RTEMS 5.2-rc1
Data Structures | Macros | Typedefs
alt_clkmgr.h File Reference
struct  ALT_CLKMGR_CTL_s
struct  ALT_CLKMGR_BYPASS_s
struct  ALT_CLKMGR_INTER_s
struct  ALT_CLKMGR_INTREN_s
struct  ALT_CLKMGR_DBCTL_s
struct  ALT_CLKMGR_STAT_s
struct  ALT_CLKMGR_MAINPLL_VCO_s
struct  ALT_CLKMGR_MAINPLL_MISC_s
struct  ALT_CLKMGR_MAINPLL_MPUCLK_s
struct  ALT_CLKMGR_MAINPLL_MAINCLK_s
struct  ALT_CLKMGR_MAINPLL_DBGATCLK_s
struct  ALT_CLKMGR_MAINPLL_MAINQSPICLK_s
struct  ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_s
struct  ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_s
struct  ALT_CLKMGR_MAINPLL_EN_s
struct  ALT_CLKMGR_MAINPLL_MAINDIV_s
struct  ALT_CLKMGR_MAINPLL_DBGDIV_s
struct  ALT_CLKMGR_MAINPLL_TRACEDIV_s
struct  ALT_CLKMGR_MAINPLL_L4SRC_s
struct  ALT_CLKMGR_MAINPLL_STAT_s
struct  ALT_CLKMGR_MAINPLL_s
struct  ALT_CLKMGR_MAINPLL_raw_s
struct  ALT_CLKMGR_PERPLL_VCO_s
struct  ALT_CLKMGR_PERPLL_MISC_s
struct  ALT_CLKMGR_PERPLL_EMAC0CLK_s
struct  ALT_CLKMGR_PERPLL_EMAC1CLK_s
struct  ALT_CLKMGR_PERPLL_PERQSPICLK_s
struct  ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_s
struct  ALT_CLKMGR_PERPLL_PERBASECLK_s
struct  ALT_CLKMGR_PERPLL_S2FUSER1CLK_s
struct  ALT_CLKMGR_PERPLL_EN_s
struct  ALT_CLKMGR_PERPLL_DIV_s
struct  ALT_CLKMGR_PERPLL_GPIODIV_s
struct  ALT_CLKMGR_PERPLL_SRC_s
struct  ALT_CLKMGR_PERPLL_STAT_s
struct  ALT_CLKMGR_PERPLL_s
struct  ALT_CLKMGR_PERPLL_raw_s
struct  ALT_CLKMGR_SDRPLL_VCO_s
struct  ALT_CLKMGR_SDRPLL_CTL_s
struct  ALT_CLKMGR_SDRPLL_DDRDQSCLK_s
struct  ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_s
struct  ALT_CLKMGR_SDRPLL_DDRDQCLK_s
struct  ALT_CLKMGR_SDRPLL_S2FUSER2CLK_s
struct  ALT_CLKMGR_SDRPLL_EN_s
struct  ALT_CLKMGR_SDRPLL_STAT_s
struct  ALT_CLKMGR_SDRPLL_s
struct  ALT_CLKMGR_SDRPLL_raw_s
struct  ALT_CLKMGR_s
struct  ALT_CLKMGR_raw_s
#define ALT_CLKMGR_CTL_SAFEMOD_LSB   0
#define ALT_CLKMGR_CTL_SAFEMOD_MSB   0
#define ALT_CLKMGR_CTL_SAFEMOD_WIDTH   1
#define ALT_CLKMGR_CTL_SAFEMOD_SET_MSK   0x00000001
#define ALT_CLKMGR_CTL_SAFEMOD_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_CTL_SAFEMOD_RESET   0x1
#define ALT_CLKMGR_CTL_SAFEMOD_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_CTL_SAFEMOD_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_CTL_ENSFMDWR_LSB   2
#define ALT_CLKMGR_CTL_ENSFMDWR_MSB   2
#define ALT_CLKMGR_CTL_ENSFMDWR_WIDTH   1
#define ALT_CLKMGR_CTL_ENSFMDWR_SET_MSK   0x00000004
#define ALT_CLKMGR_CTL_ENSFMDWR_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_CTL_ENSFMDWR_RESET   0x1
#define ALT_CLKMGR_CTL_ENSFMDWR_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_CTL_ENSFMDWR_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_CTL_OFST   0x0
#define ALT_CLKMGR_BYPASS_MAINPLL_LSB   0
#define ALT_CLKMGR_BYPASS_MAINPLL_MSB   0
#define ALT_CLKMGR_BYPASS_MAINPLL_WIDTH   1
#define ALT_CLKMGR_BYPASS_MAINPLL_SET_MSK   0x00000001
#define ALT_CLKMGR_BYPASS_MAINPLL_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_BYPASS_MAINPLL_RESET   0x1
#define ALT_CLKMGR_BYPASS_MAINPLL_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_BYPASS_MAINPLL_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_BYPASS_SDRPLL_LSB   1
#define ALT_CLKMGR_BYPASS_SDRPLL_MSB   1
#define ALT_CLKMGR_BYPASS_SDRPLL_WIDTH   1
#define ALT_CLKMGR_BYPASS_SDRPLL_SET_MSK   0x00000002
#define ALT_CLKMGR_BYPASS_SDRPLL_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_BYPASS_SDRPLL_RESET   0x1
#define ALT_CLKMGR_BYPASS_SDRPLL_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_BYPASS_SDRPLL_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1   0x0
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX   0x1
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_LSB   2
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_MSB   2
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_WIDTH   1
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET_MSK   0x00000004
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_RESET   0x0
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_BYPASS_PERPLL_LSB   3
#define ALT_CLKMGR_BYPASS_PERPLL_MSB   3
#define ALT_CLKMGR_BYPASS_PERPLL_WIDTH   1
#define ALT_CLKMGR_BYPASS_PERPLL_SET_MSK   0x00000008
#define ALT_CLKMGR_BYPASS_PERPLL_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_BYPASS_PERPLL_RESET   0x1
#define ALT_CLKMGR_BYPASS_PERPLL_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_BYPASS_PERPLL_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1   0x0
#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX   0x1
#define ALT_CLKMGR_BYPASS_PERPLLSRC_LSB   4
#define ALT_CLKMGR_BYPASS_PERPLLSRC_MSB   4
#define ALT_CLKMGR_BYPASS_PERPLLSRC_WIDTH   1
#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET_MSK   0x00000010
#define ALT_CLKMGR_BYPASS_PERPLLSRC_CLR_MSK   0xffffffef
#define ALT_CLKMGR_BYPASS_PERPLLSRC_RESET   0x0
#define ALT_CLKMGR_BYPASS_PERPLLSRC_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_CLKMGR_BYPASS_OFST   0x4
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_LSB   0
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_MSB   0
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET_MSK   0x00000001
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_LSB   1
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_MSB   1
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET_MSK   0x00000002
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_LSB   2
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_MSB   2
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET_MSK   0x00000004
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_INTER_MAINPLLLOST_LSB   3
#define ALT_CLKMGR_INTER_MAINPLLLOST_MSB   3
#define ALT_CLKMGR_INTER_MAINPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTER_MAINPLLLOST_SET_MSK   0x00000008
#define ALT_CLKMGR_INTER_MAINPLLLOST_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_INTER_MAINPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTER_MAINPLLLOST_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_INTER_MAINPLLLOST_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_INTER_PERPLLLOST_LSB   4
#define ALT_CLKMGR_INTER_PERPLLLOST_MSB   4
#define ALT_CLKMGR_INTER_PERPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTER_PERPLLLOST_SET_MSK   0x00000010
#define ALT_CLKMGR_INTER_PERPLLLOST_CLR_MSK   0xffffffef
#define ALT_CLKMGR_INTER_PERPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTER_PERPLLLOST_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_CLKMGR_INTER_PERPLLLOST_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_CLKMGR_INTER_SDRPLLLOST_LSB   5
#define ALT_CLKMGR_INTER_SDRPLLLOST_MSB   5
#define ALT_CLKMGR_INTER_SDRPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTER_SDRPLLLOST_SET_MSK   0x00000020
#define ALT_CLKMGR_INTER_SDRPLLLOST_CLR_MSK   0xffffffdf
#define ALT_CLKMGR_INTER_SDRPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTER_SDRPLLLOST_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_CLKMGR_INTER_SDRPLLLOST_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_LSB   6
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_MSB   6
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_WIDTH   1
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET_MSK   0x00000040
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_CLR_MSK   0xffffffbf
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_RESET   0x0
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_CLKMGR_INTER_PERPLLLOCKED_LSB   7
#define ALT_CLKMGR_INTER_PERPLLLOCKED_MSB   7
#define ALT_CLKMGR_INTER_PERPLLLOCKED_WIDTH   1
#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET_MSK   0x00000080
#define ALT_CLKMGR_INTER_PERPLLLOCKED_CLR_MSK   0xffffff7f
#define ALT_CLKMGR_INTER_PERPLLLOCKED_RESET   0x0
#define ALT_CLKMGR_INTER_PERPLLLOCKED_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_LSB   8
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_MSB   8
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_WIDTH   1
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET_MSK   0x00000100
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_CLR_MSK   0xfffffeff
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_RESET   0x0
