RTEMS
5.1-rc2
Files | |
| file | support.h |
| file | workspace.c |
| RTEMS Workspace Support. | |
| bool | rtems_workspace_get_information (Heap_Information_block *the_info) |
| Gets Workspace Information. More... | |
| bool | rtems_workspace_allocate (size_t bytes, void **pointer) |
| Allocates Memory from the Workspace. More... | |
| bool | rtems_workspace_free (void *pointer) |
| Frees Memory Allocated from the Workspace. More... | |
| void * | rtems_workspace_greedy_allocate (const uintptr_t *block_sizes, size_t block_count) |
| Greedy allocate that empties the workspace. More... | |
| void * | rtems_workspace_greedy_allocate_all_except_largest (uintptr_t *allocatable_size) |
| Greedy allocate all blocks except the largest free block. More... | |
| void | rtems_workspace_greedy_free (void *opaque) |
| Frees space of a greedy allocation. More... | |
Workspace definitions.
| bool rtems_workspace_allocate | ( | size_t | bytes, |
| void ** | pointer | ||
A number of bytes bytes will be allocated from the RTEMS Executive Workspace and returned in pointer.
Returns true if successful, and false otherwise.
| bool rtems_workspace_free | ( | void * | pointer | ) |
This frees the memory indicated by pointer that was allocated from the RTEMS Executive Workspace.
| bool rtems_workspace_get_information | ( | Heap_Information_block * | the_info | ) |
Returns information about the heap that is used as the RTEMS Executive Workspace in the_info.
| void* rtems_workspace_greedy_allocate | ( | const uintptr_t * | block_sizes, |
| size_t | block_count | ||
Afterwards the heap has at most block_count allocatable blocks of sizes specified by block_sizes. The block_sizes must point to an array with block_count members. All other blocks are used.
| void* rtems_workspace_greedy_allocate_all_except_largest | ( | uintptr_t * | allocatable_size | ) |
Afterwards the heap has at most one allocatable block. This block is the largest free block if it exists. The allocatable size of this block is stored in allocatable_size. All other blocks are used.
| void rtems_workspace_greedy_free | ( | void * | opaque | ) |
The opaque argument must be the return value of rtems_workspace_greedy_allocate() or rtems_workspace_greedy_allocate_all_except_largest().
1.8.15
