RTEMS
5.1-rc2
RTEMS File System Directory Support. More...
#include <dirent.h>#include <rtems/libio_.h>#include <rtems/rfs/rtems-rfs-data.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-inode.h>Go to the source code of this file.
| #define | RTEMS_RFS_DIR_ENTRY_INO (0) |
| #define | RTEMS_RFS_DIR_ENTRY_HASH (4) |
| #define | RTEMS_RFS_DIR_ENTRY_LEN (8) |
| #define | RTEMS_RFS_DIR_ENTRY_SIZE (4 + 4 + 2) |
| #define | RTEMS_RFS_DIR_ENTRY_EMPTY (0xffff) |
| #define | rtems_rfs_dir_entry_hash(_e) rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH) |
| #define | rtems_rfs_dir_set_entry_hash(_e, _h) rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH, _h) |
| #define | rtems_rfs_dir_entry_ino(_e) rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO) |
| #define | rtems_rfs_dir_set_entry_ino(_e, _i) rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO, _i) |
| #define | rtems_rfs_dir_entry_length(_e) rtems_rfs_read_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN) |
| #define | rtems_rfs_dir_set_entry_length(_e, _l) rtems_rfs_write_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN, _l) |
| int | rtems_rfs_dir_lookup_ino (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *inode, const char *name, int length, rtems_rfs_ino *ino, uint32_t *offset) |
| int | rtems_rfs_dir_add_entry (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, const char *name, size_t length, rtems_rfs_ino ino) |
| int | rtems_rfs_dir_del_entry (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_ino ino, uint32_t offset) |
| int | rtems_rfs_dir_read (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_pos_rel offset, struct dirent *dirent, size_t *length) |
| int | rtems_rfs_dir_empty (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir) |
This file provides the directory support functions.
| #define RTEMS_RFS_DIR_ENTRY_EMPTY (0xffff) |
The length when the remainder of the directory block is empty.
| #define RTEMS_RFS_DIR_ENTRY_HASH (4) |
The hash offset in a directory entry. The hash is 32bits. We need at least 16bits and given the length and ino field are 4 the extra 2 bytes is not a big overhead.
| #define rtems_rfs_dir_entry_hash | ( | _e | ) | rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH) |
Return the hash of the entry.
| [in] | _e | is a pointer to the directory entry. |
| hash | The uint32_t hash of the entry. |
| #define RTEMS_RFS_DIR_ENTRY_INO (0) |
Define the offsets of the fields of a directory entry.The ino offset in a directory entry.
| #define rtems_rfs_dir_entry_ino | ( | _e | ) | rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO) |
Return the ino of the entry.
| ino | The ino of the entry. |
| #define RTEMS_RFS_DIR_ENTRY_LEN (8) |
The length offset in a directory entry.
| #define rtems_rfs_dir_entry_length | ( | _e | ) | rtems_rfs_read_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN) |
Return the length of the entry.
| [in] | _e | Pointer to the directory entry. |
| length | The length of the entry. |
| #define RTEMS_RFS_DIR_ENTRY_SIZE (4 + 4 + 2) |
The length of the directory entry header.
| #define rtems_rfs_dir_set_entry_hash | ( | _e, | |
| _h | |||
| ) | rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH, _h) |
Set the hash of the entry.
| [in] | _h | is the hash of the entry. |
| #define rtems_rfs_dir_set_entry_ino | ( | _e, | |
| _i | |||
| ) | rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO, _i) |
Set the ino of the entry.
| [in] | _i | is the ino of the entry. |
| #define rtems_rfs_dir_set_entry_length | ( | _e, | |
| _l | |||
| ) | rtems_rfs_write_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN, _l) |
Set the length of the entry.
| [in] | _l | is the length. |
| int rtems_rfs_dir_add_entry | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | dir, | ||
| const char * | name, | ||
| size_t | length, | ||
| rtems_rfs_ino | ino | ||
Add an entry to the directory returing the inode number allocated to the entry.
| [in] | fs | is the file system data. |
| [in] | dir | is a pointer to the directory inode the entry is to be added too. |
| [in] | name | is a pointer to the name of the entry to be added. |
| [in] | length | is the length of the name excluding a terminating 0. |
| [in] | ino | is the ino of the entry. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_dir_del_entry | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino, | ||
| uint32_t | offset | ||
Del an entry from the directory using an inode number as a key.
| [in] | dir | is a pointer to the directory inode the entry is to be deleted from. |
| [in] | offset | is the offset in the directory of the entry to delete. If 0 search from the start for the ino. |
| int rtems_rfs_dir_empty | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | dir | ||
Check if the directory is empty. The current and parent directory entries are ignored.
| [in] | fs | is the file system data |
| [in] | dir | is a pointer to the directory inode to check. |
| int rtems_rfs_dir_lookup_ino | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | inode, | ||
| int | length, | ||
| rtems_rfs_ino * | ino, | ||
| uint32_t * | offset | ||
Look up a directory entry in the directory pointed to by the inode. The look up is local to this directory. No need to decend.
| [in] | fs | is the file system. |
| [in] | inode | is a pointer to the inode of the directory to search. |
| [in] | name | is a pointer to the name to look up. The name may not be nul terminated. |
| [in] | length | is the length of the name. |
| [out] | ino | will be filled in with the inode number if there is no error. |
| [in] | offset | is the offset in the directory for the entry. |
| int rtems_rfs_dir_read | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_pos_rel | offset, | ||
| struct dirent * | dirent, | ||
| size_t * | length | ||
Read the directory entry from offset into the directory entry buffer and return the length of space this entry uses in the directory table.
| [in] | dir | is a pointer to the direct inode handler. |
| [in] | offset | is the offset in the directory to read from. |
| [in] | dirent | is a ointer to the dirent structure the entry is written into. |
| [out] | length | will contain the length this entry takes in the directory. |
1.8.15
