uint32_t : 8; /* *UNDEFINED* */
4854};
4855
4856/* The typedef declaration for register ALT_CLKMGR_PERPLL_GPIODIV. */
4858#endif /* __ASSEMBLY__ */
4859
4860/* The byte offset of the ALT_CLKMGR_PERPLL_GPIODIV register from the beginning of the component. */
4861#define ALT_CLKMGR_PERPLL_GPIODIV_OFST 0x28
4862
4863/*
4864 * Register : Flash Clock Source Register - src
4865 *
4866 * Contains fields that select the source clocks for the flash controllers.
4867 *
4868 * Fields are only reset by a cold reset.
4869 *
4870 * Register Layout
4871 *
4872 * Bits | Access | Reset | Description
4873 * :-------|:-------|:------|:-------------------
4874 * [1:0] | RW | 0x1 | SDMMC Clock Source
4875 * [3:2] | RW | 0x1 | NAND Clock Source
4876 * [5:4] | RW | 0x1 | QSPI Clock Source
4877 * [31:6] | ??? | 0x0 | *UNDEFINED*
4878 *
4879 */
4880/*
4881 * Field : SDMMC Clock Source - sdmmc
4882 *
4883 * Selects the source clock for the SDMMC.
4884 *
4885 * Qsys and user documenation refer to f2s_periph_ref_clk as f2h_periph_ref_clk.
4886 *
4887 * Field Enumeration Values:
4888 *
4889 * Enum | Value | Description
4890 * :-------------------------------------------------|:------|:----------------------
4891 * ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK | 0x0 | f2s_periph_ref_clk
4892 * ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK | 0x1 | main_nand_sdmmc_clk
4893 * ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK | 0x2 | periph_nand_sdmmc_clk
4894 *
4895 * Field Access Macros:
4896 *
4897 */
4898/*
4899 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_SDMMC
4900 *
4901 * f2s_periph_ref_clk
4902 */
4903#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK 0x0
4904/*
4905 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_SDMMC
4906 *
4907 * main_nand_sdmmc_clk
4908 */
4909#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK 0x1
4910/*
4911 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_SDMMC
4912 *
4913 * periph_nand_sdmmc_clk
4914 */
4915#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK 0x2
4916
4917/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
4918#define ALT_CLKMGR_PERPLL_SRC_SDMMC_LSB 0
4919/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
4920#define ALT_CLKMGR_PERPLL_SRC_SDMMC_MSB 1
4921/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
4922#define ALT_CLKMGR_PERPLL_SRC_SDMMC_WIDTH 2
4923/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_SDMMC register field value. */
4924#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET_MSK 0x00000003
4925/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_SDMMC register field value. */
4926#define ALT_CLKMGR_PERPLL_SRC_SDMMC_CLR_MSK 0xfffffffc
4927/* The reset value of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
4928#define ALT_CLKMGR_PERPLL_SRC_SDMMC_RESET 0x1
4929/* Extracts the ALT_CLKMGR_PERPLL_SRC_SDMMC field value from a register. */
4930#define ALT_CLKMGR_PERPLL_SRC_SDMMC_GET(value) (((value) & 0x00000003) >> 0)
4931/* Produces a ALT_CLKMGR_PERPLL_SRC_SDMMC register field value suitable for setting the register. */
4932#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET(value) (((value) << 0) & 0x00000003)
4933
4934/*
4935 * Field : NAND Clock Source - nand
4936 *
4937 * Selects the source clock for the NAND.
4938 *
4939 * Qsys and user documenation refer to f2s_periph_ref_clk as f2h_periph_ref_clk.
4940 *
4941 * Field Enumeration Values:
4942 *
4943 * Enum | Value | Description
4944 * :------------------------------------------------|:------|:----------------------
4945 * ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK | 0x0 | f2s_periph_ref_clk
4946 * ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK | 0x1 | main_nand_sdmmc_clk
4947 * ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK | 0x2 | periph_nand_sdmmc_clk
4948 *
4949 * Field Access Macros:
4950 *
4951 */
4952/*
4953 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_NAND
4954 *
4955 * f2s_periph_ref_clk
4956 */
4957#define ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK 0x0
4958/*
4959 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_NAND
4960 *
4961 * main_nand_sdmmc_clk
4962 */
4963#define ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK 0x1
4964/*
4965 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_NAND
4966 *
4967 * periph_nand_sdmmc_clk
4968 */
4969#define ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK 0x2
4970
4971/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
4972#define ALT_CLKMGR_PERPLL_SRC_NAND_LSB 2
4973/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
4974#define ALT_CLKMGR_PERPLL_SRC_NAND_MSB 3
4975/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
4976#define ALT_CLKMGR_PERPLL_SRC_NAND_WIDTH 2
4977/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_NAND register field value. */
4978#define ALT_CLKMGR_PERPLL_SRC_NAND_SET_MSK 0x0000000c
4979/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_NAND register field value. */
4980#define ALT_CLKMGR_PERPLL_SRC_NAND_CLR_MSK 0xfffffff3
4981/* The reset value of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
4982#define ALT_CLKMGR_PERPLL_SRC_NAND_RESET 0x1
4983/* Extracts the ALT_CLKMGR_PERPLL_SRC_NAND field value from a register. */
4984#define ALT_CLKMGR_PERPLL_SRC_NAND_GET(value) (((value) & 0x0000000c) >> 2)
4985/* Produces a ALT_CLKMGR_PERPLL_SRC_NAND register field value suitable for setting the register. */
4986#define ALT_CLKMGR_PERPLL_SRC_NAND_SET(value) (((value) << 2) & 0x0000000c)
4987
4988/*
4989 * Field : QSPI Clock Source - qspi
4990 *
4991 * Selects the source clock for the QSPI.
4992 *
4993 * Qsys and user documenation refer to f2s_periph_ref_clk as f2h_periph_ref_clk.
4994 *
4995 * Field Enumeration Values:
4996 *
4997 * Enum | Value | Description
4998 * :------------------------------------------------|:------|:-------------------
4999 * ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK | 0x0 | f2s_periph_ref_clk
5000 * ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK | 0x1 | main_qspi_clk
5001 * ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK | 0x2 | periph_qspi_clk
5002 *
5003 * Field Access Macros:
5004 *
5005 */
5006/*
5007 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_QSPI
5008 *
5009 * f2s_periph_ref_clk
5010 */
5011#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK 0x0
5012/*
5013 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_QSPI
5014 *
5015 * main_qspi_clk
5016 */
5017#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK 0x1
5018/*
5019 * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_QSPI
5020 *
5021 * periph_qspi_clk
5022 */
5023#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK 0x2
5024
5025/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
5026#define ALT_CLKMGR_PERPLL_SRC_QSPI_LSB 4
5027/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
5028#define ALT_CLKMGR_PERPLL_SRC_QSPI_MSB 5
5029/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
5030#define ALT_CLKMGR_PERPLL_SRC_QSPI_WIDTH 2
5031/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_QSPI register field value. */
5032#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET_MSK 0x00000030
5033/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_QSPI register field value. */
5034#define ALT_CLKMGR_PERPLL_SRC_QSPI_CLR_MSK 0xffffffcf
5035/* The reset value of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
5036#define ALT_CLKMGR_PERPLL_SRC_QSPI_RESET 0x1
5037/* Extracts the ALT_CLKMGR_PERPLL_SRC_QSPI field value from a register. */
5038#define ALT_CLKMGR_PERPLL_SRC_QSPI_GET(value) (((value) & 0x00000030) >> 4)
5039/* Produces a ALT_CLKMGR_PERPLL_SRC_QSPI register field value suitable for setting the register. */
5040#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET(value) (((value) << 4) & 0x00000030)
5041
5042#ifndef __ASSEMBLY__
5043/*
5044 * WARNING: The C register and register group struct declarations are provided for
5045 * convenience and illustrative purposes. They should, however, be used with
5046 * caution as the C language standard provides no guarantees about the alignment or
5047 * atomicity of device memory accesses. The recommended practice for writing
5048 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5049 * alt_write_word() functions.
5050 *
5051 * The struct declaration for register ALT_CLKMGR_PERPLL_SRC.
