RTEMS
5.1-rc2
Low-level event recording support. More...
| struct | rtems_record_client_per_cpu |
| struct | rtems_record_client_context |
| struct | rtems_record_item_32 |
| The 32-bit format record item. More... | |
| struct | rtems_record_dump_base64_zlib_context |
| The context for record dumps with zlib compression and base64 encoding. More... | |
| #define | rtems_record_caller() _Record_Caller( RTEMS_RETURN_ADDRESS() ) |
| Generates an RTEMS_RECORD_CALLER and an RTEMS_RECORD_LINE event. More... | |
| #define | rtems_record_caller_3(event, data) _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data ) |
| Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and an extra event. More... | |
| #define | rtems_record_caller_4(event_0, data_0, event_1, data_1) |
| Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and two extra events. More... | |
| #define | rtems_record_caller_arg(data) _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data ) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and one argument event. More... | |
| #define | rtems_record_caller_arg_2(data_0, data_1) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and two argument events. More... | |
| #define | rtems_record_caller_arg_3(data_0, data_1, data_2) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and three argument events. More... | |
| #define | rtems_record_caller_arg_4(data_0, data_1, data_2, data_3) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and four argument events. More... | |
| #define | rtems_record_caller_arg_5(data_0, data_1, data_2, data_3, data_4) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and five argument events. More... | |
| #define | rtems_record_caller_arg_6(data_0, data_1, data_2, data_3, data_4, data_5) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and six argument events. More... | |
| #define | rtems_record_caller_arg_7(data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and seven argument events. More... | |
| #define | rtems_record_caller_arg_8(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and eight argument events. More... | |
| #define | rtems_record_caller_arg_9(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and nine argument events. More... | |
| #define | rtems_record_caller_arg_10(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
| Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and ten argument events. More... | |
| #define | rtems_record_entry(event) rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
| Generates the specified entry event. More... | |
| #define | rtems_record_entry_1(event, data) |
| Generates the specified entry event and an argument event. More... | |
| #define | rtems_record_entry_2(event, data_0, data_1) _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
| Generates the specified entry event and two argument events. More... | |
| #define | rtems_record_entry_3(event, data_0, data_1, data_2) |
| Generates the specified entry event and three argument events. More... | |
| #define | rtems_record_entry_4(event, data_0, data_1, data_2, data_3) |
| Generates the specified entry event and four argument events. More... | |
| #define | rtems_record_entry_5(event, data_0, data_1, data_2, data_3, data_4) |
| Generates the specified entry event and five argument events. More... | |
| #define | rtems_record_entry_6(event, data_0, data_1, data_2, data_3, data_4, data_5) |
| Generates the specified entry event and six argument events. More... | |
| #define | rtems_record_entry_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
| Generates the specified entry event and seven argument events. More... | |
| #define | rtems_record_entry_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
| Generates the specified entry event and eight argument events. More... | |
| #define | rtems_record_entry_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
| Generates the specified entry event and nine argument events. More... | |
| #define | rtems_record_entry_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
| Generates the specified entry event and ten argument events. More... | |
| #define | rtems_record_exit(event) rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
| Generates the specified exit event. More... | |
| #define | rtems_record_exit_1(event, data) |
| Generates the specified exit event and a return event. More... | |
| #define | rtems_record_exit_2(event, data_0, data_1) _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
| Generates the specified exit event and two argument events. More... | |
| #define | rtems_record_exit_3(event, data_0, data_1, data_2) |
| Generates the specified exit event and three argument events. More... | |
| #define | rtems_record_exit_4(event, data_0, data_1, data_2, data_3) |
| Generates the specified exit event and four argument events. More... | |
| #define | rtems_record_exit_5(event, data_0, data_1, data_2, data_3, data_4) |
| Generates the specified exit event and five argument events. More... | |
| #define | rtems_record_exit_6(event, data_0, data_1, data_2, data_3, data_4, data_5) |
| Generates the specified exit event and six argument events. More... | |
| #define | rtems_record_exit_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6) |
| Generates the specified exit event and seven argument events. More... | |
| #define | rtems_record_exit_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7) |
| Generates the specified exit event and eight argument events. More... | |
| #define | rtems_record_exit_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8) |
| Generates the specified exit event and nine argument events. More... | |
| #define | rtems_record_exit_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9) |
| Generates the specified exit event and ten argument events. More... | |
| #define | RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32 |
| #define | RTEMS_RECORD_THE_VERSION 9 |
| The record version. More... | |
| #define | RTEMS_RECORD_FORMAT_LE_32 0x11111111 |
| The items are in 32-bit little-endian format. | |
| #define | RTEMS_RECORD_FORMAT_LE_64 0x22222222 |
| The items are in 64-bit little-endian format. | |
| #define | RTEMS_RECORD_FORMAT_BE_32 0x33333333 |
