RTEMS 5.2-rc1
3c509.h File Reference
3C509 PC card support. More...
#define F_RX_FIRST   0x1
#define F_PROMISC   0x8
#define F_ACCESS_32_BITS   0x100
#define TX_INIT_RATE   16
#define TX_INIT_MAX_RATE   64
#define RX_INIT_LATENCY   64
#define RX_INIT_EARLY_THRESH   208 /* not less than MINCLSIZE */
#define RX_NEXT_EARLY_THRESH   500
#define EEPROMSIZE   0x40
#define MAX_EEPROMBUSY   1000
#define EP_LAST_TAG   0xd7
#define EP_MAX_BOARDS   16
#define EP_ID_PORT   0x110
#define EP_IOSIZE   16 /* 16 bytes of I/O space used. */
#define IS_BASE   (is->id_iobase)
#define BASE   (sc->ep_io_addr)
#define EEPROM_CMD_RD   0x0080 /* Read: Address required (5 bits) */
#define EEPROM_CMD_WR   0x0040 /* Write: Address required (5 bits) */
#define EEPROM_CMD_ERASE   0x00c0 /* Erase: Address required (5 bits) */
#define EEPROM_CMD_EWEN   0x0030 /* Erase/Write Enable: No data required */
#define EEPROM_BUSY   (1<<15)
#define EEPROM_TST_MODE   (1<<14)
#define is_eeprom_busy(b)   (inw((b)+EP_W0_EEPROM_COMMAND)&EEPROM_BUSY)
#define GO_WINDOW(x)   outw(BASE+EP_COMMAND, WINDOW_SELECT|(x))
#define EEPROM_NODE_ADDR_0   0x0 /* Word */
#define EEPROM_NODE_ADDR_1   0x1 /* Word */
#define EEPROM_NODE_ADDR_2   0x2 /* Word */
#define EEPROM_PROD_ID   0x3 /* 0x9[0-f]50 */
#define EEPROM_MFG_ID   0x7 /* 0x6d50 */
#define EEPROM_ADDR_CFG   0x8 /* Base addr */
#define EEPROM_RESOURCE_CFG   0x9 /* IRQ. Bits 12-15 */
#define EP_COMMAND
#define EP_STATUS
#define EP_WINDOW
#define EP_W0_EEPROM_DATA   0x0c
#define EP_W0_EEPROM_COMMAND   0x0a
#define EP_W0_RESOURCE_CFG   0x08
#define EP_W0_ADDRESS_CFG   0x06
#define EP_W0_CONFIG_CTRL   0x04
#define EP_W0_PRODUCT_ID   0x02
#define EP_W0_MFG_ID   0x00
#define EP_W1_TX_PIO_WR_2   0x02
#define EP_W1_TX_PIO_WR_1   0x00
#define EP_W1_FREE_TX   0x0c
#define EP_W1_TX_STATUS   0x0b /* byte */
#define EP_W1_TIMER   0x0a /* byte */
#define EP_W1_RX_STATUS   0x08
#define EP_W1_RX_PIO_RD_2   0x02
#define EP_W1_RX_PIO_RD_1   0x00
#define EP_W2_ADDR_5   0x05
#define EP_W2_ADDR_4   0x04
#define EP_W2_ADDR_3   0x03
#define EP_W2_ADDR_2   0x02
#define EP_W2_ADDR_1   0x01
#define EP_W2_ADDR_0   0x00
#define EP_W3_FREE_TX   0x0c
#define EP_W3_FREE_RX   0x0a
#define EP_W4_MEDIA_TYPE   0x0a
#define EP_W4_CTRLR_STATUS   0x08
#define EP_W4_NET_DIAG   0x06
#define EP_W4_FIFO_DIAG   0x04
#define EP_W4_HOST_DIAG   0x02
#define EP_W4_TX_DIAG   0x00
#define EP_W5_READ_0_MASK   0x0c
#define EP_W5_INTR_MASK   0x0a
#define EP_W5_RX_FILTER   0x08
#define EP_W5_RX_EARLY_THRESH   0x06
#define EP_W5_TX_AVAIL_THRESH   0x02
#define EP_W5_TX_START_THRESH   0x00
#define TX_TOTAL_OK   0x0c
#define RX_TOTAL_OK   0x0a
#define TX_DEFERRALS   0x08
#define RX_FRAMES_OK   0x07
#define TX_FRAMES_OK   0x06
#define RX_OVERRUNS   0x05
#define TX_COLLISIONS   0x04
#define TX_AFTER_1_COLLISION   0x03
#define TX_AFTER_X_COLLISIONS   0x02
#define TX_NO_SQE   0x01
#define TX_CD_LOST   0x00
#define GLOBAL_RESET
#define WINDOW_SELECT   (u_short) (0x1<<11)
#define START_TRANSCEIVER
#define RX_DISABLE
#define RX_ENABLE   (u_short) (0x4<<11)
#define RX_RESET   (u_short) (0x5<<11)
#define RX_DISCARD_TOP_PACK   (u_short) (0x8<<11)
#define TX_ENABLE   (u_short) (0x9<<11)
#define TX_DISABLE   (u_short) (0xa<<11)
#define TX_RESET   (u_short) (0xb<<11)
#define REQ_INTR   (u_short) (0xc<<11)
#define SET_INTR_MASK   (u_short) (0xe<<11)
#define SET_RD_0_MASK   (u_short) (0xf<<11)
#define SET_RX_FILTER   (u_short) (0x10<<11)