5052 */
5054{
5055 uint32_t sdmmc : 2; /* SDMMC Clock Source */
5056 uint32_t nand : 2; /* NAND Clock Source */
5057 uint32_t qspi : 2; /* QSPI Clock Source */
5058 uint32_t : 26; /* *UNDEFINED* */
5059};
5060
5061/* The typedef declaration for register ALT_CLKMGR_PERPLL_SRC. */
5062typedef volatile struct ALT_CLKMGR_PERPLL_SRC_s ALT_CLKMGR_PERPLL_SRC_t;
5063#endif /* __ASSEMBLY__ */
5064
5065/* The byte offset of the ALT_CLKMGR_PERPLL_SRC register from the beginning of the component. */
5066#define ALT_CLKMGR_PERPLL_SRC_OFST 0x2c
5067
5068/*
5069 * Register : Peripheral PLL Output Counter Reset Ack Status Register - stat
5070 *
5071 * Contains Output Clock Counter Reset acknowledge status.
5072 *
5073 * Register Layout
5074 *
5075 * Bits | Access | Reset | Description
5076 * :-------|:-------|:------|:---------------------------------
5077 * [5:0] | R | 0x0 | Output Counter Reset Acknowledge
5078 * [31:6] | ??? | 0x0 | *UNDEFINED*
5079 *
5080 */
5081/*
5082 * Field : Output Counter Reset Acknowledge - outresetack
5083 *
5084 * These read only bits per PLL output indicate that the PLL has received the
5085 * Output Reset Counter request and has gracefully stopped the respective PLL
5086 * output clock.
5087 *
5088 * For software to change the PLL output counter without producing glitches on the
5089 * respective clock, SW must set the VCO register respective Output Counter Reset
5090 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
5091 * the Output Counter Reset Ack Status Register. Software then writes the
5092 * appropriate counter register, and then clears the respective VCO register Output
5093 * Counter Reset bit.
5094 *
5095 * The reset value of this bit is applied on a cold reset; warm reset has no affect
5096 * on this bit.
5097 *
5098 * Field Enumeration Values:
5099 *
5100 * Enum | Value | Description
5101 * :-------------------------------------------|:------|:-------------------------------------
5102 * ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE | 0x0 | Idle
5103 * ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1 | Output Counter Acknowledge received.
5104 *
5105 * Field Access Macros:
5106 *
5107 */
5108/*
5109 * Enumerated value for register field ALT_CLKMGR_PERPLL_STAT_OUTRSTACK
5110 *
5111 * Idle
5112 */
5113#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE 0x0
5114/*
5115 * Enumerated value for register field ALT_CLKMGR_PERPLL_STAT_OUTRSTACK
5116 *
5117 * Output Counter Acknowledge received.
5118 */
5119#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
5120
5121/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
5122#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_LSB 0
5123/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
5124#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_MSB 5
5125/* The width in bits of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
5126#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_WIDTH 6
5127/* The mask used to set the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value. */
5128#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
5129/* The mask used to clear the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value. */
5130#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
5131/* The reset value of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
5132#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_RESET 0x0
5133/* Extracts the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK field value from a register. */
5134#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
5135/* Produces a ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
5136#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
5137
5138#ifndef __ASSEMBLY__
5139/*
5140 * WARNING: The C register and register group struct declarations are provided for
5141 * convenience and illustrative purposes. They should, however, be used with
5142 * caution as the C language standard provides no guarantees about the alignment or
5143 * atomicity of device memory accesses. The recommended practice for writing
5144 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5145 * alt_write_word() functions.
5146 *
5147 * The struct declaration for register ALT_CLKMGR_PERPLL_STAT.
5148 */
5150{
5151 const uint32_t outresetack : 6; /* Output Counter Reset Acknowledge */
5152 uint32_t : 26; /* *UNDEFINED* */
5153};
5154
5155/* The typedef declaration for register ALT_CLKMGR_PERPLL_STAT. */
5157#endif /* __ASSEMBLY__ */
5158
5159/* The byte offset of the ALT_CLKMGR_PERPLL_STAT register from the beginning of the component. */
5160#define ALT_CLKMGR_PERPLL_STAT_OFST 0x30
5161
5162#ifndef __ASSEMBLY__
5163/*
5164 * WARNING: The C register and register group struct declarations are provided for
5165 * convenience and illustrative purposes. They should, however, be used with
5166 * caution as the C language standard provides no guarantees about the alignment or
5167 * atomicity of device memory accesses. The recommended practice for writing
5168 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5169 * alt_write_word() functions.
5170 *
5171 * The struct declaration for register group ALT_CLKMGR_PERPLL.
5172 */
5174{
5175 volatile ALT_CLKMGR_PERPLL_VCO_t vco; /* ALT_CLKMGR_PERPLL_VCO */
5176 volatile ALT_CLKMGR_PERPLL_MISC_t misc; /* ALT_CLKMGR_PERPLL_MISC */
5177 volatile ALT_CLKMGR_PERPLL_EMAC0CLK_t emac0clk; /* ALT_CLKMGR_PERPLL_EMAC0CLK */
5178 volatile ALT_CLKMGR_PERPLL_EMAC1CLK_t emac1clk; /* ALT_CLKMGR_PERPLL_EMAC1CLK */
5179 volatile ALT_CLKMGR_PERPLL_PERQSPICLK_t perqspiclk; /* ALT_CLKMGR_PERPLL_PERQSPICLK */
5180 volatile ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_t pernandsdmmcclk; /* ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK */
5181 volatile ALT_CLKMGR_PERPLL_PERBASECLK_t perbaseclk; /* ALT_CLKMGR_PERPLL_PERBASECLK */
5182 volatile ALT_CLKMGR_PERPLL_S2FUSER1CLK_t s2fuser1clk; /* ALT_CLKMGR_PERPLL_S2FUSER1CLK */
5183 volatile ALT_CLKMGR_PERPLL_EN_t en; /* ALT_CLKMGR_PERPLL_EN */
5184 volatile ALT_CLKMGR_PERPLL_DIV_t div; /* ALT_CLKMGR_PERPLL_DIV */
5185 volatile ALT_CLKMGR_PERPLL_GPIODIV_t gpiodiv; /* ALT_CLKMGR_PERPLL_GPIODIV */
5186 volatile ALT_CLKMGR_PERPLL_SRC_t src; /* ALT_CLKMGR_PERPLL_SRC */
5187 volatile ALT_CLKMGR_PERPLL_STAT_t stat; /* ALT_CLKMGR_PERPLL_STAT */
5188 volatile uint32_t _pad_0x34_0x40[3]; /* *UNDEFINED* */
5189};
5190
5191/* The typedef declaration for register group ALT_CLKMGR_PERPLL. */
5192typedef volatile struct ALT_CLKMGR_PERPLL_s ALT_CLKMGR_PERPLL_t;
5193/* The struct declaration for the raw register contents of register group ALT_CLKMGR_PERPLL. */
5195{
5196 volatile uint32_t vco; /* ALT_CLKMGR_PERPLL_VCO */
5197 volatile uint32_t misc; /* ALT_CLKMGR_PERPLL_MISC */
5198 volatile uint32_t emac0clk; /* ALT_CLKMGR_PERPLL_EMAC0CLK */
5199 volatile uint32_t emac1clk; /* ALT_CLKMGR_PERPLL_EMAC1CLK */
5200 volatile uint32_t perqspiclk; /* ALT_CLKMGR_PERPLL_PERQSPICLK */
5201 volatile uint32_t pernandsdmmcclk; /* ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK */
5202 volatile uint32_t perbaseclk; /* ALT_CLKMGR_PERPLL_PERBASECLK */
5203 volatile uint32_t s2fuser1clk; /* ALT_CLKMGR_PERPLL_S2FUSER1CLK */
5204 volatile uint32_t en; /* ALT_CLKMGR_PERPLL_EN */
5205 volatile uint32_t div; /* ALT_CLKMGR_PERPLL_DIV */
5206 volatile uint32_t gpiodiv; /* ALT_CLKMGR_PERPLL_GPIODIV */
5207 volatile uint32_t src; /* ALT_CLKMGR_PERPLL_SRC */
5208 volatile uint32_t stat; /* ALT_CLKMGR_PERPLL_STAT */
5209 volatile uint32_t _pad_0x34_0x40[3]; /* *UNDEFINED* */
5210};
5211
5212/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_PERPLL. */
5213typedef volatile struct ALT_CLKMGR_PERPLL_raw_s ALT_CLKMGR_PERPLL_raw_t;
5214#endif /* __ASSEMBLY__ */
5215
5216
5217/*
5218 * Register Group : SDRAM PLL Group - ALT_CLKMGR_SDRPLL
5219 * SDRAM PLL Group
5220 *
5221 * Contains registers with settings for the SDRAM PLL.
