RTEMS
5.1-rc2
Information Required to Build RTEMS for a Particular Member of the SPARC Family. More...
#include <rtems/score/basedefs.h>Go to the source code of this file.
| #define | SPARC_HAS_BITSCAN 0 |
| #define | SPARC_NUMBER_OF_REGISTER_WINDOWS 8 |
| #define | SPARC_LEON3FT_B2BST_NOP |
| #define | SPARC_HAS_FPU 1 |
| #define | CPU_MODEL_NAME "w/FPU" |
| #define | CPU_NAME "SPARC" |
| #define | SPARC_PSR_CWP_MASK 0x07 /* bits 0 - 4 */ |
| #define | SPARC_PSR_ET_MASK 0x00000020 /* bit 5 */ |
| #define | SPARC_PSR_PS_MASK 0x00000040 /* bit 6 */ |
| #define | SPARC_PSR_S_MASK 0x00000080 /* bit 7 */ |
| #define | SPARC_PSR_PIL_MASK 0x00000F00 /* bits 8 - 11 */ |
| #define | SPARC_PSR_EF_MASK 0x00001000 /* bit 12 */ |
| #define | SPARC_PSR_EC_MASK 0x00002000 /* bit 13 */ |
| #define | SPARC_PSR_ICC_MASK 0x00F00000 /* bits 20 - 23 */ |
| #define | SPARC_PSR_VER_MASK 0x0F000000 /* bits 24 - 27 */ |
| #define | SPARC_PSR_IMPL_MASK 0xF0000000 /* bits 28 - 31 */ |
| #define | SPARC_PSR_CWP_BIT_POSITION 0 /* bits 0 - 4 */ |
| #define | SPARC_PSR_ET_BIT_POSITION 5 /* bit 5 */ |
| #define | SPARC_PSR_PS_BIT_POSITION 6 /* bit 6 */ |
| #define | SPARC_PSR_S_BIT_POSITION 7 /* bit 7 */ |
| #define | SPARC_PSR_PIL_BIT_POSITION 8 /* bits 8 - 11 */ |
| #define | SPARC_PSR_EF_BIT_POSITION 12 /* bit 12 */ |
| #define | SPARC_PSR_EC_BIT_POSITION 13 /* bit 13 */ |
| #define | SPARC_PSR_ICC_BIT_POSITION 20 /* bits 20 - 23 */ |
| #define | SPARC_PSR_VER_BIT_POSITION 24 /* bits 24 - 27 */ |
| #define | SPARC_PSR_IMPL_BIT_POSITION 28 /* bits 28 - 31 */ |
| #define | LEON3_ASR17_PROCESSOR_INDEX_SHIFT 28 |
| #define | SPARC_SWTRAP_SYSCALL 0 |
| #define | SPARC_SWTRAP_IRQDIS 9 |
| #define | SPARC_SWTRAP_IRQEN 10 |
| #define | SPARC_SWTRAP_IRQDIS_FP 11 |
| #define | nop() |
| #define | sparc_get_psr(_psr) |
| Macro to obtain the PSR. More... | |
| #define | sparc_set_psr(_psr) |
| Macro to set the PSR. More... | |
| #define | sparc_get_tbr(_tbr) |
| Macro to obtain the TBR. More... | |
| #define | sparc_set_tbr(_tbr) |
| Macro to set the TBR. More... | |
| #define | sparc_get_wim(_wim) |
| Macro to obtain the WIM. More... | |
| #define | sparc_set_wim(_wim) |
| Macro to set the WIM. More... | |
| #define | sparc_get_y(_y) |
| Macro to obtain the Y register. More... | |
| #define | sparc_set_y(_y) |
| Macro to set the Y register. More... | |
| #define | sparc_flash_interrupts(_psr) |
| SPARC flash processor interrupts. More... | |
| #define | sparc_get_interrupt_level(_level) |
| SPARC obtain interrupt level. More... | |
| void | sparc_syscall_exit (uint32_t exitcode1, uint32_t exitcode2) RTEMS_NO_RETURN |
| SPARC exit through system call 1. More... | |
This file contains the information required to build RTEMS for a particular member of the SPARC family. It does this by setting variables to indicate which implementation dependent features are present in a particular member of the family.
| #define CPU_MODEL_NAME "w/FPU" |
This macro contains a string describing the multilib variant being build.
| #define CPU_NAME "SPARC" |
Define the name of the CPU family.
| #define nop | ( | ) |
This macro is a standard nop instruction.
| #define sparc_flash_interrupts | ( | _psr | ) |
This method is invoked to temporarily enable all maskable interrupts.
| [in] | _psr | is the PSR returned by sparc_disable_interrupts. |
| #define sparc_get_interrupt_level | ( | _level | ) |
This method is invoked to obtain the current interrupt disable level.
| [in] | _level | is the PSR returned by sparc_disable_interrupts. |
| #define sparc_get_psr | ( | _psr | ) |
This macro returns the current contents of the PSR register in _psr.
| #define sparc_get_tbr | ( | _tbr | ) |
This macro returns the current contents of the TBR register in _tbr.
