13. Memory Management Manager
13.1. Introduction
The memory management manager is …
The directives provided by the memory management manager are:
  • mlockall - Lock the Address Space of a Process
  • munlockall - Unlock the Address Space of a Process
  • mlock - Lock a Range of the Process Address Space
  • munlock - Unlock a Range of the Process Address Space
  • mmap - Map Process Addresses to a Memory Object
  • munmap - Unmap Previously Mapped Addresses
  • mprotect - Change Memory Protection
  • msync - Memory Object Synchronization
  • shm_open - Open a Shared Memory Object
  • shm_unlink - Remove a Shared Memory Object
13.2. Background
There is currently no text in this section.
13.3. Operations
13.4. Directives
This section details the memory management manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
13.4.1. mlockall - Lock the Address Space of a Process
CALLING SEQUENCE:
#include <sys/mman.h>
int mlockall(
    int flags
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.2. munlockall - Unlock the Address Space of a Process
CALLING SEQUENCE:
int munlockall(
    void
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.3. mlock - Lock a Range of the Process Address Space
CALLING SEQUENCE:
int mlock(
    const void *addr,
    size_t len
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.4. munlock - Unlock a Range of the Process Address Space
CALLING SEQUENCE:
int munlock(
    const void *addr,
    size_t len
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.5. mmap - Map Process Addresses to a Memory Object
CALLING SEQUENCE:
void *mmap(
    void *addr,
    size_t len,
    int prot,
    int flags,
    int fildes,
    off_t off
STATUS CODES:
EBADF
The fildes argument is not a valid open file descriptor.
EINVAL
The value of len is zero.
EINVAL
The value of flags is invalid (neither MAP_PRIVATE nor MAP_SHARED is set).
EINVAL
The addr argument (if MAP_FIXED was specified) or off is not a multiple of the page size as returned by sysconf(), or is considered invalid by the implementation.
ENODEV
The fildes argument refers to a file whose type is not supported by mmap.
ENOMEM
MAP_FIXED was specified, and the range [addr,addr+len) exceeds that allowed for the address space of a process; or, if MAP_FIXED was not specified and there is insufficient room in the address space to effect the mapping.
ENOTSUP
MAP_FIXED or MAP_PRIVATE was specified in the flags argument and the implementation does not support this functionality.
ENOTSUP
The implementation does not support the combination of accesses requested in the prot argument.
ENXIO
Addresses in the range [off,off+len) are invalid for the object specified by fildes.
ENXIO
MAP_FIXED was specified in flags and the combination of addr, len, and off is invalid for the object specified by fildes.
EOVERFLOW
The file is a regular file and the value of off plus len exceeds the offset maximum established in the open file description associated with fildes.
DESCRIPTION:
mmap establishes a mapping between an address pa for len bytes to the memory object represented by the file descriptor fildes at offset off for len bytes. The value of pa is an implementation-defined function of the parameter addr and the values of flags. A successful mmap() call shall return pa as its result. An unsuccessful call returns MAP_FAILED and sets errno accordingly.
NOTES:
RTEMS is a single address space operating system without privilege separation between the kernel and user space. Therefore, the implementation of mmap has a number of implementation-specific issues to be aware of:
  • Read, write and execute permissions are allowed because the memory in RTEMS does not normally have protections but we cannot hide access to memory. Thus, the use of PROT_NONE for the prot argument is not supported. Similarly, there is no restriction of write access, so PROT_WRITE must be in the prot argument.
  • Anonymous mappings must have fildes set to -1 and off set to 0. Shared mappings are not supported with Anonymous mappings.
  • MAP_FIXED is not supported for shared memory objects with MAP_SHARED.
  • Support for shared mappings is dependent on the underlying object’s filesystem implementation of an mmap_h file operation handler.
13.4.6. munmap - Unmap Previously Mapped Addresses
CALLING SEQUENCE:
int munmap(
    void *addr,
    size_t len
STATUS CODES:
EINVAL
Addresses in the range [addr,addr+len) are outside the valid range for the address space.
EINVAL
The len argument is 0.
DESCRIPTION:
The munmap() function shall remove any mappings for those entire pages containing any part of the address space of the process starting at addr and continuing for len bytes. If there are no mappings in the specified address range, then munmap() has no effect.
Upon successful completion, munmap() shall return 0; otherwise, it shall return -1 and set errno to indicate the error.
NOTES:
13.4.7. mprotect - Change Memory Protection
CALLING SEQUENCE:
int mprotect(
    void *addr,
    size_t len,
    int prot
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.8. msync - Memory Object Synchronization
CALLING SEQUENCE:
int msync(
    void *addr,
    size_t len,
    int flags
STATUS CODES:
E
The
DESCRIPTION:
NOTES:
13.4.9. shm_open - Open a Shared Memory Object
CALLING SEQUENCE:
int shm_open(
    const char *name,
    int oflag,
    mode_t mode
STATUS CODES:
EACCES
The shared memory object exists and the permissions specified by oflag are denied, or the shared memory object does not exist and permission to create the shared memory object is denied, or O_TRUNC is specified and write permission is denied.
EEXIST
O_CREAT and O_EXCL are set and the named shared memory object already exists.
EINVAL
The shm_open() operation is not supported for the given name.
EMFILE
All file descriptors available to the process are currently open.
ENFILE
Too many shared memory objects are currently open in the system.
ENOENT
O_CREAT is not set and the named shared memory object does not exist.
ENOSPC
There is insufficient space for the creation of the new shared memory object.
ENAMETOOLONG
The length of the name argument exceeds _POSIX_PATH_MAX.
DESCRIPTION:
The shm_open() function shall establish a connection between a shared memory object and a file descriptor. It shall create an open file description that refers to the shared memory object and a file descriptor that refers to that open file description. The name argument points to a string naming a shared memory object.
If successful, shm_open() shall return a file descriptor for the shared memory object. Upon successful completion, the shm_open() function shall return a non-negative integer representing the file descriptor. Otherwise, it shall return -1 and set errno to indicate the error.
NOTES:
An application can set the _POSIX_Shm_Object_operations to control the behavior of shared memory objects when accessed via the file descriptor.
The name must be valid for an RTEMS SuperCore Object.
