RTEMS
5.1-rc2
RTEMS Flattened Device Tree. More...
| struct | rtems_fdt_handle |
| #define | RTEMS_FDT_ERR_NOTFOUND 1 |
| #define | RTEMS_FDT_ERR_EXISTS 2 |
| #define | RTEMS_FDT_ERR_NOSPACE 3 |
| #define | RTEMS_FDT_ERR_BADOFFSET 4 |
| #define | RTEMS_FDT_ERR_BADPATH 5 |
| #define | RTEMS_FDT_ERR_BADPHANDLE 6 |
| #define | RTEMS_FDT_ERR_BADSTATE 7 |
| #define | RTEMS_FDT_ERR_TRUNCATED 8 |
| #define | RTEMS_FDT_ERR_BADMAGIC 9 |
| #define | RTEMS_FDT_ERR_BADVERSION 10 |
| #define | RTEMS_FDT_ERR_BADSTRUCTURE 11 |
| #define | RTEMS_FDT_ERR_BADLAYOUT 12 |
| #define | RTEMS_FDT_ERR_INTERNAL 13 |
| #define | RTEMS_FDT_ERR_INVALID_HANDLE 100 |
| #define | RTEMS_FDT_ERR_NO_MEMORY 101 |
| #define | RTEMS_FDT_ERR_NOT_FOUND 102 |
| #define | RTEMS_FDT_ERR_READ_FAIL 103 |
| #define | RTEMS_FDT_ERR_REFERENCED 104 |
| #define | RTEMS_FDT_ERR_RTEMS_MIN 100 |
| #define | RTEMS_FDT_ERR_MAX 104 |
Typedefs | |
| typedef struct rtems_fdt_blob | rtems_fdt_blob |
| void | rtems_fdt_init_handle (rtems_fdt_handle *handle) |
| void | rtems_fdt_dup_handle (rtems_fdt_handle *from, rtems_fdt_handle *to) |
| void | rtems_fdt_release_handle (rtems_fdt_handle *handle) |
| bool | rtems_fdt_valid_handle (const rtems_fdt_handle *handle) |
| int | rtems_fdt_find_path_offset (rtems_fdt_handle *handle, const char *path) |
| int | rtems_fdt_load (const char *const filename, rtems_fdt_handle *handle) |
| int | rtems_fdt_register (const void *blob, rtems_fdt_handle *handle) |
| int | rtems_fdt_unload (rtems_fdt_handle *handle) |
| int | rtems_fdt_num_mem_rsv (rtems_fdt_handle *handle) |
| int | rtems_fdt_get_mem_rsv (rtems_fdt_handle *handle, int n, uint64_t *address, uint64_t *size) |
| int | rtems_fdt_subnode_offset_namelen (rtems_fdt_handle *handle, int parentoffset, const char *const name, int namelen) |
| int | rtems_fdt_subnode_offset (rtems_fdt_handle *handle, int parentoffset, const char *const name) |
| int | rtems_fdt_path_offset (rtems_fdt_handle *handle, const char *path) |
| const char * | rtems_fdt_get_name (rtems_fdt_handle *handle, int nodeoffset, int *length) |
| const void * | rtems_fdt_getprop_namelen (rtems_fdt_handle *handle, int nodeoffset, const char *const name, int namelen, int *length) |
| const void * | rtems_fdt_getprop (rtems_fdt_handle *handle, int nodeoffset, const char *const name, int *length) |
| uint32_t | rtems_fdt_get_phandle (rtems_fdt_handle *handle, int nodeoffset) |
| const char * | rtems_fdt_get_alias_namelen (rtems_fdt_handle *handle, const char *const name, int namelen) |
| const char * | rtems_fdt_get_alias (rtems_fdt_handle *handle, const char *name) |
| int | rtems_fdt_get_path (rtems_fdt_handle *handle, int nodeoffset, char *buf, int buflen) |
| int | rtems_fdt_supernode_atdepth_offset (rtems_fdt_handle *handle, int nodeoffset, int supernodedepth, int *nodedepth) |
| int | rtems_fdt_node_depth (rtems_fdt_handle *handle, int nodeoffset) |
| int | rtems_fdt_parent_offset (rtems_fdt_handle *handle, int nodeoffset) |
| int | rtems_fdt_node_offset_by_prop_value (rtems_fdt_handle *handle, int startoffset, const char *const propname, const void *propval, int proplen) |
| int | rtems_fdt_node_offset_by_phandle (rtems_fdt_handle *handle, uint32_t phandle) |
| int | rtems_fdt_node_check_compatible (rtems_fdt_handle *handle, int nodeoffset, const char *const compatible) |
