RTEMS
5.1-rc2
Files | |
| file | dumpbuf.c |
| Dump Buffer. | |
| void | rtems_print_buffer (const unsigned char *buffer, int length) |
| Print memory buffer. More... | |
| void rtems_print_buffer | ( | const unsigned char * | buffer, |
| const int | length | ||
This method prints length bytes beginning at buffer in a nice format similar to what one would expect from a debugger or ROM monitor.
| [in] | buffer | is the address of the buffer |
| [in] | length | is the length of the buffer |
Non-printable chars will appear as dots.
| buffer | The buffer we'll print. |
| length | Amount of bytes from buffer we'll print. This can't be unsigned because we don't have a way to check if we're erroneously getting a negative length. |
1.8.15