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_CLKMGR_INTER_OFST   0x8
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_LSB   0
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_MSB   0
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET_MSK   0x00000001
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_LSB   1
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_MSB   1
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET_MSK   0x00000002
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_LSB   2
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_MSB   2
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_WIDTH   1
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET_MSK   0x00000004
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_RESET   0x0
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_INTREN_MAINPLLLOST_LSB   3
#define ALT_CLKMGR_INTREN_MAINPLLLOST_MSB   3
#define ALT_CLKMGR_INTREN_MAINPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET_MSK   0x00000008
#define ALT_CLKMGR_INTREN_MAINPLLLOST_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_INTREN_MAINPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTREN_MAINPLLLOST_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_INTREN_PERPLLLOST_LSB   4
#define ALT_CLKMGR_INTREN_PERPLLLOST_MSB   4
#define ALT_CLKMGR_INTREN_PERPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTREN_PERPLLLOST_SET_MSK   0x00000010
#define ALT_CLKMGR_INTREN_PERPLLLOST_CLR_MSK   0xffffffef
#define ALT_CLKMGR_INTREN_PERPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTREN_PERPLLLOST_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_CLKMGR_INTREN_PERPLLLOST_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_CLKMGR_INTREN_SDRPLLLOST_LSB   5
#define ALT_CLKMGR_INTREN_SDRPLLLOST_MSB   5
#define ALT_CLKMGR_INTREN_SDRPLLLOST_WIDTH   1
#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET_MSK   0x00000020
#define ALT_CLKMGR_INTREN_SDRPLLLOST_CLR_MSK   0xffffffdf
#define ALT_CLKMGR_INTREN_SDRPLLLOST_RESET   0x0
#define ALT_CLKMGR_INTREN_SDRPLLLOST_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_CLKMGR_INTREN_OFST   0xc
#define ALT_CLKMGR_DBCTL_STAYOSC1_LSB   0
#define ALT_CLKMGR_DBCTL_STAYOSC1_MSB   0
#define ALT_CLKMGR_DBCTL_STAYOSC1_WIDTH   1
#define ALT_CLKMGR_DBCTL_STAYOSC1_SET_MSK   0x00000001
#define ALT_CLKMGR_DBCTL_STAYOSC1_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_DBCTL_STAYOSC1_RESET   0x1
#define ALT_CLKMGR_DBCTL_STAYOSC1_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_DBCTL_STAYOSC1_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_DBCTL_ENSFMDWR_LSB   1
#define ALT_CLKMGR_DBCTL_ENSFMDWR_MSB   1
#define ALT_CLKMGR_DBCTL_ENSFMDWR_WIDTH   1
#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET_MSK   0x00000002
#define ALT_CLKMGR_DBCTL_ENSFMDWR_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_DBCTL_ENSFMDWR_RESET   0x1
#define ALT_CLKMGR_DBCTL_ENSFMDWR_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_DBCTL_OFST   0x10
#define ALT_CLKMGR_STAT_BUSY_E_IDLE   0x0
#define ALT_CLKMGR_STAT_BUSY_E_BUSY   0x1
#define ALT_CLKMGR_STAT_BUSY_LSB   0
#define ALT_CLKMGR_STAT_BUSY_MSB   0
#define ALT_CLKMGR_STAT_BUSY_WIDTH   1
#define ALT_CLKMGR_STAT_BUSY_SET_MSK   0x00000001
#define ALT_CLKMGR_STAT_BUSY_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_STAT_BUSY_RESET   0x0
#define ALT_CLKMGR_STAT_BUSY_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_STAT_BUSY_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_STAT_OFST   0x14
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_LSB   0
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_MSB   0
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET_MSK   0x00000001
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_RESET   0x1
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_MAINPLL_VCO_EN_LSB   1
#define ALT_CLKMGR_MAINPLL_VCO_EN_MSB   1
#define ALT_CLKMGR_MAINPLL_VCO_EN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_VCO_EN_SET_MSK   0x00000002
#define ALT_CLKMGR_MAINPLL_VCO_EN_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_MAINPLL_VCO_EN_RESET   0x0
#define ALT_CLKMGR_MAINPLL_VCO_EN_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_MAINPLL_VCO_EN_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_LSB   2
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_MSB   2
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET_MSK   0x00000004
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_RESET   0x1
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_LSB   3
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_MSB   15
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_WIDTH   13
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET_MSK   0x0000fff8
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_CLR_MSK   0xffff0007
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_RESET   0x1
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_GET(value)   (((value) & 0x0000fff8) >> 3)
#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET(value)   (((value) << 3) & 0x0000fff8)
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_LSB   16
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_MSB   21
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_WIDTH   6
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET_MSK   0x003f0000
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_CLR_MSK   0xffc0ffff
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_RESET   0x1
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_GET(value)   (((value) & 0x003f0000) >> 16)
#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET(value)   (((value) << 16) & 0x003f0000)
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_LSB   24
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_MSB   24
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_WIDTH   1
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET_MSK   0x01000000
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_CLR_MSK   0xfeffffff
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_RESET   0x0
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_GET(value)   (((value) & 0x01000000) >> 24)
#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET(value)   (((value) << 24) & 0x01000000)
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_LSB   25
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_MSB   30
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_WIDTH   6
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET_MSK   0x7e000000
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_CLR_MSK   0x81ffffff
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_RESET   0x0
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_GET(value)   (((value) & 0x7e000000) >> 25)
#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET(value)   (((value) << 25) & 0x7e000000)
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_LSB   31
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_MSB   31
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_WIDTH   1
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET_MSK   0x80000000
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_CLR_MSK   0x7fffffff
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_RESET   0x1
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_GET(value)   (((value) & 0x80000000) >> 31)
#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET(value)   (((value) << 31) & 0x80000000)
#define ALT_CLKMGR_MAINPLL_VCO_OFST   0x0
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_LSB   0
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_MSB   0
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET_MSK   0x00000001
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_LSB   1
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_MSB   12
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_WIDTH   12
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET_MSK   0x00001ffe
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_CLR_MSK   0xffffe001
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_RESET   0x1