| int | rtems_fdt_node_offset_by_compatible (rtems_fdt_handle *handle, int startoffset, const char *compatible) |
| int | rtems_fdt_next_node (rtems_fdt_handle *handle, int offset, int *depth) |
| const char * | rtems_fdt_strerror (int errval) |
| int | rtems_fdt_prop_value (const char *const path, const char *const propname, void *value, size_t *size) |
| int | rtems_fdt_prop_map (const char *const path, const char *const propname, const char *const names[], uint32_t *values, size_t count) |
| int | rtems_fdt_get_value (const char *const path, const char *const property, size_t size, uint32_t *value) |
| int | rtems_fdt_num_entries (rtems_fdt_handle *handle) |
| const char * | rtems_fdt_entry_name (rtems_fdt_handle *handle, int id) |
| int | rtems_fdt_entry_offset (rtems_fdt_handle *handle, int id) |
| uint32_t | rtems_fdt_get_uint32 (const void *prop) |
Support for loading, managing and accessing FDT blobs in RTEMS.
| #define RTEMS_FDT_ERR_BADLAYOUT 12 |
RTEMS_FDT_ERR_BADLAYOUT: For read-write functions, the given device tree has it's sub-blocks in an order that the function can't handle (memory reserve map, then structure, then strings). Use rtems_fdt_open_into() to reorganize the tree into a form suitable for the read-write operations.
| #define RTEMS_FDT_ERR_BADMAGIC 9 |
RTEMS_FDT_ERR_BADMAGIC: Given "device tree" appears not to be a device tree at all - it is missing the flattened device tree magic number.
| #define RTEMS_FDT_ERR_BADOFFSET 4 |
RTEMS_FDT_ERR_BADOFFSET: Function was passed a structure block offset which is out-of-bounds, or which points to an unsuitable part of the structure for the operation.
| #define RTEMS_FDT_ERR_BADPATH 5 |
RTEMS_FDT_ERR_BADPATH: Function was passed a badly formatted path (e.g. missing a leading / for a function which requires an absolute path)
| #define RTEMS_FDT_ERR_BADPHANDLE 6 |
RTEMS_FDT_ERR_BADPHANDLE: Function was passed an invalid phandle value. phandle values of 0 and -1 are not permitted.
| #define RTEMS_FDT_ERR_BADSTATE 7 |
RTEMS_FDT_ERR_BADSTATE: Function was passed an incomplete device tree created by the sequential-write functions, which is not sufficiently complete for the requested operation.
| #define RTEMS_FDT_ERR_BADSTRUCTURE 11 |
RTEMS_FDT_ERR_BADSTRUCTURE: Given device tree has a corrupt structure block or other serious error (e.g. misnested nodes, or subnodes preceding properties).
| #define RTEMS_FDT_ERR_BADVERSION 10 |
RTEMS_FDT_ERR_BADVERSION: Given device tree has a version which can't be handled by the requested operation. For read-write functions, this may mean that rtems_fdt_open_into() is required to convert the tree to the expected version.
| #define RTEMS_FDT_ERR_EXISTS 2 |
RTEMS_FDT_ERR_EXISTS: Attemped to create a node or property which already exists
| #define RTEMS_FDT_ERR_INTERNAL 13 |
"Can't happen" error indicating a bug in libfdt
| #define RTEMS_FDT_ERR_INVALID_HANDLE 100 |
Invalid handle.
| #define RTEMS_FDT_ERR_NO_MEMORY 101 |
No memory.
| #define RTEMS_FDT_ERR_NOSPACE 3 |
RTEMS_FDT_ERR_NOSPACE: Operation needed to expand the device tree, but its buffer did not have sufficient space to contain the expanded tree. Use rtems_fdt_open_into() to move the device tree to a buffer with more space.
