RTEMS  5.1
usbhs.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
32 #ifndef USBHS_H
33 #define USBHS_H
34
38 #define USB_DEVICE_HS_SUPPORT
39
41 #define USB_DEVICE_EP_CTRL_SIZE 64
42
44 #define CHIP_USB_UDP
45
47 #define CHIP_USB_PULLUP_INTERNAL
48
50 #define CHIP_USB_NUMENDPOINTS 10
51
53 #define CHIP_USB_ENDPOINTS_MAXPACKETSIZE(ep) \
54  ((ep == 0) ? 64 : 1024)
55
57 #define CHIP_USB_ENDPOINTS_BANKS(ep) ((ep==0)?1:((ep<=2)?3:2))
58
59
60 #define CHIP_USB_ENDPOINTS_HBW(ep) ((((ep)>=1) &&((ep)<=2))?true:false)
61
63 #define CHIP_USB_ENDPOINTS_DMA(ep) ((((ep)>=1)&&((ep)<=7))?true:false)
64
66 #define DMA_MAX_FIFO_SIZE (65536/1)
67
68 #define EPT_VIRTUAL_SIZE 8192
69
70
75 #define uhd_get_pipe_max_nbr() (9)
76 #define USBHS_EPT_NUM (uhd_get_pipe_max_nbr()+1)
77 #define uhd_get_pipe_bank_max_nbr(ep) ((ep == 0) ? 1 : ((ep <= 2) ? 3 : 2))
79 #define uhd_get_pipe_size_max(ep) (((ep) == 0) ? 64 : 1024)
81 #define Is_uhd_pipe_dma_supported(ep) ((((ep) >= 1) && ((ep) <= 7)) ? true : false)
83 #define Is_uhd_pipe_high_bw_supported(ep) (((ep) >= 2) ? true : false)
85
87 typedef enum {
88  HOST_MODE = 0,
89  DEVICE_MODE = 1
90 } USB_Mode_t;
91
93 #define UHD_PIPE_MAX_TRANS 0x8000
94
106 __STATIC_INLINE void USBHS_FreezeClock(Usbhs *pUsbhs)
107 {
108  pUsbhs->USBHS_CTRL |= USBHS_CTRL_FRZCLK;
109 }
110
116 __STATIC_INLINE void USBHS_UnFreezeClock(Usbhs *pUsbhs)
117 {
118  pUsbhs->USBHS_CTRL &= ~((uint32_t)USBHS_CTRL_FRZCLK);
119 }
125 __STATIC_INLINE void USBHS_VBusHWC(Usbhs *pUsbhs, uint8_t Enable)
126 {
127
128  if (!Enable)
129  pUsbhs->USBHS_CTRL |= (1 << 8);
130  else
131  pUsbhs->USBHS_CTRL &= ~((uint32_t)(1 << 8));
132 }
133
140 __STATIC_INLINE void USBHS_UsbEnable(Usbhs *pUsbhs, uint8_t Enable)
141 {
142  if (Enable)
143  pUsbhs->USBHS_CTRL |= USBHS_CTRL_USBE;
144  else
145  pUsbhs->USBHS_CTRL &= ~((uint32_t)USBHS_CTRL_USBE);
146 }
147
148
155 __STATIC_INLINE void USBHS_UsbMode(Usbhs *pUsbhs, USB_Mode_t Mode)
156 {
157  if (Mode)
159  else
160  pUsbhs->USBHS_CTRL &= ~((uint32_t)USBHS_CTRL_UIMOD_DEVICE);
161 }
162
163 /********************* USBHS_SR *****************/
164
171 __STATIC_INLINE uint8_t USBHS_ISUsableClock(Usbhs *pUsbhs)
172 {
173  return ((pUsbhs->USBHS_SR & USBHS_SR_CLKUSABLE) >> 14);
174 }
175
176
183 __STATIC_INLINE uint32_t USBHS_ReadStatus(Usbhs *pUsbhs)
184 {
185  return (pUsbhs->USBHS_SR);
186 }
187
194 __STATIC_INLINE uint32_t USBHS_GetUsbSpeed(Usbhs *pUsbhs)
195 {
196  return ((pUsbhs->USBHS_SR & USBHS_SR_SPEED_Msk));
197 }
198
199
206 __STATIC_INLINE bool USBHS_IsUsbFullSpeed(Usbhs *pUsbhs)
207 {
208  return ((pUsbhs->USBHS_SR & USBHS_SR_SPEED_Msk) == USBHS_SR_SPEED_FULL_SPEED) ?
209  true : false;
210 }
211
212
219 __STATIC_INLINE bool USBHS_IsUsbHighSpeed(Usbhs *pUsbhs)
220 {
221  return ((pUsbhs->USBHS_SR & USBHS_SR_SPEED_Msk) == USBHS_SR_SPEED_HIGH_SPEED) ?
222  true : false;
223 }
224
231 __STATIC_INLINE bool USBHS_IsUsbLowSpeed(Usbhs *pUsbhs)
232 {
233  return ((pUsbhs->USBHS_SR & USBHS_SR_SPEED_Msk) == USBHS_SR_SPEED_LOW_SPEED) ?