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_GET(value)   (((value) & 0x00001ffe) >> 1)
#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET(value)   (((value) << 1) & 0x00001ffe)
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_LSB   13
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_MSB   13
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET_MSK   0x00002000
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_CLR_MSK   0xffffdfff
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_LSB   14
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_MSB   14
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_WIDTH   1
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET_MSK   0x00004000
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_CLR_MSK   0xffffbfff
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_RESET   0x1
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_CLKMGR_MAINPLL_MISC_OFST   0x4
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_MPUCLK_OFST   0x8
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_MAINCLK_OFST   0xc
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_RESET   0x0
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_DBGATCLK_OFST   0x10
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_RESET   0x3
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST   0x14
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_RESET   0x3
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST   0x18
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_LSB   0
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_MSB   8
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_WIDTH   9
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_RESET   0xf
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST   0x1c
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_LSB   0
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_MSB   0
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET_MSK   0x00000001
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_LSB   1
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_MSB   1
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET_MSK   0x00000002
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_LSB   2
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_MSB   2
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET_MSK   0x00000004
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_LSB   3
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_MSB   3
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET_MSK   0x00000008
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_LSB   4
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_MSB   4
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET_MSK   0x00000010
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_CLR_MSK   0xffffffef
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_LSB   5
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_MSB   5
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET_MSK   0x00000020
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_CLR_MSK   0xffffffdf
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_LSB   6
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_MSB   6
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET_MSK   0x00000040
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_CLR_MSK   0xffffffbf
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_LSB   7
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_MSB   7
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET_MSK   0x00000080
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_CLR_MSK   0xffffff7f
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_LSB   8
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_MSB   8
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET_MSK   0x00000100
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_CLR_MSK   0xfffffeff
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_LSB   9
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_MSB   9
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_WIDTH   1
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET_MSK   0x00000200
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_CLR_MSK   0xfffffdff
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_CLKMGR_MAINPLL_EN_OFST   0x20
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_LSB   0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_MSB   1
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_WIDTH   2
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET_MSK   0x00000003
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_CLR_MSK   0xfffffffc
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_GET(value)   (((value) & 0x00000003) >> 0)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET(value)   (((value) << 0) & 0x00000003)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_LSB   2
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_MSB   3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_WIDTH   2
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET_MSK   0x0000000c
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_CLR_MSK   0xfffffff3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_GET(value)   (((value) & 0x0000000c) >> 2)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET(value)   (((value) << 2) & 0x0000000c)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4   0x2
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8   0x3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16   0x4
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1   0x5
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2   0x6
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3   0x7
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_LSB   4
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_MSB   6
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_WIDTH   3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET_MSK   0x00000070
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_CLR_MSK   0xffffff8f
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_GET(value)   (((value) & 0x00000070) >> 4)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET(value)   (((value) << 4) & 0x00000070)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4   0x2
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8   0x3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16   0x4
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1   0x5
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2   0x6
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3   0x7
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_LSB   7
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_MSB   9
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_WIDTH   3
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET_MSK   0x00000380
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_CLR_MSK   0xfffffc7f
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_GET(value)   (((value) & 0x00000380) >> 7)
#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET(value)   (((value) << 7) & 0x00000380)
#define ALT_CLKMGR_MAINPLL_MAINDIV_OFST   0x24
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4   0x2
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_LSB   0
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_MSB   1
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_WIDTH   2
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET_MSK   0x00000003
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_CLR_MSK   0xfffffffc
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_GET(value)   (((value) & 0x00000003) >> 0)
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET(value)   (((value) << 0) & 0x00000003)
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4   0x2
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_LSB   2
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_MSB   3
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_WIDTH   2