#define FIL_INDIVIDUAL   (u_short) (0x1)
#define FIL_GROUP   (u_short) (0x2)
#define FIL_BRDCST   (u_short) (0x4)
#define FIL_ALL   (u_short) (0x8)
#define SET_RX_EARLY_THRESH   (u_short) (0x11<<11)
#define SET_TX_AVAIL_THRESH   (u_short) (0x12<<11)
#define SET_TX_START_THRESH   (u_short) (0x13<<11)
#define STATS_ENABLE   (u_short) (0x15<<11)
#define STATS_DISABLE   (u_short) (0x16<<11)
#define STOP_TRANSCEIVER   (u_short) (0x17<<11)
#define ACK_INTR   (u_short) (0x6800)
#define C_INTR_LATCH   (u_short) (ACK_INTR|0x1)
#define C_CARD_FAILURE   (u_short) (ACK_INTR|0x2)
#define C_TX_COMPLETE   (u_short) (ACK_INTR|0x4)
#define C_TX_AVAIL   (u_short) (ACK_INTR|0x8)
#define C_RX_COMPLETE   (u_short) (ACK_INTR|0x10)
#define C_RX_EARLY   (u_short) (ACK_INTR|0x20)
#define C_INT_RQD   (u_short) (ACK_INTR|0x40)
#define C_UPD_STATS   (u_short) (ACK_INTR|0x80)
#define C_MASK   (u_short) 0xFF /* mask of C_* */
#define S_INTR_LATCH   (u_short) (0x1)
#define S_CARD_FAILURE   (u_short) (0x2)
#define S_TX_COMPLETE   (u_short) (0x4)
#define S_TX_AVAIL   (u_short) (0x8)
#define S_RX_COMPLETE   (u_short) (0x10)
#define S_RX_EARLY   (u_short) (0x20)
#define S_INT_RQD   (u_short) (0x40)
#define S_UPD_STATS   (u_short) (0x80)
#define S_MASK   (u_short) 0xFF /* mask of S_* */
#define S_5_INTS
#define S_COMMAND_IN_PROGRESS   (u_short) (0x1000)
#define ACF_CONNECTOR_BITS   14
#define ACF_CONNECTOR_UTP   0
#define ACF_CONNECTOR_AUI   1
#define ACF_CONNECTOR_BNC   3
#define SET_IRQ(base, irq)
#define ERR_RX_INCOMPLETE   (u_short) (0x1<<15)
#define ERR_RX   (u_short) (0x1<<14)
#define ERR_RX_OVERRUN   (u_short) (0x8<<11)
#define ERR_RX_RUN_PKT   (u_short) (0xb<<11)
#define ERR_RX_ALIGN   (u_short) (0xc<<11)
#define ERR_RX_CRC   (u_short) (0xd<<11)
#define ERR_RX_OVERSIZE   (u_short) (0x9<<11)
#define ERR_RX_DRIBBLE   (u_short) (0x2<<11)
#define TXS_COMPLETE   0x80
#define TXS_SUCCES_INTR_REQ   0x40
#define TXS_JABBER   0x20
#define TXS_UNDERRUN   0x10
#define TXS_MAX_COLLISION   0x8
#define TXS_STATUS_OVERFLOW   0x4
#define IS_AUI   (1<<13)
#define IS_BNC   (1<<12)
#define IS_UTP   (1<<9)
#define ENABLE_DRQ_IRQ   0x0001
#define W0_P4_CMD_RESET_ADAPTER   0x4
#define W0_P4_CMD_ENABLE_ADAPTER   0x1
#define ENABLE_UTP   0xc0
#define DISABLE_UTP   0x0
#define ACTIVATE_ADAPTER_TO_CONFIG   0xff /* to the id_port */
#define MFG_ID   0x6d50 /* in EEPROM and W0 ADDR_CONFIG */
#define PROD_ID   0x9150
#define AUI   0x1
#define BNC   0x2
#define UTP   0x4
#define RX_BYTES_MASK   (u_short) (0x07ff)
◆ EP_COMMAND
#define EP_COMMAND
Value:
0x0e /* Write. BASE+0x0e is always a
* command reg. */
◆ EP_STATUS
#define EP_STATUS
Value:
0x0e /* Read. BASE+0x0e is always status
* reg. */
◆ EP_WINDOW
#define EP_WINDOW
Value:
0x0f /* Read. BASE+0x0f is always window
* reg. */
◆ GLOBAL_RESET
Value:
(u_short) 0x0000 /* Wait at least 1ms
* after issuing */
◆ RX_DISABLE
#define RX_DISABLE
Value:
(u_short) (0x3<<11) /* state disabled on
* power-up */
◆ S_5_INTS
#define S_5_INTS
Value:
(S_CARD_FAILURE|S_TX_COMPLETE|\
S_TX_AVAIL|S_RX_COMPLETE|S_RX_EARLY)
◆ SET_IRQ
#define SET_IRQ (   base,
  irq
Value:
outw((base) + EP_W0_RESOURCE_CFG, \
((inw((base) + EP_W0_RESOURCE_CFG) & 0x0fff) | \
((u_short)(irq)<<12)) ) /* set IRQ i */
◆ START_TRANSCEIVER
Value:
(u_short) (0x2<<11) /* Read ADDR_CFG reg to
* determine whether
* this is needed. If
* so; wait 800 uSec
* before using trans-
* ceiver. */