234  true : false;
235 }
236 /********************* USBHS_SCR *****************/
237
244 __STATIC_INLINE void USBHS_Ack(Usbhs *pUsbhs, uint32_t AckType)
245 {
246  pUsbhs->USBHS_SCR |= AckType;
247 }
248
249 /********************* USBHS_SFR *****************/
250
257 __STATIC_INLINE void USBHS_Set(Usbhs *pUsbhs, uint32_t SetStatus)
258 {
259  pUsbhs->USBHS_SFR |= SetStatus;
260 }
261
262
263 /*--------------------------------------------------------
264 * =========== USB Device functions ======================
265 *---------------------------------------------------------*/
266
273 __STATIC_INLINE void USBHS_EnableAddress(Usbhs *pUsbhs, uint8_t Enable)
274 {
275  if (Enable)
277  else
278  pUsbhs->USBHS_DEVCTRL &= ~((uint32_t)USBHS_DEVCTRL_ADDEN);
279 }
280
287 __STATIC_INLINE void USBHS_SetAddress(Usbhs *pUsbhs, uint8_t Addr)
288 {
289  pUsbhs->USBHS_DEVCTRL |= USBHS_DEVCTRL_UADD(Addr);
291 }
292
298 __STATIC_INLINE uint8_t USBHS_GetAddress(Usbhs *pUsbhs)
299 {
300  return (pUsbhs->USBHS_DEVCTRL & USBHS_DEVCTRL_UADD_Msk);
301 }
302
309 __STATIC_INLINE void USBHS_DetachUsb(Usbhs *pUsbhs, uint8_t Enable)
310 {
311  if (Enable)
313  else
314  pUsbhs->USBHS_DEVCTRL &= ~((uint32_t)USBHS_DEVCTRL_DETACH);
315
316 }
317
324 __STATIC_INLINE void USBHS_ForceLowSpeed(Usbhs *pUsbhs, uint8_t Enable)
325 {
326  if (Enable)
327  pUsbhs->USBHS_DEVCTRL |= USBHS_DEVCTRL_LS;
328  else
329  pUsbhs->USBHS_DEVCTRL &= ~((uint32_t)USBHS_DEVCTRL_LS);
330 }
331
338 __STATIC_INLINE void USBHS_EnableHighSpeed(Usbhs *pUsbhs, uint8_t Enable)
339 {
340  uint32_t cfg = pUsbhs->USBHS_DEVCTRL;
341  cfg &= ~((uint32_t)USBHS_DEVCTRL_SPDCONF_Msk);
342
343  if (Enable)
344  pUsbhs->USBHS_DEVCTRL |= cfg;
345  else
347
348 }
349
355 __STATIC_INLINE void USBHS_SetRemoteWakeUp(Usbhs *pUsbhs)
356 {
358 }
359
366 __STATIC_INLINE void USBHS_EnableTestMode(Usbhs *pUsbhs, uint32_t mode)
367 {
368  pUsbhs->USBHS_DEVCTRL |= mode;
369 }
370
371
377 __STATIC_INLINE void USBHS_EnableHSTestMode(Usbhs *pUsbhs)
378 {
380 }
381
388 __STATIC_INLINE uint32_t USBHS_ReadIntStatus(Usbhs *pUsbhs, uint32_t IntType)
389 {
390  return (pUsbhs->USBHS_DEVISR & IntType);
391 }
392
399 __STATIC_INLINE uint32_t USBHS_ReadEpIntStatus(Usbhs *pUsbhs, uint8_t EpNum)
400 {
401  return (pUsbhs->USBHS_DEVISR & (USBHS_DEVISR_PEP_0 << EpNum));
402 }
403
409 __STATIC_INLINE uint32_t USBHS_ReadDmaIntStatus(Usbhs *pUsbhs, uint8_t DmaNum)
410 {
411  return (pUsbhs->USBHS_DEVISR & (USBHS_DEVISR_DMA_1 << DmaNum));
412 }
413
420 __STATIC_INLINE void USBHS_AckInt(Usbhs *pUsbhs, uint32_t IntType)
421 {
422  pUsbhs->USBHS_DEVICR |= IntType;
423 }
424
432 __STATIC_INLINE void USBHS_RaiseInt(Usbhs *pUsbhs, uint32_t IntType)
433 {
434  pUsbhs->USBHS_DEVIFR |= IntType;
435 }
436
442 __STATIC_INLINE void USBHS_RaiseDmaInt(Usbhs *pUsbhs, uint8_t Dma)
443 {
444  assert(Dma < USBHSDEVDMA_NUMBER);
445  pUsbhs->USBHS_DEVIFR |= (USBHS_DEVIFR_DMA_1 << Dma);
446 }
447
454 __STATIC_INLINE uint32_t USBHS_IsIntEnable(Usbhs *pUsbhs, uint32_t IntType)
455 {
456  return (pUsbhs->USBHS_DEVIMR & IntType);
457 }
458
465 __STATIC_INLINE uint32_t USBHS_IsIntEnableEP(Usbhs *pUsbhs, uint8_t EpNum)
466 {
467  return (pUsbhs->USBHS_DEVIMR & (USBHS_DEVIMR_PEP_0 << EpNum));
468 }
469
470
478 __STATIC_INLINE uint32_t USBHS_IsDmaIntEnable(Usbhs *pUsbhs, uint8_t DmaNum)
479 {
480  return (pUsbhs->USBHS_DEVIMR & (USBHS_DEVIMR_DMA_1 << DmaNum));
481 }
482
483
489 __STATIC_INLINE void USBHS_EnableInt(Usbhs *pUsbhs, uint32_t IntType)
490 {
491  pUsbhs->USBHS_DEVIER |= IntType;
492 }
493
499 __STATIC_INLINE void USBHS_EnableIntEP(Usbhs *pUsbhs, uint8_t EpNum)
500 {
501  pUsbhs->USBHS_DEVIER |= (USBHS_DEVIER_PEP_0 << EpNum);
502 }
503
510 __STATIC_INLINE void USBHS_EnableDMAIntEP(Usbhs *pUsbhs, uint32_t DmaEp)
511 {
512  assert(DmaEp < USBHSDEVDMA_NUMBER);
513  pUsbhs->USBHS_DEVIER |= (USBHS_DEVIER_DMA_1 << DmaEp);
514 }
515
522 __STATIC_INLINE void USBHS_DisableInt(Usbhs *pUsbhs, uint32_t IntType)
523 {
524  pUsbhs->USBHS_DEVIDR |= IntType;
525 }
526
533 __STATIC_INLINE void USBHS_DisableIntEP(Usbhs *pUsbhs, uint8_t Ep)
534 {
535  pUsbhs->USBHS_DEVIDR |= (USBHS_DEVIDR_PEP_0 << Ep);
536 }
537
543 __STATIC_INLINE void USBHS_DisableDMAIntEP(Usbhs *pUsbhs, uint8_t DmaEp)
544 {
545  assert(DmaEp < USBHSDEVDMA_NUMBER);
546  pUsbhs->USBHS_DEVIDR |= (USBHS_DEVIDR_DMA_1 << DmaEp);
547 }
548
549
556 __STATIC_INLINE void USBHS_EnableEP(Usbhs *pUsbhs, uint8_t Ep, uint8_t Enable)
557 {
558  if (Enable)
559  pUsbhs->USBHS_DEVEPT |= (USBHS_DEVEPT_EPEN0 << Ep);
560  else
561  pUsbhs->USBHS_DEVEPT &= ~(uint32_t)(USBHS_DEVEPT_EPEN0 << Ep);
562
563 }
564
565
572 __STATIC_INLINE void USBHS_ResetEP(Usbhs *pUsbhs, uint8_t Ep)
573 {
574  pUsbhs->USBHS_DEVEPT |= (USBHS_DEVEPT_EPRST0 << Ep);
575  pUsbhs->USBHS_DEVEPT &= ~(uint32_t)(USBHS_DEVEPT_EPRST0 << Ep);
576 }
577
584 __STATIC_INLINE uint32_t USBHS_IsEPEnabled(Usbhs *pUsbhs, uint8_t Ep)
585 {
586  return (pUsbhs->USBHS_DEVEPT & (USBHS_DEVEPT_EPEN0 << Ep));
587 }
588
594 __STATIC_INLINE uint8_t USBHS_GetMicroFrameNum(Usbhs *pUsbhs)
595 {
596  return (pUsbhs->USBHS_DEVFNUM & USBHS_DEVFNUM_MFNUM_Msk);
597 }
598
599
605 __STATIC_INLINE uint8_t USBHS_GetFrameNum(Usbhs *pUsbhs)
606 {
607  return ((pUsbhs->USBHS_DEVFNUM & USBHS_DEVFNUM_FNUM_Msk)
608  >> USBHS_DEVFNUM_FNUM_Pos);
609 }
610
616 __STATIC_INLINE uint8_t USBHS_GetFrameNumCrcErr(Usbhs *pUsbhs)
617 {
618  return ((pUsbhs->USBHS_DEVFNUM & USBHS_DEVFNUM_FNCERR) >> 15);
619 }
620
621 /*-----------------------------------------
622 * =========== USB Device's Endpoint functions ========
623 *------------------------------------------*/
624
629 __STATIC_INLINE void USBHS_ConfigureEPs(Usbhs *pUsbhs, const uint8_t Ep,
630  const uint8_t Type, const uint8_t Dir,
631  const uint8_t Size, const uint8_t Bank)
632 {
633
634  pUsbhs->USBHS_DEVEPTCFG[Ep] |=
635  ((Size << USBHS_DEVEPTCFG_EPSIZE_Pos) & USBHS_DEVEPTCFG_EPSIZE_Msk);
636  pUsbhs->USBHS_DEVEPTCFG[Ep] |=
637  ((Dir << 8) & USBHS_DEVEPTCFG_EPDIR);
638  pUsbhs->USBHS_DEVEPTCFG[Ep] |=
639  (((Type) << USBHS_DEVEPTCFG_EPTYPE_Pos) & USBHS_DEVEPTCFG_EPTYPE_Msk);
640  pUsbhs->USBHS_DEVEPTCFG[Ep] |=
641  (((Bank) << USBHS_DEVEPTCFG_EPBK_Pos) & USBHS_DEVEPTCFG_EPBK_Msk);
642 }
643
644
648 __STATIC_INLINE void USBHS_AutoSwitchBankEnable(Usbhs *pUsbhs, uint8_t Ep,
649  uint8_t Enable)
650 {
651  if (Enable)
653  else
654  pUsbhs->USBHS_DEVEPTCFG[Ep] &= ~((uint32_t)USBHS_DEVEPTCFG_AUTOSW);
655 }
656
657
661 __STATIC_INLINE void USBHS_AllocateMemory(Usbhs *pUsbhs, uint8_t Ep)
662 {
663  pUsbhs->USBHS_DEVEPTCFG[Ep] |= USBHS_DEVEPTCFG_ALLOC;
664 }
665
666
670 __STATIC_INLINE void USBHS_FreeMemory(Usbhs *pUsbhs, uint8_t Ep)
671 {
672  pUsbhs->USBHS_DEVEPTCFG[Ep] &= ~((uint32_t)USBHS_DEVEPTCFG_ALLOC);
673 }
674
