RTEMS
5.1-rc2
Files | |
| file | _execve.c |
| _execve() | |
| file | adjtime.c |
| Adjust the Time to Synchronize the System Clock. | |
| file | aio_cancel.c |
| Cancel Asynchronous I/O Operation. | |
| file | aio_error.c |
| Returns the error status for the Asynchronous I/O request. | |
| file | aio_fsync.c |
| Syncing of all Outstanding Asynchronous I/O Operations. | |
| file | aio_misc.c |
| Actual request being processed. | |
| file | aio_read.c |
| Asynchronously reads Data from a File. | |
| file | aio_return.c |
| Final return status for Asynchronous I/O request pointed to by aiobcp. | |
| file | aio_suspend.c |
| Suspends Process until Asynchronous I/O Operation completes. | |
| file | aio_write.c |
| Function queues I/O request described by buffer pointed by aiocb. | |
| file | alarm.c |
| System Generates Signal for process after realtime seconds elapsed. | |
| file | barrierattrdestroy.c |
| Function shall Destroy a Barrier Attribues Object. | |
| file | barrierattrgetpshared.c |
| Barrier Attributes Get Process Shared. | |
| file | barrierattrinit.c |
| Initialize the Barrier Attributes Object. | |
| file | barrierattrsetpshared.c |
| Set the Process-Shared Attribute of the Barrier Attributes Object. | |
| file | cancel.c |
| Canceling Execution of a Thread. | |
| file | cleanuppush.c |
| POSIX Cleanup Support. | |
| file | clockgetcpuclockid.c |
| Function Returns Clock ID of CPU-time Clock of process specified. | |
| file | clockgetres.c |
| Function Returns the Resolution of any Clock. | |
| file | clockgettime.c |
| Retrieves the Specified Clock Time. | |
| file | clocksettime.c |
| Set Time of Clock. | |
| file | condattrdestroy.c |
| Destroy Condition Attribute. | |
| file | condattrgetclock.c |
| Get the Clock Condition Variable Attributes. | |
| file | condattrgetpshared.c |
| Get the Process-Shared Condition Variable Attributes. | |
| file | condattrinit.c |
| Initialization of Conditional Attributes. | |
| file | condattrsetclock.c |
| Set the Clock Condition Variable Attributes. | |
| file | condattrsetpshared.c |
| Set the Process-Shared Condition Variable Attributes. | |
| file | condbroadcast.c |
| Broadcast a Condition. | |
| file | conddefaultattributes.c |
| Condition variable Attributes structure. | |
| file | conddestroy.c |
| Destroy a Condition Variable. | |
| file | condinit.c |
| Initialize a Condition Variable. | |
| file | condsignal.c |
| Signal a Condition. | |
| file | condsignalsupp.c |
| Implements wake up version of the "signal" operation. | |
| file | condtimedwait.c |
| Waiting on a Condition. | |
| file | condwait.c |
| file | condwaitsupp.c |
| POSIX Condition Variables Wait Support. | |
| file | fork.c |
| Inoperable implementation of fork() for POSIX threads. | |
| file | getitimer.c |
| Function Gets Value of an Interval Timer. | |
| file | key.c |
| POSIX Keys Information with Zero Objects. | |
| file | keycreate.c |
| Thread-Specific Data Key Create. | |
| file | keydelete.c |
| Deletes Thread-specific Data Key Previously Returned by keycreate.c. | |
| file | keygetspecific.c |
| Thread-Specific Data Management. | |
| file | keysetspecific.c |
| Set Specific Key. | |
| file | kill.c |
| Send a Signal to a Process. | |
| file | kill_r.c |
| file | killinfo.c |
| file | lio_listio.c |
| Function Initiates a List of I/O Requests with Single Function Call. | |
| file | mlock.c |
| file | mlockall.c |
| file | mmap.c |
| file | mprotect.c |
| Change Memory Protection. | |
| file | mqueue.c |
| POSIX Message Queue Information with Zero Objects. | |
| file | mqueueclose.c |
| Function closes the Message Queue. | |
| file | mqueuedeletesupp.c |
| POSIX Delete Message Queue. | |