| #define RTEMS_FDT_ERR_NOT_FOUND 102 |
File not found.
| #define RTEMS_FDT_ERR_NOTFOUND 1 |
RTEMS_FDT_ERR_NOTFOUND: The requested node or property does not exist
| #define RTEMS_FDT_ERR_READ_FAIL 103 |
Cannot read the DTB into memory.
| #define RTEMS_FDT_ERR_REFERENCED 104 |
The blob cannot be unloaded as it is referenced.
| #define RTEMS_FDT_ERR_TRUNCATED 8 |
RTEMS_FDT_ERR_TRUNCATED: Structure block of the given device tree ends without an RTEMS_FDT_END tag.
| void rtems_fdt_dup_handle | ( | rtems_fdt_handle * | from, |
| rtems_fdt_handle * | to | ||
Duplicate a handle. The copy must be released.
| from | Duplicate from this handle. |
| to | Duplicate to this handle. |
| const char* rtems_fdt_entry_name | ( | rtems_fdt_handle * | handle, |
| int | id | ||
Get the numbered entry name. Note that the id isn't the same as the offset - it's numbered 0, 1, 2 ... num_entries-1
| int rtems_fdt_entry_offset | ( | rtems_fdt_handle * | handle, |
| int | id | ||
Get the numbered entry offset. Note that the id isn't the same as the offset - it's numbered 0, 1, 2 ... num_entries-1
| int rtems_fdt_find_path_offset | ( | rtems_fdt_handle * | handle, |
| const char * | path | ||
Find a tree node by its full path looking across of loaded blobs.. Each path component may omit the unit address portion, but the results of this are undefined if any such path component is ambiguous (that is if there are multiple nodes at the relevant level matching the given component, differentiated only by unit address).
If the handle points to a valid blob it is release and the search starts from the first blob.
| handle | The FDT handle assigned to the blob if found else left invalid. |
| path | Full path of the node to locate. |
| int | If less than 0 an error code else the node offset is returned. |
| const char* rtems_fdt_get_alias | ( | rtems_fdt_handle * | handle, |
| const char * | name | ||
Retreive the path referenced by a given alias. That is, the value of the property named 'name' in the node /aliases.
| handle | The FDT handle to the current blob. |
| name | The name of the alias to look up. |
| const char* rtems_fdt_get_alias_namelen | ( | rtems_fdt_handle * | handle, |
| const char *const | name, | ||
| int | namelen | ||
Get alias based on substring. Identical to rtems_fdt_get_alias(), but only examine the first namelen characters of name for matching the alias name.
| name | The name of the alias th look up. |
| namelen | The number of characters of name to consider. |
| int rtems_fdt_get_mem_rsv | ( | rtems_fdt_handle * | handle, |
| int | n, | ||
| uint64_t * | address, | ||
| uint64_t * | size | ||
Retrieve one memory reserve map entry. On success, *address and *size will contain the address and size of the n-th reserve map entry from the device tree blob, in native-endian format.
| blob_desc | A valid blob descriptor. |
| address | Pointer to 64-bit variables to hold the addresses. |
| size | Pointer to 64-bit variables to hold the size. |
| const char* rtems_fdt_get_name | ( | rtems_fdt_handle * | handle, |
| int | nodeoffset, | ||
| int * | length | ||
Retrieve the name of a given node (including unit address) of the device tree node at structure block offset @nodeoffset. If @length is non-NULL, the length of this name is also returned, in the integer pointed to by @length.
| nodeoffset | Structure block offset of the starting node. |
| length | Pointer to an integer variable (will be overwritten) or NULL. |
| int rtems_fdt_get_path | ( | rtems_fdt_handle * | handle, |
| char * | buf, | ||
| int | buflen | ||
Determine the full path of a node. This function is expensive, as it must scan the device tree structure from the start to nodeoffset. It computes the full path of the node at offset nodeoffset, and records that path in the buffer at buf.
| nodeoffset | The offset of the node whose path to find. |
| buf | A character buffer to contain the returned path (will be overwritten) |
| buflen | The size of the character buffer at buf. |
| uint32_t rtems_fdt_get_phandle | ( | rtems_fdt_handle * | handle, |
| int | nodeoffset | ||
Retrieve the phandle of a given of the device tree node at structure block offset nodeoffset.
