RTEMS
5.1-rc2
Files | |
| file | key.c |
| POSIX Keys Information with Zero Objects. | |
| struct | POSIX_Keys_Key_value_pair |
| Represents POSIX key and value pair. More... | |
| struct | POSIX_Keys_Control |
| The data structure used to manage a POSIX key. More... | |
| #define | POSIX_KEYS_INFORMATION_DEFINE(max) |
| Macro to define the objects information for the POSIX Key objects. More... | |
| #define | POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR(node) RTEMS_CONTAINER_OF( node, POSIX_Keys_Key_value_pair, Lookup_node ) |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Allocate (void) |
| Allocate a keys control block. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Free (POSIX_Keys_Control *the_key) |
| Free a keys control block. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Get (pthread_key_t key) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_release (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| POSIX_Keys_Key_value_pair * | _POSIX_Keys_Key_value_allocate (void) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_free (POSIX_Keys_Key_value_pair *key_value_pair) |
| RTEMS_INLINE_ROUTINE bool | _POSIX_Keys_Key_value_equal (const void *left, const RBTree_Node *right) |
| RTEMS_INLINE_ROUTINE bool | _POSIX_Keys_Key_value_less (const void *left, const RBTree_Node *right) |
| RTEMS_INLINE_ROUTINE void * | _POSIX_Keys_Key_value_map (RBTree_Node *node) |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Key_value_pair * | _POSIX_Keys_Key_value_find (pthread_key_t key, const Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_insert (pthread_key_t key, POSIX_Keys_Key_value_pair *key_value_pair, Thread_Control *the_thread) |
| POSIX_Keys_Key_value_pair | _POSIX_Keys_Key_value_pairs [] |
| The initial set of POSIX key and value pairs. More... | |
| const uint32_t | _POSIX_Keys_Key_value_pair_maximum |
| The POSIX key and value pairs maximum. More... | |
| Objects_Information | _POSIX_Keys_Information |
| The POSIX Key objects information. | |
| Freechain_Control | _POSIX_Keys_Keypool |
| This freechain is used as a memory pool for POSIX_Keys_Key_value_pair. | |
| #define POSIX_KEYS_INFORMATION_DEFINE | ( | max | ) |
This macro should only be used by <rtems/confdefs.h>.
| max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control* _POSIX_Keys_Allocate | ( | void | ) |
This function allocates a keys control block from the inactive chain of free keys control blocks.
| RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free | ( | POSIX_Keys_Control * | the_key | ) |
This routine frees a keys control block to the inactive chain of free keys control blocks.
| const uint32_t _POSIX_Keys_Key_value_pair_maximum |
This value is provided via <rtems/confdefs.h> in case POSIX key and value pairs are configured. The OBJECTS_UNLIMITED_OBJECTS flag may be set.
| POSIX_Keys_Key_value_pair _POSIX_Keys_Key_value_pairs[] |
This array is provided via <rtems/confdefs.h> in case POSIX key and value pairs are configured. The POSIX key and value pair count in this array must be equal to _Objects_Maximum_per_allocation( _POSIX_Keys_Key_value_pair_maximum ).
1.8.15
