RTEMS
5.1-rc2
SD Card LibI2C driver. More...
| struct | sd_card_driver_entry |
| #define | SD_CARD_IDLE_TOKEN 0xff |
| #define | SD_CARD_COMMAND_SIZE 18 |
| #define | SD_CARD_TRANSFER_MODE_DEFAULT { .baudrate = 400000, .bits_per_char = 8, .lsb_first = FALSE, .clock_inv = FALSE, .clock_phs = FALSE, .idle_char = SD_CARD_IDLE_TOKEN } |
| #define | SD_CARD_COMMAND_DEFAULT |
| #define | SD_CARD_N_AC_MAX_DEFAULT 5000 |
| rtems_status_code | sd_card_register (void) |
| sd_card_driver_entry | sd_card_driver_table [] |
| size_t | sd_card_driver_table_size |
| #define SD_CARD_COMMAND_DEFAULT |
| #define SD_CARD_COMMAND_SIZE 18 |
1 idle token before command 6 bytes for the command 1 to 8 bytes for response start (N_CR) 1 to 2 bytes for response 1 idle token after command (minimum N_RC)
1.8.15
