RTEMS
5.1-rc2
The ALT_DMA_CCR_OPT_* macro definitions are defined here to facilitate the dynamic microcode programming of the assembler directive:
DMAMOV CCR, [SB<1-16>] [SS<8|16|32|64|128>] [SA<I|F>]
[SP<imm3>] [SC<imm4>]
[DB<1-16>] [DS<8|16|32|64|128>] [DA<I|F>]
[DP<imm3>] [DC<imm4>]
[ES<8|16|32|64|128>]with a DMAMOV instruction (see: alt_dma_program_DMAMOV()).
For example the assembler directive:
DMAMOV CCR SB1 SS32 DB1 DS32
would be dynamically programmed with the following API call:
alt_dma_program_DMAMOV( pgm,
ALT_DMA_PROGRAM_REG_CCR,
( ALT_DMA_CCR_OPT_SB1
| ALT_DMA_CCR_OPT_SS32
| ALT_DMA_CCR_OPT_SA_DEFAULT
| ALT_DMA_CCR_OPT_SP_DEFAULT
| ALT_DMA_CCR_OPT_SC_DEFAULT
| ALT_DMA_CCR_OPT_DB1
| ALT_DMA_CCR_OPT_DS32
| ALT_DMA_CCR_OPT_DA_DEFAULT
| ALT_DMA_CCR_OPT_DP_DEFAULT
| ALT_DMA_CCR_OPT_DC_DEFAULT
| ALT_DMA_CCR_OPT_ES8
Each CCR option category should be specified regardless of whether it specifies a custom value or the normal default value (i.e. an ALT_DMA_CCR_OPT_*_DEFAULT.
| #define ALT_DMA_CCR_OPT_DA_DEFAULT ALT_DMA_CCR_OPT_DAI |
Destination Address Default value.
| #define ALT_DMA_CCR_OPT_DAF (0 << 14) |
Destination Address Fixed address burst.
| #define ALT_DMA_CCR_OPT_DAI (1 << 14) |
Destination Address Incrementing address burst.
| #define ALT_DMA_CCR_OPT_DB1 (0x0 << 18) |
Destination Burst length of 1 transfer.
| #define ALT_DMA_CCR_OPT_DB10 (0x9 << 18) |
Destination Burst length of 10 transfers.
| #define ALT_DMA_CCR_OPT_DB11 (0xa << 18) |
Destination Burst length of 11 transfers.
| #define ALT_DMA_CCR_OPT_DB12 (0xb << 18) |
Destination Burst length of 12 transfers.
| #define ALT_DMA_CCR_OPT_DB13 (0xc << 18) |
Destination Burst length of 13 transfers.
| #define ALT_DMA_CCR_OPT_DB14 (0xd << 18) |
Destination Burst length of 14 transfers.
| #define ALT_DMA_CCR_OPT_DB15 (0xe << 18) |
Destination Burst length of 15 transfers.
| #define ALT_DMA_CCR_OPT_DB16 (0xf << 18) |
Destination Burst length of 16 transfers.
| #define ALT_DMA_CCR_OPT_DB2 (0x1 << 18) |
Destination Burst length of 2 transfers.
| #define ALT_DMA_CCR_OPT_DB3 (0x2 << 18) |
Destination Burst length of 3 transfers.
| #define ALT_DMA_CCR_OPT_DB4 (0x3 << 18) |
Destination Burst length of 4 transfers.
| #define ALT_DMA_CCR_OPT_DB5 (0x4 << 18) |
Destination Burst length of 5 transfers.
| #define ALT_DMA_CCR_OPT_DB6 (0x5 << 18) |
Destination Burst length of 6 transfers.
| #define ALT_DMA_CCR_OPT_DB7 (0x6 << 18) |
Destination Burst length of 7 transfers.
| #define ALT_DMA_CCR_OPT_DB8 (0x7 << 18) |
Destination Burst length of 8 transfers.
| #define ALT_DMA_CCR_OPT_DB9 (0x8 << 18) |
Destination Burst length of 9 transfers.
| #define ALT_DMA_CCR_OPT_DB_DEFAULT ALT_DMA_CCR_OPT_DB1 |
Destination Burst length default transfers.
| #define ALT_DMA_CCR_OPT_DC | ( | imm4 | ) | ((imm4) << 25) |
Destination Cache bits for AXI bus AWCACHE[3,1:0].
| #define ALT_DMA_CCR_OPT_DC_DEFAULT ALT_DMA_CCR_OPT_DC(0) |
Destination Cache bits default value.
| #define ALT_DMA_CCR_OPT_DEFAULT |
Default CCR register options for a DMAMOV CCR assembler directive.
| #define ALT_DMA_CCR_OPT_DP | ( | imm3 | ) | ((imm3) << 22) |
Destination Protection bits for AXI bus AWPROT[2:0].
| #define ALT_DMA_CCR_OPT_DP_DEFAULT ALT_DMA_CCR_OPT_DP(0) |
Destination Protection bits default value.
| #define ALT_DMA_CCR_OPT_DS128 (4 << 15) |
Destination burst Size of 128 bits.
| #define ALT_DMA_CCR_OPT_DS16 (1 << 15) |
Destination burst Size of 16 bits.
