RTEMS
5.1-rc2
JFFS2 flash device control. More...
#include <jffs2.h>
Data Fields | |
| uint32_t | block_size |
| The size in bytes of the erasable unit of the flash device. | |
| uint32_t | flash_size |
| The size in bytes of the flash device. More... | |
| rtems_jffs2_flash_read | read |
| Read from flash operation. | |
| rtems_jffs2_flash_write | write |
| Write to flash operation. | |
| rtems_jffs2_flash_erase | erase |
| Flash erase operation. | |
| rtems_jffs2_flash_destroy | destroy |
| Flash destroy operation. More... | |
| dev_t | device_identifier |
| The device identifier of the flash device. More... | |
| rtems_jffs2_trigger_garbage_collection | trigger_garbage_collection |
| Trigger garbage collection operation. More... | |
| rtems_jffs2_flash_destroy rtems_jffs2_flash_control::destroy |
This operation is optional and the pointer may be NULL.
| dev_t rtems_jffs2_flash_control::device_identifier |
It is used in combination with the inode number to uniquely identify a file system node in the system.
| uint32_t rtems_jffs2_flash_control::flash_size |
It must be an integral multiple of the block size. The flash device must have at least five blocks.
| rtems_jffs2_trigger_garbage_collection rtems_jffs2_flash_control::trigger_garbage_collection |
This operation is optional and may be NULL. This operation should wake up a garbage collection thread. The garbage collection thread should use the RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION IO control to carry out the work.
1.8.15
