RTEMS
5.1-rc2
The CPU specific per-CPU control. More...
#include <cpuimpl.h>
Data Fields | |
| volatile RISCV_PLIC_hart_regs * | plic_hart_regs |
| volatile uint32_t * | plic_m_ie |
| volatile RISCV_CLINT_timer_reg * | clint_mtimecmp |
| volatile uint32_t * | clint_msip |
The CPU port can place here all state information that must be available and maintained for each processor in the system. This structure must contain at least one field for C/C++ compatibility. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used.
1.8.15
