RTEMS
5.1-rc2
LM32 EVR Board Support Package. More...
Files | |
| file | bsp.h |
| Global BSP definitions. | |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. More... | |
| void | BSP_uart_polled_write (char ch) |
| int | BSP_uart_polled_read (void) |
| char | BSP_uart_is_character_ready (char *ch) |
| rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
| rtems_vector_number | vector, | ||
| int | type | ||
This method installs an interrupt handle.
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
1.8.15