5222 *
5223 */
5224/*
5225 * Register : SDRAM PLL VCO Control Register - vco
5226 *
5227 * Contains settings that control the SDRAM PLL VCO. The VCO output frequency is
5228 * the input frequency multiplied by the numerator (M+1) and divided by the
5229 * denominator (N+1).
5230 *
5231 * Fields are only reset by a cold reset.
5232 *
5233 * Register Layout
5234 *
5235 * Bits | Access | Reset | Description
5236 * :--------|:-------|:------|:--------------------------------
5237 * [0] | RW | 0x1 | BG PWRDN
5238 * [1] | RW | 0x0 | Enable
5239 * [2] | RW | 0x1 | Power down
5240 * [15:3] | RW | 0x1 | Numerator (M)
5241 * [21:16] | RW | 0x1 | Denominator (N)
5242 * [23:22] | RW | 0x0 | Clock Source
5243 * [24] | RW | 0x0 | SDRAM All Output Counter Reset
5244 * [30:25] | RW | 0x0 | Output Counter Reset
5245 * [31] | RW | 0x1 | External Regulator Input Select
5246 *
5247 */
5248/*
5249 * Field : BG PWRDN - bgpwrdn
5250 *
5251 * If '1', powers down bandgap. If '0', bandgap is not power down.
5252 *
5253 * Field Access Macros:
5254 *
5255 */
5256/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
5257#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_LSB 0
5258/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
5259#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_MSB 0
5260/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
5261#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_WIDTH 1
5262/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value. */
5263#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET_MSK 0x00000001
5264/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value. */
5265#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
5266/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
5267#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_RESET 0x1
5268/* Extracts the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN field value from a register. */
5269#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
5270/* Produces a ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value suitable for setting the register. */
5271#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
5272
5273/*
5274 * Field : Enable - en
5275 *
5276 * If '1', VCO is enabled. If '0', VCO is in reset.
5277 *
5278 * Field Access Macros:
5279 *
5280 */
5281/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
5282#define ALT_CLKMGR_SDRPLL_VCO_EN_LSB 1
5283/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
5284#define ALT_CLKMGR_SDRPLL_VCO_EN_MSB 1
5285/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
5286#define ALT_CLKMGR_SDRPLL_VCO_EN_WIDTH 1
5287/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_EN register field value. */
5288#define ALT_CLKMGR_SDRPLL_VCO_EN_SET_MSK 0x00000002
5289/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_EN register field value. */
5290#define ALT_CLKMGR_SDRPLL_VCO_EN_CLR_MSK 0xfffffffd
5291/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
5292#define ALT_CLKMGR_SDRPLL_VCO_EN_RESET 0x0
5293/* Extracts the ALT_CLKMGR_SDRPLL_VCO_EN field value from a register. */
5294#define ALT_CLKMGR_SDRPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
5295/* Produces a ALT_CLKMGR_SDRPLL_VCO_EN register field value suitable for setting the register. */
5296#define ALT_CLKMGR_SDRPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
5297
5298/*
5299 * Field : Power down - pwrdn
5300 *
5301 * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
5302 *
5303 * Field Access Macros:
5304 *
5305 */
5306/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
5307#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_LSB 2
5308/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
5309#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_MSB 2
5310/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
5311#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_WIDTH 1
5312/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value. */
5313#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET_MSK 0x00000004
5314/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value. */
5315#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
5316/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
5317#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_RESET 0x1
5318/* Extracts the ALT_CLKMGR_SDRPLL_VCO_PWRDN field value from a register. */
5319#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
5320/* Produces a ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value suitable for setting the register. */
5321#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
5322
5323/*
5324 * Field : Numerator (M) - numer
5325 *
5326 * Numerator in VCO output frequency equation. For incremental frequency change, if
5327 * the new value lead to less than 20% of the frequency change, this value can be
5328 * changed without resetting the PLL. The Numerator and Denominator can not be
5329 * changed at the same time for incremental frequency changed.
5330 *
5331 * Field Access Macros:
5332 *
5333 */
5334/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
5335#define ALT_CLKMGR_SDRPLL_VCO_NUMER_LSB 3
5336/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
5337#define ALT_CLKMGR_SDRPLL_VCO_NUMER_MSB 15
5338/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
5339#define ALT_CLKMGR_SDRPLL_VCO_NUMER_WIDTH 13
5340/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_NUMER register field value. */
5341#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET_MSK 0x0000fff8
5342/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_NUMER register field value. */
5343#define ALT_CLKMGR_SDRPLL_VCO_NUMER_CLR_MSK 0xffff0007
5344/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
5345#define ALT_CLKMGR_SDRPLL_VCO_NUMER_RESET 0x1
5346/* Extracts the ALT_CLKMGR_SDRPLL_VCO_NUMER field value from a register. */
5347#define ALT_CLKMGR_SDRPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
5348/* Produces a ALT_CLKMGR_SDRPLL_VCO_NUMER register field value suitable for setting the register. */
5349#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
5350
5351/*
5352 * Field : Denominator (N) - denom
5353 *
5354 * Denominator in VCO output frequency equation. For incremental frequency change,
5355 * if the new value lead to less than 20% of the frequency change, this value can
5356 * be changed without resetting the PLL. The Numerator and Denominator can not be
5357 * changed at the same time for incremental frequency changed.
5358 *
5359 * Field Access Macros:
5360 *
5361 */
5362/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
5363#define ALT_CLKMGR_SDRPLL_VCO_DENOM_LSB 16
5364/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
5365#define ALT_CLKMGR_SDRPLL_VCO_DENOM_MSB 21
5366/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
5367#define ALT_CLKMGR_SDRPLL_VCO_DENOM_WIDTH 6
5368/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_DENOM register field value. */
5369#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET_MSK 0x003f0000
5370/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_DENOM register field value. */
5371#define ALT_CLKMGR_SDRPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
5372/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
5373#define ALT_CLKMGR_SDRPLL_VCO_DENOM_RESET 0x1
5374/* Extracts the ALT_CLKMGR_SDRPLL_VCO_DENOM field value from a register. */
5375#define ALT_CLKMGR_SDRPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
5376/* Produces a ALT_CLKMGR_SDRPLL_VCO_DENOM register field value suitable for setting the register. */
5377#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
5378
5379/*
5380 * Field : Clock Source - ssrc
5381 *
5382 * Controls the VCO input clock source. The PLL must by bypassed to eosc1_clk
5383 * before changing this field.
5384 *
5385 * Qsys and user documenation refer to f2s_sdram_ref_clk as f2h_sdram_ref_clk.
5386 *
5387 * Field Enumeration Values:
5388 *
5389 * Enum | Value | Description
5390 * :-------------------------------------------|:------|:------------------
5391 * ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1 | 0x0 | eosc1_clk
5392 * ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2 | 0x1 | eosc2_clk
5393 * ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF | 0x2 | f2s_sdram_ref_clk
5394 *
5395 * Field Access Macros:
5396 *
5397 */
5398/*
5399 * Enumerated value for register field ALT_CLKMGR_SDRPLL_VCO_SSRC
5400 *
5401 * eosc1_clk
5402 */
5403#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1 0x0
5404/*
5405 * Enumerated value for register field ALT_CLKMGR_SDRPLL_VCO_SSRC
5406 *
5407 * eosc2_clk
5408 */
5409#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2 0x1
5410/*
5411 * Enumerated value for register field ALT_CLKMGR_SDRPLL_VCO_SSRC
5412 *
5413 * f2s_sdram_ref_clk
5414 */
5415#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF 0x2
5416
5417/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
5418#define ALT_CLKMGR_SDRPLL_VCO_SSRC_LSB 22
5419/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
5420#define ALT_CLKMGR_SDRPLL_VCO_SSRC_MSB 23
5421/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
5422#define ALT_CLKMGR_SDRPLL_VCO_SSRC_WIDTH 2
5423/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_SSRC register field value. */
5424#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET_MSK 0x00c00000
5425/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_SSRC register field value. */
5426#define ALT_CLKMGR_SDRPLL_VCO_SSRC_CLR_MSK 0xff3fffff
5427/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
5428#define ALT_CLKMGR_SDRPLL_VCO_SSRC_RESET 0x0
5429/* Extracts the ALT_CLKMGR_SDRPLL_VCO_SSRC field value from a register. */
5430#define ALT_CLKMGR_SDRPLL_VCO_SSRC_GET(value) (((value) & 0x00c00000) >> 22)
5431/* Produces a ALT_CLKMGR_SDRPLL_VCO_SSRC register field value suitable for setting the register. */
5432#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET(value) (((value) << 22) & 0x00c00000)
5433
5434/*
5435 * Field : SDRAM All Output Counter Reset - outresetall
5436 *
5437 * Before releasing Bypass, All Output Counter Reset must be set and cleared by
5438 * software for correct clock operation.
