RTEMS
5.1-rc2
| int | rtems_deviceio_open (rtems_libio_t *iop, const char *path, int oflag, mode_t mode, rtems_device_major_number major, rtems_device_minor_number minor) |
| IMFS device node handlers. More... | |
| int | rtems_deviceio_close (rtems_libio_t *iop, rtems_device_major_number major, rtems_device_minor_number minor) |
| ssize_t | rtems_deviceio_read (rtems_libio_t *iop, void *buf, size_t nbyte, rtems_device_major_number major, rtems_device_minor_number minor) |
| ssize_t | rtems_deviceio_write (rtems_libio_t *iop, const void *buf, size_t nbyte, rtems_device_major_number major, rtems_device_minor_number minor) |
| int | rtems_deviceio_control (rtems_libio_t *iop, ioctl_command_t command, void *buffer, rtems_device_major_number major, rtems_device_minor_number minor) |
This contains the interface to device drivers using the RTEMS Classic API.
| int rtems_deviceio_open | ( | rtems_libio_t * | iop, |
| const char * | path, | ||
| int | oflag, | ||
| mode_t | mode, | ||
| rtems_device_major_number | major, | ||
| rtems_device_minor_number | minor | ||
IMFS Device Node Handlers
This file contains the set of handlers used to map operations on IMFS device nodes onto calls to the RTEMS Classic API IO Manager.
1.8.15
