RTEMS
5.1-rc2
Thread register context. More...
#include <cpu.h>
Data Fields | |
| void * | register_sp |
| uint32_t | register_r4 |
| uint32_t | register_r5 |
| uint32_t | register_r6 |
| uint32_t | register_r7 |
| uint32_t | register_p3 |
| uint32_t | register_p4 |
| uint32_t | register_p5 |
| uint32_t | register_fp |
| uint32_t | register_sp |
| uint32_t | register_rets |
| uint32_t | imask |
| uint32_t | r [64] |
| uint32_t | status |
| uint32_t | config |
| uint32_t | iret |
| uint32_t | eflags |
| void * | esp |
| void * | ebp |
| uint32_t | ebx |
| uint32_t | esi |
| uint32_t | edi |
| segment_descriptors | gs |
| uint32_t | isr_dispatch_disable |
| uint32_t | r11 |
| uint32_t | r12 |
| uint32_t | r13 |
| uint32_t | r14 |
| uint32_t | r15 |
| uint32_t | r16 |
| uint32_t | r17 |
| uint32_t | r18 |
| uint32_t | r19 |
| uint32_t | r20 |
| uint32_t | r21 |
| uint32_t | r22 |
| uint32_t | r23 |
| uint32_t | r24 |
| uint32_t | r25 |
| uint32_t | gp |
| uint32_t | fp |
| uint32_t | sp |
| uint32_t | ra |
| uint32_t | ie |
| uint32_t | epc |
| uint32_t | sr |
| uint32_t | d2 |
| uint32_t | d3 |
| uint32_t | d4 |
| uint32_t | d5 |
| uint32_t | d6 |
| uint32_t | d7 |
| void * | a2 |
| void * | a3 |
| void * | a4 |
| void * | a5 |
| void * | a6 |
| void * | a7_msp |
| __MIPS_REGISTER_TYPE | s0 |
| __MIPS_REGISTER_TYPE | s1 |
| __MIPS_REGISTER_TYPE | s2 |
| __MIPS_REGISTER_TYPE | s3 |
| __MIPS_REGISTER_TYPE | s4 |
| __MIPS_REGISTER_TYPE | s5 |
| __MIPS_REGISTER_TYPE | s6 |
| __MIPS_REGISTER_TYPE | s7 |
| __MIPS_REGISTER_TYPE | sp |
| __MIPS_REGISTER_TYPE | fp |
| __MIPS_REGISTER_TYPE | ra |
| __MIPS_REGISTER_TYPE | c0_sr |
| __MIPS_REGISTER_TYPE | c0_epc |
| void *fp | nogap |
| void *sp | nogap |
| uint32_t r0 | nogap |
| uint32_t r1 | nogap |
| uint32_t r2 | nogap |
| uint32_t r3 | nogap |
| uint32_t r4 | nogap |
| uint32_t r5 | nogap |
| uint32_t r6 | nogap |
| uint32_t r7 | nogap |
| uint32_t r8 | nogap |
| uint32_t r9 | nogap |
| uint32_t r10 | nogap |
| uint32_t r11 | nogap |
| uint32_t r12 | nogap |
| uint32_t r13 | nogap |
| uint32_t | thread_dispatch_disabled |
| uint32_t | stack_mpubase |
| uint32_t | stack_mpuacc |
| uint32_t | some_integer_register |
| uint32_t | some_system_register |
| uint32_t | stack_pointer |
| uint32_t | r1 |
| uint32_t | r2 |
| uint32_t | r3 |
| uint32_t | r4 |
| uint32_t | r5 |
| uint32_t | r6 |
| uint32_t | r7 |
| uint32_t | r8 |
| uint32_t | r9 |
| uint32_t | r10 |
| uint32_t | r26 |
| uint32_t | r27 |
| uint32_t | r28 |
| uint32_t | r29 |
| uint32_t | r30 |
| uint32_t | r31 |
| uint32_t | epcr |
| uint32_t | eear |
| uint32_t | esr |
| uint8_t | context [PPC_DEFAULT_CACHE_LINE_SIZE+sizeof(ppc_context)+(sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE==0 ? 0 :PPC_DEFAULT_CACHE_LINE_SIZE - sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE)] |
| uint32_t | reserved |
| uintptr_t | ra |
| uintptr_t | sp |
| uintptr_t | tp |
| uintptr_t | s0 |
| uintptr_t | s1 |
| uintptr_t | s2 |
| uintptr_t | s3 |
| uintptr_t | s4 |
| uintptr_t | s5 |
| uintptr_t | s6 |
| uintptr_t | s7 |
| uintptr_t | s8 |
| uintptr_t | s9 |
| uintptr_t | s10 |
| uintptr_t | s11 |
| uint32_t * | r15 |
| uint32_t | macl |
| uint32_t | mach |
| uint32_t * | pr |
| uint32_t * | r14 |
| uint32_t * | r7 |
| uint32_t * | r6 |
| uint32_t * | r3 |
| uint32_t * | r2 |
| uint32_t * | r1 |
| uint32_t * | r0 |
| uint32_t | gbr |
| uint32_t | g5 |
| uint32_t | g7 |
| double | l0_and_l1 |
| uint32_t | l2 |
| uint32_t | l3 |
| uint32_t | l4 |
| uint32_t | l5 |
| uint32_t | l6 |
| uint32_t | l7 |
| uint32_t | i0 |
| uint32_t | i1 |
| uint32_t | i2 |
| uint32_t | i3 |
| uint32_t | i4 |
| uint32_t | i5 |
| uint32_t | i6_fp |
| uint32_t | i7 |
| uint32_t | o6_sp |
| uint32_t | o7 |
| uint32_t | psr |
| uint64_t | g1 |
| uint64_t | g2 |
| uint64_t | g3 |
| uint64_t | g4 |
| uint64_t | g5 |
| uint64_t | g6 |
| uint64_t | g7 |
| uint64_t | l0 |
| uint64_t | l1 |
| uint64_t | l2 |
| uint64_t | l3 |
| uint64_t | l4 |
| uint64_t | l5 |
| uint64_t | l6 |
| uint64_t | l7 |
| uint64_t | i0 |
| uint64_t | i1 |
| uint64_t | i2 |
| uint64_t | i3 |
| uint64_t | i4 |
| uint64_t | i5 |
| uint64_t | i6_fp |
| uint64_t | i7 |
| uint64_t | o0 |
| uint64_t | o1 |
| uint64_t | o2 |