| handle | The FDT handle to the current blob. @oaram nodeoffset The structure block offset of the node. return uint32_t The phandle of the node at nodeoffset, on success (!= 0, != -1) 0, if the node has no phandle, or another error occurs. |
| const void* rtems_fdt_getprop | ( | rtems_fdt_handle * | handle, |
| int * | length | ||
Retrieve the value of a given property. Retrieves a pointer to the value of the property named 'name' of the node at offset nodeoffset (this will be a pointer to within the device blob itself, not a copy of the value). If lenp is non-NULL, the length of the property value is also returned, in the integer pointed to by @length.
| nodeoffset | The offset of the node whose property to find. |
| name | The name of the property to find. |
| length | A pointer to an integer variable (will be overwritten) or NULL. |
| const void* rtems_fdt_getprop_namelen | ( | rtems_fdt_handle * | handle, |
| int | namelen, | ||
| int * | length | ||
Get property value based on substring. Identical to rtems_fdt_getprop(), but only examine the first namelen characters of name for matching the property name.
| nodeoffset | Offset of the node whose property to find |
| name | The name of the property to find |
| namelen | The number of characters of name to consider |
| void rtems_fdt_init_handle | ( | rtems_fdt_handle * | handle | ) |
Initialise a handle to a default state.
| handle | The handle to initialise. |
| int rtems_fdt_load | ( | const char *const | filename, |
| rtems_fdt_handle * | handle | ||
Load a device tree blob or DTB file into memory and register it on the chain of blobs.
| filename | The name of the blob file to load. |
| handle | The handle returns the reference to the blob once load. |
| int rtems_fdt_next_node | ( | rtems_fdt_handle * | handle, |
| int | offset, | ||
| int * | depth | ||
Traverse to the next node.
| offset | The offset in the blob to start looking for the next node. |
| depth | Pointer to return the depth the node is. |
| int rtems_fdt_node_check_compatible | ( | rtems_fdt_handle * | handle, |
| const char *const | compatible | ||
Check a node's compatible property returning 0 if the given node contains a 'compatible' property with the given string as one of its elements, it returns non-zero otherwise, or on error.
| nodeoffset | The offset of a tree node. |
| compatible | The string to match against. |
| 0,if | the node has a 'compatible' property listing the given string. |
| 1,if | the node has a 'compatible' property, but it does not list the given string |
| int rtems_fdt_node_depth | ( | rtems_fdt_handle * | handle, |
Find the depth of a given node. The root node has depth 0, its immediate subnodes depth 1 and so forth.
| nodeoffset | The offset of the node whose parent to find. |
| int rtems_fdt_node_offset_by_compatible | ( | rtems_fdt_handle * | handle, |
| int | startoffset, | ||
| const char * | compatible | ||
Find nodes with a given 'compatible' value returning the offset of the first node after startoffset, which has a 'compatible' property which lists the given compatible string; or if startoffset is -1, the very first such node in the tree.
To iterate through all nodes matching the criterion, the following idiom can be used:
offset = rtems_fdt_node_offset_by_compatible(blob, -1, compatible); while (offset != -RTEMS_FDT_ERR_NOTFOUND) { // other code here offset = rtems_fdt_node_offset_by_compatible(blob, offset, compatible); }
| startoffset | Only find nodes after this offset. |
| compatible | The 'compatible' string to match against. |
| int rtems_fdt_node_offset_by_phandle | ( | rtems_fdt_handle * | handle, |
| uint32_t | phandle | ||
Find the node with a given phandle returning the offset of the node which has the given phandle value. If there is more than one node in the tree with the given phandle (an invalid tree), results are undefined.
| phandle | The phandle value. |
| int rtems_fdt_node_offset_by_prop_value | ( | rtems_fdt_handle * | handle, |
| const char *const | propname, | ||
| const void * | propval, | ||
| int | proplen | ||
Find nodes with a given property value. This funtion returns the offset of the first node after startoffset, which has a property named propname whose value is of length proplen and has value equal to propval; or if startoffset is -1, the very first such node in the tree.