| file | mqueuegetattr.c |
| Message Queue Attributes. | |
| file | mqueuenotify.c |
| Notify Process that a Message is Available on a Queue. | |
| file | mqueueopen.c |
| Creates a new POSIX Message Queue or Opens an Existing Queue. | |
| file | mqueuereceive.c |
| Receive a Message From a Message Queue. | |
| file | mqueuerecvsupp.c |
| POSIX Message Queue Receive Support. | |
| file | mqueuesend.c |
| Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes. | |
| file | mqueuesendsupp.c |
| POSIX Message Queue and Send Support. | |
| file | mqueuesetattr.c |
| Set Message Queue Attributes. | |
| file | mqueuetimedreceive.c |
| Receive Message from Message Queue. | |
| file | mqueuetimedsend.c |
| Send a Message to a Message Queue. | |
| file | mqueueunlink.c |
| Remove a Message Queue. | |
| file | msync.c |
| file | munlock.c |
| file | munlockall.c |
| file | mutexattrdestroy.c |
| Destroy Mutex Attributes Object. | |
| file | mutexattrgetprioceiling.c |
| Mutex Initialization Scheduling Attributes. | |
| file | mutexattrgetprotocol.c |
| Get protocol Attribute of Mutex Attribute Obect. | |
| file | mutexattrgetpshared.c |
| Obtaining process-shared Attribute Value from the Attributes Object. | |
| file | mutexattrgettype.c |
| Function gets the Mutex Type Attribute. | |
| file | mutexattrinit.c |
| Mutex Initialization Attribute. | |
| file | mutexattrsetprioceiling.c |
| file | mutexattrsetprotocol.c |
| file | mutexattrsetpshared.c |
| Function sets Current pshared Attribute for Mutex Attributes Object. | |
| file | mutexattrsettype.c |
| Set a Mutex Type. | |
| file | mutexdestroy.c |
| Initializing and Destroying a Mutex. | |
| file | mutexgetprioceiling.c |
| Returns the Current Priority Ceiling of the Mutex. | |
| file | mutexinit.c |
| Initialize a Mutex. | |
| file | mutexlock.c |
| Call to function enables locking of Mutex Object referenced by mutex. | |
| file | mutexlocksupp.c |
| Support Call to function Enables Locking of Mutex Object. | |
| file | mutexsetprioceiling.c |
| Changes the Priority Ceiling of a Mutex and Releases it. | |
| file | mutextimedlock.c |
| Mutex Timed Lock. | |
| file | mutextrylock.c |
| Try to Lock Mutex. | |
| file | mutexunlock.c |
| Locking and Unlocking a Mutex. | |
| file | nanosleep.c |
| Suspends Execution of calling thread until Time elapses. | |
| file | pause.c |
| Suspend Process Execution. | |
| file | pbarrierdestroy.c |
| Destroy a Barrier Object. | |
| file | pbarrierinit.c |
| Call to Function Enables Reinitializing of the Barrier. | |
| file | pbarrierwait.c |
| Wait at a Barrier. | |
| file | posix_madvise.c |
| file | prwlockdestroy.c |
| Destroy a RWLock. | |
| file | prwlockinit.c |
| Allocate resources to use the read-write lock and Initialize it. | |
| file | prwlockrdlock.c |
| Obtain a Read Lock on a RWLock Instance. | |
| file | prwlocktimedrdlock.c |
| Attempt to Obtain a Read Lock on a RWLock Instance. | |
| file | prwlocktimedwrlock.c |
| Function applies a Write lock to RWLock referenced by rwlock. | |
| file | prwlocktryrdlock.c |
| file | prwlocktrywrlock.c |
| Attempt to Obtain a Write Lock on a RWLock Instance. | |
| file | prwlockunlock.c |
| Function Releases a lock held on RWLock object referenced by rwlock. | |
| file | prwlockwrlock.c |
| Obtain a Write Lock on a RWlock Instance. | |
| file | psignal.c |
| POSIX Signals Manager Initialization. | |
| file | psignalclearprocesssignals.c |
| POSIX_signals clear_process_signals. | |
| file | psignalclearsignals.c |
| POSIX Signals Clear Signals. | |
| file | psignalsetprocesssignals.c |
| POSIX Signals Set Process Signals. | |
| file | psignalunblockthread.c |
| POSIX Signals Thread Unlock. | |
| file | pspindestroy.c |
