RTEMS
5.1-rc2
EDF Priority SMP Scheduler. More...
Files | |
| file | scheduleredfsmp.h |
| EDF SMP Scheduler API. | |
| file | scheduleredfsmp.c |
| EDF SMP Scheduler Implementation. | |
| struct | Scheduler_EDF_SMP_Node |
| struct | Scheduler_EDF_SMP_Ready_queue |
| struct | Scheduler_EDF_SMP_Context |
| #define | SCHEDULER_EDF_SMP_ENTRY_POINTS |
| void | _Scheduler_EDF_SMP_Initialize (const Scheduler_Control *scheduler) |
| Initializes the context of the scheduler control. More... | |
| void | _Scheduler_EDF_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given priority. More... | |
| void | _Scheduler_EDF_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Blocks the thread. More... | |
| void | _Scheduler_EDF_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Unblocks the thread. More... | |
| void | _Scheduler_EDF_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the node. More... | |
| bool | _Scheduler_EDF_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help operation. More... | |
| void | _Scheduler_EDF_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help operation. More... | |
| void | _Scheduler_EDF_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws node operation. More... | |
| void | _Scheduler_EDF_SMP_Pin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu) |
| Pin thread operation. More... | |
| void | _Scheduler_EDF_SMP_Unpin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu) |
| Unpin thread operation. More... | |
| void | _Scheduler_EDF_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds processor. More... | |
| Thread_Control * | _Scheduler_EDF_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. More... | |
| void | _Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Performs the yield of a thread. More... | |
| void | _Scheduler_EDF_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu) |
| Starts an idle thread. More... | |
| bool | _Scheduler_EDF_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity) |
| Checks if the processor set of the scheduler is the subset of the affinity set. More... | |
| #define SCHEDULER_EDF_SMP_ENTRY_POINTS |
| void _Scheduler_EDF_SMP_Add_processor | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | idle | ||
Adds processor.
| [in,out] | scheduler | The scheduler instance to add the processor to. |
| idle | The idle thread of the processor to add. |
| bool _Scheduler_EDF_SMP_Ask_for_help | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
| scheduler | The scheduler instance to ask for help. |
| the_thread | The thread needing help. |
| node | The scheduler node. |
| true | Ask for help was successful. |
| false | Ask for help was not successful. |
| void _Scheduler_EDF_SMP_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | thread, | ||
Blocks the thread.
| scheduler | The scheduler instance. | |
| [in,out] | the_thread | The thread to block. |
| [in,out] | node | The thread's scheduler node. |
| void _Scheduler_EDF_SMP_Initialize | ( | const Scheduler_Control * | scheduler | ) |
| scheduler | The scheduler control. |
| void _Scheduler_EDF_SMP_Node_initialize | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | node, | ||
| Priority_Control | priority | ||
| [out] | node | The node to initialize. |
| the_thread | The thread of the scheduler node. | |
| priority | The priority for the initialization. |
| void _Scheduler_EDF_SMP_Pin | ( | const Scheduler_Control * | scheduler, |
| struct Per_CPU_Control * | cpu | ||
| scheduler | The scheduler instance of the specified processor. |
| the_thread | The thread to pin. |
| node | The scheduler node of the thread. |
| cpu | The processor to pin the thread. |
| void _Scheduler_EDF_SMP_Reconsider_help_request | ( | const Scheduler_Control * | scheduler, |
| scheduler | The scheduler instance to reconsider the help request. |
| the_thread | The thread reconsidering a help request. |
| Thread_Control* _Scheduler_EDF_SMP_Remove_processor | ( | const Scheduler_Control * | scheduler, |
| cpu | The cpu control to remove from scheduler. |
| bool _Scheduler_EDF_SMP_Set_affinity | ( | const Scheduler_Control * | scheduler, |
| const Processor_mask * | affinity | ||
Default implementation of the set affinity scheduler operation.
| scheduler | This parameter is unused. |
| thread | This parameter is unused. |
| node | This parameter is unused. |
| affinity | The new processor affinity set for the thread. |
| true | The processor set of the scheduler is a subset of the affinity set. |
| false | The processor set of the scheduler is not a subset of the affinity set. |
| void _Scheduler_EDF_SMP_Start_idle | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | idle, | ||
| [in,out] | the_thread | An idle thread. |
| cpu | The cpu for the operation. |
| void _Scheduler_EDF_SMP_Unblock | ( | const Scheduler_Control * | scheduler, |
| [in,out] | the_thread | The thread to unblock. |
| void _Scheduler_EDF_SMP_Unpin | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread to unpin. |
| cpu | The processor to unpin the thread. |
| void _Scheduler_EDF_SMP_Update_priority | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread for the operation. |
| void _Scheduler_EDF_SMP_Withdraw_node | ( | const Scheduler_Control * | scheduler, |
| Thread_Scheduler_state | next_state | ||
| scheduler | The scheduler instance to withdraw the node. |
| the_thread | The thread using the node. |
| node | The scheduler node to withdraw. |
| next_state | The next thread scheduler state in case the node is scheduled. |
| void _Scheduler_EDF_SMP_Yield | ( | const Scheduler_Control * | scheduler, |
| [in,out] | the_thread | The thread that performed the yield operation. |
| node | The scheduler node of the_thread. |
1.8.15
