RTEMS
5.1-rc2
Typedefs | |
| typedef enum ALT_DMA_CHANNEL_e | ALT_DMA_CHANNEL_t |
| typedef enum ALT_DMA_PERIPH_e | ALT_DMA_PERIPH_t |
| typedef enum ALT_DMA_SECURITY_e | ALT_DMA_SECURITY_t |
| typedef enum ALT_DMA_EVENT_e | ALT_DMA_EVENT_t |
This module contains the common definitions for the DMA controller related APIs.
| typedef enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t |
This type definition enumerates the DMA controller channel threads.
| typedef enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t |
This type definition enumerates the DMA event-interrupt resources.
| typedef enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t |
This type definition enumerates the SoC system peripherals implementing the required request interface that enables direct DMA transfers to/from the device.
FPGA soft IP interface to the DMA are required to comply with the Synopsys protocol.
Request interface numbers 4 through 7 are multiplexed between the CAN controllers and soft logic implemented in the FPGA fabric. The selection between the CAN controller and FPGA interfaces is determined at DMA initialization.
| typedef enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t |
This type enumerates the DMA security state options available.
1.8.15