675
679 __STATIC_INLINE uint32_t USBHS_GetConfigureEPs(Usbhs *pUsbhs, uint8_t Ep,
680  uint32_t IntType)
681 {
682  return ((pUsbhs->USBHS_DEVEPTCFG[Ep]) & IntType);
683 }
684
688 __STATIC_INLINE uint8_t USBHS_GetEpType(Usbhs *pUsbhs, uint8_t Ep)
689 {
690  return ((pUsbhs->USBHS_DEVEPTCFG[Ep] & USBHS_DEVEPTCFG_EPTYPE_Msk)
691  >> USBHS_DEVEPTCFG_EPTYPE_Pos);
692 }
693
697 __STATIC_INLINE uint32_t USBHS_GetEpSize(Usbhs *pUsbhs, uint8_t Ep)
698 {
699  return (8 << ((pUsbhs->USBHS_DEVEPTCFG[Ep] & USBHS_DEVEPTCFG_EPSIZE_Msk)
700  >> USBHS_DEVEPTCFG_EPSIZE_Pos));
701 }
702
703
707 __STATIC_INLINE void USBHS_SetIsoTrans(Usbhs *pUsbhs, uint8_t Ep,
708  uint8_t nbTrans)
709 {
710  pUsbhs->USBHS_DEVEPTCFG[Ep] |= USBHS_DEVEPTCFG_NBTRANS(nbTrans);
711 }
712
716 __STATIC_INLINE uint32_t USBHS_IsEpIntEnable(Usbhs *pUsbhs, uint8_t Ep,
717  uint32_t EpIntType)
718 {
719  return (pUsbhs->USBHS_DEVEPTIMR[Ep] & EpIntType);
720 }
721
722
726 __STATIC_INLINE void USBHS_EnableEPIntType(Usbhs *pUsbhs, uint8_t Ep,
727  uint32_t EpInt)
728 {
729  pUsbhs->USBHS_DEVEPTIER[Ep] |= EpInt;
730 }
731
735 __STATIC_INLINE uint32_t USBHS_IsBankKilled(Usbhs *pUsbhs, uint8_t Ep)
736 {
737  return (pUsbhs->USBHS_DEVEPTIMR[Ep] & USBHS_DEVEPTIMR_KILLBK);
738 }
739
743 __STATIC_INLINE void USBHS_KillBank(Usbhs *pUsbhs, uint8_t Ep)
744 {
746 }
750 __STATIC_INLINE void USBHS_DisableEPIntType(Usbhs *pUsbhs, uint8_t Ep,
751  uint32_t EpInt)
752 {
753  pUsbhs->USBHS_DEVEPTIDR[Ep] |= EpInt;
754 }
755
759 __STATIC_INLINE void USBHS_AckEpInterrupt(Usbhs *pUsbhs, uint8_t Ep,
760  uint32_t EpInt)
761 {
762  pUsbhs->USBHS_DEVEPTICR[Ep] |= EpInt;
763 }
764
768 __STATIC_INLINE void USBHS_RaiseEPInt(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
769 {
770  pUsbhs->USBHS_DEVEPTIFR[Ep] |= EpInt;
771 }
772
776 __STATIC_INLINE uint32_t USBHS_ReadEPStatus(Usbhs *pUsbhs, uint8_t Ep,
777  uint32_t EpInt)
778 {
779  return (pUsbhs->USBHS_DEVEPTISR[Ep] & EpInt);
780 }
781
785 __STATIC_INLINE uint8_t USBHS_IsBankFree(Usbhs *pUsbhs, uint8_t Ep)
786 {
787  if ((pUsbhs->USBHS_DEVEPTISR[Ep] & USBHS_DEVEPTISR_NBUSYBK_Msk))
788  return false;
789  else
790  return true;
791 }
792
796 __STATIC_INLINE uint8_t USBHS_NumOfBanksInUse(Usbhs *pUsbhs, uint8_t Ep)
797 {
798  return ((pUsbhs->USBHS_DEVEPTISR[Ep] & USBHS_DEVEPTISR_NBUSYBK_Msk)
799  >> USBHS_DEVEPTISR_NBUSYBK_Pos);
800 }
801
802
806 __STATIC_INLINE uint16_t USBHS_ByteCount(Usbhs *pUsbhs, uint8_t Ep)
807 {
808  return (uint16_t)((pUsbhs->USBHS_DEVEPTISR[Ep] & USBHS_DEVEPTISR_BYCT_Msk)
809  >> USBHS_DEVEPTISR_BYCT_Pos);
810 }
811
812 /*--------------------------------------------------------
813 * =========== USB Device's Ep's DMA functions =========
814 *---------------------------------------------------------*/
815
821 __STATIC_INLINE void USBHS_SetDmaNDA(UsbhsDevdma *pUsbDma, uint32_t Desc)
822 {
823  pUsbDma->USBHS_DEVDMANXTDSC = Desc;
824 }
825
831 __STATIC_INLINE uint32_t USBHS_GetDmaNDA(UsbhsDevdma *pUsbDma)
832 {
833  return (pUsbDma->USBHS_DEVDMANXTDSC);
834 }
835
841 __STATIC_INLINE void USBHS_SetDmaBuffAdd(UsbhsDevdma *pUsbDma, uint32_t Addr)
842 {
843  pUsbDma->USBHS_DEVDMAADDRESS = Addr;
844 }
845
846
852 __STATIC_INLINE uint32_t USBHS_GetDmaBuffAdd(UsbhsDevdma *pUsbDma)
853 {
854  return (pUsbDma->USBHS_DEVDMAADDRESS);
855 }
856
862 __STATIC_INLINE void USBHS_ConfigureDma(UsbhsDevdma *pUsbDma, uint32_t Cfg)