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET_MSK   0x0000000c
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_CLR_MSK   0xfffffff3
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_RESET   0x1
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_GET(value)   (((value) & 0x0000000c) >> 2)
#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET(value)   (((value) << 2) & 0x0000000c)
#define ALT_CLKMGR_MAINPLL_DBGDIV_OFST   0x28
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1   0x0
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2   0x1
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4   0x2
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8   0x3
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16   0x4
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1   0x5
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2   0x6
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3   0x7
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_LSB   0
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_MSB   2
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_WIDTH   3
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET_MSK   0x00000007
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_CLR_MSK   0xfffffff8
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_GET(value)   (((value) & 0x00000007) >> 0)
#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET(value)   (((value) << 0) & 0x00000007)
#define ALT_CLKMGR_MAINPLL_TRACEDIV_OFST   0x2c
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL   0x0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL   0x1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_LSB   0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_MSB   0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_WIDTH   1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET_MSK   0x00000001
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_RESET   0x0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL   0x0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL   0x1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_LSB   1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_MSB   1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_WIDTH   1
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET_MSK   0x00000002
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_RESET   0x0
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_MAINPLL_L4SRC_OFST   0x30
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE   0x0
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD   0x1
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_LSB   0
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_MSB   5
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_WIDTH   6
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET_MSK   0x0000003f
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_CLR_MSK   0xffffffc0
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_RESET   0x0
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_GET(value)   (((value) & 0x0000003f) >> 0)
#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET(value)   (((value) << 0) & 0x0000003f)
#define ALT_CLKMGR_MAINPLL_STAT_OFST   0x34
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_LSB   0
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_MSB   0
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_WIDTH   1
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET_MSK   0x00000001
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_RESET   0x1
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_PERPLL_VCO_EN_LSB   1
#define ALT_CLKMGR_PERPLL_VCO_EN_MSB   1
#define ALT_CLKMGR_PERPLL_VCO_EN_WIDTH   1
#define ALT_CLKMGR_PERPLL_VCO_EN_SET_MSK   0x00000002
#define ALT_CLKMGR_PERPLL_VCO_EN_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_PERPLL_VCO_EN_RESET   0x0
#define ALT_CLKMGR_PERPLL_VCO_EN_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_PERPLL_VCO_EN_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_LSB   2
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_MSB   2
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_WIDTH   1
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET_MSK   0x00000004
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_RESET   0x1
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_PERPLL_VCO_NUMER_LSB   3
#define ALT_CLKMGR_PERPLL_VCO_NUMER_MSB   15
#define ALT_CLKMGR_PERPLL_VCO_NUMER_WIDTH   13
#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET_MSK   0x0000fff8
#define ALT_CLKMGR_PERPLL_VCO_NUMER_CLR_MSK   0xffff0007
#define ALT_CLKMGR_PERPLL_VCO_NUMER_RESET   0x1
#define ALT_CLKMGR_PERPLL_VCO_NUMER_GET(value)   (((value) & 0x0000fff8) >> 3)
#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET(value)   (((value) << 3) & 0x0000fff8)
#define ALT_CLKMGR_PERPLL_VCO_DENOM_LSB   16
#define ALT_CLKMGR_PERPLL_VCO_DENOM_MSB   21
#define ALT_CLKMGR_PERPLL_VCO_DENOM_WIDTH   6
#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET_MSK   0x003f0000
#define ALT_CLKMGR_PERPLL_VCO_DENOM_CLR_MSK   0xffc0ffff
#define ALT_CLKMGR_PERPLL_VCO_DENOM_RESET   0x1
#define ALT_CLKMGR_PERPLL_VCO_DENOM_GET(value)   (((value) & 0x003f0000) >> 16)
#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET(value)   (((value) << 16) & 0x003f0000)
#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1   0x0
#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2   0x1
#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF   0x2
#define ALT_CLKMGR_PERPLL_VCO_PSRC_LSB   22
#define ALT_CLKMGR_PERPLL_VCO_PSRC_MSB   23
#define ALT_CLKMGR_PERPLL_VCO_PSRC_WIDTH   2
#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET_MSK   0x00c00000
#define ALT_CLKMGR_PERPLL_VCO_PSRC_CLR_MSK   0xff3fffff
#define ALT_CLKMGR_PERPLL_VCO_PSRC_RESET   0x0
#define ALT_CLKMGR_PERPLL_VCO_PSRC_GET(value)   (((value) & 0x00c00000) >> 22)
#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET(value)   (((value) << 22) & 0x00c00000)
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_LSB   24
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_MSB   24
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_WIDTH   1
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET_MSK   0x01000000
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_CLR_MSK   0xfeffffff
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_RESET   0x0
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_GET(value)   (((value) & 0x01000000) >> 24)
#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET(value)   (((value) << 24) & 0x01000000)
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_LSB   25
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_MSB   30
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_WIDTH   6
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET_MSK   0x7e000000
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_CLR_MSK   0x81ffffff
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_RESET   0x0
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_GET(value)   (((value) & 0x7e000000) >> 25)
#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET(value)   (((value) << 25) & 0x7e000000)
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_LSB   31
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_MSB   31
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_WIDTH   1
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET_MSK   0x80000000
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_CLR_MSK   0x7fffffff
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_RESET   0x1
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_GET(value)   (((value) & 0x80000000) >> 31)
#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET(value)   (((value) << 31) & 0x80000000)
#define ALT_CLKMGR_PERPLL_VCO_OFST   0x0
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_LSB   0
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_MSB   0
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_WIDTH   1
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET_MSK   0x00000001
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_RESET   0x0