5439 *
5440 * If '1', Reset phase multiplexer and output counter state. So that after the
5441 * assertion all the clocks output are start from rising edge align.
5442 *
5443 * If '0', phase multiplexer and output counter state not reset and no change to
5444 * the phase of the clock outputs.
5445 *
5446 * Field Access Macros:
5447 *
5448 */
5449/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
5450#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_LSB 24
5451/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
5452#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_MSB 24
5453/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
5454#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_WIDTH 1
5455/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value. */
5456#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
5457/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value. */
5458#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
5459/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
5460#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_RESET 0x0
5461/* Extracts the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL field value from a register. */
5462#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
5463/* Produces a ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
5464#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
5465
5466/*
5467 * Field : Output Counter Reset - outreset
5468 *
5469 * Resets the individual PLL output counter.
5470 *
5471 * For software to change the PLL output counter without producing glitches on the
5472 * respective clock, SW must set the VCO register respective Output Counter Reset
5473 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
5474 * the Output Counter Reset Ack Status Register. Software then writes the
5475 * appropriate counter register, and then clears the respective VCO register Output
5476 * Counter Reset bit.
5477 *
5478 * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
5479 *
5480 * If set to '1', reset output divider, no clock output from counter.
5481 *
5482 * If set to '0', counter is not reset.
5483 *
5484 * The reset value of this bit is applied on a cold reset; warm reset has no affect
5485 * on this bit.
5486 *
5487 * Field Access Macros:
5488 *
5489 */
5490/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
5491#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_LSB 25
5492/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
5493#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_MSB 30
5494/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
5495#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_WIDTH 6
5496/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value. */
5497#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET_MSK 0x7e000000
5498/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value. */
5499#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
5500/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
5501#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_RESET 0x0
5502/* Extracts the ALT_CLKMGR_SDRPLL_VCO_OUTRST field value from a register. */
5503#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
5504/* Produces a ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value suitable for setting the register. */
5505#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
5506
5507/*
5508 * Field : External Regulator Input Select - regextsel
5509 *
5510 * If set to '1', the external regulator is selected for the PLL.
5511 *
5512 * If set to '0', the internal regulator is slected.
5513 *
5514 * It is strongly recommended to select the external regulator while the PLL is not
5515 * enabled (in reset), and then disable the external regulater once the PLL
5516 * becomes enabled. Software should simulateously update the 'Enable' bit and the
5517 * 'External Regulator Input Select' in the same write access to the VCO register.
5518 * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
5519 * set, and vice versa.
5520 *
5521 * The reset value of this bit is applied on a cold reset; warm reset has no affect
5522 * on this bit.
5523 *
5524 * Field Access Macros:
5525 *
5526 */
5527/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
5528#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_LSB 31
5529/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
5530#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_MSB 31
5531/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
5532#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_WIDTH 1
5533/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value. */
5534#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
5535/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value. */
5536#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
5537/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
5538#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_RESET 0x1
5539/* Extracts the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL field value from a register. */
5540#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
5541/* Produces a ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
5542#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
5543
5544#ifndef __ASSEMBLY__
5545/*
5546 * WARNING: The C register and register group struct declarations are provided for
5547 * convenience and illustrative purposes. They should, however, be used with
5548 * caution as the C language standard provides no guarantees about the alignment or
5549 * atomicity of device memory accesses. The recommended practice for writing
5550 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5551 * alt_write_word() functions.
5552 *
5553 * The struct declaration for register ALT_CLKMGR_SDRPLL_VCO.
5554 */
5556{
5557 uint32_t bgpwrdn : 1; /* BG PWRDN */
5558 uint32_t en : 1; /* Enable */
5559 uint32_t pwrdn : 1; /* Power down */
5560 uint32_t numer : 13; /* Numerator (M) */
5561 uint32_t denom : 6; /* Denominator (N) */
5562 uint32_t ssrc : 2; /* Clock Source */
5563 uint32_t outresetall : 1; /* SDRAM All Output Counter Reset */
5564 uint32_t outreset : 6; /* Output Counter Reset */
5565 uint32_t regextsel : 1; /* External Regulator Input Select */
5566};
5567
5568/* The typedef declaration for register ALT_CLKMGR_SDRPLL_VCO. */
5569typedef volatile struct ALT_CLKMGR_SDRPLL_VCO_s ALT_CLKMGR_SDRPLL_VCO_t;
5570#endif /* __ASSEMBLY__ */
5571
5572/* The byte offset of the ALT_CLKMGR_SDRPLL_VCO register from the beginning of the component. */
5573#define ALT_CLKMGR_SDRPLL_VCO_OFST 0x0
5574
5575/*
5576 * Register : SDRAM PLL VCO Advanced Control Register - ctrl
5577 *
5578 * Contains VCO control signals and other PLL control signals need to be
5579 * controllable through register.
5580 *
5581 * Fields are only reset by a cold reset.
5582 *
5583 * Register Layout
5584 *
5585 * Bits | Access | Reset | Description
5586 * :--------|:-------|:------|:------------------------------
5587 * [0] | RW | 0x0 | Loop Bandwidth Adjust Enabled
5588 * [12:1] | RW | 0x1 | Loop Bandwidth Adjust
5589 * [13] | RW | 0x0 | Fast Locking Enable
5590 * [14] | RW | 0x1 | Saturation Enable
5591 * [31:15] | ??? | 0x0 | *UNDEFINED*
5592 *
5593 */
5594/*
5595 * Field : Loop Bandwidth Adjust Enabled - bwadjen
5596 *
5597 * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
5598 * Adjust field.
5599 *
5600 * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
5601 * value of the VCO Control Register. The M divided by 2 is the upper 12 bits
5602 * (12:1) of the M field in the VCO register.
5603 *
5604 * Field Access Macros:
5605 *
5606 */
5607/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
5608#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_LSB 0
5609/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
5610#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_MSB 0
5611/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
5612#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_WIDTH 1
5613/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value. */
5614#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET_MSK 0x00000001
5615/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value. */
5616#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_CLR_MSK 0xfffffffe
5617/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
5618#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_RESET 0x0
5619/* Extracts the ALT_CLKMGR_SDRPLL_CTL_BWADJEN field value from a register. */
5620#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
5621/* Produces a ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value suitable for setting the register. */
5622#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
5623
5624/*
5625 * Field : Loop Bandwidth Adjust - bwadj
5626 *
5627 * Provides Loop Bandwidth Adjust value.
5628 *
5629 * Field Access Macros:
5630 *
5631 */
5632/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
5633#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_LSB 1
5634/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
5635#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_MSB 12
5636/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
5637#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_WIDTH 12
5638/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value. */
5639#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET_MSK 0x00001ffe
5640/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value. */
5641#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_CLR_MSK 0xffffe001
5642/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
5643#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_RESET 0x1
5644/* Extracts the ALT_CLKMGR_SDRPLL_CTL_BWADJ field value from a register. */
5645#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
5646/* Produces a ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value suitable for setting the register. */
5647#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
5648
5649/*
5650 * Field : Fast Locking Enable - fasten
5651 *
5652 * Enables fast locking circuit.
5653 *
5654 * Field Access Macros:
5655 *
5656 */
5657/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
5658#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_LSB 13
5659/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
5660#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_MSB 13
5661/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
5662#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_WIDTH 1
5663/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value. */
5664#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET_MSK 0x00002000
5665/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value. */
5666#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_CLR_MSK 0xffffdfff
5667/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
5668#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_RESET 0x0
5669/* Extracts the ALT_CLKMGR_SDRPLL_CTL_FASTEN field value from a register. */
5670#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
5671/* Produces a ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value suitable for setting the register. */
5672#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET(value) (((value) << 13) & 0x00002000)
5673
5674/*
5675 * Field : Saturation Enable - saten
5676 *
5677 * Enables saturation behavior.
