RTEMS 5.2-rc1
Macros | Functions
afec.h File Reference
#include <assert.h>
#include <stdint.h>
#define AFEC_MR_SETTLING_Pos   20
#define AFEC_MR_SETTLING_Msk   (0x3u << AFEC_MR_SETTLING_Pos)
 (AFEC_MR) Trigger Selection
#define AFEC_MR_SETTLING_AST3   (0x0u << 20)
 (AFEC_MR) ADC_SETTLING_AST3 3 periods of AFEClock
#define AFEC_MR_SETTLING_AST5   (0x1u << 20)
 (AFEC_MR) ADC_SETTLING_AST5 5 periods of AFEClock
#define AFEC_MR_SETTLING_AST9   (0x2u << 20)
 (AFEC_MR) ADC_SETTLING_AST9 9 periods of AFEClock
#define AFEC_MR_SETTLING_AST17   (0x3u << 20)
 (AFEC_MR) ADC_SETTLING_AST17 17 periods of AFEClock
#define AFEC_EMR_STM_Pos   25
#define AFEC_EMR_STM_Msk   (0x1u << AFEC_EMR_STM_Pos)
 (AFEC_EMR) Single Trigger Mode
#define AFEC_EMR_STM_MULTI_TRIG   (0x0u << 25)
 (AFEC_EMR) Single Trigger Mode: Multiple triggers are required to get an averaged result.
#define AFEC_EMR_STM_SINGLE_TRIG   (0x1u << 25)
 (AFEC_EMR) Single Trigger Mode: Only a Single Trigger is required to get an averaged value.
#define AFEC_EMR_TAG_Pos   24
#define AFEC_EMR_TAG_Msk   (0x1u << AFEC_EMR_TAG_Pos)
 (AFEC_EMR) TAG of the AFEC_LDCR Register
#define AFEC_EMR_TAG_CHNB_ZERO   (0x0u << 24)
 (AFEC_EMR) TAG of the AFEC_LDCR Register: Sets CHNB to zero in AFEC_LDCR.
#define AFEC_EMR_TAG_APPENDS   (0x1u << 24)
 (AFEC_EMR) TAG of the AFEC_LDCR Register: Appends the channel number to the conversion result in AFEC_LDCR register.
#define AFEC_EMR_CMPALL_Pos   9
#define AFEC_EMR_CMPALL_Msk   (0x1u << AFEC_EMR_TAG_Pos)
 (AFEC_EMR) Compare All Channels
#define AFEC_EMR_CMPALL_ONE_CHANNEL_COMP   (0x0u << 9)
 (AFEC_EMR) Compare All Channels: Only channel indicated in CMPSEL field is compared.
#define AFEC_EMR_CMPALL_ALL_CHANNELS_COMP   (0x1u << 9)
 (AFEC_EMR) Compare All Channels: All channels are compared.
#define AFEC_ACR_PGA0_ON   (0x1u << 2)
#define AFEC_ACR_PGA1_ON   (0x1u << 3)
#define AFEC_GetModeReg(pAFEC)   ((pAFEC)->AFEC_MR)
#define AFEC_SetModeReg(pAFEC, mode)   ((pAFEC)->AFEC_MR = mode)
#define AFEC_GetExtModeReg(pAFEC)   ((pAFEC)->AFEC_EMR)
#define AFEC_SetExtModeReg(pAFEC, mode)   ((pAFEC)->AFEC_EMR = mode)
#define AFEC_StartConversion(pAFEC)   ((pAFEC)->AFEC_CR = AFEC_CR_START)
#define AFEC_EnableChannel(pAFEC, dwChannel)
#define AFEC_DisableChannel(pAFEC, dwChannel)
#define AFEC_EnableIt(pAFEC, dwMode)
#define AFEC_DisableIt(pAFEC, dwMode)
#define AFEC_SetChannelGain(pAFEC, dwMode)
#define AFEC_EnableDataReadyIt(pAFEC)   ((pAFEC)->AFEC_IER = AFEC_IER_DRDY)
#define AFEC_GetStatus(pAFEC)   ((pAFEC)->AFEC_ISR)
#define AFEC_GetCompareMode(pAFEC)   (((pAFEC)->AFEC_EMR)& (AFEC_EMR_CMPMODE_Msk))
#define AFEC_GetChannelStatus(pAFEC)   ((pAFEC)->AFEC_CHSR)
#define AFEC_GetInterruptMaskStatus(pAFEC)   ((pAFEC)->AFEC_IMR)
#define AFEC_GetLastConvertedData(pAFEC)   ((pAFEC)->AFEC_LCDR)
void AFEC_Initialize (Afec *pAFEC, uint32_t dwId)
 Initialize the AFE controller. More...