| The items are in 32-bit big-endian format. | |
| #define | RTEMS_RECORD_FORMAT_BE_64 0x44444444 |
| The items are in 64-bit big-endian format. | |
| #define | RTEMS_RECORD_MAGIC 0x82e14ec1 |
| Magic number to identify a record item stream. More... | |
| #define | RTEMS_RECORD_LAST RTEMS_RECORD_USER_511 |
| #define | RTEMS_RECORD_USER(index) ( RTEMS_RECORD_USER_0 + ( index ) ) |
| #define | RTEMS_RECORD_EVENT_BITS 10 |
| Bits in the record item event member reserved for the actual event. | |
| #define | RTEMS_RECORD_TIME_BITS 22 |
| Bits in the record item event member reserved for the time of the event. | |
| #define | RTEMS_RECORD_TIME_EVENT(time, event) ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) ) |
| Builds a time event for the specified time stamp and event. More... | |
| #define | RTEMS_RECORD_GET_TIME(time_event) ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS ) |
| Gets the time of a time event. | |
| #define | RTEMS_RECORD_GET_EVENT(time_event) ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) ) |
| Gets the event of a time event. | |
Typedefs | |
| typedef void(* | rtems_record_drain_visitor) (const rtems_record_item *items, size_t count, void *arg) |
| typedef rtems_record_client_status(* | rtems_record_client_handler) (uint64_t bt, uint32_t cpu, rtems_record_event event, uint64_t data, void *arg) |
| typedef struct rtems_record_client_context | rtems_record_client_context |
| typedef unsigned long | rtems_record_data |
| The record data integer type. More... | |
| typedef void(* | rtems_record_dump_chunk) (void *arg, const void *data, size_t length) |
| Handler for record dumps to output a chunk of data. More... | |
Enumerations | |
| enum | rtems_record_client_status { RTEMS_RECORD_CLIENT_SUCCESS, RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC, RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT, RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION, RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU, RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU_MAX, RTEMS_RECORD_CLIENT_ERROR_DOUBLE_CPU_MAX, RTEMS_RECORD_CLIENT_ERROR_DOUBLE_PER_CPU_COUNT, RTEMS_RECORD_CLIENT_ERROR_NO_CPU_MAX, RTEMS_RECORD_CLIENT_ERROR_NO_MEMORY, RTEMS_RECORD_CLIENT_ERROR_PER_CPU_ITEMS_OVERFLOW } |
| enum | rtems_record_event { RTEMS_RECORD_EMPTY, RTEMS_RECORD_VERSION, RTEMS_RECORD_ACCEPT_ENTRY, RTEMS_RECORD_ACCEPT_EXIT, RTEMS_RECORD_ADDRESS, RTEMS_RECORD_ALIGNED_ALLOC_ENTRY, RTEMS_RECORD_ALIGNED_ALLOC_EXIT, RTEMS_RECORD_ARCH, RTEMS_RECORD_ARG_0, RTEMS_RECORD_ARG_1, RTEMS_RECORD_ARG_2, RTEMS_RECORD_ARG_3, RTEMS_RECORD_ARG_4, RTEMS_RECORD_ARG_5, RTEMS_RECORD_ARG_6, RTEMS_RECORD_ARG_7, RTEMS_RECORD_ARG_8, RTEMS_RECORD_ARG_9, RTEMS_RECORD_BIND_ENTRY, RTEMS_RECORD_BIND_EXIT, RTEMS_RECORD_BSP, RTEMS_RECORD_BUFFER, RTEMS_RECORD_CALLER, RTEMS_RECORD_CALLOC_ENTRY, RTEMS_RECORD_CALLOC_EXIT, RTEMS_RECORD_CHOWN_ENTRY, RTEMS_RECORD_CHOWN_EXIT, RTEMS_RECORD_CLOSE_ENTRY, RTEMS_RECORD_CLOSE_EXIT, RTEMS_RECORD_CONNECT_ENTRY, RTEMS_RECORD_CONNECT_EXIT, RTEMS_RECORD_ETHER_INPUT, RTEMS_RECORD_ETHER_OUTPUT, RTEMS_RECORD_ERRNO, RTEMS_RECORD_FATAL_CODE, RTEMS_RECORD_FATAL_SOURCE, RTEMS_RECORD_FCHMOD_ENTRY, RTEMS_RECORD_FCHMOD_EXIT, RTEMS_RECORD_FCNTL_ENTRY, RTEMS_RECORD_FCNTL_EXIT, RTEMS_RECORD_FDATASYNC_ENTRY, RTEMS_RECORD_FDATASYNC_EXIT, RTEMS_RECORD_FREE_ENTRY, RTEMS_RECORD_FREE_EXIT, RTEMS_RECORD_FREQUENCY, RTEMS_RECORD_FSTAT_ENTRY, RTEMS_RECORD_FSTAT_EXIT, RTEMS_RECORD_FSYNC_ENTRY, RTEMS_RECORD_FSYNC_EXIT, RTEMS_RECORD_FTRUNCATE_ENTRY, RTEMS_RECORD_FTRUNCATE_EXIT, RTEMS_RECORD_FUNCTION_ENTRY, RTEMS_RECORD_FUNCTION_EXIT, RTEMS_RECORD_GETSOCKOPT_ENTRY, RTEMS_RECORD_GETSOCKOPT_EXIT, RTEMS_RECORD_HEAP_ALLOC, RTEMS_RECORD_HEAP_FREE, RTEMS_RECORD_HEAP_SIZE, RTEMS_RECORD_HEAP_USAGE, RTEMS_RECORD_INTERRUPT_ENTRY, RTEMS_RECORD_INTERRUPT_EXIT, RTEMS_RECORD_INTERRUPT_INSTALL, RTEMS_RECORD_INTERRUPT_REMOVE, RTEMS_RECORD_INTERRUPT_SERVER_ENTRY, RTEMS_RECORD_INTERRUPT_SERVER_EXIT, RTEMS_RECORD_INTERRUPT_SERVER_INSTALL, RTEMS_RECORD_INTERRUPT_SERVER_MOVE, RTEMS_RECORD_INTERRUPT_SERVER_REMOVE, RTEMS_RECORD_INTERRUPT_SERVER_TRIGGER, RTEMS_RECORD_IOCTL_ENTRY, RTEMS_RECORD_IOCTL_EXIT, RTEMS_RECORD_IP6_INPUT, RTEMS_RECORD_IP6_OUTPUT, RTEMS_RECORD_IP_INPUT, RTEMS_RECORD_IP_OUTPUT, RTEMS_RECORD_ISR_DISABLE, RTEMS_RECORD_ISR_ENABLE, RTEMS_RECORD_ISR_LOCK_ACQUIRE_ENTRY, RTEMS_RECORD_ISR_LOCK_ACQUIRE_EXIT, RTEMS_RECORD_ISR_LOCK_ADDRESS, RTEMS_RECORD_ISR_LOCK_DESTROY, RTEMS_RECORD_ISR_LOCK_INITIALIZE, RTEMS_RECORD_ISR_LOCK_NAME, RTEMS_RECORD_ISR_LOCK_RELEASE, RTEMS_RECORD_KEVENT_ENTRY, RTEMS_RECORD_KEVENT_EXIT, RTEMS_RECORD_KQUEUE_ENTRY, RTEMS_RECORD_KQUEUE_EXIT, RTEMS_RECORD_LENGTH, RTEMS_RECORD_LINE, RTEMS_RECORD_LINK_ENTRY, RTEMS_RECORD_LINK_EXIT, RTEMS_RECORD_LISTEN_ENTRY, RTEMS_RECORD_LISTEN_EXIT, RTEMS_RECORD_LSEEK_ENTRY, RTEMS_RECORD_LSEEK_EXIT, RTEMS_RECORD_MALLOC_ENTRY, RTEMS_RECORD_MALLOC_EXIT, RTEMS_RECORD_MEMORY, RTEMS_RECORD_MKNOD_ENTRY, RTEMS_RECORD_MKNOD_EXIT, RTEMS_RECORD_MMAP_ENTRY, RTEMS_RECORD_MMAP_EXIT, RTEMS_RECORD_MOUNT_ENTRY, RTEMS_RECORD_MOUNT_EXIT, RTEMS_RECORD_MULTILIB, RTEMS_RECORD_OPEN_ENTRY, RTEMS_RECORD_OPEN_EXIT, RTEMS_RECORD_PAGE_ALLOC, RTEMS_RECORD_PAGE_FREE, RTEMS_RECORD_PER_CPU_COUNT, RTEMS_RECORD_PER_CPU_HEAD, RTEMS_RECORD_PER_CPU_OVERFLOW, RTEMS_RECORD_PER_CPU_TAIL, RTEMS_RECORD_POLL_ENTRY, RTEMS_RECORD_POLL_EXIT, RTEMS_RECORD_POSIX_MEMALIGN_ENTRY, RTEMS_RECORD_POSIX_MEMALIGN_EXIT, RTEMS_RECORD_PROCESSOR, RTEMS_RECORD_PROCESSOR_MAXIMUM, RTEMS_RECORD_READ_ENTRY, RTEMS_RECORD_READ_EXIT, RTEMS_RECORD_READLINK_ENTRY, RTEMS_RECORD_READLINK_EXIT, RTEMS_RECORD_READV_ENTRY, RTEMS_RECORD_READV_EXIT, RTEMS_RECORD_REALLOC_ENTRY, RTEMS_RECORD_REALLOC_EXIT, RTEMS_RECORD_RECV_ENTRY, RTEMS_RECORD_RECV_EXIT, RTEMS_RECORD_RECVFROM_ENTRY, RTEMS_RECORD_RECVFROM_EXIT, RTEMS_RECORD_RECVMSG_ENTRY, RTEMS_RECORD_RECVMSG_EXIT, RTEMS_RECORD_REGISTERS, RTEMS_RECORD_RENAME_ENTRY, RTEMS_RECORD_RENAME_EXIT, RTEMS_RECORD_RETURN_0, RTEMS_RECORD_RETURN_1, RTEMS_RECORD_RETURN_2, RTEMS_RECORD_RETURN_3, RTEMS_RECORD_RETURN_4, RTEMS_RECORD_RETURN_5, RTEMS_RECORD_RETURN_6, RTEMS_RECORD_RETURN_7, RTEMS_RECORD_RETURN_8, RTEMS_RECORD_RETURN_9, RTEMS_RECORD_RTEMS_BARRIER_CREATE, RTEMS_RECORD_RTEMS_BARRIER_DELETE, RTEMS_RECORD_RTEMS_BARRIER_RELEASE, RTEMS_RECORD_RTEMS_BARRIER_WAIT, RTEMS_RECORD_RTEMS_CALLOC_ENTRY, RTEMS_RECORD_RTEMS_CALLOC_EXIT, RTEMS_RECORD_RTEMS_EVENT_RECEIVE, RTEMS_RECORD_RTEMS_EVENT_SEND, RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE, RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND, RTEMS_RECORD_RTEMS_MALLOC_ENTRY, RTEMS_RECORD_RTEMS_MALLOC_EXIT, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND, RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT, RTEMS_RECORD_RTEMS_PARTITION_CREATE, RTEMS_RECORD_RTEMS_PARTITION_DELETE, RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER, RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER, RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL, RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE, RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE, RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD, RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE, RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE, RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH, RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN, RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE, RTEMS_RECORD_RTEMS_TIMER_CANCEL, RTEMS_RECORD_RTEMS_TIMER_CREATE, RTEMS_RECORD_RTEMS_TIMER_DELETE, RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER, RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN, RTEMS_RECORD_RTEMS_TIMER_RESET, RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER, RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN, RTEMS_RECORD_SBWAIT_ENTRY, RTEMS_RECORD_SBWAIT_EXIT, RTEMS_RECORD_SBWAKEUP_ENTRY, RTEMS_RECORD_SBWAKEUP_EXIT, RTEMS_RECORD_SCHEDULER_ADD_PROCESSOR, RTEMS_RECORD_SCHEDULER_ASK_FOR_HELP, RTEMS_RECORD_SCHEDULER_BLOCK, RTEMS_RECORD_SCHEDULER_CANCEL_JOB, RTEMS_RECORD_SCHEDULER_ID, RTEMS_RECORD_SCHEDULER_MAP_PRIORITY, RTEMS_RECORD_SCHEDULER_NAME, RTEMS_RECORD_SCHEDULER_PIN, RTEMS_RECORD_SCHEDULER_RECONSIDER_HELP_REQUEST, RTEMS_RECORD_SCHEDULER_RELEASE_JOB, RTEMS_RECORD_SCHEDULER_REMOVE_PROCESSOR, RTEMS_RECORD_SCHEDULER_SCHEDULE, RTEMS_RECORD_SCHEDULER_SET_AFFINITY, RTEMS_RECORD_SCHEDULER_TICK, RTEMS_RECORD_SCHEDULER_UNBLOCK, RTEMS_RECORD_SCHEDULER_UNMAP_PRIORITY, RTEMS_RECORD_SCHEDULER_UNPIN, RTEMS_RECORD_SCHEDULER_UPDATE_PRIORITY, RTEMS_RECORD_SCHEDULER_WITHDRAW_NODE, RTEMS_RECORD_SCHEDULER_YIELD, RTEMS_RECORD_SELECT_ENTRY, RTEMS_RECORD_SELECT_EXIT, RTEMS_RECORD_SEND_ENTRY, RTEMS_RECORD_SEND_EXIT, RTEMS_RECORD_SENDMSG_ENTRY, RTEMS_RECORD_SENDMSG_EXIT, RTEMS_RECORD_SENDTO_ENTRY, RTEMS_RECORD_SENDTO_EXIT, RTEMS_RECORD_SETSOCKOPT_ENTRY, RTEMS_RECORD_SETSOCKOPT_EXIT, RTEMS_RECORD_SHUTDOWN_ENTRY, RTEMS_RECORD_SHUTDOWN_EXIT, RTEMS_RECORD_SOABORT_ENTRY, RTEMS_RECORD_SOABORT_EXIT, RTEMS_RECORD_SOACCEPT_ENTRY, RTEMS_RECORD_SOACCEPT_EXIT, RTEMS_RECORD_SOALLOC_ENTRY, RTEMS_RECORD_SOALLOC_EXIT, RTEMS_RECORD_SOBINDAT_ENTRY, RTEMS_RECORD_SOBINDAT_EXIT, RTEMS_RECORD_SOBIND_ENTRY, RTEMS_RECORD_SOBIND_EXIT, RTEMS_RECORD_SOCKET_ENTRY, RTEMS_RECORD_SOCKET_EXIT, RTEMS_RECORD_SOCLOSE_ENTRY, RTEMS_RECORD_SOCLOSE_EXIT, RTEMS_RECORD_SOCONNECT2_ENTRY, RTEMS_RECORD_SOCONNECT2_EXIT, RTEMS_RECORD_SOCONNECTAT_ENTRY, RTEMS_RECORD_SOCONNECTAT_EXIT, RTEMS_RECORD_SOCREATE_ENTRY, RTEMS_RECORD_SOCREATE_EXIT, RTEMS_RECORD_SODEALLOC_ENTRY, RTEMS_RECORD_SODEALLOC_EXIT, RTEMS_RECORD_SODISCONNECT_ENTRY, RTEMS_RECORD_SODISCONNECT_EXIT, RTEMS_RECORD_SOFREE_ENTRY, RTEMS_RECORD_SOFREE_EXIT, RTEMS_RECORD_SOLISTEN_ENTRY, RTEMS_RECORD_SOLISTEN_EXIT, RTEMS_RECORD_SONEWCONN_ENTRY, RTEMS_RECORD_SONEWCONN_EXIT, RTEMS_RECORD_SORECEIVE_ENTRY, RTEMS_RECORD_SORECEIVE_EXIT, RTEMS_RECORD_SORFLUSH_ENTRY, RTEMS_RECORD_SORFLUSH_EXIT, RTEMS_RECORD_SOSEND_ENTRY, RTEMS_RECORD_SOSEND_EXIT, RTEMS_RECORD_SOSHUTDOWN_ENTRY, RTEMS_RECORD_SOSHUTDOWN_EXIT, RTEMS_RECORD_STATVFS_ENTRY, RTEMS_RECORD_STATVFS_EXIT, RTEMS_RECORD_SYMLINK_ENTRY, RTEMS_RECORD_SYMLINK_EXIT, RTEMS_RECORD_TCP_CLOSE, RTEMS_RECORD_TCP_INPUT, RTEMS_RECORD_TCP_OUTPUT, RTEMS_RECORD_THREAD_BEGIN, RTEMS_RECORD_THREAD_CONTINUE_ENTRY, RTEMS_RECORD_THREAD_CONTINUE_EXIT, RTEMS_RECORD_THREAD_CREATE, RTEMS_RECORD_THREAD_DELETE, RTEMS_RECORD_THREAD_DISPATCH_DISABLE, RTEMS_RECORD_THREAD_DISPATCH_ENABLE, RTEMS_RECORD_THREAD_EXIT, RTEMS_RECORD_THREAD_EXITTED, RTEMS_RECORD_THREAD_ID, RTEMS_RECORD_THREAD_NAME, RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH, RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW, RTEMS_RECORD_THREAD_PRIO_REAL_HIGH, RTEMS_RECORD_THREAD_PRIO_REAL_LOW, RTEMS_RECORD_THREAD_QUEUE_ADDRESS, RTEMS_RECORD_THREAD_QUEUE_DESTROY, RTEMS_RECORD_THREAD_QUEUE_ENQUEUE, RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY, RTEMS_RECORD_THREAD_QUEUE_EXTRACT, RTEMS_RECORD_THREAD_QUEUE_ID, RTEMS_RECORD_THREAD_QUEUE_INITIALIZE, RTEMS_RECORD_THREAD_QUEUE_NAME, RTEMS_RECORD_THREAD_QUEUE_SURRENDER, RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY, RTEMS_RECORD_THREAD_RESOURCE_OBTAIN, RTEMS_RECORD_THREAD_RESOURCE_RELEASE, RTEMS_RECORD_THREAD_RESTART, RTEMS_RECORD_THREAD_STACK_CURRENT, RTEMS_RECORD_THREAD_STACK_SIZE, RTEMS_RECORD_THREAD_STACK_USAGE, RTEMS_RECORD_THREAD_START, RTEMS_RECORD_THREAD_STATE_CLEAR, RTEMS_RECORD_THREAD_STATE_SET, RTEMS_RECORD_THREAD_SWITCH_IN, RTEMS_RECORD_THREAD_SWITCH_OUT, RTEMS_RECORD_THREAD_TERMINATE, RTEMS_RECORD_THREAD_TIMER_INSERT_MONOTONIC, RTEMS_RECORD_THREAD_TIMER_INSERT_REALTIME, RTEMS_RECORD_THREAD_TIMER_INSERT_TICKS, RTEMS_RECORD_THREAD_TIMER_REMOVE, RTEMS_RECORD_TOOLS, RTEMS_RECORD_UDP_INPUT, RTEMS_RECORD_UDP_OUTPUT, RTEMS_RECORD_UMA_ALLOC_PTR, RTEMS_RECORD_UMA_ALLOC_ZONE, RTEMS_RECORD_UMA_FREE_PTR, RTEMS_RECORD_UMA_FREE_ZONE, RTEMS_RECORD_UNLINK_ENTRY, RTEMS_RECORD_UNLINK_EXIT, RTEMS_RECORD_UNMOUNT_ENTRY, RTEMS_RECORD_UNMOUNT_EXIT, RTEMS_RECORD_UPTIME_HIGH, RTEMS_RECORD_UPTIME_LOW, RTEMS_RECORD_VERSION_CONTROL_KEY, RTEMS_RECORD_WATCHDOG_ADDRESS, RTEMS_RECORD_WATCHDOG_CPU, RTEMS_RECORD_WATCHDOG_INITIALIZE, RTEMS_RECORD_WATCHDOG_INSERT, RTEMS_RECORD_WATCHDOG_PREINITIALIZE, RTEMS_RECORD_WATCHDOG_REMOVE, RTEMS_RECORD_WATCHDOG_ROUTINE, RTEMS_RECORD_WATCHDOG_STATE, RTEMS_RECORD_WORKSPACE_ALLOC_ENTRY, RTEMS_RECORD_WORKSPACE_ALLOC_EXIT, RTEMS_RECORD_WORKSPACE_FREE_ENTY, RTEMS_RECORD_WORKSPACE_FREE_EXIT, RTEMS_RECORD_WORKSPACE_SIZE, RTEMS_RECORD_WORKSPACE_USAGE, RTEMS_RECORD_WRITE_ENTRY, RTEMS_RECORD_WRITE_EXIT, RTEMS_RECORD_WRITEV_ENTRY, RTEMS_RECORD_WRITEV_EXIT, RTEMS_RECORD_SYSTEM_341, RTEMS_RECORD_SYSTEM_342, RTEMS_RECORD_SYSTEM_343, RTEMS_RECORD_SYSTEM_344, RTEMS_RECORD_SYSTEM_345, RTEMS_RECORD_SYSTEM_346, RTEMS_RECORD_SYSTEM_347, RTEMS_RECORD_SYSTEM_348, RTEMS_RECORD_SYSTEM_349, RTEMS_RECORD_SYSTEM_350, RTEMS_RECORD_SYSTEM_351, RTEMS_RECORD_SYSTEM_352, RTEMS_RECORD_SYSTEM_353, RTEMS_RECORD_SYSTEM_354, RTEMS_RECORD_SYSTEM_355, RTEMS_RECORD_SYSTEM_356, RTEMS_RECORD_SYSTEM_357, RTEMS_RECORD_SYSTEM_358, RTEMS_RECORD_SYSTEM_359, RTEMS_RECORD_SYSTEM_360, RTEMS_RECORD_SYSTEM_361, RTEMS_RECORD_SYSTEM_362, RTEMS_RECORD_SYSTEM_363, RTEMS_RECORD_SYSTEM_364, RTEMS_RECORD_SYSTEM_365, RTEMS_RECORD_SYSTEM_366, RTEMS_RECORD_SYSTEM_367, RTEMS_RECORD_SYSTEM_368, RTEMS_RECORD_SYSTEM_369, RTEMS_RECORD_SYSTEM_370, RTEMS_RECORD_SYSTEM_371, RTEMS_RECORD_SYSTEM_372, RTEMS_RECORD_SYSTEM_373, RTEMS_RECORD_SYSTEM_374, RTEMS_RECORD_SYSTEM_375, RTEMS_RECORD_SYSTEM_376, RTEMS_RECORD_SYSTEM_377, RTEMS_RECORD_SYSTEM_378, RTEMS_RECORD_SYSTEM_379, RTEMS_RECORD_SYSTEM_380, RTEMS_RECORD_SYSTEM_381, RTEMS_RECORD_SYSTEM_382, RTEMS_RECORD_SYSTEM_383, RTEMS_RECORD_SYSTEM_384, RTEMS_RECORD_SYSTEM_385, RTEMS_RECORD_SYSTEM_386, RTEMS_RECORD_SYSTEM_387, RTEMS_RECORD_SYSTEM_388, RTEMS_RECORD_SYSTEM_389, RTEMS_RECORD_SYSTEM_390, RTEMS_RECORD_SYSTEM_391, RTEMS_RECORD_SYSTEM_392, RTEMS_RECORD_SYSTEM_393, RTEMS_RECORD_SYSTEM_394, RTEMS_RECORD_SYSTEM_395, RTEMS_RECORD_SYSTEM_396, RTEMS_RECORD_SYSTEM_397, RTEMS_RECORD_SYSTEM_398, RTEMS_RECORD_SYSTEM_399, RTEMS_RECORD_SYSTEM_400, RTEMS_RECORD_SYSTEM_401, RTEMS_RECORD_SYSTEM_402, RTEMS_RECORD_SYSTEM_403, RTEMS_RECORD_SYSTEM_404, RTEMS_RECORD_SYSTEM_405, RTEMS_RECORD_SYSTEM_406, RTEMS_RECORD_SYSTEM_407, RTEMS_RECORD_SYSTEM_408, RTEMS_RECORD_SYSTEM_409, RTEMS_RECORD_SYSTEM_410, RTEMS_RECORD_SYSTEM_411, RTEMS_RECORD_SYSTEM_412, RTEMS_RECORD_SYSTEM_413, RTEMS_RECORD_SYSTEM_414, RTEMS_RECORD_SYSTEM_415, RTEMS_RECORD_SYSTEM_416, RTEMS_RECORD_SYSTEM_417, RTEMS_RECORD_SYSTEM_418, RTEMS_RECORD_SYSTEM_419, RTEMS_RECORD_SYSTEM_420, RTEMS_RECORD_SYSTEM_421, RTEMS_RECORD_SYSTEM_422, RTEMS_RECORD_SYSTEM_423, RTEMS_RECORD_SYSTEM_424, RTEMS_RECORD_SYSTEM_425, RTEMS_RECORD_SYSTEM_426, RTEMS_RECORD_SYSTEM_427, RTEMS_RECORD_SYSTEM_428, RTEMS_RECORD_SYSTEM_429, RTEMS_RECORD_SYSTEM_430, RTEMS_RECORD_SYSTEM_431, RTEMS_RECORD_SYSTEM_432, RTEMS_RECORD_SYSTEM_433, RTEMS_RECORD_SYSTEM_434, RTEMS_RECORD_SYSTEM_435, RTEMS_RECORD_SYSTEM_436, RTEMS_RECORD_SYSTEM_437, RTEMS_RECORD_SYSTEM_438, RTEMS_RECORD_SYSTEM_439, RTEMS_RECORD_SYSTEM_440, RTEMS_RECORD_SYSTEM_441, RTEMS_RECORD_SYSTEM_442, RTEMS_RECORD_SYSTEM_443, RTEMS_RECORD_SYSTEM_444, RTEMS_RECORD_SYSTEM_445, RTEMS_RECORD_SYSTEM_446, RTEMS_RECORD_SYSTEM_447, RTEMS_RECORD_SYSTEM_448, RTEMS_RECORD_SYSTEM_449, RTEMS_RECORD_SYSTEM_450, RTEMS_RECORD_SYSTEM_451, RTEMS_RECORD_SYSTEM_452, RTEMS_RECORD_SYSTEM_453, RTEMS_RECORD_SYSTEM_454, RTEMS_RECORD_SYSTEM_455, RTEMS_RECORD_SYSTEM_456, RTEMS_RECORD_SYSTEM_457, RTEMS_RECORD_SYSTEM_458, RTEMS_RECORD_SYSTEM_459, RTEMS_RECORD_SYSTEM_460, RTEMS_RECORD_SYSTEM_461, RTEMS_RECORD_SYSTEM_462, RTEMS_RECORD_SYSTEM_463, RTEMS_RECORD_SYSTEM_464, RTEMS_RECORD_SYSTEM_465, RTEMS_RECORD_SYSTEM_466, RTEMS_RECORD_SYSTEM_467, RTEMS_RECORD_SYSTEM_468, RTEMS_RECORD_SYSTEM_469, RTEMS_RECORD_SYSTEM_470, RTEMS_RECORD_SYSTEM_471, RTEMS_RECORD_SYSTEM_472, RTEMS_RECORD_SYSTEM_473, RTEMS_RECORD_SYSTEM_474, RTEMS_RECORD_SYSTEM_475, RTEMS_RECORD_SYSTEM_476, RTEMS_RECORD_SYSTEM_477, RTEMS_RECORD_SYSTEM_478, RTEMS_RECORD_SYSTEM_479, RTEMS_RECORD_SYSTEM_480, RTEMS_RECORD_SYSTEM_481, RTEMS_RECORD_SYSTEM_482, RTEMS_RECORD_SYSTEM_483, RTEMS_RECORD_SYSTEM_484, RTEMS_RECORD_SYSTEM_485, RTEMS_RECORD_SYSTEM_486, RTEMS_RECORD_SYSTEM_487, RTEMS_RECORD_SYSTEM_488, RTEMS_RECORD_SYSTEM_489, RTEMS_RECORD_SYSTEM_490, RTEMS_RECORD_SYSTEM_491, RTEMS_RECORD_SYSTEM_492, RTEMS_RECORD_SYSTEM_493, RTEMS_RECORD_SYSTEM_494, RTEMS_RECORD_SYSTEM_495, RTEMS_RECORD_SYSTEM_496, RTEMS_RECORD_SYSTEM_497, RTEMS_RECORD_SYSTEM_498, RTEMS_RECORD_SYSTEM_499, RTEMS_RECORD_SYSTEM_500, RTEMS_RECORD_SYSTEM_501, RTEMS_RECORD_SYSTEM_502, RTEMS_RECORD_SYSTEM_503, RTEMS_RECORD_SYSTEM_504, RTEMS_RECORD_SYSTEM_505, RTEMS_RECORD_SYSTEM_506, RTEMS_RECORD_SYSTEM_507, RTEMS_RECORD_SYSTEM_508, RTEMS_RECORD_SYSTEM_509, RTEMS_RECORD_SYSTEM_510, RTEMS_RECORD_SYSTEM_511, RTEMS_RECORD_USER_0, RTEMS_RECORD_USER_1, RTEMS_RECORD_USER_2, RTEMS_RECORD_USER_3, RTEMS_RECORD_USER_4, RTEMS_RECORD_USER_5, RTEMS_RECORD_USER_6, RTEMS_RECORD_USER_7, RTEMS_RECORD_USER_8, RTEMS_RECORD_USER_9, RTEMS_RECORD_USER_10, RTEMS_RECORD_USER_11, RTEMS_RECORD_USER_12, RTEMS_RECORD_USER_13, RTEMS_RECORD_USER_14, RTEMS_RECORD_USER_15, RTEMS_RECORD_USER_16, RTEMS_RECORD_USER_17, RTEMS_RECORD_USER_18, RTEMS_RECORD_USER_19, RTEMS_RECORD_USER_20, RTEMS_RECORD_USER_21, RTEMS_RECORD_USER_22, RTEMS_RECORD_USER_23, RTEMS_RECORD_USER_24, RTEMS_RECORD_USER_25, RTEMS_RECORD_USER_26, RTEMS_RECORD_USER_27, RTEMS_RECORD_USER_28, RTEMS_RECORD_USER_29, RTEMS_RECORD_USER_30, RTEMS_RECORD_USER_31, RTEMS_RECORD_USER_32, RTEMS_RECORD_USER_33, RTEMS_RECORD_USER_34, RTEMS_RECORD_USER_35, RTEMS_RECORD_USER_36, RTEMS_RECORD_USER_37, RTEMS_RECORD_USER_38, RTEMS_RECORD_USER_39, RTEMS_RECORD_USER_40, RTEMS_RECORD_USER_41, RTEMS_RECORD_USER_42, RTEMS_RECORD_USER_43, RTEMS_RECORD_USER_44, RTEMS_RECORD_USER_45, RTEMS_RECORD_USER_46, RTEMS_RECORD_USER_47, RTEMS_RECORD_USER_48, RTEMS_RECORD_USER_49, RTEMS_RECORD_USER_50, RTEMS_RECORD_USER_51, RTEMS_RECORD_USER_52, RTEMS_RECORD_USER_53, RTEMS_RECORD_USER_54, RTEMS_RECORD_USER_55, RTEMS_RECORD_USER_56, RTEMS_RECORD_USER_57, RTEMS_RECORD_USER_58, RTEMS_RECORD_USER_59, RTEMS_RECORD_USER_60, RTEMS_RECORD_USER_61, RTEMS_RECORD_USER_62, RTEMS_RECORD_USER_63, RTEMS_RECORD_USER_64, RTEMS_RECORD_USER_65, RTEMS_RECORD_USER_66, RTEMS_RECORD_USER_67, RTEMS_RECORD_USER_68, RTEMS_RECORD_USER_69, RTEMS_RECORD_USER_70, RTEMS_RECORD_USER_71, RTEMS_RECORD_USER_72, RTEMS_RECORD_USER_73, RTEMS_RECORD_USER_74, RTEMS_RECORD_USER_75, RTEMS_RECORD_USER_76, RTEMS_RECORD_USER_77, RTEMS_RECORD_USER_78, RTEMS_RECORD_USER_79, RTEMS_RECORD_USER_80, RTEMS_RECORD_USER_81, RTEMS_RECORD_USER_82, RTEMS_RECORD_USER_83, RTEMS_RECORD_USER_84, RTEMS_