RTEMS
5.1-rc2
| struct | Rstc |
| Rstc hardware registers. More... | |
| #define | RSTC_CR_PROCRST (0x1u << 0) |
| (RSTC_CR) Processor Reset | |
| #define | RSTC_CR_EXTRST (0x1u << 3) |
| (RSTC_CR) External Reset | |
| #define | RSTC_CR_KEY_Pos 24 |
| #define | RSTC_CR_KEY_Msk (0xffu << RSTC_CR_KEY_Pos) |
| (RSTC_CR) System Reset Key | |
| #define | RSTC_CR_KEY(value) ((RSTC_CR_KEY_Msk & ((value) << RSTC_CR_KEY_Pos))) |
| #define | RSTC_CR_KEY_PASSWD (0xA5u << 24) |
| (RSTC_CR) Writing any other value in this field aborts the write operation. | |
| #define | RSTC_SR_URSTS (0x1u << 0) |
| (RSTC_SR) User Reset Status | |
| #define | RSTC_SR_RSTTYP_Pos 8 |
| #define | RSTC_SR_RSTTYP_Msk (0x7u << RSTC_SR_RSTTYP_Pos) |
| (RSTC_SR) Reset Type | |
| #define | RSTC_SR_RSTTYP_GENERAL_RST (0x0u << 8) |
| (RSTC_SR) First power-up reset | |
| #define | RSTC_SR_RSTTYP_BACKUP_RST (0x1u << 8) |
| (RSTC_SR) Return from Backup Mode | |
| #define | RSTC_SR_RSTTYP_WDT_RST (0x2u << 8) |
| (RSTC_SR) Watchdog fault occurred | |
| #define | RSTC_SR_RSTTYP_SOFT_RST (0x3u << 8) |
| (RSTC_SR) Processor reset required by the software | |
| #define | RSTC_SR_RSTTYP_USER_RST (0x4u << 8) |
| (RSTC_SR) NRST pin detected low | |
| #define | RSTC_SR_NRSTL (0x1u << 16) |
| (RSTC_SR) NRST Pin Level | |
| #define | RSTC_SR_SRCMP (0x1u << 17) |
| (RSTC_SR) Software Reset Command in Progress | |
| #define | RSTC_MR_URSTEN (0x1u << 0) |
| (RSTC_MR) User Reset Enable | |
| #define | RSTC_MR_URSTIEN (0x1u << 4) |
| (RSTC_MR) User Reset Interrupt Enable | |
| #define | RSTC_MR_ERSTL_Pos 8 |
| #define | RSTC_MR_ERSTL_Msk (0xfu << RSTC_MR_ERSTL_Pos) |
| (RSTC_MR) External Reset Length | |
| #define | RSTC_MR_ERSTL(value) ((RSTC_MR_ERSTL_Msk & ((value) << RSTC_MR_ERSTL_Pos))) |
| #define | RSTC_MR_KEY_Pos 24 |
| #define | RSTC_MR_KEY_Msk (0xffu << RSTC_MR_KEY_Pos) |
| (RSTC_MR) Write Access Password | |
| #define | RSTC_MR_KEY(value) ((RSTC_MR_KEY_Msk & ((value) << RSTC_MR_KEY_Pos))) |
| #define | RSTC_MR_KEY_PASSWD (0xA5u << 24) |
| (RSTC_MR) Writing any other value in this field aborts the write operation.Always reads as 0. | |
SOFTWARE API DEFINITION FOR Reset Controller
1.8.15