863 {
864  pUsbDma->USBHS_DEVDMACONTROL |= Cfg;
865 }
866
872 __STATIC_INLINE uint32_t USBHS_GetDmaConfiguration(UsbhsDevdma *pUsbDma)
873 {
874  return (pUsbDma->USBHS_DEVDMACONTROL);
875 }
876
877
883 __STATIC_INLINE void USBHS_SetDmaStatus(UsbhsDevdma *pUsbDma, uint32_t Status)
884 {
885  pUsbDma->USBHS_DEVDMASTATUS = Status;
886 }
887
888
894 __STATIC_INLINE uint32_t USBHS_GetDmaStatus(UsbhsDevdma *pUsbDma)
895 {
896  return (pUsbDma->USBHS_DEVDMASTATUS);
897 }
898
899
905 __STATIC_INLINE uint16_t USBHS_GetDmaBuffCount(UsbhsDevdma *pUsbDma)
906 {
908  >> USBHS_DEVDMASTATUS_BUFF_COUNT_Pos);
909 }
910
911
912 /*--------------------------------------------------------
913 * =========== USB Host Functions ========================
914 *---------------------------------------------------------*/
915
917 #define CHIP_USB_NUMPIPE 10
918
919 #define CHIP_USB_DMA_NUMPIPE 7
920
922 #define CHIP_USB_PIPE_MAXPACKETSIZE(ep) \
923  ((ep == 0) ? 64 : 1024)
924
926 #define CHIP_USB_PIPE_BANKS(ep) ((ep==0)?1:((ep<=2)?3:2))
927
928
929 #define CHIP_USB_PIPE_HBW(ep) ((((ep)>=1) &&((ep)<=2))?true:false)
930
932 #define CHIP_USB_PIPE_DMA(ep) ((((ep)>=1)&&((ep)<=7))?true:false)
933
938 __STATIC_INLINE void USBHS_SetHostHighSpeed(Usbhs *pUsbhs)
939 {
942 }
943
948 __STATIC_INLINE void USBHS_SetHostLowSpeed(Usbhs *pUsbhs)
949 {
952 }
953
958 __STATIC_INLINE void USBHS_SetHostForcedFullSpeed(Usbhs *pUsbhs)
959 {
962 }
963
968 __STATIC_INLINE void USBHS_Reset(void)
969 {
970  USBHS->USBHS_HSTCTRL |= USBHS_HSTCTRL_RESET;
971 }
972
977 __STATIC_INLINE void USBHS_StopReset(void)
978 {
979  USBHS->USBHS_HSTCTRL &= ~USBHS_HSTCTRL_RESET;
980 }
981
986 __STATIC_INLINE void USBHS_Resume(void)
987 {
988  USBHS->USBHS_HSTCTRL |= USBHS_HSTCTRL_RESUME;
989 }
990
995 __STATIC_INLINE void USBHS_EnableSOF(Usbhs *pUsbhs)
996 {
998 }
999
1004 __STATIC_INLINE uint8_t USBHS_IsEnableSOF(Usbhs *pUsbhs)
1005 {
1006  return (pUsbhs->USBHS_HSTCTRL & USBHS_HSTCTRL_SOFE) >> 8;
1007 }
1012 __STATIC_INLINE void USBHS_DisableSOF(void)
1013 {
1014  USBHS->USBHS_HSTCTRL &= ~USBHS_HSTCTRL_SOFE;
1015 }
1016
1021 __STATIC_INLINE uint32_t USBHS_GetHostStatus(Usbhs *pUsbhs, uint8_t IntType)
1022 {
1023  return (pUsbhs->USBHS_HSTISR & IntType);
1024 }
1025
1026
1031 __STATIC_INLINE uint32_t USBHS_GetHostPipeStatus(Usbhs *pUsbhs, uint8_t PipeInt)
1032 {
1033  assert(PipeInt < CHIP_USB_NUMPIPE);
1034  return (pUsbhs->USBHS_HSTISR & (USBHS_HSTISR_PEP_0 << PipeInt));
1035 }
1036
1037
1042 __STATIC_INLINE uint32_t USBHS_GetHostDmaPipeStatus(Usbhs *pUsbhs,
1043  uint8_t PipeInt)
1044 {
1045  assert(PipeInt);
1046  assert(PipeInt < CHIP_USB_DMA_NUMPIPE);
1047  return (pUsbhs->USBHS_HSTISR & (USBHS_HSTISR_DMA_1 << PipeInt));
1048 }
1049
1054 __STATIC_INLINE void USBHS_ClearHostStatus(Usbhs *pUsbhs, uint32_t IntType)
1055 {
1056  pUsbhs->USBHS_HSTICR = IntType;
1057 }
1058
1063 __STATIC_INLINE void USBHS_SetHostStatus(Usbhs *pUsbhs, uint32_t IntType)
1064 {
1065  pUsbhs->USBHS_HSTIFR = IntType;
1066 }
1067
1072 __STATIC_INLINE void USBHS_SetHostDmaStatus(Usbhs *pUsbhs, uint8_t PipeInt)
1073 {
1074  assert(PipeInt);
1075  assert(PipeInt < CHIP_USB_DMA_NUMPIPE);
1076  pUsbhs->USBHS_HSTIFR = (USBHS_HSTIFR_DMA_1 << PipeInt);
1077 }
1078
1079 /*** Interrupt Mask ****/
1084 __STATIC_INLINE uint8_t USBHS_IsHostIntEnable(Usbhs *pUsbhs, uint8_t IntType)
1085 {
