RTEMS  5.1
vpd.h
1 #ifndef PPC_MOTLOAD_VPD_H
2 #define PPC_MOTLOAD_VPD_H
3
4 /* MotLoad VPD format */
5
6 /* Till Straumann, 2005; see copyright notice at the end of this file */
7
8 #ifdef __cplusplus
9  extern "C" {
10 #endif
11
12 /*
13 VPD = "MOTOROLA" , { field }
14
15 field = type_byte, length_byte, { data }
16 */
17
18 /* Known fields so far */
19 typedef enum {
20  ProductIdent = 0x01, /* String */
21  AssemblyNumber = 0x02, /* String */
22  SerialNumber = 0x03, /* String */
23  CpuClockHz = 0x05, /* binary (5bytes), 0x01 byte appended to unsigned int */
24  BusClockHz = 0x06, /* binary (5bytes), 0x01 byte appended to unsigned int */
25  EthernetAddr = 0x08, /* binary (7bytes), 0x00 byte appended, 2nd has 0x01 appended */
26  CpuType = 0x09, /* String */
27  EEpromCrc = 0x0a, /* binary (4bytes) */
28  FlashConfig = 0x0b, /* binary */
29  L2CacheConfig = 0x0e, /* binary */
30  VPDRevision = 0x0f, /* binary (4bytes) */
31  L3CacheConfig = 0x19, /* binary */
32  End = 0xff
33 } VpdKey;
34
35 typedef struct {
36  VpdKey key; /* key for the data item to be read into 'buf' */
37  char instance; /* instance # (starting with 0) - some keys are present more than one time */
38  void *buf; /* pointer to area where the data item is to be stored */
39  int buflen; /* available space in the buffer */
40  char found; /* set by BSP_vpdRetrieveFields() to the original length as found in the PROM */
41 } VpdBufRec, *VpdBuf;
42
43
44 #define VPD_END { key:End, }
45
46
47 /* Scan the VPD EEPROM for a number of fields
48  *
49  * Pass an array of VpdBufRec items. The routine
50  * fills the 'buf'fers for all keys that are found
51  * and sets the 'found' field to the original length
52  * of the data (i.e., as found in the PROM) so that
53  * the routine could be called again with a larger
54  * buffer.
55  *
56  * NOTE: - the array must be terminated by a VPD_END record!
57  * - no CRC check is performed.
58  * - INTERRUPT MANAGEMENT MUST BE FUNCTIONAL
59  *
60  * RETURNS: 0 on success, -1 if any read errors were
61  * encountered or if the "MOTOROLA" header
62  * was not found.
63  */
64 int
65 BSP_vpdRetrieveFields(VpdBuf data);
66
67 /* Example:
68  * Read 2nd ethernet address:
69  *
70  * char enet_addr_2[6];
71  *
72  * VpdBufRec enetVpd [] = {
73  * { key: EthernetAddr, instance: 1, buf: enet_addr_2, buflen: 2},
74  * VPD_END
75  * };
76  *
77  * if ( BSP_vpdRetrieveFields(enetVpd) ) {
78  * error("ethernet address couldn't be read\n");
79  * } else if ( enetVpd[0].found < 6 ) {
80  * error("2nd ethernet address not found in VPD\n");
81  * } else {
82  * use_it(enet_addr_2);
83  * }
84  */
85
86
87 /* Simple wrapper if only one field is needed
88  *
89  * RETURNS: original length if key is found, -1 on error or if key is not found
90  */
91 int
92 BSP_vpdRetrieveKey(VpdKey k, void *buf, int buflen, int instance);
93
94 #ifdef __cplusplus
95  }
96 #endif
97
98 /*
99  * Authorship
100  * ----------
101  * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
102  * created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
103  * Stanford Linear Accelerator Center, Stanford University.
104  *
105  * Acknowledgement of sponsorship
106  * ------------------------------
107  * The 'beatnik' BSP was produced by
108  * the Stanford Linear Accelerator Center, Stanford University,
109  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
110  *
111  * Government disclaimer of liability
112  * ----------------------------------
113  * Neither the United States nor the United States Department of Energy,
114  * nor any of their employees, makes any warranty, express or implied, or
115  * assumes any legal liability or responsibility for the accuracy,
116  * completeness, or usefulness of any data, apparatus, product, or process
117  * disclosed, or represents that its use would not infringe privately owned
118  * rights.
119  *
120  * Stanford disclaimer of liability
121  * --------------------------------
122  * Stanford University makes no representations or warranties, express or
123  * implied, nor assumes any liability for the use of this software.
124  *
125  * Stanford disclaimer of copyright
126  * --------------------------------
127  * Stanford University, owner of the copyright, hereby disclaims its
128  * copyright and all other rights in this software. Hence, anyone may
129  * freely use it for any purpose without restriction.
130  *
131  * Maintenance of notices
132  * ----------------------
133  * In the interest of clarity regarding the origin and status of this
134  * SLAC software, this and all the preceding Stanford University notices
135  * are to remain affixed to any copy or derivative of this software made
136  * or distributed by the recipient and are to be affixed to any copy of
137  * software made or distributed by the recipient that contains a copy or
138  * derivative of this software.
139  *
140  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
141  */
142
143 #endif
Definition: vpd.h:35