5678 *
5679 * Field Access Macros:
5680 *
5681 */
5682/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
5683#define ALT_CLKMGR_SDRPLL_CTL_SATEN_LSB 14
5684/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
5685#define ALT_CLKMGR_SDRPLL_CTL_SATEN_MSB 14
5686/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
5687#define ALT_CLKMGR_SDRPLL_CTL_SATEN_WIDTH 1
5688/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_SATEN register field value. */
5689#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET_MSK 0x00004000
5690/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_SATEN register field value. */
5691#define ALT_CLKMGR_SDRPLL_CTL_SATEN_CLR_MSK 0xffffbfff
5692/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
5693#define ALT_CLKMGR_SDRPLL_CTL_SATEN_RESET 0x1
5694/* Extracts the ALT_CLKMGR_SDRPLL_CTL_SATEN field value from a register. */
5695#define ALT_CLKMGR_SDRPLL_CTL_SATEN_GET(value) (((value) & 0x00004000) >> 14)
5696/* Produces a ALT_CLKMGR_SDRPLL_CTL_SATEN register field value suitable for setting the register. */
5697#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET(value) (((value) << 14) & 0x00004000)
5698
5699#ifndef __ASSEMBLY__
5700/*
5701 * WARNING: The C register and register group struct declarations are provided for
5702 * convenience and illustrative purposes. They should, however, be used with
5703 * caution as the C language standard provides no guarantees about the alignment or
5704 * atomicity of device memory accesses. The recommended practice for writing
5705 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5706 * alt_write_word() functions.
5707 *
5708 * The struct declaration for register ALT_CLKMGR_SDRPLL_CTL.
5709 */
5711{
5712 uint32_t bwadjen : 1; /* Loop Bandwidth Adjust Enabled */
5713 uint32_t bwadj : 12; /* Loop Bandwidth Adjust */
5714 uint32_t fasten : 1; /* Fast Locking Enable */
5715 uint32_t saten : 1; /* Saturation Enable */
5716 uint32_t : 17; /* *UNDEFINED* */
5717};
5718
5719/* The typedef declaration for register ALT_CLKMGR_SDRPLL_CTL. */
5720typedef volatile struct ALT_CLKMGR_SDRPLL_CTL_s ALT_CLKMGR_SDRPLL_CTL_t;
5721#endif /* __ASSEMBLY__ */
5722
5723/* The byte offset of the ALT_CLKMGR_SDRPLL_CTL register from the beginning of the component. */
5724#define ALT_CLKMGR_SDRPLL_CTL_OFST 0x4
5725
5726/*
5727 * Register : SDRAM PLL C0 Control Register for Clock ddr_dqs_clk - ddrdqsclk
5728 *
5729 * Contains settings that control clock ddr_dqs_clk generated from the C0 output of
5730 * the SDRAM PLL.
5731 *
5732 * Fields are only reset by a cold reset.
5733 *
5734 * Register Layout
5735 *
5736 * Bits | Access | Reset | Description
5737 * :--------|:-------|:------|:------------
5738 * [8:0] | RW | 0x1 | Counter
5739 * [20:9] | RW | 0x0 | Phase Shift
5740 * [31:21] | ??? | 0x0 | *UNDEFINED*
5741 *
5742 */
5743/*
5744 * Field : Counter - cnt
5745 *
5746 * Divides the VCO frequency by the value+1 in this field.
5747 *
5748 * Field Access Macros:
5749 *
5750 */
5751/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
5752#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_LSB 0
5753/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
5754#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_MSB 8
5755/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
5756#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_WIDTH 9
5757/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value. */
5758#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET_MSK 0x000001ff
5759/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value. */
5760#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_CLR_MSK 0xfffffe00
5761/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
5762#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_RESET 0x1
5763/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT field value from a register. */
5764#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5765/* Produces a ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value suitable for setting the register. */
5766#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5767
5768/*
5769 * Field : Phase Shift - phase
5770 *
5771 * Increment the phase of the VCO output by the value in this field multiplied by
5772 * 45 degrees. The accumulated phase shift is the total shifted amount since the
5773 * last assertion of the 'SDRAM All Output Divider Reset' bit in the SDRAM vco
5774 * control register. In order to guarantee the phase shift to a known value, 'SDRAM
5775 * clocks output phase align' bit should be asserted before programming this field.
5776 *
5777 * This field is only writeable by SW when it is zero. HW updates this field in
5778 * real time as the phase adjustment is being made. SW may poll this field
5779 * waiting for zero indicating the phase adjustment has completed by HW.
5780 *
5781 * Field Access Macros:
5782 *
5783 */
5784/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
5785#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_LSB 9
5786/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
5787#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_MSB 20
5788/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
5789#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_WIDTH 12
5790/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value. */
5791#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET_MSK 0x001ffe00
5792/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value. */
5793#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_CLR_MSK 0xffe001ff
5794/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
5795#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_RESET 0x0
5796/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE field value from a register. */
5797#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5798/* Produces a ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value suitable for setting the register. */
5799#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
5800
5801#ifndef __ASSEMBLY__
5802/*
5803 * WARNING: The C register and register group struct declarations are provided for
5804 * convenience and illustrative purposes. They should, however, be used with
5805 * caution as the C language standard provides no guarantees about the alignment or
5806 * atomicity of device memory accesses. The recommended practice for writing
5807 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5808 * alt_write_word() functions.
5809 *
5810 * The struct declaration for register ALT_CLKMGR_SDRPLL_DDRDQSCLK.
5811 */
5813{
5814 uint32_t cnt : 9; /* Counter */
5815 uint32_t phase : 12; /* Phase Shift */
5816 uint32_t : 11; /* *UNDEFINED* */
5817};
5818
5819/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDRDQSCLK. */
5821#endif /* __ASSEMBLY__ */
5822
5823/* The byte offset of the ALT_CLKMGR_SDRPLL_DDRDQSCLK register from the beginning of the component. */
5824#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST 0x8
5825
5826/*
5827 * Register : SDRAM PLL C1 Control Register for Clock ddr_2x_dqs_clk - ddr2xdqsclk
5828 *
5829 * Contains settings that control clock ddr_2x_dqs_clk generated from the C1 output
5830 * of the SDRAM PLL.
5831 *
5832 * Fields are only reset by a cold reset.
5833 *
5834 * Register Layout
5835 *
5836 * Bits | Access | Reset | Description
5837 * :--------|:-------|:------|:------------
5838 * [8:0] | RW | 0x1 | Counter
5839 * [20:9] | RW | 0x0 | Phase Shift
5840 * [31:21] | ??? | 0x0 | *UNDEFINED*
5841 *
5842 */
5843/*
5844 * Field : Counter - cnt
5845 *
5846 * Divides the VCO frequency by the value+1 in this field.
5847 *
5848 * Field Access Macros:
5849 *
5850 */
5851/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
5852#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_LSB 0
5853/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
5854#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_MSB 8
5855/* The width in bits of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
5856#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_WIDTH 9
5857/* The mask used to set the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value. */
5858#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET_MSK 0x000001ff
5859/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value. */
5860#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_CLR_MSK 0xfffffe00
5861/* The reset value of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
5862#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_RESET 0x1
5863/* Extracts the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT field value from a register. */
5864#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5865/* Produces a ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value suitable for setting the register. */
5866#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5867
5868/*
5869 * Field : Phase Shift - phase
5870 *
5871 * Increment the phase of the VCO output by the value in this field multiplied by
5872 * 45 degrees. The accumulated phase shift is the total shifted amount since the
5873 * last assertion of the 'SDRAM All Output Divider Reset' bit in the SDRAM vco
5874 * control register. In order to guarantee the phase shift to a known value, 'SDRAM
5875 * clocks output phase align' bit should be asserted before programming this field.
5876 *
5877 * This field is only writeable by SW when it is zero. HW updates this field in
5878 * real time as the phase adjustment is being made. SW may poll this field
5879 * waiting for zero indicating the phase adjustment has completed by HW.
5880 *
5881 * Field Access Macros:
5882 *
5883 */
5884/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
5885#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_LSB 9
5886/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
5887#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_MSB 20
5888/* The width in bits of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
5889#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_WIDTH 12
5890/* The mask used to set the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value. */
5891#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET_MSK 0x001ffe00
5892/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value. */
5893#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_CLR_MSK 0xffe001ff
5894/* The reset value of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
5895#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_RESET 0x0
5896/* Extracts the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE field value from a register. */
5897#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5898/* Produces a ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value suitable for setting the register. */
5899#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
5900
5901#ifndef __ASSEMBLY__
5902/*
5903 * WARNING: The C register and register group struct declarations are provided for
5904 * convenience and illustrative purposes. They should, however, be used with
5905 * caution as the C language standard provides no guarantees about the alignment or
5906 * atomicity of device memory accesses. The recommended practice for writing
5907 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5908 * alt_write_word() functions.
