RTEMS
5.1-rc2
JFFS2 filesystem instance information. More...
#include <jffs2.h>
Data Fields | |
| uint32_t | flash_size |
| Flash size in bytes. | |
| uint32_t | flash_blocks |
| Count of flash blocks (erasable units). | |
| uint32_t | flash_block_size |
| Size of a flash block in bytes. | |
| uint32_t | used_size |
| Used size in bytes. More... | |
| uint32_t | dirty_size |
| Dirty size in bytes. More... | |
| uint32_t | wasted_size |
| Wasted size in bytes. More... | |
| uint32_t | free_size |
| Free size in bytes. More... | |
| uint32_t | bad_size |
| Bad size in bytes. More... | |
| uint32_t | clean_blocks |
| Count of clean blocks. More... | |
| uint32_t | dirty_blocks |
| Count of dirty blocks. More... | |
| uint32_t | erasable_blocks |
| Count of erasable blocks. More... | |
| uint32_t | free_blocks |
| Count of free blocks. More... | |
| uint32_t | bad_blocks |
| Count of bad blocks. More... | |
| uint32_t rtems_jffs2_info::bad_blocks |
Bad blocks are damaged.
| uint32_t rtems_jffs2_info::bad_size |
Bad size in bytes.
Bad areas indicate damaged flash blocks.
| uint32_t rtems_jffs2_info::clean_blocks |
Clean blocks contain only used areas.
| uint32_t rtems_jffs2_info::dirty_blocks |
Dirty blocks contain dirty and used areas.
| uint32_t rtems_jffs2_info::dirty_size |
Used areas contain no longer used data.
| uint32_t rtems_jffs2_info::erasable_blocks |
Erase blocks contain only dirty or wasted areas.
| uint32_t rtems_jffs2_info::free_blocks |
Free blocks contain a free area.
| uint32_t rtems_jffs2_info::free_size |
Free size in bytes.
Free areas may be used to store new data.
| uint32_t rtems_jffs2_info::used_size |
Used size in bytes.
Used areas contain valid data.
| uint32_t rtems_jffs2_info::wasted_size |
Wasted areas are unusable.
1.8.15
