RTEMS
5.1-rc2
#include "chip.h"Functions | |
| void | ICM_Enable (void) |
| Enable ICM, the ICM controller is activated. | |
| void | ICM_Disable (void) |
| Disable ICM, if a region is active, this region is terminated. | |
| void | ICM_SoftReset (void) |
| Resets the ICM controller. | |
| void | ICM_ReComputeHash (uint8_t region) |
| Recompute Internal hash. More... | |
| void | ICM_EnableMonitor (uint8_t region) |
| Enable region monitoring for given region. More... | |
| void | ICM_DisableMonitor (uint8_t region) |
| Disable region monitoring for given region. More... | |
| void | ICM_Configure (uint32_t mode) |
| Configures an ICM peripheral with the specified parameters. More... | |
| void | ICM_EnableIt (uint32_t sources) |
| Enables the selected interrupts sources on a ICM peripheral. More... | |
| void | ICM_DisableIt (uint32_t sources) |
| Disables the selected interrupts sources on a ICM peripheral. More... | |
| uint32_t | ICM_GetIntStatus (void) |
| Get the current interrupt status register of the given ICM peripheral. More... | |
| uint32_t | ICM_GetStatus (void) |
| Get the current status register of the given ICM peripheral. More... | |
| uint32_t | ICM_GetUStatus (void) |
| Get the undefined access status register of the given ICM peripheral. More... | |
| void | ICM_SetDescStartAddress (uint32_t addr) |
| Set descriptor area start address register. More... | |
| void | ICM_SetHashStartAddress (uint32_t addr) |
| Set hash area start address register. More... | |
| void | ICM_SetInitHashValue (uint32_t val) |
| Set ICM user initial Hash value register. More... | |
Implementation of True Random Number Generator (ICM)
| void ICM_Configure | ( | uint32_t | mode | ) |
| mode | Desired value for the ICM mode register (see the datasheet). |
| void ICM_DisableIt | ( | uint32_t | sources | ) |
| sources | Bitwise OR of selected interrupt sources. |
| void ICM_DisableMonitor | ( | uint8_t | region | ) |
| region,When | bit RMDIS[region] is set to one, the monitoring of Region is disabled. |
| void ICM_EnableIt | ( | uint32_t | sources | ) |
| void ICM_EnableMonitor | ( | uint8_t | region | ) |
| region,When | bit RMEN[region] is set to one, the monitoring of Region is activated. |
| uint32_t ICM_GetIntStatus | ( | void | ) |
| uint32_t ICM_GetStatus | ( | void | ) |
| uint32_t ICM_GetUStatus | ( | void | ) |
| void ICM_ReComputeHash | ( | uint8_t | region | ) |
| region,When | REHASH[region] is set to one, the region digest is re-computed. |
| void ICM_SetDescStartAddress | ( | uint32_t | addr | ) |
| addr | start address |
| void ICM_SetHashStartAddress | ( | uint32_t | addr | ) |
| void ICM_SetInitHashValue | ( | uint32_t | val | ) |
| val | Initial Hash Value |
1.8.15