5909 *
5910 * The struct declaration for register ALT_CLKMGR_SDRPLL_DDR2XDQSCLK.
5911 */
5913{
5914 uint32_t cnt : 9; /* Counter */
5915 uint32_t phase : 12; /* Phase Shift */
5916 uint32_t : 11; /* *UNDEFINED* */
5917};
5918
5919/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDR2XDQSCLK. */
5921#endif /* __ASSEMBLY__ */
5922
5923/* The byte offset of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK register from the beginning of the component. */
5924#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST 0xc
5925
5926/*
5927 * Register : SDRAM PLL C2 Control Register for Clock ddr_dq_clk - ddrdqclk
5928 *
5929 * Contains settings that control clock ddr_dq_clk generated from the C2 output of
5930 * the SDRAM PLL.
5931 *
5932 * Fields are only reset by a cold reset.
5933 *
5934 * Register Layout
5935 *
5936 * Bits | Access | Reset | Description
5937 * :--------|:-------|:------|:------------
5938 * [8:0] | RW | 0x1 | Counter
5939 * [20:9] | RW | 0x0 | Phase Shift
5940 * [31:21] | ??? | 0x0 | *UNDEFINED*
5941 *
5942 */
5943/*
5944 * Field : Counter - cnt
5945 *
5946 * Divides the VCO frequency by the value+1 in this field.
5947 *
5948 * Field Access Macros:
5949 *
5950 */
5951/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
5952#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_LSB 0
5953/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
5954#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_MSB 8
5955/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
5956#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_WIDTH 9
5957/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value. */
5958#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET_MSK 0x000001ff
5959/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value. */
5960#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_CLR_MSK 0xfffffe00
5961/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
5962#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_RESET 0x1
5963/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT field value from a register. */
5964#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5965/* Produces a ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value suitable for setting the register. */
5966#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5967
5968/*
5969 * Field : Phase Shift - phase
5970 *
5971 * Increment the phase of the VCO output by the value in this field multiplied by
5972 * 45 degrees. The accumulated phase shift is the total shifted amount since the
5973 * last assertion of the 'SDRAM All Output Divider Reset' bit in the SDRAM vco
5974 * control register. In order to guarantee the phase shift to a known value, 'SDRAM
5975 * clocks output phase align' bit should be asserted before programming this field.
5976 *
5977 * This field is only writeable by SW when it is zero. HW updates this field in
5978 * real time as the phase adjustment is being made. SW may poll this field
5979 * waiting for zero indicating the phase adjustment has completed by HW.
5980 *
5981 * Field Access Macros:
5982 *
5983 */
5984/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
5985#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_LSB 9
5986/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
5987#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_MSB 20
5988/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
5989#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_WIDTH 12
5990/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value. */
5991#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET_MSK 0x001ffe00
5992/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value. */
5993#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_CLR_MSK 0xffe001ff
5994/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
5995#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_RESET 0x0
5996/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE field value from a register. */
5997#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5998/* Produces a ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value suitable for setting the register. */
5999#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
6000
6001#ifndef __ASSEMBLY__
6002/*
6003 * WARNING: The C register and register group struct declarations are provided for
6004 * convenience and illustrative purposes. They should, however, be used with
6005 * caution as the C language standard provides no guarantees about the alignment or
6006 * atomicity of device memory accesses. The recommended practice for writing
6007 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6008 * alt_write_word() functions.
6009 *
6010 * The struct declaration for register ALT_CLKMGR_SDRPLL_DDRDQCLK.
6011 */
6013{
6014 uint32_t cnt : 9; /* Counter */
6015 uint32_t phase : 12; /* Phase Shift */
6016 uint32_t : 11; /* *UNDEFINED* */
6017};
6018
6019/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDRDQCLK. */
6021#endif /* __ASSEMBLY__ */
6022
6023/* The byte offset of the ALT_CLKMGR_SDRPLL_DDRDQCLK register from the beginning of the component. */
6024#define ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST 0x10
6025
6026/*
6027 * Register : SDRAM PLL C5 Control Register for Clock s2f_user2_clk - s2fuser2clk
6028 *
6029 * Contains settings that control clock s2f_user2_clk generated from the C5 output
6030 * of the SDRAM PLL.
6031 *
6032 * Qsys and user documenation refer to s2f_user2_clk as h2f_user2_clk
6033 *
6034 * Fields are only reset by a cold reset.
6035 *
6036 * Register Layout
6037 *
6038 * Bits | Access | Reset | Description
6039 * :--------|:-------|:------|:------------
6040 * [8:0] | RW | 0x1 | Counter
6041 * [20:9] | RW | 0x0 | Phase Shift
6042 * [31:21] | ??? | 0x0 | *UNDEFINED*
6043 *
6044 */
6045/*
6046 * Field : Counter - cnt
6047 *
6048 * Divides the VCO frequency by the value+1 in this field.
6049 *
6050 * Field Access Macros:
6051 *
6052 */
6053/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
6054#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_LSB 0
6055/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
6056#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_MSB 8
6057/* The width in bits of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
6058#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_WIDTH 9
6059/* The mask used to set the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value. */
6060#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET_MSK 0x000001ff
6061/* The mask used to clear the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value. */
6062#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_CLR_MSK 0xfffffe00
6063/* The reset value of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
6064#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_RESET 0x1
6065/* Extracts the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT field value from a register. */
6066#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
6067/* Produces a ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value suitable for setting the register. */
6068#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
6069
6070/*
6071 * Field : Phase Shift - phase
6072 *
6073 * Increment the phase of the VCO output by the value in this field multiplied by
6074 * 45 degrees. The accumulated phase shift is the total shifted amount since the
6075 * last assertion of the 'SDRAM All Output Divider Reset' bit in the SDRAM vco
6076 * control register. In order to guarantee the phase shift to a known value, 'SDRAM
6077 * clocks output phase align' bit should be asserted before programming this field.
6078 *
6079 * This field is only writeable by SW when it is zero. HW updates this field in
6080 * real time as the phase adjustment is being made. SW may poll this field
6081 * waiting for zero indicating the phase adjustment has completed by HW.
6082 *
6083 * Field Access Macros:
6084 *
6085 */
6086/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
6087#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_LSB 9
6088/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
6089#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_MSB 20
6090/* The width in bits of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
6091#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_WIDTH 12
6092/* The mask used to set the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value. */
6093#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET_MSK 0x001ffe00
6094/* The mask used to clear the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value. */
6095#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_CLR_MSK 0xffe001ff
6096/* The reset value of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
6097#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_RESET 0x0
6098/* Extracts the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE field value from a register. */
6099#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
6100/* Produces a ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value suitable for setting the register. */
6101#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
6102
6103#ifndef __ASSEMBLY__
6104/*
6105 * WARNING: The C register and register group struct declarations are provided for
6106 * convenience and illustrative purposes. They should, however, be used with
6107 * caution as the C language standard provides no guarantees about the alignment or
6108 * atomicity of device memory accesses. The recommended practice for writing
6109 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6110 * alt_write_word() functions.
6111 *
6112 * The struct declaration for register ALT_CLKMGR_SDRPLL_S2FUSER2CLK.
6113 */
6115{
6116 uint32_t cnt : 9; /* Counter */
6117 uint32_t phase : 12; /* Phase Shift */
6118 uint32_t : 11; /* *UNDEFINED* */
6119};
6120
6121/* The typedef declaration for register ALT_CLKMGR_SDRPLL_S2FUSER2CLK. */
6123#endif /* __ASSEMBLY__ */
6124
6125/* The byte offset of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK register from the beginning of the component. */
6126#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST 0x14
6127
6128/*
6129 * Register : Enable Register - en
6130 *
6131 * Contains fields that control the SDRAM Clock Group enables generated from the
6132 * SDRAM PLL clock outputs.
6133 *
6134 * 1: The clock is enabled.
6135 *
6136 * 0: The clock is disabled.
6137 *
6138 * Fields are only reset by a cold reset.
