21. Services Provided by C Library (libc)
21.1. Introduction
This section lists the routines that provided by the Newlib C Library.
21.2. Standard Utility Functions (stdlib.h)
  • abort - Abnormal termination of a program
  • abs - Integer absolute value (magnitude)
  • assert - Macro for Debugging Diagnostics
  • atexit - Request execution of functions at program exit
  • atof - String to double or float
  • atoi - String to integer
  • bsearch - Binary search
  • calloc - Allocate space for arrays
  • div - Divide two integers
  • ecvtbuf - Double or float to string of digits
  • ecvt - Double or float to string of digits (malloc result)
  • __env_lock - Lock environment list for getenv and setenv
  • gvcvt - Format double or float as string
  • exit - End program execution
  • getenv - Look up environment variable
  • labs - Long integer absolute value (magnitude)
  • ldiv - Divide two long integers
  • malloc - Allocate memory
  • realloc - Reallocate memory
  • free - Free previously allocated memory
  • mallinfo - Get information about allocated memory
  • __malloc_lock - Lock memory pool for malloc and free
  • mbstowcs - Minimal multibyte string to wide string converter
  • mblen - Minimal multibyte length
  • mbtowc - Minimal multibyte to wide character converter
  • qsort - Sort an array
  • rand - Pseudo-random numbers
  • strtod - String to double or float
  • strtol - String to long
  • strtoul - String to unsigned long
  • system - Execute command string
  • wcstombs - Minimal wide string to multibyte string converter
  • wctomb - Minimal wide character to multibyte converter
21.3. Character Type Macros and Functions (ctype.h)
  • isalnum - Alphanumeric character predicate
  • isalpha - Alphabetic character predicate
  • isascii - ASCII character predicate
  • iscntrl - Control character predicate
  • isdigit - Decimal digit predicate
  • islower - Lower-case character predicate
  • isprint - Printable character predicates (isprint, isgraph)
  • ispunct - Punctuation character predicate
  • isspace - Whitespace character predicate
  • isupper - Uppercase character predicate
  • isxdigit - Hexadecimal digit predicate
  • toascii - Force integers to ASCII range
  • tolower - Translate characters to lower case
  • toupper - Translate characters to upper case
21.4. Input and Output (stdio.h)
  • clearerr - Clear file or stream error indicator
  • fclose - Close a file
  • feof - Test for end of file
  • ferror - Test whether read/write error has occurred
  • fflush - Flush buffered file output
  • fgetc - Get a character from a file or stream
  • fgetpos - Record position in a stream or file
  • fgets - Get character string from a file or stream
  • fiprintf - Write formatted output to file (integer only)
  • fopen - Open a file
  • fdopen - Turn an open file into a stream
  • fputc - Write a character on a stream or file
  • fputs - Write a character string in a file or stream
  • fread - Read array elements from a file
  • freopen - Open a file using an existing file descriptor
  • fseek - Set file position
  • fsetpos - Restore position of a stream or file
  • ftell - Return position in a stream or file
  • fwrite - Write array elements from memory to a file or stream
  • getc - Get a character from a file or stream (macro)
  • getchar - Get a character from standard input (macro)
  • gets - Get character string from standard input (obsolete)
  • iprintf - Write formatted output (integer only)
  • mktemp - Generate unused file name
  • perror - Print an error message on standard error
  • putc - Write a character on a stream or file (macro)
  • putchar - Write a character on standard output (macro)
  • puts - Write a character string on standard output
  • remove - Delete a file’s name
  • rename - Rename a file
  • rewind - Reinitialize a file or stream
  • setbuf - Specify full buffering for a file or stream
  • setvbuf - Specify buffering for a file or stream
  • siprintf - Write formatted output (integer only)
  • printf - Write formatted output
  • scanf - Scan and format input
  • tmpfile - Create a temporary file
  • tmpnam - Generate name for a temporary file
  • vprintf - Format variable argument list
21.5. Strings and Memory (string.h)
