RTEMS
5.1-rc2
Timecounter Handler. More...
Files | |
| file | timecounter.h |
| Timecounter API. | |
| file | timecounterimpl.h |
| Timecounter Implementation. | |
| #define | _Timecounter_Acquire(lock_context) _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context ) |
| Lock to protect the timecounter mechanic. More... | |
| #define | _Timecounter_Release(lock_context) _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context) |
| Releases the timecounter lock. More... | |
| void | _Timecounter_Bintime (struct bintime *bt) |
| Returns the wall clock time in the bintime format. More... | |
| void | _Timecounter_Nanotime (struct timespec *ts) |
| Returns the wall clock time in the timespec format. More... | |
| void | _Timecounter_Microtime (struct timeval *tv) |
| Returns the wall clock time in the timeval format. More... | |
| void | _Timecounter_Binuptime (struct bintime *bt) |
| Returns the uptime in the bintime format. More... | |
| int64_t | _Timecounter_Sbinuptime (void) |
| Returns the uptime in the sbintime_t format. More... | |
| void | _Timecounter_Nanouptime (struct timespec *ts) |
| Returns the uptime in the timespec format. More... | |
| void | _Timecounter_Microuptime (struct timeval *tv) |
| Returns the uptime in the timeval format. More... | |
| void | _Timecounter_Getbintime (struct bintime *bt) |
| void | _Timecounter_Getnanotime (struct timespec *ts) |
| void | _Timecounter_Getmicrotime (struct timeval *tv) |
| void | _Timecounter_Getbinuptime (struct bintime *bt) |
| void | _Timecounter_Getnanouptime (struct timespec *ts) |
| void | _Timecounter_Getmicrouptime (struct timeval *tv) |
| void | _Timecounter_Getboottime (struct timeval *tv) |
| Returns the boot time in the timeval format. More... | |
| void | _Timecounter_Getboottimebin (struct bintime *bt) |
| Returns the boot time in the bintime format. More... | |
| void | _Timecounter_Install (struct timecounter *tc) |
| Installs the timecounter. More... | |
| void | _Timecounter_Tick (void) |
| Performs a timecounter tick. | |
| void | _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context) |
| Performs a simple timecounter tick. More... | |
| void | _Timecounter_Set_clock (const struct bintime *bt, ISR_lock_Context *lock_context) |
| Sets the timecounter clock to the given value. More... | |
| volatile time_t | _Timecounter_Time_second |
| The wall clock time in seconds. | |
| volatile int32_t | _Timecounter_Time_uptime |
| The uptime in seconds. More... | |
| struct timecounter * | _Timecounter |
| The current timecounter. | |
| #define _Timecounter_Acquire | ( | lock_context | ) | _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context ) |
Acquires the timecounter lock.
| lock_context | The lock context. |
| #define _Timecounter_Release | ( | lock_context | ) | _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context) |
| void _Timecounter_Bintime | ( | struct bintime * | bt | ) |
| [out] | bt | Returns the wall clock time. |
| void _Timecounter_Binuptime | ( | struct bintime * | bt | ) |
| [out] | bt | Returns the uptime. |
| void _Timecounter_Getbintime | ( | struct bintime * | bt | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Bintime() variant.
| [out] | ts | Returns the wall clock time. |
| void _Timecounter_Getbinuptime | ( | struct bintime * | bt | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Binuptime() variant.
| [out] | ts | Returns the uptime. |
| void _Timecounter_Getboottime | ( | struct timeval * | tv | ) |
| [out] | tv | Returns the boot time. |
| void _Timecounter_Getboottimebin | ( | struct bintime * | bt | ) |
| void _Timecounter_Getmicrotime | ( | struct timeval * | tv | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microtime() variant.
| [out] | tv | Returns the wall clock time. |
| void _Timecounter_Getmicrouptime | ( | struct timeval * | tv | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microuptime() variant.
| [out] | tv | Returns the uptime. |
| void _Timecounter_Getnanotime | ( | struct timespec * | ts | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanotime() variant.
| void _Timecounter_Getnanouptime | ( | struct timespec * | ts | ) |
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanouptime() variant.
| void _Timecounter_Install | ( | struct timecounter * | tc | ) |
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
| tc | The timecounter. |
| void _Timecounter_Microtime | ( | struct timeval * | tv | ) |
| void _Timecounter_Microuptime | ( | struct timeval * | tv | ) |
| void _Timecounter_Nanotime | ( | struct timespec * | ts | ) |
| void _Timecounter_Nanouptime | ( | struct timespec * | ts | ) |
| int64_t _Timecounter_Sbinuptime | ( | void | ) |
| void _Timecounter_Set_clock | ( | const struct bintime * | bt, |
| ISR_lock_Context * | lock_context | ||
| bt | The value to set the clock to. |
| lock_context | The interrupt lock context. |
| void _Timecounter_Tick_simple | ( | uint32_t | delta, |
| uint32_t | offset, | ||
This is a special purpose tick function for simple timecounter to support legacy clock drivers.
| delta | The time in timecounter ticks elapsed since the last call to _Timecounter_Tick_simple(). |
| offset | The current value of the timecounter. |
| ] | lock_context The lock context of the corresponding _Timecounter_Acquire(). |
| volatile int32_t _Timecounter_Time_uptime |
For compatibility with the FreeBSD network stack the initial value is one second.
1.8.15