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_LSB   1
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_MSB   12
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_WIDTH   12
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET_MSK   0x00001ffe
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_CLR_MSK   0xffffe001
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_RESET   0x1
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_GET(value)   (((value) & 0x00001ffe) >> 1)
#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET(value)   (((value) << 1) & 0x00001ffe)
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_LSB   13
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_MSB   13
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_WIDTH   1
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET_MSK   0x00002000
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_CLR_MSK   0xffffdfff
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_RESET   0x0
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_CLKMGR_PERPLL_MISC_SATEN_LSB   14
#define ALT_CLKMGR_PERPLL_MISC_SATEN_MSB   14
#define ALT_CLKMGR_PERPLL_MISC_SATEN_WIDTH   1
#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET_MSK   0x00004000
#define ALT_CLKMGR_PERPLL_MISC_SATEN_CLR_MSK   0xffffbfff
#define ALT_CLKMGR_PERPLL_MISC_SATEN_RESET   0x1
#define ALT_CLKMGR_PERPLL_MISC_SATEN_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_CLKMGR_PERPLL_MISC_OFST   0x4
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_EMAC0CLK_OFST   0x8
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_EMAC1CLK_OFST   0xc
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_PERQSPICLK_OFST   0x10
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST   0x14
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_PERBASECLK_OFST   0x18
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_LSB   0
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_MSB   8
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_WIDTH   9
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_RESET   0x1
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST   0x1c
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_LSB   0
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_MSB   0
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET_MSK   0x00000001
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_LSB   1
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_MSB   1
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET_MSK   0x00000002
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_PERPLL_EN_USBCLK_LSB   2
#define ALT_CLKMGR_PERPLL_EN_USBCLK_MSB   2
#define ALT_CLKMGR_PERPLL_EN_USBCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET_MSK   0x00000004
#define ALT_CLKMGR_PERPLL_EN_USBCLK_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_PERPLL_EN_USBCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_USBCLK_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_LSB   3
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_MSB   3
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET_MSK   0x00000008
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_LSB   4
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_MSB   4
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET_MSK   0x00000010
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_CLR_MSK   0xffffffef
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_GET(value)   (((value) & 0x00000010) >> 4)
#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET(value)   (((value) << 4) & 0x00000010)
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_LSB   5
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_MSB   5
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET_MSK   0x00000020
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_CLR_MSK   0xffffffdf
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_GET(value)   (((value) & 0x00000020) >> 5)
#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET(value)   (((value) << 5) & 0x00000020)
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_LSB   6
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_MSB   6
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET_MSK   0x00000040
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_CLR_MSK   0xffffffbf
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_GET(value)   (((value) & 0x00000040) >> 6)
#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET(value)   (((value) << 6) & 0x00000040)
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_LSB   7
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_MSB   7
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET_MSK   0x00000080
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_CLR_MSK   0xffffff7f
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_GET(value)   (((value) & 0x00000080) >> 7)
#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET(value)   (((value) << 7) & 0x00000080)
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_LSB   8
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_MSB   8
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET_MSK   0x00000100
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_CLR_MSK   0xfffffeff
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_GET(value)   (((value) & 0x00000100) >> 8)
#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET(value)   (((value) << 8) & 0x00000100)
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_LSB   9
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_MSB   9
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET_MSK   0x00000200
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_CLR_MSK   0xfffffdff
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_GET(value)   (((value) & 0x00000200) >> 9)
#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET(value)   (((value) << 9) & 0x00000200)
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_LSB   10
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_MSB   10
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET_MSK   0x00000400
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_CLR_MSK   0xfffffbff
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_GET(value)   (((value) & 0x00000400) >> 10)
#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET(value)   (((value) << 10) & 0x00000400)
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_LSB   11
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_MSB   11
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_WIDTH   1
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET_MSK   0x00000800
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_CLR_MSK   0xfffff7ff
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_GET(value)   (((value) & 0x00000800) >> 11)
#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET(value)   (((value) << 11) & 0x00000800)
#define ALT_CLKMGR_PERPLL_EN_OFST   0x20
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1   0x0
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2   0x1
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4   0x2
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8   0x3
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16   0x4
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1   0x5
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2   0x6
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3   0x7
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_LSB   0
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_MSB   2
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_WIDTH   3
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET_MSK   0x00000007
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_CLR_MSK   0xfffffff8
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_RESET   0x0
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_GET(value)   (((value) & 0x00000007) >> 0)
#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET(value)   (((value) << 0) & 0x00000007)
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1   0x0