| #define ALT_DMA_CCR_OPT_DS32 (2 << 15) |
Destination burst Size of 32 bits.
| #define ALT_DMA_CCR_OPT_DS64 (3 << 15) |
Destination burst Size of 64 bits.
| #define ALT_DMA_CCR_OPT_DS8 (0 << 15) |
Destination burst Size of 8 bits.
| #define ALT_DMA_CCR_OPT_DS_DEFAULT ALT_DMA_CCR_OPT_DS8 |
Destination burst Size default bits.
| #define ALT_DMA_CCR_OPT_ES128 (4 << 28) |
Endian Swap: Swap bytes within 128-bit data.
| #define ALT_DMA_CCR_OPT_ES16 (1 << 28) |
Endian Swap: Swap bytes within 16-bit data.
| #define ALT_DMA_CCR_OPT_ES32 (2 << 28) |
Endian Swap: Swap bytes within 32-bit data.
| #define ALT_DMA_CCR_OPT_ES64 (3 << 28) |
Endian Swap: Swap bytes within 64-bit data.
| #define ALT_DMA_CCR_OPT_ES8 (0 << 28) |
Endian Swap: No swap, 8-bit data.
| #define ALT_DMA_CCR_OPT_ES_DEFAULT ALT_DMA_CCR_OPT_ES8 |
Endian Swap: Default byte swap.
| #define ALT_DMA_CCR_OPT_SA_DEFAULT ALT_DMA_CCR_OPT_SAI |
Source Address Default value.
| #define ALT_DMA_CCR_OPT_SAF (0 << 0) |
Source Address Fixed address burst.
| #define ALT_DMA_CCR_OPT_SAI (1 << 0) |
Source Address Incrementing address burst.
| #define ALT_DMA_CCR_OPT_SB1 (0x0 << 4) |
Source Burst length of 1 transfer.
| #define ALT_DMA_CCR_OPT_SB10 (0x9 << 4) |
Source Burst length of 10 transfers.
| #define ALT_DMA_CCR_OPT_SB11 (0xa << 4) |
Source Burst length of 11 transfers.
| #define ALT_DMA_CCR_OPT_SB12 (0xb << 4) |
Source Burst length of 12 transfers.
| #define ALT_DMA_CCR_OPT_SB13 (0xc << 4) |
Source Burst length of 13 transfers.
| #define ALT_DMA_CCR_OPT_SB14 (0xd << 4) |
Source Burst length of 14 transfers.
| #define ALT_DMA_CCR_OPT_SB15 (0xe << 4) |
Source Burst length of 15 transfers.
| #define ALT_DMA_CCR_OPT_SB16 (0xf << 4) |
Source Burst length of 16 transfers.
| #define ALT_DMA_CCR_OPT_SB2 (0x1 << 4) |
Source Burst length of 2 transfers.
| #define ALT_DMA_CCR_OPT_SB3 (0x2 << 4) |
Source Burst length of 3 transfers.
| #define ALT_DMA_CCR_OPT_SB4 (0x3 << 4) |
Source Burst length of 4 transfers.
| #define ALT_DMA_CCR_OPT_SB5 (0x4 << 4) |
Source Burst length of 5 transfers.
| #define ALT_DMA_CCR_OPT_SB6 (0x5 << 4) |
Source Burst length of 6 transfers.
| #define ALT_DMA_CCR_OPT_SB7 (0x6 << 4) |
Source Burst length of 7 transfers.
| #define ALT_DMA_CCR_OPT_SB8 (0x7 << 4) |
Source Burst length of 8 transfers.
| #define ALT_DMA_CCR_OPT_SB9 (0x8 << 4) |
Source Burst length of 9 transfers.
| #define ALT_DMA_CCR_OPT_SB_DEFAULT ALT_DMA_CCR_OPT_SB1 |
Source Burst length default transfers.
| #define ALT_DMA_CCR_OPT_SC | ( | imm4 | ) | ((imm4) << 11) |
Source Cache bits for AXI bus ARCACHE[2:0].
| #define ALT_DMA_CCR_OPT_SC_DEFAULT ALT_DMA_CCR_OPT_SC(0) |
Source Cache bits default value.
| #define ALT_DMA_CCR_OPT_SP | ( | imm3 | ) | ((imm3) << 8) |
Source Protection bits for AXI bus ARPROT[2:0].
| #define ALT_DMA_CCR_OPT_SP_DEFAULT ALT_DMA_CCR_OPT_SP(0) |
Source Protection bits default value.
| #define ALT_DMA_CCR_OPT_SS128 (4 << 1) |
Source burst Size of 128 bits.
| #define ALT_DMA_CCR_OPT_SS16 (1 << 1) |
Source burst Size of 16 bits.
| #define ALT_DMA_CCR_OPT_SS32 (2 << 1) |
Source burst Size of 32 bits.
| #define ALT_DMA_CCR_OPT_SS64 (3 << 1) |
Source burst Size of 64 bits.
| #define ALT_DMA_CCR_OPT_SS8 (0 << 1) |
Source burst Size of 8 bits.
| #define ALT_DMA_CCR_OPT_SS_DEFAULT ALT_DMA_CCR_OPT_SS8 |
Source burst Size default bits.
1.8.15