| #define sparc_get_wim | ( | _wim | ) |
This macro returns the current contents of the WIM field in _wim.
| #define sparc_get_y | ( | _y | ) |
This macro returns the current contents of the Y register in _y.
| #define SPARC_HAS_BITSCAN 0 |
Some higher end SPARCs have a bitscan instructions. It would be nice to take advantage of them. Right now, there is no port to a CPU model with this feature and no (untested) code that is based on this feature flag.
| #define SPARC_HAS_FPU 1 |
This macro indicates whether this multilib variation has hardware floating point or not. We use the gcc cpp predefine _SOFT_FLOAT to determine that.
| #define SPARC_LEON3FT_B2BST_NOP |
See GRLIB-TN-0009: "LEON3FT Stale Cache Entry After Store with Data Tag Parity Error"
| #define SPARC_NUMBER_OF_REGISTER_WINDOWS 8 |
This should be OK until a port to a higher end SPARC processor is made that has more than 8 register windows. If this cannot be determined based on multilib settings (v7/v8/v9), then the cpu_asm.S code that depends on this will have to move to libcpu.
| #define SPARC_PSR_CWP_BIT_POSITION 0 /* bits 0 - 4 */ |
This constant is the starting bit position of the CWP in the PSR.
| #define SPARC_PSR_CWP_MASK 0x07 /* bits 0 - 4 */ |
PSR masks and starting bit positions
NOTE: Reserved bits are ignored.
| #define SPARC_PSR_EC_BIT_POSITION 13 /* bit 13 */ |
This constant is the starting bit position of the EC in the PSR.
| #define SPARC_PSR_EC_MASK 0x00002000 /* bit 13 */ |
This constant is a mask for the EC bits in the PSR.
| #define SPARC_PSR_EF_BIT_POSITION 12 /* bit 12 */ |
This constant is the starting bit position of the EF in the PSR.
| #define SPARC_PSR_EF_MASK 0x00001000 /* bit 12 */ |
This constant is a mask for the EF bits in the PSR.
| #define SPARC_PSR_ET_BIT_POSITION 5 /* bit 5 */ |
This constant is the starting bit position of the ET in the PSR.
| #define SPARC_PSR_ET_MASK 0x00000020 /* bit 5 */ |
This constant is a mask for the ET bits in the PSR.
| #define SPARC_PSR_ICC_BIT_POSITION 20 /* bits 20 - 23 */ |
This constant is the starting bit position of the ICC in the PSR.
| #define SPARC_PSR_ICC_MASK 0x00F00000 /* bits 20 - 23 */ |
This constant is a mask for the ICC bits in the PSR.
| #define SPARC_PSR_IMPL_BIT_POSITION 28 /* bits 28 - 31 */ |
This constant is the starting bit position of the IMPL in the PSR.
| #define SPARC_PSR_IMPL_MASK 0xF0000000 /* bits 28 - 31 */ |
This constant is a mask for the IMPL bits in the PSR.
| #define SPARC_PSR_PIL_BIT_POSITION 8 /* bits 8 - 11 */ |
This constant is the starting bit position of the PIL in the PSR.
| #define SPARC_PSR_PIL_MASK 0x00000F00 /* bits 8 - 11 */ |
This constant is a mask for the PIL bits in the PSR.
| #define SPARC_PSR_PS_BIT_POSITION 6 /* bit 6 */ |
This constant is the starting bit position of the PS in the PSR.
| #define SPARC_PSR_PS_MASK 0x00000040 /* bit 6 */ |
This constant is a mask for the PS bits in the PSR.
| #define SPARC_PSR_S_BIT_POSITION 7 /* bit 7 */ |
This constant is the starting bit position of the S in the PSR.
| #define SPARC_PSR_S_MASK 0x00000080 /* bit 7 */ |
This constant is a mask for the S bits in the PSR.
| #define SPARC_PSR_VER_BIT_POSITION 24 /* bits 24 - 27 */ |
This constant is the starting bit position of the VER in the PSR.
| #define SPARC_PSR_VER_MASK 0x0F000000 /* bits 24 - 27 */ |
This constant is a mask for the VER bits in the PSR.
| #define sparc_set_psr | ( | _psr | ) |
This macro sets the PSR register to the value in _psr.
| #define sparc_set_tbr | ( | _tbr | ) |
This macro sets the TBR register to the value in _tbr.
| #define sparc_set_wim | ( | _wim | ) |
This macro sets the WIM field to the value in _wim.
| #define sparc_set_y | ( | _y | ) |
This macro sets the Y register to the value in _y.
| void sparc_syscall_exit | ( | uint32_t | exitcode1, |
| uint32_t | exitcode2 | ||
This method is invoked to go into system error halt. The optional arguments can be given to hypervisor, hardware debugger, simulator or similar.
System error mode is entered when taking a trap when traps have been disabled. What happens when error mode is entered depends on the motherboard. In a typical development systems the CPU relingish control to the debugger, simulator, hypervisor or similar. The following steps are taken:
This function never returns.
| [in] | exitcode1 | Primary exit code stored in CPU g2 register after exit |
| [in] | exitcode2 | Primary exit code stored in CPU g3 register after exit |
1.8.15