1086  return (pUsbhs->USBHS_HSTIMR & IntType);
1087 }
1088
1093 __STATIC_INLINE uint32_t USBHS_IsHostPipeIntEnable(Usbhs *pUsbhs,
1094  uint8_t PipeInt)
1095 {
1096  assert(PipeInt < CHIP_USB_NUMPIPE);
1097  return (pUsbhs->USBHS_HSTIMR & (USBHS_HSTIMR_PEP_0 << PipeInt));
1098 }
1099
1104 __STATIC_INLINE uint32_t USBHS_IsHostDmaIntEnable(Usbhs *pUsbhs,
1105  uint8_t PipeInt)
1106 {
1107  assert(PipeInt);
1108  assert(PipeInt < CHIP_USB_DMA_NUMPIPE);
1109  return (pUsbhs->USBHS_HSTIMR & (USBHS_HSTIMR_DMA_1 << PipeInt));
1110 }
1111
1112 /*** Interrupt Disable ****/
1117 __STATIC_INLINE void USBHS_HostIntDisable(Usbhs *pUsbhs, uint32_t IntType)
1118 {
1119  pUsbhs->USBHS_HSTIDR = IntType;
1120 }
1121
1126 __STATIC_INLINE void USBHS_HostPipeIntDisable(Usbhs *pUsbhs, uint8_t PipeInt)
1127 {
1128  assert(PipeInt < CHIP_USB_NUMPIPE);
1129  pUsbhs->USBHS_HSTIDR = (USBHS_HSTIDR_PEP_0 << PipeInt);
1130 }
1131
1136 __STATIC_INLINE void USBHS_HostDmaIntDisable(Usbhs *pUsbhs, uint8_t PipeInt)
1137 {
1138  assert(PipeInt);
1139  assert(PipeInt < CHIP_USB_DMA_NUMPIPE);
1140  pUsbhs->USBHS_HSTIDR = (USBHS_HSTIDR_DMA_1 << PipeInt);
1141 }
1142
1143 /*** Interrupt Enable ****/
1144
1149 __STATIC_INLINE void USBHS_HostIntEnable(Usbhs *pUsbhs, uint32_t IntType)
1150 {
1151  pUsbhs->USBHS_HSTIER = IntType;
1152 }
1153
1158 __STATIC_INLINE void USBHS_HostPipeIntEnable(Usbhs *pUsbhs, uint8_t PipeInt)
1159 {
1160  assert(PipeInt < CHIP_USB_NUMPIPE);
1161  pUsbhs->USBHS_HSTIER = (USBHS_HSTIER_PEP_0 << PipeInt);
1162 }
1163
1168 __STATIC_INLINE void USBHS_HostDmaIntEnable(Usbhs *pUsbhs, uint8_t PipeInt)
1169 {
1170  assert(PipeInt < CHIP_USB_DMA_NUMPIPE);
1171  pUsbhs->USBHS_HSTIER |= (USBHS_HSTIER_DMA_1 << PipeInt);
1172 }
1173
1178 __STATIC_INLINE uint16_t USBHS_HostGetSOF(void)
1179 {
1180  return ((USBHS->USBHS_HSTFNUM & USBHS_HSTFNUM_FNUM_Msk) >>
1181  USBHS_HSTFNUM_FNUM_Pos);
1182 }
1183
1188 __STATIC_INLINE uint16_t USBHS_HostGetFramePos(void)
1189 {
1190  return ((USBHS->USBHS_HSTFNUM & USBHS_HSTFNUM_FLENHIGH_Msk) >>
1191  USBHS_HSTFNUM_FLENHIGH_Pos);
1192 }
1193
1194
1199 __STATIC_INLINE uint16_t USBHS_HostGetMSOF(void)
1200 {
1201  return ((USBHS->USBHS_HSTFNUM & USBHS_HSTFNUM_MFNUM_Msk) >>
1202  USBHS_HSTFNUM_MFNUM_Pos);
1203 }
1204
1205 __STATIC_INLINE void USBHS_HostSetAddr(Usbhs *pUsbhs, uint8_t Pipe,
1206  uint8_t Addr)
1207 {
1208  assert(Pipe < CHIP_USB_NUMPIPE);
1209
1210  if (Pipe < 4)
1211  pUsbhs->USBHS_HSTADDR1 |= (Addr << (8 * Pipe));
1212  else if ((Pipe < 8) && (Pipe >= 4))
1213  pUsbhs->USBHS_HSTADDR2 |= (Addr << (8 * (Pipe - 4)));
1214  else
1215  pUsbhs->USBHS_HSTADDR3 |= (Addr << (8 * (Pipe - 8)));
1216
1217 }
1218
1219 __STATIC_INLINE uint8_t USBHS_HostGetAddr(Usbhs *pUsbhs, uint8_t Pipe)
1220 {
1221  assert(Pipe < CHIP_USB_NUMPIPE);
1222
1223  if (Pipe < 4)
1224  return (pUsbhs->USBHS_HSTADDR1 >> (8 * Pipe));
1225  else if ((Pipe < 8) && (Pipe >= 4))
1226  return (pUsbhs->USBHS_HSTADDR2 >> (8 * (Pipe - 4)));
1227  else
1228  return (pUsbhs->USBHS_HSTADDR3 >> (8 * (Pipe - 8)));
1229
1230 }
1231
1236 __STATIC_INLINE void USBHS_HostPipeEnable(Usbhs *pUsbhs, uint8_t Pipe)
1237 {
1238  assert(Pipe < CHIP_USB_NUMPIPE);
1239  pUsbhs->USBHS_HSTPIP |= (USBHS_HSTPIP_PEN0 << Pipe);
1240 }
1241
1246 __STATIC_INLINE void USBHS_HostPipeDisable(Usbhs *pUsbhs, uint8_t Pipe)
1247 {
1248  assert(Pipe < CHIP_USB_NUMPIPE);