uint32_t AFEC_SetClock (Afec *pAFEC, uint32_t dwPres, uint32_t dwMck)
 Set AFE clock. More...
void AFEC_SetTiming (Afec *pAFEC, uint32_t dwStartup, uint32_t dwTracking, uint32_t dwSettling)
 Set AFE timing. More...
void AFEC_SetTrigger (Afec *pAFEC, uint32_t dwTrgSel)
 Set AFE trigger. More...
void AFEC_SetAnalogChange (Afec *pAFE, uint8_t bEnDis)
 Set analog change. IF enabled, it allows different analog settings for each channel, otherwise, DIFF0, GAIN0 and OFF0 are used for all channels. More...
void AFEC_SetSleepMode (Afec *pAFEC, uint8_t bEnDis)
 Enable/Disable sleep mode. More...
void AFEC_SetFastWakeup (Afec *pAFEC, uint8_t bEnDis)
 Enable/Disable fast wake up. More...
void AFEC_SetSequenceMode (Afec *pAFEC, uint8_t bEnDis)
 Enable/Disable sequence mode. More...
void AFEC_SetSequence (Afec *pAFEC, uint32_t dwSEQ1, uint32_t dwSEQ2)
 Set channel sequence. More...
void AFEC_SetSequenceByList (Afec *pAFEC, uint8_t ucChList[], uint8_t ucNumCh)
 Set channel sequence by given channel list. More...
void AFEC_SetTagEnable (Afec *pAFEC, uint8_t bEnDis)
 Set "TAG" mode, show channel number in last data or not. More...
void AFEC_SetCompareChannel (Afec *pAFEC, uint32_t dwChannel)
 Set compare channel. More...
void AFEC_SetCompareMode (Afec *pAFEC, uint32_t dwMode)
 Set compare mode. More...
void AFEC_SetComparisonWindow (Afec *pAFEC, uint32_t dwHi_Lo)
 Set comparison window. More...
uint8_t AFEC_CheckConfiguration (Afec *pAFEC, uint32_t dwMcK)
uint32_t AFEC_GetConvertedData (Afec *pAFEC, uint32_t dwChannel)
 Return the Channel Converted Data. More...
void AFEC_SetStartupTime (Afec *pAFEC, uint32_t dwUs)
void AFEC_SetTrackingTime (Afec *pAFEC, uint32_t dwNs)
void AFEC_SetAnalogOffset (Afec *pAFE, uint32_t dwChannel, uint32_t aoffset)
 Set analog offset to be used for channel CSEL. More...
void AFEC_SetAnalogControl (Afec *pAFE, uint32_t control)
Purpose
Interface for configuration the Analog-to-Digital Converter (AFEC) peripheral.
Usage
  1. Configurate the pins for AFEC.
  2. Initialize the AFEC with AFEC_Initialize().
  3. Set AFEC clock and timing with AFEC_SetClock() and AFEC_SetTiming().
  4. Select the active channel using AFEC_EnableChannel().
  5. Start the conversion with AFEC_StartConversion().
  6. Wait the end of the conversion by polling status with AFEC_GetStatus().
  7. Finally, get the converted data using AFEC_GetConvertedData() or AFEC_GetLastConvertedData().
◆ AFEC_DisableChannel
#define AFEC_DisableChannel (   pAFEC,
  dwChannel
Value:
(pAFEC)->AFEC_CHDR = (1 << (dwChannel));\
◆ AFEC_DisableIt
#define AFEC_DisableIt (   pAFEC,
  dwMode
Value:
(pAFEC)->AFEC_IDR = (dwMode);\
◆ AFEC_EnableChannel
#define AFEC_EnableChannel (   pAFEC,
  dwChannel
Value:
(pAFEC)->AFEC_CHER = (1 << (dwChannel));\
◆ AFEC_EnableIt
#define AFEC_EnableIt (   pAFEC,
  dwMode
Value:
(pAFEC)->AFEC_IER = (dwMode);\
◆ AFEC_SetChannelGain
#define AFEC_SetChannelGain (   pAFEC,
  dwMode
Value:
(pAFEC)->AFEC_CGR = dwMode;\
◆ AFEC_GetConvertedData()
uint32_t AFEC_GetConvertedData ( Afec pAFE,
uint32_t  dwChannel
Parameters
pAFEPointer to an AFE instance.
