RTEMS
5.1-rc2
RTEMS Flattened Device Tree Shell Command. More...
#include <ctype.h>#include <inttypes.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <time.h>#include <unistd.h>#include <rtems/shell.h>#include <rtems/rtems-fdt-shell.h>Data Structures | |
| struct | rtems_fdt_shell_cmd |
| #define | RTEMS_FDT_COMMANDS (sizeof (table) / sizeof (const rtems_fdt_shell_cmd)) |
Typedefs | |
| typedef int(* | rtems_fdt_shell_handler) (int argc, char *argv[]) |
| void | rtems_fdt_add_shell_command (void) |
| rtems_fdt_handle * | rtems_fdt_get_shell_handle (void) |
Command to play with the memory in a FDT.
| typedef int(* rtems_fdt_shell_handler) (int argc, char *argv[]) |
The type of the shell handlers we have.
| void rtems_fdt_add_shell_command | ( | void | ) |
Add a shell command to access memory and registers associated with the DTF.
| rtems_fdt_handle* rtems_fdt_get_shell_handle | ( | void | ) |
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
1.8.15