RECORD_USER_85, RTEMS_RECORD_USER_86, RTEMS_RECORD_USER_87, RTEMS_RECORD_USER_88, RTEMS_RECORD_USER_89, RTEMS_RECORD_USER_90, RTEMS_RECORD_USER_91, RTEMS_RECORD_USER_92, RTEMS_RECORD_USER_93, RTEMS_RECORD_USER_94, RTEMS_RECORD_USER_95, RTEMS_RECORD_USER_96, RTEMS_RECORD_USER_97, RTEMS_RECORD_USER_98, RTEMS_RECORD_USER_99, RTEMS_RECORD_USER_100, RTEMS_RECORD_USER_101, RTEMS_RECORD_USER_102, RTEMS_RECORD_USER_103, RTEMS_RECORD_USER_104, RTEMS_RECORD_USER_105, RTEMS_RECORD_USER_106, RTEMS_RECORD_USER_107, RTEMS_RECORD_USER_108, RTEMS_RECORD_USER_109, RTEMS_RECORD_USER_110, RTEMS_RECORD_USER_111, RTEMS_RECORD_USER_112, RTEMS_RECORD_USER_113, RTEMS_RECORD_USER_114, RTEMS_RECORD_USER_115, RTEMS_RECORD_USER_116, RTEMS_RECORD_USER_117, RTEMS_RECORD_USER_118, RTEMS_RECORD_USER_119, RTEMS_RECORD_USER_120, RTEMS_RECORD_USER_121, RTEMS_RECORD_USER_122, RTEMS_RECORD_USER_123, RTEMS_RECORD_USER_124, RTEMS_RECORD_USER_125, RTEMS_RECORD_USER_126, RTEMS_RECORD_USER_127, RTEMS_RECORD_USER_128, RTEMS_RECORD_USER_129, RTEMS_RECORD_USER_130, RTEMS_RECORD_USER_131, RTEMS_RECORD_USER_132, RTEMS_RECORD_USER_133, RTEMS_RECORD_USER_134, RTEMS_RECORD_USER_135, RTEMS_RECORD_USER_136, RTEMS_RECORD_USER_137, RTEMS_RECORD_USER_138, RTEMS_RECORD_USER_139, RTEMS_RECORD_USER_140, RTEMS_RECORD_USER_141, RTEMS_RECORD_USER_142, RTEMS_RECORD_USER_143, RTEMS_RECORD_USER_144, RTEMS_RECORD_USER_145, RTEMS_RECORD_USER_146, RTEMS_RECORD_USER_147, RTEMS_RECORD_USER_148, RTEMS_RECORD_USER_149, RTEMS_RECORD_USER_150, RTEMS_RECORD_USER_151, RTEMS_RECORD_USER_152, RTEMS_RECORD_USER_153, RTEMS_RECORD_USER_154, RTEMS_RECORD_USER_155, RTEMS_RECORD_USER_156, RTEMS_RECORD_USER_157, RTEMS_RECORD_USER_158, RTEMS_RECORD_USER_159, RTEMS_RECORD_USER_160, RTEMS_RECORD_USER_161, RTEMS_RECORD_USER_162, RTEMS_RECORD_USER_163, RTEMS_RECORD_USER_164, RTEMS_RECORD_USER_165, RTEMS_RECORD_USER_166, RTEMS_RECORD_USER_167, RTEMS_RECORD_USER_168, RTEMS_RECORD_USER_169, RTEMS_RECORD_USER_170, RTEMS_RECORD_USER_171, RTEMS_RECORD_USER_172, RTEMS_RECORD_USER_173, RTEMS_RECORD_USER_174, RTEMS_RECORD_USER_175, RTEMS_RECORD_USER_176, RTEMS_RECORD_USER_177, RTEMS_RECORD_USER_178, RTEMS_RECORD_USER_179, RTEMS_RECORD_USER_180, RTEMS_RECORD_USER_181, RTEMS_RECORD_USER_182, RTEMS_RECORD_USER_183, RTEMS_RECORD_USER_184, RTEMS_RECORD_USER_185, RTEMS_RECORD_USER_186, RTEMS_RECORD_USER_187, RTEMS_RECORD_USER_188, RTEMS_RECORD_USER_189, RTEMS_RECORD_USER_190, RTEMS_RECORD_USER_191, RTEMS_RECORD_USER_192, RTEMS_RECORD_USER_193, RTEMS_RECORD_USER_194, RTEMS_RECORD_USER_195, RTEMS_RECORD_USER_196, RTEMS_RECORD_USER_197, RTEMS_RECORD_USER_198, RTEMS_RECORD_USER_199, RTEMS_RECORD_USER_200, RTEMS_RECORD_USER_201, RTEMS_RECORD_USER_202, RTEMS_RECORD_USER_203, RTEMS_RECORD_USER_204, RTEMS_RECORD_USER_205, RTEMS_RECORD_USER_206, RTEMS_RECORD_USER_207, RTEMS_RECORD_USER_208, RTEMS_RECORD_USER_209, RTEMS_RECORD_USER_210, RTEMS_RECORD_USER_211, RTEMS_RECORD_USER_212, RTEMS_RECORD_USER_213, RTEMS_RECORD_USER_214, RTEMS_RECORD_USER_215, RTEMS_RECORD_USER_216, RTEMS_RECORD_USER_217, RTEMS_RECORD_USER_218, RTEMS_RECORD_USER_219, RTEMS_RECORD_USER_220, RTEMS_RECORD_USER_221, RTEMS_RECORD_USER_222, RTEMS_RECORD_USER_223, RTEMS_RECORD_USER_224, RTEMS_RECORD_USER_225, RTEMS_RECORD_USER_226, RTEMS_RECORD_USER_227, RTEMS_RECORD_USER_228, RTEMS_RECORD_USER_229, RTEMS_RECORD_USER_230, RTEMS_RECORD_USER_231, RTEMS_RECORD_USER_232, RTEMS_RECORD_USER_233, RTEMS_RECORD_USER_234, RTEMS_RECORD_USER_235, RTEMS_RECORD_USER_236, RTEMS_RECORD_USER_237, RTEMS_RECORD_USER_238, RTEMS_RECORD_USER_239, RTEMS_RECORD_USER_240, RTEMS_RECORD_USER_241, RTEMS_RECORD_USER_242, RTEMS_RECORD_USER_243, RTEMS_RECORD_USER_244, RTEMS_RECORD_USER_245, RTEMS_RECORD_USER_246, RTEMS_RECORD_USER_247, RTEMS_RECORD_USER_248, RTEMS_RECORD_USER_249, RTEMS_RECORD_USER_250, RTEMS_RECORD_USER_251, RTEMS_RECORD_USER_252, RTEMS_RECORD_USER_253, RTEMS_RECORD_USER_254, RTEMS_RECORD_USER_255, RTEMS_RECORD_USER_256, RTEMS_RECORD_USER_257, RTEMS_RECORD_USER_258, RTEMS_RECORD_USER_259, RTEMS_RECORD_USER_260, RTEMS_RECORD_USER_261, RTEMS_RECORD_USER_262, RTEMS_RECORD_USER_263, RTEMS_RECORD_USER_264, RTEMS_RECORD_USER_265, RTEMS_RECORD_USER_266, RTEMS_RECORD_USER_267, RTEMS_RECORD_USER_268, RTEMS_RECORD_USER_269, RTEMS_RECORD_USER_270, RTEMS_RECORD_USER_271, RTEMS_RECORD_USER_272, RTEMS_RECORD_USER_273, RTEMS_RECORD_USER_274, RTEMS_RECORD_USER_275, RTEMS_RECORD_USER_276, RTEMS_RECORD_USER_277, RTEMS_RECORD_USER_278, RTEMS_RECORD_USER_279, RTEMS_RECORD_USER_280, RTEMS_RECORD_USER_281, RTEMS_RECORD_USER_282, RTEMS_RECORD_USER_283, RTEMS_RECORD_USER_284, RTEMS_RECORD_USER_285, RTEMS_RECORD_USER_286, RTEMS_RECORD_USER_287, RTEMS_RECORD_USER_288, RTEMS_RECORD_USER_289, RTEMS_RECORD_USER_290, RTEMS_RECORD_USER_291, RTEMS_RECORD_USER_292, RTEMS_RECORD_USER_293, RTEMS_RECORD_USER_294, RTEMS_RECORD_USER_295, RTEMS_RECORD_USER_296, RTEMS_RECORD_USER_297, RTEMS_RECORD_USER_298, RTEMS_RECORD_USER_299, RTEMS_RECORD_USER_300, RTEMS_RECORD_USER_301, RTEMS_RECORD_USER_302, RTEMS_RECORD_USER_303, RTEMS_RECORD_USER_304, RTEMS_RECORD_USER_305, RTEMS_RECORD_USER_306, RTEMS_RECORD_USER_307, RTEMS_RECORD_USER_308, RTEMS_RECORD_USER_309, RTEMS_RECORD_USER_310, RTEMS_RECORD_USER_311, RTEMS_RECORD_USER_312, RTEMS_RECORD_USER_313, RTEMS_RECORD_USER_314, RTEMS_RECORD_USER_315, RTEMS_RECORD_USER_316, RTEMS_RECORD_USER_317, RTEMS_RECORD_USER_318, RTEMS_RECORD_USER_319, RTEMS_RECORD_USER_320, RTEMS_RECORD_USER_321, RTEMS_RECORD_USER_322, RTEMS_RECORD_USER_323, RTEMS_RECORD_USER_324, RTEMS_RECORD_USER_325, RTEMS_RECORD_USER_326, RTEMS_RECORD_USER_327, RTEMS_RECORD_USER_328, RTEMS_RECORD_USER_329, RTEMS_RECORD_USER_330, RTEMS_RECORD_USER_331, RTEMS_RECORD_USER_332, RTEMS_RECORD_USER_333, RTEMS_RECORD_USER_334, RTEMS_RECORD_USER_335, RTEMS_RECORD_USER_336, RTEMS_RECORD_USER_337, RTEMS_RECORD_USER_338, RTEMS_RECORD_USER_339, RTEMS_RECORD_USER_340, RTEMS_RECORD_USER_341, RTEMS_RECORD_USER_342, RTEMS_RECORD_USER_343, RTEMS_RECORD_USER_344, RTEMS_RECORD_USER_345, RTEMS_RECORD_USER_346, RTEMS_RECORD_USER_347, RTEMS_RECORD_USER_348, RTEMS_RECORD_USER_349, RTEMS_RECORD_USER_350, RTEMS_RECORD_USER_351, RTEMS_RECORD_USER_352, RTEMS_RECORD_USER_353, RTEMS_RECORD_USER_354, RTEMS_RECORD_USER_355, RTEMS_RECORD_USER_356, RTEMS_RECORD_USER_357, RTEMS_RECORD_USER_358, RTEMS_RECORD_USER_359, RTEMS_RECORD_USER_360, RTEMS_RECORD_USER_361, RTEMS_RECORD_USER_362, RTEMS_RECORD_USER_363, RTEMS_RECORD_USER_364, RTEMS_RECORD_USER_365, RTEMS_RECORD_USER_366, RTEMS_RECORD_USER_367, RTEMS_RECORD_USER_368, RTEMS_RECORD_USER_369, RTEMS_RECORD_USER_370, RTEMS_RECORD_USER_371, RTEMS_RECORD_USER_372, RTEMS_RECORD_USER_373, RTEMS_RECORD_USER_374, RTEMS_RECORD_USER_375, RTEMS_RECORD_USER_376, RTEMS_RECORD_USER_377, RTEMS_RECORD_USER_378, RTEMS_RECORD_USER_379, RTEMS_RECORD_USER_380, RTEMS_RECORD_USER_381, RTEMS_RECORD_USER_382, RTEMS_RECORD_USER_383, RTEMS_RECORD_USER_384, RTEMS_RECORD_USER_385, RTEMS_RECORD_USER_386, RTEMS_RECORD_USER_387, RTEMS_RECORD_USER_388, RTEMS_RECORD_USER_389, RTEMS_RECORD_USER_390, RTEMS_RECORD_USER_391, RTEMS_RECORD_USER_392, RTEMS_RECORD_USER_393, RTEMS_RECORD_USER_394, RTEMS_RECORD_USER_395, RTEMS_RECORD_USER_396, RTEMS_RECORD_USER_397, RTEMS_RECORD_USER_398, RTEMS_RECORD_USER_399, RTEMS_RECORD_USER_400, RTEMS_RECORD_USER_401, RTEMS_RECORD_USER_402, RTEMS_RECORD_USER_403, RTEMS_RECORD_USER_404, RTEMS_RECORD_USER_405, RTEMS_RECORD_USER_406, RTEMS_RECORD_USER_407, RTEMS_RECORD_USER_408, RTEMS_RECORD_USER_409, RTEMS_RECORD_USER_410, RTEMS_RECORD_USER_411, RTEMS_RECORD_USER_412, RTEMS_RECORD_USER_413, RTEMS_RECORD_USER_414, RTEMS_RECORD_USER_415, RTEMS_RECORD_USER_416, RTEMS_RECORD_USER_417, RTEMS_RECORD_USER_418, RTEMS_RECORD_USER_419, RTEMS_RECORD_USER_420, RTEMS_RECORD_USER_421, RTEMS_RECORD_USER_422, RTEMS_RECORD_USER_423, RTEMS_RECORD_USER_424, RTEMS_RECORD_USER_425, RTEMS_RECORD_USER_426, RTEMS_RECORD_USER_427, RTEMS_RECORD_USER_428, RTEMS_RECORD_USER_429, RTEMS_RECORD_USER_430, RTEMS_RECORD_USER_431, RTEMS_RECORD_USER_432, RTEMS_RECORD_USER_433, RTEMS_RECORD_USER_434, RTEMS_RECORD_USER_435, RTEMS_RECORD_USER_436, RTEMS_RECORD_USER_437, RTEMS_RECORD_USER_438, RTEMS_RECORD_USER_439, RTEMS_RECORD_USER_440, RTEMS_RECORD_USER_441, RTEMS_RECORD_USER_442, RTEMS_RECORD_USER_443, RTEMS_RECORD_USER_444, RTEMS_RECORD_USER_445, RTEMS_RECORD_USER_446, RTEMS_RECORD_USER_447, RTEMS_RECORD_USER_448, RTEMS_RECORD_USER_449, RTEMS_RECORD_USER_450, RTEMS_RECORD_USER_451, RTEMS_RECORD_USER_452, RTEMS_RECORD_USER_453, RTEMS_RECORD_USER_454, RTEMS_RECORD_USER_455, RTEMS_RECORD_USER_456, RTEMS_RECORD_USER_457, RTEMS_RECORD_USER_458, RTEMS_RECORD_USER_459, RTEMS_RECORD_USER_460, RTEMS_RECORD_USER_461, RTEMS_RECORD_USER_462, RTEMS_RECORD_USER_463, RTEMS_RECORD_USER_464, RTEMS_RECORD_USER_465, RTEMS_RECORD_USER_466, RTEMS_RECORD_USER_467, RTEMS_RECORD_USER_468, RTEMS_RECORD_USER_469, RTEMS_RECORD_USER_470, RTEMS_RECORD_USER_471, RTEMS_RECORD_USER_472, RTEMS_RECORD_USER_473, RTEMS_RECORD_USER_474, RTEMS_RECORD_USER_475, RTEMS_RECORD_USER_476, RTEMS_RECORD_USER_477, RTEMS_RECORD_USER_478, RTEMS_RECORD_USER_479, RTEMS_RECORD_USER_480, RTEMS_RECORD_USER_481, RTEMS_RECORD_USER_482, RTEMS_RECORD_USER_483, RTEMS_RECORD_USER_484, RTEMS_RECORD_USER_485, RTEMS_RECORD_USER_486, RTEMS_RECORD_USER_487, RTEMS_RECORD_USER_488, RTEMS_RECORD_USER_489, RTEMS_RECORD_USER_490, RTEMS_RECORD_USER_491, RTEMS_RECORD_USER_492, RTEMS_RECORD_USER_493, RTEMS_RECORD_USER_494, RTEMS_RECORD_USER_495, RTEMS_RECORD_USER_496, RTEMS_RECORD_USER_497, RTEMS_RECORD_USER_498, RTEMS_RECORD_USER_499, RTEMS_RECORD_USER_500, RTEMS_RECORD_USER_501, RTEMS_RECORD_USER_502, RTEMS_RECORD_USER_503, RTEMS_RECORD_USER_504, RTEMS_RECORD_USER_505, RTEMS_RECORD_USER_506, RTEMS_RECORD_USER_507, RTEMS_RECORD_USER_508, RTEMS_RECORD_USER_509, RTEMS_RECORD_USER_510, RTEMS_RECORD_USER_511 } |
| The record events. | |
| RTEMS_INLINE_ROUTINE void | rtems_record_prepare_critical (rtems_record_context *context, const Per_CPU_Control *cpu_self) |
| Prepares to add and commit record items in a critical section with interrupts disabled. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_record_prepare (rtems_record_context *context) |
| Prepares to add and commit record items. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_record_add (rtems_record_context *context, rtems_record_event event, rtems_record_data data) |
| Adds a record item. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_record_commit_critical (rtems_record_context *context) |
| Commits a set of record items in a critical section with interrupts disabled. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_record_commit (rtems_record_context *context) |
| Commits a set of record items. More... | |
| void | rtems_record_produce (rtems_record_event event, rtems_record_data data) |
| Produces a record item. More... | |
| void | rtems_record_produce_2 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1) |
| Produces two record items. More... | |
| void | rtems_record_produce_n (const rtems_record_item *items, size_t n) |
| Produces n record items. More... | |
| void | rtems_record_line (void) |
| Generates an RTEMS_RECORD_LINE event. More... | |
| void | rtems_record_line_2 (rtems_record_event event, rtems_record_data data) |
| Generates an RTEMS_RECORD_LINE event and an extra event. More... | |
| void | rtems_record_line_3 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1) |
| Generates an RTEMS_RECORD_LINE event and two extra events. More... | |
| void | rtems_record_line_arg (rtems_record_data data) |
| Generates an RTEMS_RECORD_LINE event and one argument event. More... | |
| void | rtems_record_line_arg_2 (rtems_record_data data_0, rtems_record_data data_1) |
| Generates an RTEMS_RECORD_LINE event and two argument events. More... | |
| void | rtems_record_line_arg_3 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2) |
| Generates an RTEMS_RECORD_LINE event and three argument events. More... | |
| void | rtems_record_line_arg_4 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3) |
| Generates an RTEMS_RECORD_LINE event and four argument events. More... | |
| void | rtems_record_line_arg_5 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4) |
| Generates an RTEMS_RECORD_LINE event and five argument events. More... | |
| void | rtems_record_line_arg_6 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5) |
| Generates an RTEMS_RECORD_LINE event and six argument events. More... | |
