RTEMS
5.1-rc2
EDF Scheduler. More...
Files | |
| file | scheduleredf.h |
| Data Related to the Manipulation of Threads for the EDF Scheduler. | |
| file | scheduleredfimpl.h |
| EDF Scheduler Implementation. | |
| struct | Scheduler_EDF_Context |
| struct | Scheduler_EDF_Node |
| Scheduler node specialization for EDF schedulers. More... | |
| #define | SCHEDULER_EDF_MAXIMUM_PRIORITY INT_MAX |
| #define | SCHEDULER_EDF_ENTRY_POINTS |
| #define | SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
| void | _Scheduler_EDF_Initialize (const Scheduler_Control *scheduler) |
| Initializes EDF scheduler. More... | |
| void | _Scheduler_EDF_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Removes the blocking thread from the ready queue and schedules is only again if the thread is executing or the heir thread. More... | |
| void | _Scheduler_EDF_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Sets the heir thread to be the next ready thread in the rbtree ready queue. More... | |
| void | _Scheduler_EDF_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes an EDF specific scheduler node of the_thread. More... | |
| void | _Scheduler_EDF_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Performs an unblocking of the thread. More... | |
| void | _Scheduler_EDF_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the scheduler node. More... | |
| Priority_Control | _Scheduler_EDF_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Gets the mapped priority map of the priority control. More... | |
| Priority_Control | _Scheduler_EDF_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Gets the unmapped priority map of the priority control. More... | |
| void | _Scheduler_EDF_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Executes a thread yield for the thread. More... | |
| void | _Scheduler_EDF_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
| Releases a EDF job. More... | |
| void | _Scheduler_EDF_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Cancels a job and removes the thread from the queue context. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Context * | _Scheduler_EDF_Get_context (const Scheduler_Control *scheduler) |
| Gets the context of the scheduler. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Node * | _Scheduler_EDF_Thread_get_node (Thread_Control *the_thread) |
| Gets the scheduler EDF node of the thread. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Node * | _Scheduler_EDF_Node_downcast (Scheduler_Node *node) |
| Returns the scheduler EDF node for the scheduler node. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_EDF_Less (const void *left, const RBTree_Node *right) |
| Checks if left is less than the priority of the node right. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_EDF_Priority_less_equal (const void *left, const RBTree_Node *right) |
| Checks if left is less or equal than the priority of the node right. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_EDF_Enqueue (Scheduler_EDF_Context *context, Scheduler_EDF_Node *node, Priority_Control insert_priority) |
| Inserts the scheduler node with the given priority in the ready queue of the context. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_EDF_Extract (Scheduler_EDF_Context *context, Scheduler_EDF_Node *node) |
| Extracts the scheduler node from the ready queue of the context. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_EDF_Extract_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Extracts the node from the context of the given scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_EDF_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch) |
| Schedules the next ready thread as the heir. More... | |
EDF Scheduler.
| #define SCHEDULER_EDF_ENTRY_POINTS |
Entry points for the Earliest Deadline First Scheduler.
| #define SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
This is just a most significant bit of Priority_Control type. It distinguishes threads which are deadline driven (priority represented by a lower number than SCHEDULER_EDF_PRIO_MSB) from those ones who do not have any deadlines and thus are considered background tasks.
| void _Scheduler_EDF_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
| [in,out] | scheduler | The scheduler for the operation. |
| the_thread | The thread to operate upon. | |
| [in,out] | node | The scheduler node for this thread. |
| void _Scheduler_EDF_Cancel_job | ( | const Scheduler_Control * | scheduler, |
| Priority_Node * | priority_node, | ||
| Thread_queue_Context * | queue_context | ||
| scheduler | The scheduler instance. | |
| the_thread | The thread for the operation. | |
| [in,out] | priority_node | The corresponding priority node. |
| [in,out] | queue_context | The thread queue context. |
| RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Enqueue | ( | Scheduler_EDF_Context * | context, |
| Scheduler_EDF_Node * | node, | ||
| Priority_Control | insert_priority | ||
| [in,out] | context | The context to insert the node in. |
| node | The node to be inserted. | |
| insert_priority | The priority with which the node will be inserted. |
| RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Extract | ( | Scheduler_EDF_Context * | context, |
| Scheduler_EDF_Node * | node | ||
| [in,out] | context | The context to extract the node from. |
| [in,out] | node | The node to extract. |
| RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Extract_body | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread is not used in this method. | |
| [in,out] | node | The node to be extracted. |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Context* _Scheduler_EDF_Get_context | ( | const Scheduler_Control * | scheduler | ) |
| void _Scheduler_EDF_Initialize | ( | const Scheduler_Control * | scheduler | ) |
This routine initializes the EDF scheduler.
| [in,out] | scheduler | The scheduler instance. |
| RTEMS_INLINE_ROUTINE bool _Scheduler_EDF_Less | ( | const void * | left, |
| const RBTree_Node * | right | ||
| left | The priority on the left hand side of the comparison. |
| right | The node of which the priority is compared to left. |
| true | left is less than the priority of right. |
| false | left is greater or equal than the priority of right. |
| Priority_Control _Scheduler_EDF_Map_priority | ( | const Scheduler_Control * | scheduler, |
| Priority_Control | priority | ||
| scheduler | Not used in this operation. |
| priority | The priority control to get the priority map of. |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Node* _Scheduler_EDF_Node_downcast | ( | Scheduler_Node * | node | ) |
| node | The scheduler node of which the scheduler EDF node is returned. |
| void _Scheduler_EDF_Node_initialize | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | node, | ||
| node | The node being initialized. |
| the_thread | The thread of the node. |
| priority | The thread priority. |
| RTEMS_INLINE_ROUTINE bool _Scheduler_EDF_Priority_less_equal | ( | const void * | left, |
| true | left is less or equal than the priority of right. |
| false | left is greater than the priority of right. |
| void _Scheduler_EDF_Release_job | ( | const Scheduler_Control * | scheduler, |
| uint64_t | deadline, | ||
Releases a EDF job.
| scheduler | The scheduler instance | |
| the_thread | The thread | |
| [in,out] | priority_node | The priority node for the operation. |
| deadline | The deadline for the job. | |
| void _Scheduler_EDF_Schedule | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
This kernel routine sets the heir thread to be the next ready thread in the rbtree ready queue.
| the_thread | The thread being scheduled. |
| RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Schedule_body | ( | const Scheduler_Control * | scheduler, |
| bool | force_dispatch | ||
| scheduler | The scheduler instance to schedule the minimum of the context of. |
| the_thread | This parameter is not used. |
| force_dispatch | Indicates whether the current heir is blocked even if it is not set as preemptible. |
| RTEMS_INLINE_ROUTINE Scheduler_EDF_Node* _Scheduler_EDF_Thread_get_node | ( | Thread_Control * | the_thread | ) |
| the_thread | The thread to get the scheduler node of. |
| void _Scheduler_EDF_Unblock | ( | const Scheduler_Control * | scheduler, |
| the_thread | The unblocking thread. May be set as new heir. | |
| [in,out] | node | The scheduler node for the thread. |
| Priority_Control _Scheduler_EDF_Unmap_priority | ( | const Scheduler_Control * | scheduler, |
| void _Scheduler_EDF_Update_priority | ( | const Scheduler_Control * | scheduler, |
| [in,out] | node | The priority node to update the priority of. |
| void _Scheduler_EDF_Yield | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread that performs the yield. | |
1.8.15