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2   0x1
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4   0x2
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8   0x3
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16   0x4
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1   0x5
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2   0x6
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3   0x7
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_LSB   3
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_MSB   5
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_WIDTH   3
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET_MSK   0x00000038
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_CLR_MSK   0xffffffc7
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_RESET   0x0
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_GET(value)   (((value) & 0x00000038) >> 3)
#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET(value)   (((value) << 3) & 0x00000038)
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1   0x0
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2   0x1
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4   0x2
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8   0x3
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16   0x4
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1   0x5
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2   0x6
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3   0x7
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_LSB   6
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_MSB   8
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_WIDTH   3
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET_MSK   0x000001c0
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_CLR_MSK   0xfffffe3f
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_RESET   0x0
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_GET(value)   (((value) & 0x000001c0) >> 6)
#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET(value)   (((value) << 6) & 0x000001c0)
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1   0x0
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2   0x1
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4   0x2
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8   0x3
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16   0x4
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1   0x5
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2   0x6
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3   0x7
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_LSB   9
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_MSB   11
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_WIDTH   3
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET_MSK   0x00000e00
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_CLR_MSK   0xfffff1ff
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_RESET   0x0
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_GET(value)   (((value) & 0x00000e00) >> 9)
#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET(value)   (((value) << 9) & 0x00000e00)
#define ALT_CLKMGR_PERPLL_DIV_OFST   0x24
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_LSB   0
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_MSB   23
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_WIDTH   24
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET_MSK   0x00ffffff
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_CLR_MSK   0xff000000
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_RESET   0x1
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_GET(value)   (((value) & 0x00ffffff) >> 0)
#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET(value)   (((value) << 0) & 0x00ffffff)
#define ALT_CLKMGR_PERPLL_GPIODIV_OFST   0x28
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK   0x0
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK   0x1
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK   0x2
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_LSB   0
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_MSB   1
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_WIDTH   2
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET_MSK   0x00000003
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_CLR_MSK   0xfffffffc
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_RESET   0x1
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_GET(value)   (((value) & 0x00000003) >> 0)
#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET(value)   (((value) << 0) & 0x00000003)
#define ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK   0x0
#define ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK   0x1
#define ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK   0x2
#define ALT_CLKMGR_PERPLL_SRC_NAND_LSB   2
#define ALT_CLKMGR_PERPLL_SRC_NAND_MSB   3
#define ALT_CLKMGR_PERPLL_SRC_NAND_WIDTH   2
#define ALT_CLKMGR_PERPLL_SRC_NAND_SET_MSK   0x0000000c
#define ALT_CLKMGR_PERPLL_SRC_NAND_CLR_MSK   0xfffffff3
#define ALT_CLKMGR_PERPLL_SRC_NAND_RESET   0x1
#define ALT_CLKMGR_PERPLL_SRC_NAND_GET(value)   (((value) & 0x0000000c) >> 2)
#define ALT_CLKMGR_PERPLL_SRC_NAND_SET(value)   (((value) << 2) & 0x0000000c)
#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK   0x0
#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK   0x1
#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK   0x2
#define ALT_CLKMGR_PERPLL_SRC_QSPI_LSB   4
#define ALT_CLKMGR_PERPLL_SRC_QSPI_MSB   5
#define ALT_CLKMGR_PERPLL_SRC_QSPI_WIDTH   2
#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET_MSK   0x00000030
#define ALT_CLKMGR_PERPLL_SRC_QSPI_CLR_MSK   0xffffffcf
#define ALT_CLKMGR_PERPLL_SRC_QSPI_RESET   0x1
#define ALT_CLKMGR_PERPLL_SRC_QSPI_GET(value)   (((value) & 0x00000030) >> 4)
#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET(value)   (((value) << 4) & 0x00000030)
#define ALT_CLKMGR_PERPLL_SRC_OFST   0x2c
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE   0x0
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD   0x1
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_LSB   0
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_MSB   5
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_WIDTH   6
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET_MSK   0x0000003f
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_CLR_MSK   0xffffffc0
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_RESET   0x0
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_GET(value)   (((value) & 0x0000003f) >> 0)
#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET(value)   (((value) << 0) & 0x0000003f)
#define ALT_CLKMGR_PERPLL_STAT_OFST   0x30
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_LSB   0
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_MSB   0
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET_MSK   0x00000001
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_RESET   0x1
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_SDRPLL_VCO_EN_LSB   1
#define ALT_CLKMGR_SDRPLL_VCO_EN_MSB   1
#define ALT_CLKMGR_SDRPLL_VCO_EN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_VCO_EN_SET_MSK   0x00000002
#define ALT_CLKMGR_SDRPLL_VCO_EN_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_SDRPLL_VCO_EN_RESET   0x0
#define ALT_CLKMGR_SDRPLL_VCO_EN_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_SDRPLL_VCO_EN_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_LSB   2
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_MSB   2
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET_MSK   0x00000004
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_RESET   0x1
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_LSB   3
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_MSB   15
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_WIDTH   13
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET_MSK   0x0000fff8
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_CLR_MSK   0xffff0007
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_RESET   0x1
