RTEMS
5.1-rc2
RTEMS Run-Time Link Editor. More...
#include <errno.h>#include <fcntl.h>#include <inttypes.h>#include <stdlib.h>#include <string.h>#include <stdio.h>#include <unistd.h>#include <rtems/rtl/rtl.h>#include "rtl-elf.h"#include "rtl-error.h"#include <rtems/rtl/rtl-obj-comp.h>#include "rtl-rap.h"#include <rtems/rtl/rtl-trace.h>#include <rtems/rtl/rtl-unresolved.h>Data Structures | |
| struct | rtems_rtl_rap_sectdef |
| struct | rtems_rtl_rap_section |
| struct | rtems_rtl_rap |
| #define | REL_R_OFFSET (0) |
| #define | REL_R_INFO (1) |
| #define | REL_R_ADDEND (2) |
| #define | RTEMS_RTL_RAP_TEXT_SEC (0) |
| #define | RTEMS_RTL_RAP_CONST_SEC (1) |
| #define | RTEMS_RTL_RAP_CTOR_SEC (2) |
| #define | RTEMS_RTL_RAP_DTOR_SEC (3) |
| #define | RTEMS_RTL_RAP_DATA_SEC (4) |
| #define | RTEMS_RTL_RAP_BSS_SEC (5) |
| #define | RTEMS_RTL_RAP_SECS (6) |
| #define | SYMNAME_BUFFER_SIZE (1024) |
Typedefs | |
| typedef struct rtems_rtl_rap_sectdef | rtems_rtl_rap_sectdef |
| typedef struct rtems_rtl_rap_section | rtems_rtl_rap_section |
| typedef struct rtems_rtl_rap | rtems_rtl_rap |
| bool | rtems_rtl_rap_file_check (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_rap_file_load (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_rap_file_unload (rtems_rtl_obj *obj) |
| rtems_rtl_loader_format * | rtems_rtl_rap_file_sig (void) |
This is the RAP format loader support..
| #define REL_R_OFFSET (0) |
The offsets in the unresolved array.
| #define RTEMS_RTL_RAP_TEXT_SEC (0) |
The section indexes. These are fixed.
| typedef struct rtems_rtl_rap rtems_rtl_rap |
The RAP loader.
| typedef struct rtems_rtl_rap_sectdef rtems_rtl_rap_sectdef |
The section definitions found in a RAP file.
| typedef struct rtems_rtl_rap_section rtems_rtl_rap_section |
| bool rtems_rtl_rap_file_check | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The RAP format check handler.
| obj | The object being checked. |
| fd | The file descriptor. |
| bool rtems_rtl_rap_file_load | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The RAP format load handler.
| obj | The object to load. |
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
| rtems_rtl_loader_format* rtems_rtl_rap_file_sig | ( | void | ) |
The RAP format signature handler.
| bool rtems_rtl_rap_file_unload | ( | rtems_rtl_obj * | obj | ) |
The RAP format unload handler.
| obj | The object to unload. |
1.8.15