6139 *
6140 * Register Layout
6141 *
6142 * Bits | Access | Reset | Description
6143 * :-------|:-------|:------|:----------------------
6144 * [0] | RW | 0x1 | ddr_dqs_clk Enable
6145 * [1] | RW | 0x1 | ddr_2x_dqs_clk Enable
6146 * [2] | RW | 0x1 | ddr_dq_clk Enable
6147 * [3] | RW | 0x1 | s2f_user2_clk Enable
6148 * [31:4] | ??? | 0x0 | *UNDEFINED*
6149 *
6150 */
6151/*
6152 * Field : ddr_dqs_clk Enable - ddrdqsclk
6153 *
6154 * Enables clock ddr_dqs_clk output
6155 *
6156 * Field Access Macros:
6157 *
6158 */
6159/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
6160#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_LSB 0
6161/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
6162#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_MSB 0
6163/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
6164#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_WIDTH 1
6165/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value. */
6166#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET_MSK 0x00000001
6167/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value. */
6168#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_CLR_MSK 0xfffffffe
6169/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
6170#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_RESET 0x1
6171/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK field value from a register. */
6172#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_GET(value) (((value) & 0x00000001) >> 0)
6173/* Produces a ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value suitable for setting the register. */
6174#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET(value) (((value) << 0) & 0x00000001)
6175
6176/*
6177 * Field : ddr_2x_dqs_clk Enable - ddr2xdqsclk
6178 *
6179 * Enables clock ddr_2x_dqs_clk output
6180 *
6181 * Field Access Macros:
6182 *
6183 */
6184/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
6185#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_LSB 1
6186/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
6187#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_MSB 1
6188/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
6189#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_WIDTH 1
6190/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value. */
6191#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET_MSK 0x00000002
6192/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value. */
6193#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_CLR_MSK 0xfffffffd
6194/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
6195#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_RESET 0x1
6196/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK field value from a register. */
6197#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_GET(value) (((value) & 0x00000002) >> 1)
6198/* Produces a ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value suitable for setting the register. */
6199#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET(value) (((value) << 1) & 0x00000002)
6200
6201/*
6202 * Field : ddr_dq_clk Enable - ddrdqclk
6203 *
6204 * Enables clock ddr_dq_clk output
6205 *
6206 * Field Access Macros:
6207 *
6208 */
6209/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
6210#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_LSB 2
6211/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
6212#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_MSB 2
6213/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
6214#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_WIDTH 1
6215/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value. */
6216#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET_MSK 0x00000004
6217/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value. */
6218#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_CLR_MSK 0xfffffffb
6219/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
6220#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_RESET 0x1
6221/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK field value from a register. */
6222#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_GET(value) (((value) & 0x00000004) >> 2)
6223/* Produces a ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value suitable for setting the register. */
6224#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET(value) (((value) << 2) & 0x00000004)
6225
6226/*
6227 * Field : s2f_user2_clk Enable - s2fuser2clk
6228 *
6229 * Enables clock s2f_user2_clk output.
6230 *
6231 * Qsys and user documenation refer to s2f_user2_clk as h2f_user2_clk.
6232 *
6233 * Field Access Macros:
6234 *
6235 */
6236/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
6237#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_LSB 3
6238/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
6239#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_MSB 3
6240/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
6241#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_WIDTH 1
6242/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value. */
6243#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET_MSK 0x00000008
6244/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value. */
6245#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_CLR_MSK 0xfffffff7
6246/* The reset value of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
6247#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_RESET 0x1
6248/* Extracts the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK field value from a register. */
6249#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_GET(value) (((value) & 0x00000008) >> 3)
6250/* Produces a ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value suitable for setting the register. */
6251#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET(value) (((value) << 3) & 0x00000008)
6252
6253#ifndef __ASSEMBLY__
6254/*
6255 * WARNING: The C register and register group struct declarations are provided for
6256 * convenience and illustrative purposes. They should, however, be used with
6257 * caution as the C language standard provides no guarantees about the alignment or
6258 * atomicity of device memory accesses. The recommended practice for writing
6259 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6260 * alt_write_word() functions.
6261 *
6262 * The struct declaration for register ALT_CLKMGR_SDRPLL_EN.
6263 */
6265{
6266 uint32_t ddrdqsclk : 1; /* ddr_dqs_clk Enable */
6267 uint32_t ddr2xdqsclk : 1; /* ddr_2x_dqs_clk Enable */
6268 uint32_t ddrdqclk : 1; /* ddr_dq_clk Enable */
6269 uint32_t s2fuser2clk : 1; /* s2f_user2_clk Enable */
6270 uint32_t : 28; /* *UNDEFINED* */
6271};
6272
6273/* The typedef declaration for register ALT_CLKMGR_SDRPLL_EN. */
6274typedef volatile struct ALT_CLKMGR_SDRPLL_EN_s ALT_CLKMGR_SDRPLL_EN_t;
6275#endif /* __ASSEMBLY__ */
6276
6277/* The byte offset of the ALT_CLKMGR_SDRPLL_EN register from the beginning of the component. */
6278#define ALT_CLKMGR_SDRPLL_EN_OFST 0x18
6279
6280/*
6281 * Register : SDRAM PLL Output Counter Reset Ack Status Register - stat
6282 *
6283 * Contains Output Clock Counter Reset acknowledge status.
6284 *
6285 * Register Layout
6286 *
6287 * Bits | Access | Reset | Description
6288 * :-------|:-------|:------|:---------------------------------
6289 * [5:0] | R | 0x0 | Output Counter Reset Acknowledge
6290 * [31:6] | ??? | 0x0 | *UNDEFINED*
6291 *
6292 */
6293/*
6294 * Field : Output Counter Reset Acknowledge - outresetack
6295 *
6296 * These read only bits per PLL output indicate that the PLL has received the
6297 * Output Reset Counter request and has gracefully stopped the respective PLL
6298 * output clock.
6299 *
6300 * For software to change the PLL output counter without producing glitches on the
6301 * respective clock, SW must set the VCO register respective Output Counter Reset
6302 * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
6303 * the Output Counter Reset Ack Status Register. Software then writes the
6304 * appropriate counter register, and then clears the respective VCO register Output
6305 * Counter Reset bit.
6306 *
6307 * The reset value of this bit is applied on a cold reset; warm reset has no affect
6308 * on this bit.
6309 *
6310 * Field Enumeration Values:
6311 *
6312 * Enum | Value | Description
6313 * :-------------------------------------------|:------|:-------------------------------------
6314 * ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE | 0x0 | Idle
6315 * ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1 | Output Counter Acknowledge received.
6316 *
6317 * Field Access Macros:
6318 *
6319 */
6320/*
6321 * Enumerated value for register field ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK
6322 *
6323 * Idle
6324 */
6325#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE 0x0
6326/*
6327 * Enumerated value for register field ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK
6328 *
6329 * Output Counter Acknowledge received.
6330 */
6331#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
6332
6333/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
6334#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_LSB 0
6335/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
6336#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_MSB 5
6337/* The width in bits of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
6338#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_WIDTH 6
6339/* The mask used to set the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value. */
6340#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
6341/* The mask used to clear the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value. */
6342#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
6343/* The reset value of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
6344#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_RESET 0x0
6345/* Extracts the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK field value from a register. */
6346#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
6347/* Produces a ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
6348#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
6349
6350#ifndef __ASSEMBLY__
6351/*
6352 * WARNING: The C register and register group struct declarations are provided for
6353 * convenience and illustrative purposes. They should, however, be used with
6354 * caution as the C language standard provides no guarantees about the alignment or
6355 * atomicity of device memory accesses. The recommended practice for writing
6356 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6357 * alt_write_word() functions.
6358 *
6359 * The struct declaration for register ALT_CLKMGR_SDRPLL_STAT.
6360 */
6362{
6363 const uint32_t outresetack : 6; /* Output Counter Reset Acknowledge */
6364 uint32_t : 26; /* *UNDEFINED* */
6365};
6366
6367/* The typedef declaration for register ALT_CLKMGR_SDRPLL_STAT. */
6369#endif /* __ASSEMBLY__ */
6370
6371/* The byte offset of the ALT_CLKMGR_SDRPLL_STAT register from the beginning of the component. */
6372#define ALT_CLKMGR_SDRPLL_STAT_OFST 0x1c
6373
6374#ifndef __ASSEMBLY__
6375/*
6376 * WARNING: The C register and register group struct declarations are provided for
6377 * convenience and illustrative purposes. They should, however, be used with
6378 * caution as the C language standard provides no guarantees about the alignment or
6379 * atomicity of device memory accesses. The recommended practice for writing
6380 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6381 * alt_write_word() functions.
6382 *
6383 * The struct declaration for register group ALT_CLKMGR_SDRPLL.