To iterate through all nodes matching the criterion, the following idiom can be used: offset = rtemsfdt_node_offset_by_prop_value(blob, -1, propname, propval, proplen); while (offset != -RTEMS_FDT_ERR_NOTFOUND) { // other code here offset = rtems_fdt_node_offset_by_prop_value(fdt, offset, propname, propval, proplen); }
| propname | The property name to check. |
| propval | The property value to search for. |
| proplen | The length of the value in propval. |
| int rtems_fdt_num_entries | ( | rtems_fdt_handle * | handle | ) |
Get the number of entries in an FDT handle.
| int rtems_fdt_num_mem_rsv | ( | rtems_fdt_handle * | handle | ) |
Returns the number of entries in the device tree blob's memory reservation map. This does not include the terminating 0,0 entry or any other (0,0) entries reserved for expansion.
| int rtems_fdt_parent_offset | ( | rtems_fdt_handle * | handle, |
Find the parent of a given node. This funciton locates the parent node of a given node (that is, it finds the offset of the node which contains the node at nodeoffset as a subnode).
| int rtems_fdt_path_offset | ( | rtems_fdt_handle * | handle, |
Find a tree node by its full path. Each path component may omit the unit address portion, but the results of this are undefined if any such path component is ambiguous (that is if there are multiple nodes at the relevant level matching the given component, differentiated only by unit address).
| int rtems_fdt_prop_map | ( | const char *const | path, |
| const char *const | names[], | ||
| uint32_t * | values, | ||
| size_t | count | ||
Create a map given a path the property name and the names of the subnodes of the path.
| int rtems_fdt_prop_value | ( | const char *const | path, |
| void * | value, | ||
| size_t * | size | ||
Return a property given a path.
| int rtems_fdt_register | ( | const void * | blob, |
Register a device tree blob or DTB on to the chain of blobs.
| blob_desc | A pointer to the blob. |
| void rtems_fdt_release_handle | ( | rtems_fdt_handle * | handle | ) |
Release a blob from a handle and clear it.
| handle | The handle to check. |
| const char* rtems_fdt_strerror | ( | int | errval | ) |
Return an error string given an error value.
| errval | The error value. |
| int rtems_fdt_subnode_offset | ( | rtems_fdt_handle * | handle, |
| int | parentoffset, | ||
| const char *const | name | ||
Find a subnode of a given node at structure block offset parentoffset with the given name. The name may include a unit address, in which case rtems_fdt_subnode_offset() will find the subnode with that unit address, or the unit address may be omitted, in which case rtems_fdt_subnode_offset() will find an arbitrary subnode whose name excluding unit address matches the given name.
| parentoffset | Structure block offset of a node. |
| name | The name of the subnode to locate. |
| int rtems_fdt_subnode_offset_namelen | ( | rtems_fdt_handle * | handle, |
| int | namelen | ||
Find a subnode based on substring. Identical to rtems_fdt_subnode_offset(), but only examine the first namelen characters of name for matching the subnode name. This is useful for finding subnodes based on a portion of a larger string, such as a full path.
| arentoffset | Structure block offset of a node |
| name | Name of the subnode to locate. |
| namelen | Number of characters of name to consider. |
| int rtems_fdt_supernode_atdepth_offset | ( | rtems_fdt_handle * | handle, |
| int | supernodedepth, | ||
| int * | nodedepth | ||
Find a specific ancestor of a node at a specific depth from the root (where the root itself has depth 0, its immediate subnodes depth 1 and so forth). So rtems_fdt_supernode_atdepth_offset(blob, nodeoffset, 0, NULL); will always return 0, the offset of the root node. If the node at nodeoffset has depth D, then: rtems_fdt_supernode_atdepth_offset(blob, nodeoffset, D, NULL); will return nodeoffset itself.
| supernodedepth | The depth of the ancestor to find. @oaram nodedepth The pointer to an integer variable (will be overwritten) or NULL |
| int rtems_fdt_unload | ( | rtems_fdt_handle * | handle | ) |
Unload a device tree blob or DTB file and release any memory allocated when loading. The blob is removed from the list of registered.
| bool rtems_fdt_valid_handle | ( | const rtems_fdt_handle * | handle | ) |
Check if a handle had a valid blob assigned.
| true | The handle has a valid blob. |
| false | The handle does not have a valid blob. |
1.8.15