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_GET(value)   (((value) & 0x0000fff8) >> 3)
#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET(value)   (((value) << 3) & 0x0000fff8)
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_LSB   16
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_MSB   21
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_WIDTH   6
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET_MSK   0x003f0000
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_CLR_MSK   0xffc0ffff
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_RESET   0x1
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_GET(value)   (((value) & 0x003f0000) >> 16)
#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET(value)   (((value) << 16) & 0x003f0000)
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1   0x0
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2   0x1
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF   0x2
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_LSB   22
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_MSB   23
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_WIDTH   2
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET_MSK   0x00c00000
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_CLR_MSK   0xff3fffff
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_RESET   0x0
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_GET(value)   (((value) & 0x00c00000) >> 22)
#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET(value)   (((value) << 22) & 0x00c00000)
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_LSB   24
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_MSB   24
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_WIDTH   1
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET_MSK   0x01000000
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_CLR_MSK   0xfeffffff
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_RESET   0x0
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_GET(value)   (((value) & 0x01000000) >> 24)
#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET(value)   (((value) << 24) & 0x01000000)
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_LSB   25
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_MSB   30
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_WIDTH   6
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET_MSK   0x7e000000
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_CLR_MSK   0x81ffffff
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_RESET   0x0
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_GET(value)   (((value) & 0x7e000000) >> 25)
#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET(value)   (((value) << 25) & 0x7e000000)
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_LSB   31
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_MSB   31
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_WIDTH   1
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET_MSK   0x80000000
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_CLR_MSK   0x7fffffff
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_RESET   0x1
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_GET(value)   (((value) & 0x80000000) >> 31)
#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET(value)   (((value) << 31) & 0x80000000)
#define ALT_CLKMGR_SDRPLL_VCO_OFST   0x0
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_LSB   0
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_MSB   0
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET_MSK   0x00000001
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_RESET   0x0
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_LSB   1
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_MSB   12
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_WIDTH   12
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET_MSK   0x00001ffe
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_CLR_MSK   0xffffe001
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_RESET   0x1
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_GET(value)   (((value) & 0x00001ffe) >> 1)
#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET(value)   (((value) << 1) & 0x00001ffe)
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_LSB   13
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_MSB   13
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET_MSK   0x00002000
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_CLR_MSK   0xffffdfff
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_RESET   0x0
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_GET(value)   (((value) & 0x00002000) >> 13)
#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET(value)   (((value) << 13) & 0x00002000)
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_LSB   14
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_MSB   14
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_WIDTH   1
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET_MSK   0x00004000
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_CLR_MSK   0xffffbfff
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_RESET   0x1
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_GET(value)   (((value) & 0x00004000) >> 14)
#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET(value)   (((value) << 14) & 0x00004000)
#define ALT_CLKMGR_SDRPLL_CTL_OFST   0x4
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_LSB   0
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_MSB   8
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_WIDTH   9
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_RESET   0x1
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_LSB   9
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_MSB   20
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_WIDTH   12
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET_MSK   0x001ffe00
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_CLR_MSK   0xffe001ff
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_RESET   0x0
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_GET(value)   (((value) & 0x001ffe00) >> 9)
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET(value)   (((value) << 9) & 0x001ffe00)
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST   0x8
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_LSB   0
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_MSB   8
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_WIDTH   9
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_RESET   0x1
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_LSB   9
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_MSB   20
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_WIDTH   12
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET_MSK   0x001ffe00
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_CLR_MSK   0xffe001ff
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_RESET   0x0
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_GET(value)   (((value) & 0x001ffe00) >> 9)
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET(value)   (((value) << 9) & 0x001ffe00)
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST   0xc
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_LSB   0
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_MSB   8
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_WIDTH   9
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_RESET   0x1
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_LSB   9
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_MSB   20
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_WIDTH   12
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET_MSK   0x001ffe00
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_CLR_MSK   0xffe001ff
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_RESET   0x0
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_GET(value)   (((value) & 0x001ffe00) >> 9)
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET(value)   (((value) << 9) & 0x001ffe00)
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST   0x10