1249  pUsbhs->USBHS_HSTPIP &= ~(USBHS_HSTPIP_PEN0 << Pipe);
1250 }
1251
1256 __STATIC_INLINE uint32_t USBHS_IsHostPipeEnable(Usbhs *pUsbhs, uint8_t Pipe)
1257 {
1258  assert(Pipe < CHIP_USB_NUMPIPE);
1259  return (pUsbhs->USBHS_HSTPIP & (USBHS_HSTPIP_PEN0 << Pipe));
1260 }
1265 __STATIC_INLINE void USBHS_HostPipeReset(Usbhs *pUsbhs, uint8_t Pipe)
1266 {
1267  assert(Pipe < CHIP_USB_NUMPIPE);
1268  pUsbhs->USBHS_HSTPIP |= (USBHS_HSTPIP_PRST0 << Pipe);
1269  pUsbhs->USBHS_HSTPIP &= ~(USBHS_HSTPIP_PRST0 << Pipe);
1270 }
1271
1276 __STATIC_INLINE void USBHS_HostConfigure(Usbhs *pUsbhs, uint8_t Pipe,
1277  uint32_t pipeBank, uint8_t pipeSize, uint32_t pipeType, uint32_t pipeToken,
1278  uint8_t pipeEpNum, uint8_t PipeIntFreq)
1279 {
1280  assert(Pipe < CHIP_USB_NUMPIPE);
1281  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= (pipeBank | pipeToken | USBHS_HSTPIPCFG_PSIZE(
1282  pipeSize) | pipeType | USBHS_HSTPIPCFG_PEPNUM(pipeEpNum) |
1283  USBHS_HSTPIPCFG_INTFRQ(PipeIntFreq));
1284 }
1285
1290 __STATIC_INLINE void USBHS_HostAllocMem(Usbhs *pUsbhs, uint8_t Pipe)
1291 {
1292  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= USBHS_HSTPIPCFG_ALLOC;
1293
1294 }
1295
1300 __STATIC_INLINE void USBHS_HostFreeMem(Usbhs *pUsbhs, uint8_t Pipe)
1301 {
1302  pUsbhs->USBHS_HSTPIPCFG[Pipe] &= ~USBHS_HSTPIPCFG_ALLOC;
1303
1304 }
1305
1306
1311 __STATIC_INLINE uint16_t USBHS_HostGetSize(Usbhs *pUsbhs, uint8_t Pipe)
1312 {
1313  return (8 << ((pUsbhs->USBHS_HSTPIPCFG[Pipe] & USBHS_HSTPIPCFG_PSIZE_Msk) >>
1314  USBHS_HSTPIPCFG_PSIZE_Pos));
1315
1316 }
1317
1322 __STATIC_INLINE void USBHS_HostSetToken(Usbhs *pUsbhs, uint8_t Pipe,
1323  uint32_t Token)
1324 {
1325  pUsbhs->USBHS_HSTPIPCFG[Pipe] &= ~USBHS_HSTPIPCFG_PTOKEN_Msk;
1326  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= Token;
1327
1328 }
1329
1330
1335 __STATIC_INLINE uint32_t USBHS_HostGetToken(Usbhs *pUsbhs, uint8_t Pipe)
1336 {
1337  return (pUsbhs->USBHS_HSTPIPCFG[Pipe] & USBHS_HSTPIPCFG_PTOKEN_Msk);
1338
1339 }
1340
1341
1346 __STATIC_INLINE void USBHS_HostSetPipeType(Usbhs *pUsbhs, uint8_t Pipe,
1347  uint8_t PipeType)
1348 {
1349  pUsbhs->USBHS_HSTPIPCFG[Pipe] &= ~USBHS_HSTPIPCFG_PTYPE_Msk;
1350  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= PipeType;
1351
1352 }
1353
1358 __STATIC_INLINE uint32_t USBHS_HostGetPipeType(Usbhs *pUsbhs, uint8_t Pipe)
1359 {
1360  return (pUsbhs->USBHS_HSTPIPCFG[Pipe] & USBHS_HSTPIPCFG_PTYPE_Msk);
1361
1362 }
1363
1364 __STATIC_INLINE uint8_t USBHS_GetPipeEpAddr(Usbhs *pUsbhs, uint8_t Pipe)
1365 {
1366
1368  return (((pUsbhs->USBHS_HSTPIPCFG[Pipe] & USBHS_HSTPIPCFG_PEPNUM_Msk) >>
1369  USBHS_HSTPIPCFG_PEPNUM_Pos) | 0x80);
1370  else
1371  return (((pUsbhs->USBHS_HSTPIPCFG[Pipe] & USBHS_HSTPIPCFG_PEPNUM_Msk) >>
1372  USBHS_HSTPIPCFG_PEPNUM_Pos) | 0x00);
1373 }
1374
1375
1376
1381 __STATIC_INLINE void USBHS_HostEnableAutoSw(Usbhs *pUsbhs, uint8_t Pipe)
1382 {
1383  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= USBHS_HSTPIPCFG_AUTOSW;
1384 }
1385
1390 __STATIC_INLINE void USBHS_HostDisableAutoSw(Usbhs *pUsbhs, uint8_t Pipe)
1391 {
1392  pUsbhs->USBHS_HSTPIPCFG[Pipe] &= ~USBHS_HSTPIPCFG_AUTOSW;
1393 }
1394
1399 __STATIC_INLINE void USBHS_HostSetIntFreq(Usbhs *pUsbhs, uint8_t Pipe,
1400  uint8_t Freq)
1401 {
1402  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= USBHS_HSTPIPCFG_BINTERVAL(Freq);
