RTEMS
5.1-rc2
File Transfer Protocol file system (FTP client). More...
| #define | RTEMS_FTPFS_CTRL_PORT 21 |
| Well-known port number for FTP control connection. | |
| #define | RTEMS_FTPFS_MOUNT_POINT_DEFAULT "/FTP" |
| Default mount point for FTP file system. | |
Enumerations | |
| enum | rtems_ftpfs_ioctl_numbers { RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR( 'd', 1, bool *), RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW( 'd', 1, bool *), RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR( 'd', 2, struct timeval *), RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW( 'd', 2, struct timeval *) } |
| FTP file system IO control requests. | |
| rtems_status_code | rtems_ftpfs_get_verbose (const char *mount_point, bool *verbose) |
| Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_set_verbose (const char *mount_point, bool verbose) |
Enables or disables the verbose mode if verbose is true or false respectively for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_get_timeout (const char *mount_point, struct timeval *timeout) |
| Returns the current timeout value in timeout for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_set_timeout (const char *mount_point, const struct timeval *timeout) |
| Sets the timeout value to timeout for the file system at mount_point. More... | |
| int | rtems_ftpfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Do not call directly, use mount(). | |
1.8.15
