RTEMS
5.1-rc2
Constants and Structures Associated with the QoS RES library in RTEMS. More...
| struct | qres_params_t |
Typedefs | |
| typedef int | qos_rv |
| typedef Scheduler_CBS_Server_id | qres_sid_t |
| typedef rtems_id | tid_t |
| typedef time_t | qres_time_t |
| typedef time_t | qres_atime_t |
This include file contains all the constants and structures associated with the QoS RES library in RTEMS.
| typedef int qos_rv |
Return values.
| typedef time_t qres_atime_t |
Absolute time value
| typedef Scheduler_CBS_Server_id qres_sid_t |
Server id.
| typedef time_t qres_time_t |
Time value.
| RTEMS_INLINE_ROUTINE qos_rv qres_attach_thread | ( | qres_sid_t | server_id, |
| pid_t | pid, | ||
| tid_t | task_id | ||
qres attach thread
Attach a task to an already existing server.
| RTEMS_INLINE_ROUTINE qos_rv qres_cleanup | ( | void | ) |
qres cleanup
Cleanup resources associated to the QoS RES Library.
| RTEMS_INLINE_ROUTINE qos_rv qres_create_server | ( | qres_params_t * | params, |
| qres_sid_t * | server_id | ||
qres create server
Create a new server with specified parameters.
| RTEMS_INLINE_ROUTINE qos_rv qres_destroy_server | ( | qres_sid_t | server_id | ) |
qres destroy server
Detach all tasks from a server and destroy it.
| RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread | ( | qres_sid_t | server_id, |
| pid_t | pid, | ||
qres detach thread
Detach from the QoS Server.
| RTEMS_INLINE_ROUTINE qos_rv qres_get_appr_budget | ( | qres_sid_t | server_id, |
| qres_time_t * | appr_budget | ||
qres get approved budget
Retrieve the budget that has been approved for the subsequent server instances.
| RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget | ( | qres_sid_t | server_id, |
| qres_time_t * | current_budget | ||
qres get current budget
Retrieve remaining budget for the current server instance.
| RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time | ( | qres_sid_t | server_id, |
| qres_time_t * | exec_time, | ||
| qres_atime_t * | abs_time | ||
qres get execution time
Retrieve time info relative to the current server.
| RTEMS_INLINE_ROUTINE qos_rv qres_get_params | ( | qres_sid_t | server_id, |
| qres_params_t * | params | ||
qres get params
Retrieve QoS scheduling parameters.
| RTEMS_INLINE_ROUTINE qos_rv qres_get_sid | ( | pid_t | pid, |
| tid_t | task_id, | ||
qres get server id
Get a thread server id, or QOS_E_NOT_FOUND if it is not attached to any server.
| RTEMS_INLINE_ROUTINE qos_rv qres_init | ( | void | ) |
qres init
Initializes the QoS RES library.
| RTEMS_INLINE_ROUTINE qos_rv qres_set_params | ( | qres_sid_t | server_id, |
qres set params
Change QoS scheduling parameters.
1.8.15