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_LSB   0
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_MSB   8
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_WIDTH   9
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET_MSK   0x000001ff
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_CLR_MSK   0xfffffe00
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_RESET   0x1
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0)
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET(value)   (((value) << 0) & 0x000001ff)
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_LSB   9
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_MSB   20
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_WIDTH   12
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET_MSK   0x001ffe00
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_CLR_MSK   0xffe001ff
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_RESET   0x0
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_GET(value)   (((value) & 0x001ffe00) >> 9)
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET(value)   (((value) << 9) & 0x001ffe00)
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST   0x14
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_LSB   0
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_MSB   0
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_WIDTH   1
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET_MSK   0x00000001
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_CLR_MSK   0xfffffffe
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_RESET   0x1
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_GET(value)   (((value) & 0x00000001) >> 0)
#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET(value)   (((value) << 0) & 0x00000001)
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_LSB   1
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_MSB   1
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_WIDTH   1
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET_MSK   0x00000002
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_CLR_MSK   0xfffffffd
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_RESET   0x1
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_GET(value)   (((value) & 0x00000002) >> 1)
#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET(value)   (((value) << 1) & 0x00000002)
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_LSB   2
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_MSB   2
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_WIDTH   1
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET_MSK   0x00000004
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_CLR_MSK   0xfffffffb
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_RESET   0x1
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_GET(value)   (((value) & 0x00000004) >> 2)
#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET(value)   (((value) << 2) & 0x00000004)
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_LSB   3
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_MSB   3
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_WIDTH   1
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET_MSK   0x00000008
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_CLR_MSK   0xfffffff7
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_RESET   0x1
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_GET(value)   (((value) & 0x00000008) >> 3)
#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET(value)   (((value) << 3) & 0x00000008)
#define ALT_CLKMGR_SDRPLL_EN_OFST   0x18
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE   0x0
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD   0x1
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_LSB   0
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_MSB   5
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_WIDTH   6
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET_MSK   0x0000003f
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_CLR_MSK   0xffffffc0
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_RESET   0x0
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_GET(value)   (((value) & 0x0000003f) >> 0)
#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET(value)   (((value) << 0) & 0x0000003f)
#define ALT_CLKMGR_SDRPLL_STAT_OFST   0x1c
typedef volatile struct ALT_CLKMGR_CTL_s ALT_CLKMGR_CTL_t
typedef volatile struct ALT_CLKMGR_BYPASS_s ALT_CLKMGR_BYPASS_t
typedef volatile struct ALT_CLKMGR_INTER_s ALT_CLKMGR_INTER_t
typedef volatile struct ALT_CLKMGR_INTREN_s ALT_CLKMGR_INTREN_t
typedef volatile struct ALT_CLKMGR_DBCTL_s ALT_CLKMGR_DBCTL_t
typedef volatile struct ALT_CLKMGR_STAT_s ALT_CLKMGR_STAT_t
typedef volatile struct ALT_CLKMGR_MAINPLL_VCO_s ALT_CLKMGR_MAINPLL_VCO_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MISC_s ALT_CLKMGR_MAINPLL_MISC_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MPUCLK_s ALT_CLKMGR_MAINPLL_MPUCLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MAINCLK_s ALT_CLKMGR_MAINPLL_MAINCLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_DBGATCLK_s ALT_CLKMGR_MAINPLL_DBGATCLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MAINQSPICLK_s ALT_CLKMGR_MAINPLL_MAINQSPICLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_s ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_s ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_t
typedef volatile struct ALT_CLKMGR_MAINPLL_EN_s ALT_CLKMGR_MAINPLL_EN_t
typedef volatile struct ALT_CLKMGR_MAINPLL_MAINDIV_s ALT_CLKMGR_MAINPLL_MAINDIV_t
typedef volatile struct ALT_CLKMGR_MAINPLL_DBGDIV_s ALT_CLKMGR_MAINPLL_DBGDIV_t
typedef volatile struct ALT_CLKMGR_MAINPLL_TRACEDIV_s ALT_CLKMGR_MAINPLL_TRACEDIV_t
typedef volatile struct ALT_CLKMGR_MAINPLL_L4SRC_s ALT_CLKMGR_MAINPLL_L4SRC_t
typedef volatile struct ALT_CLKMGR_MAINPLL_STAT_s ALT_CLKMGR_MAINPLL_STAT_t
typedef volatile struct ALT_CLKMGR_MAINPLL_s ALT_CLKMGR_MAINPLL_t
typedef volatile struct ALT_CLKMGR_MAINPLL_raw_s ALT_CLKMGR_MAINPLL_raw_t
typedef volatile struct ALT_CLKMGR_PERPLL_VCO_s ALT_CLKMGR_PERPLL_VCO_t
typedef volatile struct ALT_CLKMGR_PERPLL_MISC_s ALT_CLKMGR_PERPLL_MISC_t
typedef volatile struct ALT_CLKMGR_PERPLL_EMAC0CLK_s ALT_CLKMGR_PERPLL_EMAC0CLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_EMAC1CLK_s ALT_CLKMGR_PERPLL_EMAC1CLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_PERQSPICLK_s ALT_CLKMGR_PERPLL_PERQSPICLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_s ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_PERBASECLK_s ALT_CLKMGR_PERPLL_PERBASECLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_S2FUSER1CLK_s ALT_CLKMGR_PERPLL_S2FUSER1CLK_t
typedef volatile struct ALT_CLKMGR_PERPLL_EN_s ALT_CLKMGR_PERPLL_EN_t
typedef volatile struct ALT_CLKMGR_PERPLL_DIV_s ALT_CLKMGR_PERPLL_DIV_t
typedef volatile struct ALT_CLKMGR_PERPLL_GPIODIV_s ALT_CLKMGR_PERPLL_GPIODIV_t
typedef volatile struct ALT_CLKMGR_PERPLL_SRC_s ALT_CLKMGR_PERPLL_SRC_t
typedef volatile struct ALT_CLKMGR_PERPLL_STAT_s ALT_CLKMGR_PERPLL_STAT_t
typedef volatile struct ALT_CLKMGR_PERPLL_s ALT_CLKMGR_PERPLL_t
typedef volatile struct ALT_CLKMGR_PERPLL_raw_s ALT_CLKMGR_PERPLL_raw_t
typedef volatile struct ALT_CLKMGR_SDRPLL_VCO_s ALT_CLKMGR_SDRPLL_VCO_t
typedef volatile struct ALT_CLKMGR_SDRPLL_CTL_s ALT_CLKMGR_SDRPLL_CTL_t
typedef volatile struct ALT_CLKMGR_SDRPLL_DDRDQSCLK_s ALT_CLKMGR_SDRPLL_DDRDQSCLK_t
typedef volatile struct ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_s ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_t
typedef volatile struct ALT_CLKMGR_SDRPLL_DDRDQCLK_s ALT_CLKMGR_SDRPLL_DDRDQCLK_t
typedef volatile struct ALT_CLKMGR_SDRPLL_S2FUSER2CLK_s ALT_CLKMGR_SDRPLL_S2FUSER2CLK_t
typedef volatile struct ALT_CLKMGR_SDRPLL_EN_s ALT_CLKMGR_SDRPLL_EN_t
typedef volatile struct ALT_CLKMGR_SDRPLL_STAT_s ALT_CLKMGR_SDRPLL_STAT_t
typedef volatile struct ALT_CLKMGR_SDRPLL_s ALT_CLKMGR_SDRPLL_t
typedef volatile struct ALT_CLKMGR_SDRPLL_raw_s ALT_CLKMGR_SDRPLL_raw_t
typedef volatile struct ALT_CLKMGR_s ALT_CLKMGR_t
typedef volatile struct ALT_CLKMGR_raw_s ALT_CLKMGR_raw_t
