RTEMS
5.1-rc2
Time of Day Handler API. More...
#include <rtems/score/status.h>#include <rtems/score/timestamp.h>#include <rtems/score/timecounterimpl.h>#include <rtems/score/watchdog.h>#include <sys/time.h>#include <time.h>Go to the source code of this file.
| struct | TOD_Control |
| TOD control. More... | |
| struct | TOD_Hook |
| Structure to manage each TOD action hook. More... | |
| #define | TOD_SECONDS_PER_MINUTE (uint32_t)60 |
| #define | TOD_MINUTES_PER_HOUR (uint32_t)60 |
| #define | TOD_MONTHS_PER_YEAR (uint32_t)12 |
| #define | TOD_DAYS_PER_YEAR (uint32_t)365 |
| #define | TOD_HOURS_PER_DAY (uint32_t)24 |
| #define | TOD_SECONDS_PER_DAY |
| #define | TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY) |
| #define | TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 |
| #define | TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 |
| #define | TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 |
| #define | TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 |
| #define | TOD_SECONDS_1970_THROUGH_1988 |
| #define | TOD_BASE_YEAR 1988 |
| Earliest year to which an time of day can be initialized. More... | |
| #define | TOD_TICKS_PER_SECOND TOD_TICKS_PER_SECOND_method() |
| Gets number of ticks in a second. More... | |
Typedefs | |
| typedef struct TOD_Hook | TOD_Hook |
| Structure to manage each TOD action hook. | |
Enumerations | |
| enum | TOD_Action { TOD_ACTION_SET_CLOCK } |
| Possible actions where a registered hook could be invoked. More... | |
| void | _TOD_Lock (void) |
| Locks the time of day mutex. | |
| void | _TOD_Unlock (void) |
| Unlocks the time of day mutex. | |
| Status_Control | _TOD_Set (const struct timespec *tod, ISR_lock_Context *lock_context) |
| Sets the time of day. More... | |
| uint32_t | TOD_TICKS_PER_SECOND_method (void) |
| RTEMS_INLINE_ROUTINE void | _TOD_Get_timeval (struct timeval *time) |
| This routine returns a timeval based upon the internal timespec format TOD. More... | |
| void | _TOD_Adjust (const struct timespec *delta) |
| Adjusts the Time of Time. More... | |
| RTEMS_INLINE_ROUTINE bool | _TOD_Is_set (void) |
| Check if the TOD is Set. More... | |
| void | _TOD_Hook_Register (TOD_Hook *hook) |
| Add a TOD Action Hook. More... | |
| void | _TOD_Hook_Unregister (TOD_Hook *hook) |
| Remove a TOD Action Hook. More... | |
| Status_Control | _TOD_Hook_Run (TOD_Action action, const struct timespec *tod) |
| Run the TOD Action Hooks. More... | |
| TOD_Control | _TOD |
| TOD Management information. | |
| Chain_Control | _TOD_Hooks |
| Set of registered methods for TOD Actions. | |
| #define TOD_BASE_YEAR 1988 |
The following constant define the earliest year to which an time of day can be initialized. This is considered the epoch.
| #define TOD_SECONDS_1970_THROUGH_1988 |
Seconds from January 1, 1970 to January 1, 1988. Used to account for differences between POSIX API and RTEMS core. The timespec format time is kept in POSIX compliant form.
1.8.15