| uint64_t | o3 |
| uint64_t | o4 |
| uint64_t | o5 |
| uint64_t | o6_sp |
| uint64_t | o7 |
| uint32_t | pad |
| uint32_t | r3_stack_pointer |
| uint32_t | psw |
| uint64_t | rflags |
| uint64_t | rbx |
| void * | rsp |
| void * | rbp |
| uint64_t | r12 |
| uint64_t | r13 |
| uint64_t | r14 |
| uint64_t | r15 |
SPARC basic context.
This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another.
The thread register context covers the non-volatile registers, the thread stack pointer, the return address, and the processor status.
There is no need to save the global pointer (gp) since it is a system wide constant and set-up with the C runtime environment.
The thread_dispatch_disabled field is used for the external interrupt controller (EIC) support.
This structure defines the non-volatile integer and processor state context for the SPARC architecture according to "SYSTEM V APPLICATION BINARY INTERFACE - SPARC Processor Supplement", Third Edition.
The registers g2 through g4 are reserved for applications. GCC uses them as volatile registers by default. So they are treated like volatile registers in RTEMS as well.
The register g6 contains the per-CPU control of the current processor. It is an invariant of the processor context. This register must not be saved and restored during context switches or interrupt services.
| uint32_t Context_Control::g5 |
This will contain the contents of the g5 register.
| uint32_t Context_Control::g7 |
This will contain the contents of the g7 register.
| uint32_t Context_Control::i0 |
This will contain the contents of the i0 register.
| uint32_t Context_Control::i1 |
This will contain the contents of the i1 register.
| uint32_t Context_Control::i2 |
This will contain the contents of the i2 register.
| uint32_t Context_Control::i3 |
This will contain the contents of the i3 register.
| uint32_t Context_Control::i4 |
This will contain the contents of the i4 register.
| uint32_t Context_Control::i5 |
This will contain the contents of the i5 register.
| uint32_t Context_Control::i6_fp |
This will contain the contents of the i6 (e.g. frame pointer) register.
| uint32_t Context_Control::i7 |
This will contain the contents of the i7 register.
| uint32_t Context_Control::isr_dispatch_disable |
This field is used to prevent heavy nesting of calls to _Thread_Dispatch on an interrupted task's stack. This is problematic on the slower SPARC CPU models at high interrupt rates.
| double Context_Control::l0_and_l1 |
This will contain the contents of the l0 and l1 registers.
Using a double l0_and_l1 will put everything in this structure on a double word boundary which allows us to use double word loads and stores safely in the context switch.
| uint32_t Context_Control::l2 |
This will contain the contents of the l2 register.
| uint32_t Context_Control::l3 |
This will contain the contents of the l3 register.
| uint32_t Context_Control::l4 |
This will contain the contents of the l4 register.
| uint32_t Context_Control::l5 |
This will contain the contents of the l5 registeer.
| uint32_t Context_Control::l6 |
This will contain the contents of the l6 register.
| uint32_t Context_Control::l7 |
This will contain the contents of the l7 register.
| uint32_t Context_Control::o6_sp |
This will contain the contents of the o6 (e.g. frame pointer) register.
| uint32_t Context_Control::o7 |
This will contain the contents of the o7 (e.g. address of CALL instruction) register.
| uint32_t Context_Control::psr |
This will contain the contents of the processor status register.
| uint32_t Context_Control::r3_stack_pointer |
This field is the stack pointer (e.g. r3).
| uint64_t Context_Control::rbx |
Callee-saved registers as listed in the SysV ABI document: https://github.com/hjl-tools/x86-psABI/wiki/X86-psABI
| uint32_t Context_Control::some_integer_register |
This field is a hint that a port will have a number of integer registers that need to be saved at a context switch.
| uint32_t Context_Control::some_system_register |
This field is a hint that a port will have a number of system registers that need to be saved at a context switch.
| uint32_t Context_Control::stack_pointer |
This field is a hint that a port will have a register that is the stack pointer.
1.8.15
