RTEMS
5.1-rc2
SPI transfer message. More...
#include <spidev.h>
Data Fields | |
| void * | rx_buf |
| Buffer for receive data. | |
| const void * | tx_buf |
| Buffer for transmit data. | |
| size_t | len |
| Length of receive and transmit buffers in bytes. | |
| uint32_t | speed_hz |
| Sets the bit-rate of the device. | |
| uint16_t | delay_usecs |
| Sets the delay after a transfer before the chip select status is changed and the next transfer is triggered. | |
| uint8_t | bits_per_word |
| Sets the device wordsize. | |
| uint8_t | cs_change |
| If true, device is deselected after transfer ended and before a new transfer is started. | |
| uint8_t | rx_nbits |
| Amount of bits that are used for reading. | |
| uint8_t | tx_nbits |
| Amount of bits that are used for writing. | |
| uint32_t | mode |
| Sets one of the possible modes that can be used for SPI transfers (dependent on clock phase and polarity). | |
| uint8_t | cs |
| Indicates which device is currently used. | |
1.8.15