dwChannelchannel to get converted value
◆ AFEC_Initialize()
void AFEC_Initialize ( Afec pAFE,
uint32_t  dwID
Parameters
dwIDAFE Index
◆ AFEC_SetAnalogChange()
void AFEC_SetAnalogChange ( Afec pAFE,
uint8_t  bEnDis
Parameters
bEnDisEnable/Disable.
◆ AFEC_SetAnalogControl()
void AFEC_SetAnalogControl ( Afec pAFE,
uint32_t  control
Parameters
afecBase address of the AFEC.
controlAnalog control value.
◆ AFEC_SetAnalogOffset()
void AFEC_SetAnalogOffset ( Afec pAFE,
uint32_t  dwChannel,
uint32_t  aoffset
Parameters
dwChannelAFEC channel number.
aoffsetAnalog offset value.
◆ AFEC_SetClock()
uint32_t AFEC_SetClock ( Afec pAFE,
uint32_t  dwClk,
uint32_t  dwMck
Set AFE clock.
Parameters
dwPresprescale value
dwMckBoard MCK (Hz)
Returns
AFE clock
◆ AFEC_SetCompareChannel()
void AFEC_SetCompareChannel ( Afec pAFE,
uint32_t  dwChannel
Parameters
dwChannelchannel number to be set,16 for all channels
◆ AFEC_SetCompareMode()
void AFEC_SetCompareMode ( Afec pAFE,
uint32_t  dwMode
Set compare mode.
Parameters
dwModecompare mode
◆ AFEC_SetComparisonWindow()
void AFEC_SetComparisonWindow ( Afec pAFE,
uint32_t  dwHi_Lo
Parameters
dwHi_LoComparison Window
◆ AFEC_SetFastWakeup()
void AFEC_SetFastWakeup ( Afec pAFE,
uint8_t  bEnDis
Parameters
bEnDisEnable/Disable fast wake up in sleep mode.
◆ AFEC_SetSequence()
void AFEC_SetSequence ( Afec pAFE,
uint32_t  dwSEQ1,
uint32_t  dwSEQ2
Parameters
dwSEQ1Sequence 1 ~ 8 channel number.
dwSEQ2Sequence 9 ~ 16 channel number.
◆ AFEC_SetSequenceByList()
void AFEC_SetSequenceByList ( Afec pAFE,
uint8_t  ucChList[],
uint8_t  ucNumCh
Parameters
ucChListChannel list.
ucNumChNumber of channels in list.
◆ AFEC_SetSequenceMode()
void AFEC_SetSequenceMode ( Afec pAFE,
uint8_t  bEnDis
Parameters
bEnDisEnable/Disable sequence mode.
◆ AFEC_SetSleepMode()
void AFEC_SetSleepMode ( Afec pAFE,
uint8_t  bEnDis
Parameters
bEnDisEnable/Disable sleep mode.
◆ AFEC_SetStartupTime()
void AFEC_SetStartupTime ( Afec pAFE,
uint32_t  dwUs
Sets the AFE startup time.
Parameters
dwUsStartup time in uS.
◆ AFEC_SetTagEnable()
void AFEC_SetTagEnable ( Afec pAFE,
uint8_t  bEnDis
Parameters
bEnDisEnable/Disable TAG value.
◆ AFEC_SetTiming()
void AFEC_SetTiming ( Afec pAFE,
uint32_t  dwStartup,
uint32_t  dwSettling
Set AFE timing.
Parameters
dwStartupstartup value
dwTrackingtracking value
dwSettlingsettling value
◆ AFEC_SetTrackingTime()
void AFEC_SetTrackingTime ( Afec pAFE,
uint32_t  dwNs
Set AFE tracking time
Parameters
dwNsTracking time in nS.
◆ AFEC_SetTrigger()
void AFEC_SetTrigger ( Afec pAFE,
uint32_t  dwTrgSel
Set AFE trigger.
Parameters
dwTrgSelTrigger selection