| void | rtems_record_line_arg_7 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6) |
| Generates an RTEMS_RECORD_LINE event and seven argument events. More... | |
| void | rtems_record_line_arg_8 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7) |
| Generates an RTEMS_RECORD_LINE event and eight argument events. More... | |
| void | rtems_record_line_arg_9 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8) |
| Generates an RTEMS_RECORD_LINE event and nine argument events. More... | |
| void | rtems_record_line_arg_10 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8, rtems_record_data data_9) |
| Generates an RTEMS_RECORD_LINE event and ten argument events. More... | |
| uint32_t | rtems_record_interrupt_disable (void) |
| Disables interrupts and generates an RTEMS_RECORD_ISR_DISABLE event. More... | |
| void | rtems_record_interrupt_enable (uint32_t level) |
| Restores the previous interrupt level and generates an RTEMS_RECORD_ISR_ENABLE event. More... | |
| void | _Record_Drain (Record_Control *control, uint32_t cpu_index, rtems_record_drain_visitor visitor, void *arg) |
| void | rtems_record_drain (rtems_record_drain_visitor visitor, void *arg) |
| Drains the record items on all processors. More... | |
| void | rtems_record_client_init (rtems_record_client_context *ctx, rtems_record_client_handler handler, void *arg) |
| Initializes a record client. More... | |
| rtems_record_client_status | rtems_record_client_run (rtems_record_client_context *ctx, const void *buf, size_t n) |
| Runs the record client to consume new stream data. More... | |
| void | rtems_record_client_destroy (rtems_record_client_context *ctx) |
| Drains all internal buffers and frees the allocated resources. More... | |
| struct | __attribute__ ((__packed__)) |
| The native record item. More... | |
| const char * | rtems_record_event_text (rtems_record_event event) |
| void | rtems_record_dump (rtems_record_dump_chunk chunk, void *arg) |
| Dumps the record header, the thread names, and all items of all processors. More... | |
| void | rtems_record_dump_base64 (void(*put_char)(int, void *), void *arg) |
| Dumps the event records in base64 encoding. More... | |
| void | rtems_record_dump_zlib_base64 (rtems_record_dump_base64_zlib_context *ctx, void(*put_char)(int, void *), void *arg) |
| Dumps the event records compressed with zlib in base64 encoding. More... | |
| rtems_record_item | |
| rtems_record_item_64 | |
| #define rtems_record_caller | ( | ) | _Record_Caller( RTEMS_RETURN_ADDRESS() ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller().
| #define rtems_record_caller_3 | ( | event, | |
| data | |||
| ) | _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_3().
| event | The record event without a time stamp for the third item. |
| data | The record data for the third item. |
| #define rtems_record_caller_4 | ( | event_0, | |
| data_0, | |||
| event_1, | |||
| data_1 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_4().
| event_0 | The record event without a time stamp for the third item. |
| data_0 | The record data for the third item. |
| event_1 | The record event without a time stamp for the fourth item. |
| data_1 | The record data for the fourth item. |
| #define rtems_record_caller_arg | ( | data | ) | _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data ) |
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg().
| data | The RTEMS_RECORD_ARG_0 event data. |
| #define rtems_record_caller_arg_10 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8, | |||
| data_9 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_10().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_10().
| data_0 | The RTEMS_RECORD_ARG_0 event data. |
| data_1 | The RTEMS_RECORD_ARG_1 event data. |
| data_2 | The RTEMS_RECORD_ARG_2 event data. |
| data_3 | The RTEMS_RECORD_ARG_3 event data. |
| data_4 | The RTEMS_RECORD_ARG_4 event data. |
| data_5 | The RTEMS_RECORD_ARG_5 event data. |
| data_6 | The RTEMS_RECORD_ARG_6 event data. |
| data_7 | The RTEMS_RECORD_ARG_7 event data. |
| data_8 | The RTEMS_RECORD_ARG_8 event data. |
| data_10 | The RTEMS_RECORD_ARG_10 event data. |
| #define rtems_record_caller_arg_2 | ( | data_0, | |
| data_1 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_2().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_2().
| #define rtems_record_caller_arg_3 | ( | data_0, | |
| data_1, | |||
| data_2 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_3().
| #define rtems_record_caller_arg_4 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_4().
| #define rtems_record_caller_arg_5 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_5().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_5().
| #define rtems_record_caller_arg_6 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_6().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_6().
| #define rtems_record_caller_arg_7 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_7().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_7().
| #define rtems_record_caller_arg_8 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_8().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_8().
| #define rtems_record_caller_arg_9 | ( | data_0, | |
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8 | |||
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_9().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_9().
| #define rtems_record_entry | ( | event | ) | rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
The event data of the specified entry event is the return address of the function calling rtems_record_entry().
| event | The entry event. |
| #define rtems_record_entry_1 | ( | event, | |
| data | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_1().
| #define rtems_record_entry_10 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8, | |||
| data_9 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_10().
| #define rtems_record_entry_2 | ( | event, | |
| data_0, | |||
| data_1 | |||
| ) | _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 ) |
The event data of the specified entry event is the return address of the function calling rtems_record_entry_2().
| #define rtems_record_entry_3 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_3().