| Destroy a Spinlock. | |
| file | pspininit.c |
| POSIX Function Initializes a Spinlock Instance. | |
| file | pspinlock.c |
| Wait at a Spinlock. | |
| file | pspinunlock.c |
| Function Unlocks a Spin Lock Object. | |
| file | psxnametoid.c |
| POSIX Name to ID. | |
| file | psxpriorityisvalid.c |
| POSIX Is Priority Valid. | |
| file | psxsemaphore.c |
| POSIX Semaphore Information with Zero Objects. | |
| file | psxtimercreate.c |
| Create a Per-Process Timer. | |
| file | psxtimerdelete.c |
| Deletes a POSIX Interval Timer. | |
| file | psxtransschedparam.c |
| Translate sched_param into SuperCore Terms. | |
| file | pthread.c |
| Private Support Information for POSIX Threads. | |
| file | pthreadatfork.c |
| Register Fork Handlers. | |
| file | pthreadattrdefault.c |
| file | pthreadattrdestroy.c |
| Thread Creation Attributes. | |
| file | pthreadattrgetaffinitynp.c |
| Pthread Attribute Get Affinity. | |
| file | pthreadattrgetdetachstate.c |
| Function gets the detachstate Attribute in the attr Object. | |
| file | pthreadattrgetguardsize.c |
| file | pthreadattrgetinheritsched.c |
| Thread Creation Scheduling Attributes. | |
| file | pthreadattrgetschedparam.c |
| Returns Scheduling Parameter Attributes of Thread Attributes Object. | |
| file | pthreadattrgetschedpolicy.c |
| Get The Schedpolicy Attribute. | |
| file | pthreadattrgetscope.c |
| Function gets the Contentionscope Attribute in the attr object. | |
| file | pthreadattrgetstack.c |
| Function Gets the Thread Creation Stack Attributes in the attr. | |
| file | pthreadattrgetstackaddr.c |
| file | pthreadattrgetstacksize.c |
| file | pthreadattrinit.c |
| Thread Attributes Creation. | |
| file | pthreadattrsetaffinitynp.c |
| Pthread Attribute Set Affinity. | |
| file | pthreadattrsetdetachstate.c |
| file | pthreadattrsetguardsize.c |
| file | pthreadattrsetinheritsched.c |
| Function sets the inheritsched Attribute in the attr Argument. | |
| file | pthreadattrsetschedparam.c |
| Thread Creation Scheduling Parameters. | |
| file | pthreadattrsetschedpolicy.c |
| Sets Scheduling policy Attributes of Thread Attributes Object. | |
| file | pthreadattrsetscope.c |
| Function Sets the Contentionscope Attribute in the attr Object. | |
| file | pthreadattrsetstack.c |
| Function Sets Thread Creation Stack Attributes in the attr object. | |
| file | pthreadattrsetstackaddr.c |
| Sets the Thread Creation stackaddr Attribute in the attr Object. | |
| file | pthreadattrsetstacksize.c |
| Sets the Thread Creation Stacksize Attribute in the attr object. | |
| file | pthreadconcurrency.c |
| Pthread Get/Set Concurrency. | |
| file | pthreadcreate.c |
| Function Starts a New Thread in The Calling Process. | |
| file | pthreaddetach.c |
| Detaching a Thread. | |
| file | pthreadequal.c |
| Compare Thread IDs. | |
| file | pthreadexit.c |
| POSIX Thread Exit Shared Helper. | |
| file | pthreadgetaffinitynp.c |
| Pthread Get Affinity. | |
| file | pthreadgetattrnp.c |
| Pthread Get Attribute. | |
| file | pthreadgetcpuclockid.c |
| Returns Clock ID for CPU time clock of the thread. | |
| file | pthreadgetschedparam.c |
| Gets Scheduling Policy and Parameters of Individual Threads. | |
| file | pthreadinitthreads.c |
| POSIX Threads Initialize User Threads Body. | |
| file | pthreadjoin.c |
| Suspends Execution of Calling Thread until Target Thread Terminates. | |
| file | pthreadkill.c |
| Sends a signal Asynchronously directed to a thread. | |
| file | pthreadonce.c |
| Call to function by Thread will call init_routine with no Arguments. | |
| file | pthreadself.c |
| Function returns the ID of the Calling Thread. | |
| file | pthreadsetaffinitynp.c |
| Pthread Set Affinity. | |
