RTEMS
5.1-rc2
Table of User Defined Configuration Parameters. More...
#include <rtems/score/object.h>#include <rtems/score/isr.h>#include <rtems/score/memory.h>#include <rtems/score/smp.h>#include <rtems/score/stack.h>#include <rtems/score/userextdata.h>#include <rtems/score/threadidledata.h>#include <rtems/score/watchdogticks.h>#include <rtems/score/wkspacedata.h>#include <rtems/rtems/config.h>#include <rtems/extension.h>Go to the source code of this file.
| #define | RTEMS_UNLIMITED_OBJECTS OBJECTS_UNLIMITED_OBJECTS |
| #define | rtems_resource_unlimited(resource) ( resource | RTEMS_UNLIMITED_OBJECTS ) |
| #define | rtems_resource_is_unlimited(resource) _Objects_Is_unlimited(resource) |
| #define | rtems_resource_maximum_per_allocation(resource) _Objects_Maximum_per_allocation(resource) |
| #define | rtems_configuration_get_unified_work_area() (_Workspace_Is_unified) |
| #define | rtems_configuration_get_stack_allocator_avoids_work_space() (_Stack_Allocator_avoids_workspace) |
| Return if the stack allocator avoids the work space. More... | |
| #define | rtems_configuration_get_work_space_size() |
| #define | rtems_configuration_get_microseconds_per_tick() (_Watchdog_Microseconds_per_tick) |
| #define | rtems_configuration_get_milliseconds_per_tick() (_Watchdog_Microseconds_per_tick / 1000) |
| #define | rtems_configuration_get_nanoseconds_per_tick() (_Watchdog_Nanoseconds_per_tick) |
| #define | rtems_configuration_get_ticks_per_timeslice() (_Watchdog_Ticks_per_timeslice) |
| #define | rtems_configuration_get_idle_task() (_Thread_Idle_entry) |
| #define | rtems_configuration_get_idle_task_stack_size() (_Thread_Idle_stack_size) |
| #define | rtems_configuration_get_interrupt_stack_size() ((size_t) _ISR_Stack_size) |
| #define | rtems_configuration_get_stack_allocate_init_hook() (_Stack_Allocator_initialize) |
| #define | rtems_configuration_get_stack_allocate_hook() (_Stack_Allocator_allocate) |
| #define | rtems_configuration_get_stack_free_hook() (_Stack_Allocator_free) |
| #define | rtems_configuration_get_do_zero_of_workspace() _Memory_Zero_before_use |
| #define | rtems_configuration_get_number_of_initial_extensions() ((uint32_t) _User_extensions_Initial_count) |
| #define | rtems_configuration_get_user_extension_table() (&_User_extensions_Initial_extensions[ 0 ]) |
| #define | rtems_configuration_get_user_multiprocessing_table() NULL |
| #define | rtems_configuration_get_maximum_processors() (_SMP_Processor_configured_maximum) |
| Returns the configured maximum count of processors. More... | |
Typedefs | |
| typedef Stack_Allocator_initialize | rtems_stack_allocate_init_hook |
| The stack allocator initialization handler. More... | |
| typedef Stack_Allocator_allocate | rtems_stack_allocate_hook |
| Stack allocator allocate handler. More... | |
| typedef Stack_Allocator_free | rtems_stack_free_hook |
| Stack allocator free handler. More... | |
| uintptr_t | rtems_configuration_get_stack_space_size (void) |
| uint32_t | rtems_configuration_get_maximum_extensions (void) |
This include file contains the table of user defined configuration parameters.
| #define rtems_configuration_get_do_zero_of_workspace | ( | ) | _Memory_Zero_before_use |
This macro assists in accessing the field which indicates whether RTEMS is responsible for zeroing the Executive Workspace.
| #define rtems_configuration_get_maximum_processors | ( | ) | (_SMP_Processor_configured_maximum) |
The actual number of processors available for the application will be less than or equal to the configured maximum count of processors.
On single-processor configurations this is a compile time constant which evaluates to one.
| #define rtems_configuration_get_stack_allocator_avoids_work_space | ( | ) | (_Stack_Allocator_avoids_workspace) |
| true | The stack allocator must not allocate the thread stacks from the RTEMS Workspace |
| false | The stack allocator should allocate the thread stacks from the RTEMS Workspace. |
| #define rtems_configuration_get_work_space_size | ( | ) |
| stack_size | The size of the stack area to allocate in bytes. |
| NULL | Not enough memory. |
| other | Pointer to begin of stack area. |
| stack_space_size | The size of the stack space in bytes. |
| ] | addr A pointer to previously allocated stack area or NULL. |
1.8.15