| #define rtems_record_entry_4 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_4().
| #define rtems_record_entry_5 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_5().
| #define rtems_record_entry_6 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_6().
| #define rtems_record_entry_7 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_7().
| #define rtems_record_entry_8 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_8().
| #define rtems_record_entry_9 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8 | |||
The event data of the specified entry event is the return address of the function calling rtems_record_entry_9().
| #define rtems_record_exit | ( | event | ) | rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() ) |
The event data of the specified exit event is the return address of the function calling rtems_record_exit().
| event | The exit event. |
| #define rtems_record_exit_1 | ( | event, | |
| data | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_1().
| data | The RTEMS_RECORD_RETURN_0 event data. |
| #define rtems_record_exit_10 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8, | |||
| data_9 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_10().
| data_0 | The RTEMS_RECORD_RETURN_0 event data. |
| data_1 | The RTEMS_RECORD_RETURN_1 event data. |
| data_2 | The RTEMS_RECORD_RETURN_2 event data. |
| data_3 | The RTEMS_RECORD_RETURN_3 event data. |
| data_4 | The RTEMS_RECORD_RETURN_4 event data. |
| data_5 | The RTEMS_RECORD_RETURN_5 event data. |
| data_6 | The RTEMS_RECORD_RETURN_6 event data. |
| data_7 | The RTEMS_RECORD_RETURN_7 event data. |
| data_8 | The RTEMS_RECORD_RETURN_8 event data. |
| data_10 | The RTEMS_RECORD_RETURN_10 event data. |
| #define rtems_record_exit_2 | ( | event, | |
| data_0, | |||
| data_1 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_2().
| #define rtems_record_exit_3 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_3().
| #define rtems_record_exit_4 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_4().
| #define rtems_record_exit_5 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_5().
| #define rtems_record_exit_6 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_6().
| #define rtems_record_exit_7 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_7().
| #define rtems_record_exit_8 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_8().
| #define rtems_record_exit_9 | ( | event, | |
| data_0, | |||
| data_1, | |||
| data_2, | |||
| data_3, | |||
| data_4, | |||
| data_5, | |||
| data_6, | |||
| data_7, | |||
| data_8 | |||
The event data of the specified exit event is the return address of the function calling rtems_record_exit_9().
| #define RTEMS_RECORD_MAGIC 0x82e14ec1 |
This is a random number.
| #define RTEMS_RECORD_THE_VERSION 9 |
The record version.
The record version reflects the record event definitions. It is reported by the RTEMS_RECORD_VERSION event.
| #define RTEMS_RECORD_TIME_EVENT | ( | time, | |
| event | |||
| ) | ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) ) |
The events are stored in the record item with a time stamp. There are 22 bits allocated to the time stamp and 10 bits allocated to the event. The 22 bits are enough to get reliable time stamps on a system with a 4GHz CPU counter and a 1000Hz clock tick.
| typedef unsigned long rtems_record_data |
It is big enough to store 32-bit integers and pointers.
| typedef void( * rtems_record_dump_chunk) (void *arg, const void *data, size_t length) |
| arg | The argument passed to rtems_record_dump(). |
| data | The begin of the data chunk. |
| length | The length in bytes of the data chunk. |
| struct __attribute__ | ( | (__packed__) | ) |
The 64-bit format record item.
| RTEMS_INLINE_ROUTINE void rtems_record_add | ( | rtems_record_context * | context, |
| rtems_record_event | event, | ||
| rtems_record_data | data | ||
Adds a record item.
| context | The record context initialized via rtems_record_prepare(). |
| event | The record event without a time stamp for the item. |
| data | The record data for the item. |
| void rtems_record_client_destroy | ( | rtems_record_client_context * | ctx | ) |
The client context must not be used afterwards. It can be re-initialized via rtems_record_client_init().
| ctx | The record client context. |
| void rtems_record_client_init | ( | rtems_record_client_context * | ctx, |
| rtems_record_client_handler | handler, | ||
| void * | arg | ||
The record client consumes a record item stream produces by the record server.
| ctx | The record client context to initialize. |
| handler | The handler is invoked for each received record item. |
| arg | The handler argument. |
| rtems_record_client_status rtems_record_client_run | ( | rtems_record_client_context * | ctx, |
| const void * | buf, | ||
| size_t | n | ||
| buf | The buffer with new stream data. |
| n | The size of the buffer. |
| RTEMS_INLINE_ROUTINE void rtems_record_commit | ( | rtems_record_context * | context | ) |
| RTEMS_INLINE_ROUTINE void rtems_record_commit_critical | ( | rtems_record_context * | context | ) |
| context | The record context initialized via rtems_record_prepare_critical(). |
| void rtems_record_drain | ( | rtems_record_drain_visitor | visitor, |
| void * | arg | ||
Calls the visitor function for each drained item set.
| visitor | The visitor function. |
| arg | The argument for the visitor function. |
| void rtems_record_dump | ( | rtems_record_dump_chunk | chunk, |
| void * | arg | ||
| chunk | Handler to dump a chunk of data. |
| flush | Handler to flush the data. |
| arg | The argument for the handlers. |
| void rtems_record_dump_base64 | ( | void(*)(int, void *) | put_char, |
| void * | arg | ||
| put_char | The put char handler. |
| arg | The argument for the put char handler. |
| void rtems_record_dump_zlib_base64 | ( | rtems_record_dump_base64_zlib_context * | ctx, |
| void(*)(int, void *) | put_char, | ||
| void * | arg | ||
| ctx | The context to perform the record dump with zlib compression and base64 encoding. This context is too large for normal stack sizes. |
| uint32_t rtems_record_interrupt_disable | ( | void | ) |
| void rtems_record_interrupt_enable | ( | uint32_t | level | ) |
| level | The previous interrupt level. Must be the return value of the corresponding rtems_record_interrupt_disable(). |
| void rtems_record_line | ( | void | ) |
The event data is the address of the call to this function.
| void rtems_record_line_2 | ( | rtems_record_event | event, |
| event | The record event without a time stamp for the second item. |
| data | The record data for the second item. |
| void rtems_record_line_3 | ( | rtems_record_event | event_0, |
| rtems_record_data | data_0, | ||
| rtems_record_event | event_1, | ||
| rtems_record_data | data_1 | ||
| event_0 | The record event without a time stamp for the second item. |
| data_0 | The record data for the second item. |
| event_1 | The record event without a time stamp for the third item. |
| data_1 | The record data for the third item. |
| void rtems_record_line_arg | ( | rtems_record_data | data | ) |
The event data of the RTEMS_RECORD_LINE event is the address of the call to this function.
| void rtems_record_line_arg_10 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_1, | ||
| rtems_record_data | data_2, | ||
| rtems_record_data | data_3, | ||
| rtems_record_data | data_4, | ||
| rtems_record_data | data_5, | ||
| rtems_record_data | data_6, | ||
| rtems_record_data | data_7, | ||
| rtems_record_data | data_8, | ||
| rtems_record_data | data_9 | ||
| data_9 | The RTEMS_RECORD_ARG_9 event data. |
| void rtems_record_line_arg_2 | ( | rtems_record_data | data_0, |
| void rtems_record_line_arg_3 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_2 | ||
| void rtems_record_line_arg_4 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_3 | ||
| void rtems_record_line_arg_5 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_4 | ||
| void rtems_record_line_arg_6 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_5 | ||
| void rtems_record_line_arg_7 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_6 | ||
| void rtems_record_line_arg_8 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_7 | ||
| void rtems_record_line_arg_9 | ( | rtems_record_data | data_0, |
| rtems_record_data | data_8 | ||
| RTEMS_INLINE_ROUTINE void rtems_record_prepare | ( | rtems_record_context * | context | ) |
This function disables interrupts.
| context | The record context which must be used for the following rtems_record_add() and rtems_record_commit() calls. The record context may have an arbitrary content at function entry. |
| RTEMS_INLINE_ROUTINE void rtems_record_prepare_critical | ( | rtems_record_context * | context, |
| const Per_CPU_Control * | cpu_self | ||
This function does not disable interrupts. It must be called with interrupts disabled. Interrupts must be disabled until the corresponding rtems_record_commit_critical() was called.
| context | The record context which must be used for the following rtems_record_add() and rtems_record_commit_critical() calls. The record context may have an arbitrary content at function entry. |
| cpu_self | The control of the current processor. |
| void rtems_record_produce | ( | rtems_record_event | event, |
| void rtems_record_produce_2 | ( | rtems_record_event | event_0, |
| event_0 | The record event without a time stamp for the first item. |
| data_0 | The record data for the first item. |
| event_1 | The record event without a time stamp for the second item. |
| data_1 | The record data for the second item. |
| void rtems_record_produce_n | ( | const rtems_record_item * | items, |
| size_t | n | ||
| item | The record items without a time stamps. |
| n | The count of record items. |
1.8.15