| file | pthreadsetschedparam.c |
| Function sets scheduling policy and parameters of the thread. | |
| file | pthreadsigmask.c |
| Examine and/or change the calling thread's signal mask. | |
| file | ptimer.c |
| POSIX Timer Information with Zero Objects. | |
| file | rwlockattrdestroy.c |
| Function Destroys a read-write lock Attributes object. | |
| file | rwlockattrgetpshared.c |
| Get the Process-Shared Attribute of the RWLock. | |
| file | rwlockattrinit.c |
| Initialises a RWLock Attributes object attr with the default value. | |
| file | rwlockattrsetpshared.c |
| RWLock Attributes Set Process Shared. | |
| file | sched_getparam.c |
| Set Scheduling Parameters. | |
| file | sched_getprioritymax.c |
| Returns the Appropriate Maximum for Scheduling policy. | |
| file | sched_getprioritymin.c |
| Get the Minimum Priority Limit. | |
| file | sched_getscheduler.c |
| Function Returns Scheduling Policy of the process specified by pid. | |
| file | sched_rr_get_interval.c |
| Limits for Scheduling Parameter. | |
| file | sched_setparam.c |
| Sets Scheduling Parameters Associated with Scheduling Policies. | |
| file | sched_setscheduler.c |
| Set Scheduling Policy and Scheduling Parameters. | |
| file | sched_yield.c |
| Yield Processor. | |
| file | semaphoredeletesupp.c |
| POSIX Delete Semaphore. | |
| file | semclose.c |
| Close a Named Semaphore. | |
| file | semdestroy.c |
| Destroy an Unnamed Semaphore. | |
| file | semgetvalue.c |
| Get the Value of a Semaphore. | |
| file | seminit.c |
| Initializing of an Unnamed Semaphore. | |
| file | semopen.c |
| Function Creates New POSIX semaphore or Opens an existing Semaphore. | |
| file | sempost.c |
| Unlock a Semaphore. | |
| file | semtimedwait.c |
| Lock a Semaphore. | |
| file | semtrywait.c |
| file | semunlink.c |
| Remove a Named Semaphore. | |
| file | semwait.c |
| file | setcancelstate.c |
| Setting Cancelability State. | |
| file | setcanceltype.c |
| Sets the Cancelability Type of Calling Thread to value given in type. | |
| file | setitimer.c |
| Set the Timer. | |
| file | shm.c |
| POSIX Shared Memory Information with Zero Objects. | |
| file | shmheap.c |
| file | shmopen.c |
| file | shmunlink.c |
| file | shmwkspace.c |
| file | sigaction.c |
| Allows calling process to examine action of a Specific Signal. | |
| file | sigaddset.c |
| Function Adds Signal from Set. | |
| file | sigdelset.c |
| Deleted Signal from Set. | |
| file | sigemptyset.c |
| Manipulate Signal Sets. | |
| file | sigfillset.c |
| file | sigismember.c |
| file | signal_2.c |
| POSIX Function Installs signal Handler. | |
| file | sigpending.c |
| Examine Pending Signals. | |
| file | sigprocmask.c |
| Examine and Change Blocked Signals. | |
| file | sigqueue.c |
| Queue a Signal to a Process. | |
| file | sigsuspend.c |
| Replacing signal mask with *sigmask and suspending calling process. | |
| file | sigtimedwait.c |
| Wait for Queued Signals. | |
| file | sigwait.c |
| Synchronously Accept a Signal. | |
| file | sigwaitinfo.c |
| Suspends Execution of Calling Thread until Signals in set Delivered. | |
| file | sysconf.c |
| Get Configurable System Variables. | |
| file | testcancel.c |
| Setting test on Cancelability State. | |
| file | timergetoverrun.c |
| Get Overrun Count for a POSIX Per-Process Timer. | |
| file | timergettime.c |
| Function Fetches State of POSIX Per-Process Timers. | |
| file | timersettime.c |
| Function Arms or Disarms the Timer Identified by timerid. | |
| file | ualarm.c |
| Schedule Alarm. | |
| file | vfork.c |
| Creates Child process Of The Calling process. | |
| file | wait.c |
| Wait for Process to Change State. | |
| file | waitpid.c |
1.8.15