6384 */
6386{
6387 volatile ALT_CLKMGR_SDRPLL_VCO_t vco; /* ALT_CLKMGR_SDRPLL_VCO */
6388 volatile ALT_CLKMGR_SDRPLL_CTL_t ctrl; /* ALT_CLKMGR_SDRPLL_CTL */
6389 volatile ALT_CLKMGR_SDRPLL_DDRDQSCLK_t ddrdqsclk; /* ALT_CLKMGR_SDRPLL_DDRDQSCLK */
6390 volatile ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_t ddr2xdqsclk; /* ALT_CLKMGR_SDRPLL_DDR2XDQSCLK */
6391 volatile ALT_CLKMGR_SDRPLL_DDRDQCLK_t ddrdqclk; /* ALT_CLKMGR_SDRPLL_DDRDQCLK */
6392 volatile ALT_CLKMGR_SDRPLL_S2FUSER2CLK_t s2fuser2clk; /* ALT_CLKMGR_SDRPLL_S2FUSER2CLK */
6393 volatile ALT_CLKMGR_SDRPLL_EN_t en; /* ALT_CLKMGR_SDRPLL_EN */
6394 volatile ALT_CLKMGR_SDRPLL_STAT_t stat; /* ALT_CLKMGR_SDRPLL_STAT */
6395};
6396
6397/* The typedef declaration for register group ALT_CLKMGR_SDRPLL. */
6398typedef volatile struct ALT_CLKMGR_SDRPLL_s ALT_CLKMGR_SDRPLL_t;
6399/* The struct declaration for the raw register contents of register group ALT_CLKMGR_SDRPLL. */
6401{
6402 volatile uint32_t vco; /* ALT_CLKMGR_SDRPLL_VCO */
6403 volatile uint32_t ctrl; /* ALT_CLKMGR_SDRPLL_CTL */
6404 volatile uint32_t ddrdqsclk; /* ALT_CLKMGR_SDRPLL_DDRDQSCLK */
6405 volatile uint32_t ddr2xdqsclk; /* ALT_CLKMGR_SDRPLL_DDR2XDQSCLK */
6406 volatile uint32_t ddrdqclk; /* ALT_CLKMGR_SDRPLL_DDRDQCLK */
6407 volatile uint32_t s2fuser2clk; /* ALT_CLKMGR_SDRPLL_S2FUSER2CLK */
6408 volatile uint32_t en; /* ALT_CLKMGR_SDRPLL_EN */
6409 volatile uint32_t stat; /* ALT_CLKMGR_SDRPLL_STAT */
6410};
6411
6412/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_SDRPLL. */
6413typedef volatile struct ALT_CLKMGR_SDRPLL_raw_s ALT_CLKMGR_SDRPLL_raw_t;
6414#endif /* __ASSEMBLY__ */
6415
6416
6417#ifndef __ASSEMBLY__
6418/*
6419 * WARNING: The C register and register group struct declarations are provided for
6420 * convenience and illustrative purposes. They should, however, be used with
6421 * caution as the C language standard provides no guarantees about the alignment or
6422 * atomicity of device memory accesses. The recommended practice for writing
6423 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6424 * alt_write_word() functions.
6425 *
6426 * The struct declaration for register group ALT_CLKMGR.
6427 */
6429{
6430 volatile ALT_CLKMGR_CTL_t ctrl; /* ALT_CLKMGR_CTL */
6431 volatile ALT_CLKMGR_BYPASS_t bypass; /* ALT_CLKMGR_BYPASS */
6432 volatile ALT_CLKMGR_INTER_t inter; /* ALT_CLKMGR_INTER */
6433 volatile ALT_CLKMGR_INTREN_t intren; /* ALT_CLKMGR_INTREN */
6434 volatile ALT_CLKMGR_DBCTL_t dbctrl; /* ALT_CLKMGR_DBCTL */
6435 volatile ALT_CLKMGR_STAT_t stat; /* ALT_CLKMGR_STAT */
6436 volatile uint32_t _pad_0x18_0x3f[10]; /* *UNDEFINED* */
6437 volatile ALT_CLKMGR_MAINPLL_t mainpllgrp; /* ALT_CLKMGR_MAINPLL */
6438 volatile ALT_CLKMGR_PERPLL_t perpllgrp; /* ALT_CLKMGR_PERPLL */
6439 volatile ALT_CLKMGR_SDRPLL_t sdrpllgrp; /* ALT_CLKMGR_SDRPLL */
6440 volatile uint32_t _pad_0xe0_0x200[72]; /* *UNDEFINED* */
6441};
6442
6443/* The typedef declaration for register group ALT_CLKMGR. */
6444typedef volatile struct ALT_CLKMGR_s ALT_CLKMGR_t;
6445/* The struct declaration for the raw register contents of register group ALT_CLKMGR. */
6447{
6448 volatile uint32_t ctrl; /* ALT_CLKMGR_CTL */
6449 volatile uint32_t bypass; /* ALT_CLKMGR_BYPASS */
6450 volatile uint32_t inter; /* ALT_CLKMGR_INTER */
6451 volatile uint32_t intren; /* ALT_CLKMGR_INTREN */
6452 volatile uint32_t dbctrl; /* ALT_CLKMGR_DBCTL */
6453 volatile uint32_t stat; /* ALT_CLKMGR_STAT */
6454 volatile uint32_t _pad_0x18_0x3f[10]; /* *UNDEFINED* */
6455 volatile ALT_CLKMGR_MAINPLL_raw_t mainpllgrp; /* ALT_CLKMGR_MAINPLL */
6456 volatile ALT_CLKMGR_PERPLL_raw_t perpllgrp; /* ALT_CLKMGR_PERPLL */
6457 volatile ALT_CLKMGR_SDRPLL_raw_t sdrpllgrp; /* ALT_CLKMGR_SDRPLL */
6458 volatile uint32_t _pad_0xe0_0x200[72]; /* *UNDEFINED* */
6459};
6460
6461/* The typedef declaration for the raw register contents of register group ALT_CLKMGR. */
6462typedef volatile struct ALT_CLKMGR_raw_s ALT_CLKMGR_raw_t;
6463#endif /* __ASSEMBLY__ */
6464
6465
6466#ifdef __cplusplus
6467}
6468#endif /* __cplusplus */
6469#endif /* __ALTERA_ALT_CLKMGR_H__ */
6470
Definition: alt_clkmgr.h:386
Definition: alt_clkmgr.h:145
Definition: alt_clkmgr.h:994
Definition: alt_clkmgr.h:672
Definition: alt_clkmgr.h:886
Definition: alt_clkmgr.h:1931
Definition: alt_clkmgr.h:1734
Definition: alt_clkmgr.h:2698
Definition: alt_clkmgr.h:2235
Definition: alt_clkmgr.h:2957
Definition: alt_clkmgr.h:1669
Definition: alt_clkmgr.h:2555
Definition: alt_clkmgr.h:1864
Definition: alt_clkmgr.h:1799
Definition: alt_clkmgr.h:1536
Definition: alt_clkmgr.h:1604
Definition: alt_clkmgr.h:3052
Definition: alt_clkmgr.h:2827
Definition: alt_clkmgr.h:1381
Definition: alt_clkmgr.h:3098
Definition: alt_clkmgr.h:3076
Definition: alt_clkmgr.h:4782
Definition: alt_clkmgr.h:3682
Definition: alt_clkmgr.h:3747
Definition: alt_clkmgr.h:4376
Definition: alt_clkmgr.h:4851
Definition: alt_clkmgr.h:3614
Definition: alt_clkmgr.h:3942
Definition: alt_clkmgr.h:3877
Definition: alt_clkmgr.h:3812
Definition: alt_clkmgr.h:4009
Definition: alt_clkmgr.h:5054
Definition: alt_clkmgr.h:5150
Definition: alt_clkmgr.h:3459
Definition: alt_clkmgr.h:5195
Definition: alt_clkmgr.h:5174
Definition: alt_clkmgr.h:5711
Definition: alt_clkmgr.h:5913
Definition: alt_clkmgr.h:6013
Definition: alt_clkmgr.h:5813
Definition: alt_clkmgr.h:6265
Definition: alt_clkmgr.h:6115
Definition: alt_clkmgr.h:6362
Definition: alt_clkmgr.h:5556
Definition: alt_clkmgr.h:6401
Definition: alt_clkmgr.h:6386
Definition: alt_clkmgr.h:1085
Definition: alt_clkmgr.h:6447
Definition: alt_clkmgr.h:6429
