RTEMS
5.1-rc2
Files | |
| file | mw_uid.h |
| Input Devices for MicroWindows. | |
| file | mw_print.c |
| MicroWindows Print. | |
| file | mw_uid.c |
| MicroWindows UID. | |
| struct | MW_UID_MESSAGE |
Enumerations | |
| enum | MW_INPUT_DEVICE_TYPE { MV_UID_INVALID = 0, MV_UID_REL_POS = 1, MV_UID_ABS_POS = 2, MV_UID_KBD = 3, MV_UID_TIMER = 4 } |
| int | uid_open_queue (const char *q_name, int flags, size_t max_msgs) |
| int | uid_close_queue (void) |
| int | uid_read_message (struct MW_UID_MESSAGE *m, unsigned long timeout) |
| int | uid_send_message (struct MW_UID_MESSAGE *m) |
| int | uid_register_device (int fd, const char *q_name) |
| int | uid_unregister_device (int fd) |
| int | uid_set_kbd_mode (int fd, int mode, int *old_mode) |
| void | uid_print_message (struct MW_UID_MESSAGE *uid) |
| void | uid_print_message_with_plugin (const rtems_printer *printer, struct MW_UID_MESSAGE *uid) |
| int uid_close_queue | ( | void | ) |
This method closes the message queue and deletes it.
| This | method returns 0 on success and -1 on error. |
| int uid_open_queue | ( | const char * | q_name, |
| int | flags, | ||
| size_t | max_msgs | ||
This method creates the message queue that holds events from the input devices.
| [in] | q_name | is the name of the message queue |
| [in] | flags | controls the behaviour of the queue |
| [in] | max_msgs | specifies the maximum number of pending messages |
| void uid_print_message | ( | struct MW_UID_MESSAGE * | uid | ) |
This methods prints the specified UID message using printk
| [in] | uid | points to the message to print |
| void uid_print_message_with_plugin | ( | const rtems_printer * | printer, |
| struct MW_UID_MESSAGE * | uid | ||
This methods prints the specified UID message using your fprintf style method of choice.
| [in] | RTEMS | printer |
| int uid_read_message | ( | struct MW_UID_MESSAGE * | m, |
| unsigned long | timeout | ||
This method reads a message from the queue. It waits up to the specified timeout in miliseconds. A timeout of 0 is a poll.
| [in] | m | will be filled in with the received message |
| [in] | timeout | is the maximum number of mulliseconds to wait |
| int uid_register_device | ( | int | fd, |
| const char * | q_name | ||
This method registers the device associated with fd to to insert data to the queue
| int uid_send_message | ( | struct MW_UID_MESSAGE * | m | ) |
This methods writes a message to the queue.
| [in] | m | is the message to send |
1.8.15