  • bcmp - Compare two memory areas
  • bcopy - Copy memory regions
  • bzero - Initialize memory to zero
  • index - Search for character in string
  • memchr - Find character in memory
  • memcmp - Compare two memory areas
  • memcpy - Copy memory regions
  • memmove - Move possibly overlapping memory
  • memset - Set an area of memory
  • rindex - Reverse search for character in string
  • strcasecmp - Compare strings ignoring case
  • strcat - Concatenate strings
  • strchr - Search for character in string
  • strcmp - Character string compare
  • strcoll - Locale specific character string compare
  • strcpy - Copy string
  • strcspn - Count chars not in string
  • strerror - Convert error number to string
  • strlen - Character string length
  • strlwr - Convert string to lower case
  • strncasecmp - Compare strings ignoring case
  • strncat - Concatenate strings
  • strncmp - Character string compare
  • strncpy - Counted copy string
  • strpbrk - Find chars in string
  • strrchr - Reverse search for character in string
  • strspn - Find initial match
  • strstr - Find string segment
  • strtok - Get next token from a string
  • strupr - Convert string to upper case
  • strxfrm - Transform string
21.6. Signal Handling (signal.h)
  • raise - Send a signal
  • signal - Specify handler subroutine for a signal
21.7. Time Functions (time.h)
  • asctime - Format time as string
  • clock - Cumulative processor time
  • ctime - Convert time to local and format as string
  • difftime - Subtract two times
  • gmtime - Convert time to UTC (GMT) traditional representation
  • localtime - Convert time to local representation
  • mktime - Convert time to arithmetic representation
  • strftime - Flexible calendar time formatter
  • time - Get current calendar time (as single number)
21.8. Locale (locale.h)
  • setlocale - Select or query locale
21.9. Reentrant Versions of Functions
  • Equivalent for errno variable: - errno_r - XXX
  • Locale functions:
    • localeconv_r - XXX
    • setlocale_r - XXX
  • Equivalents for stdio variables:
    • stdin_r - XXX
    • stdout_r - XXX
    • stderr_r - XXX
  • Stdio functions:
    • fdopen_r - XXX
    • perror_r - XXX
    • tempnam_r - XXX
    • fopen_r - XXX
    • putchar_r - XXX
    • tmpnam_r - XXX
    • getchar_r - XXX
    • puts_r - XXX
    • tmpfile_r - XXX
    • gets_r - XXX
    • remove_r - XXX
    • vfprintf_r - XXX
    • iprintf_r - XXX
    • rename_r - XXX
    • vsnprintf_r - XXX
    • mkstemp_r - XXX
    • snprintf_r - XXX
    • vsprintf_r - XXX
    • mktemp_t - XXX
    • sprintf_r - XXX
  • Signal functions:
    • init_signal_r - XXX
    • signal_r - XXX
    • kill_r - XXX
    • _sigtramp_r - XXX
    • raise_r - XXX
  • Stdlib functions:
    • calloc_r - XXX
    • mblen_r - XXX
    • srand_r - XXX
    • dtoa_r - XXX
    • mbstowcs_r - XXX
    • strtod_r - XXX
    • free_r - XXX
    • mbtowc_r - XXX
    • strtol_r - XXX
    • getenv_r - XXX
    • memalign_r - XXX
    • strtoul_r - XXX
    • mallinfo_r - XXX
    • mstats_r - XXX
    • system_r - XXX
    • malloc_r - XXX
    • rand_r - XXX
    • wcstombs_r - XXX
    • malloc_r - XXX
    • realloc_r - XXX
    • wctomb_r - XXX
    • malloc_stats_r - XXX
    • setenv_r - XXX
  • String functions:
    • strtok_r - XXX
  • System functions:
    • close_r - XXX
    • link_r - XXX
    • unlink_r - XXX
    • execve_r - XXX
    • lseek_r - XXX
    • wait_r - XXX
    • fcntl_r - XXX
    • open_r - XXX
    • write_r - XXX
    • fork_r - XXX
    • read_r - XXX
    • fstat_r - XXX
    • sbrk_r - XXX
    • gettimeofday_r - XXX
    • stat_r - XXX
    • getpid_r - XXX
    • times_r - XXX
  • Time function:
    • asctime_r - XXX
21.10. Miscellaneous Macros and Functions
  • unctrl - Return printable representation of a character
21.11. Variable Argument Lists
  • Stdarg (stdarg.h):
    • va_start - XXX
    • va_arg - XXX
    • va_end - XXX
  • Vararg (varargs.h):
    • va_alist - XXX
    • va_start-trad - XXX
    • va_arg-trad - XXX
    • va_end-trad - XXX
21.12. Reentrant System Calls
  • open_r - XXX
  • close_r - XXX
  • lseek_r - XXX
  • read_r - XXX
  • write_r - XXX
  • fork_r - XXX
  • wait_r - XXX
  • stat_r - XXX
  • fstat_r - XXX
  • link_r - XXX
  • unlink_r - XXX
  • sbrk_r - XXX