1403 }
1404
1405
1410 __STATIC_INLINE void USBHS_HostEnablePing(Usbhs *pUsbhs, uint8_t Pipe)
1411 {
1412  pUsbhs->USBHS_HSTPIPCFG[Pipe] |= USBHS_HSTPIPCFG_PINGEN;
1413 }
1414
1415
1420 __STATIC_INLINE uint8_t USBHS_HostGetDataTogSeq(Usbhs *pUsbhs, uint8_t Pipe)
1421 {
1422  return ((pUsbhs->USBHS_HSTPIPISR[Pipe] & USBHS_HSTPIPISR_DTSEQ_Msk) >>
1423  USBHS_HSTPIPISR_DTSEQ_Pos);
1424 }
1425
1426
1431 __STATIC_INLINE uint8_t USBHS_HostGetNumOfBusyBank(Usbhs *pUsbhs, uint8_t Pipe)
1432 {
1433  return ((pUsbhs->USBHS_HSTPIPISR[Pipe] & USBHS_HSTPIPISR_NBUSYBK_Msk) >>
1434  USBHS_HSTPIPISR_NBUSYBK_Pos);
1435 }
1436
1437
1442 __STATIC_INLINE uint8_t USBHS_HostGetCurrentBank(Usbhs *pUsbhs, uint8_t Pipe)
1443 {
1444  return ((pUsbhs->USBHS_HSTPIPISR[Pipe] & USBHS_HSTPIPISR_CURRBK_Msk) >>
1445  USBHS_HSTPIPISR_CURRBK_Pos);
1446 }
1447
1448
1453 __STATIC_INLINE uint8_t USBHS_HostGetPipeByteCount(Usbhs *pUsbhs, uint8_t Pipe)
1454 {
1455  return ((pUsbhs->USBHS_HSTPIPISR[Pipe] & USBHS_HSTPIPISR_PBYCT_Msk) >>
1456  USBHS_HSTPIPISR_PBYCT_Pos);
1457 }
1458
1463 __STATIC_INLINE uint32_t USBHS_IsHostConfigOk(Usbhs *pUsbhs, uint8_t Pipe)
1464 {
1465  return (pUsbhs->USBHS_HSTPIPISR[Pipe] & USBHS_DEVEPTISR_CFGOK);
1466 }
1467
1472 __STATIC_INLINE uint32_t USBHS_HostGetIntTypeStatus(Usbhs *pUsbhs, uint8_t Pipe,
1473  uint32_t intType)
1474 {
1475  return (pUsbhs->USBHS_HSTPIPISR[Pipe] & intType);
1476 }
1477
1482 __STATIC_INLINE void USBHS_HostAckPipeIntType(Usbhs *pUsbhs, uint8_t Pipe,
1483  uint32_t intType)
1484 {
1485  pUsbhs->USBHS_HSTPIPICR[Pipe] = intType;
1486 }
1487
1492 __STATIC_INLINE void USBHS_HostSetPipeIntType(Usbhs *pUsbhs, uint8_t Pipe,
1493  uint32_t intType)
1494 {
1495  pUsbhs->USBHS_HSTPIPIFR[Pipe] = intType;
1496 }
1497
1502 __STATIC_INLINE uint32_t USBHS_IsHostPipeIntTypeEnable(Usbhs *pUsbhs,
1503  uint8_t Pipe, uint32_t intType)
1504 {
1505  return (pUsbhs->USBHS_HSTPIPIMR[Pipe] & intType);
1506 }
1507
1512 __STATIC_INLINE void USBHS_HostDisablePipeIntType(Usbhs *pUsbhs, uint8_t Pipe,
1513  uint32_t intType)
1514 {
1515  pUsbhs->USBHS_HSTPIPIDR[Pipe] = intType;
1516 }
1517
1522 __STATIC_INLINE void USBHS_HostEnablePipeIntType(Usbhs *pUsbhs, uint8_t Pipe,
1523  uint32_t intType)
1524 {
1525  pUsbhs->USBHS_HSTPIPIER[Pipe] = intType;
1526 }
1527
1532 __STATIC_INLINE void USBHS_HostEnableInReq(Usbhs *pUsbhs, uint8_t Pipe)
1533 {
1534  pUsbhs->USBHS_HSTPIPINRQ[Pipe] |= USBHS_HSTPIPINRQ_INMODE;
1535 }
1536
1541 __STATIC_INLINE void USBHS_HostDisableInReq(Usbhs *pUsbhs, uint8_t Pipe)
1542 {
1543  pUsbhs->USBHS_HSTPIPINRQ[Pipe] &= ~USBHS_HSTPIPINRQ_INMODE;
1544 }
1545
1550 __STATIC_INLINE uint8_t USBHS_IsHostInReqEnable(Usbhs *pUsbhs, uint8_t Pipe)
1551 {
1552  return ((pUsbhs->USBHS_HSTPIPINRQ[Pipe] & USBHS_HSTPIPINRQ_INMODE) >> 8);
1553 }
1554
1559 __STATIC_INLINE void USBHS_HostInReq(Usbhs *pUsbhs, uint8_t Pipe, uint8_t InReq)
1560 {
1561  pUsbhs->USBHS_HSTPIPINRQ[Pipe] = USBHS_HSTPIPINRQ_INRQ(InReq - 1);
1562 }
1563
1564
1569 __STATIC_INLINE void USBHS_HostSetErr(Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
1570 {
1571  pUsbhs->USBHS_HSTPIPERR[Pipe] |= Err;
1572 }
1573
1578 __STATIC_INLINE uint8_t USBHS_HostGetErr(Usbhs *pUsbhs, uint8_t Pipe,
1579  uint8_t Err)
1580 {
1581  return (pUsbhs->USBHS_HSTPIPERR[Pipe] & Err);
1582 }
1583
1584
1589 __STATIC_INLINE void USBHS_HostClearErr(Usbhs *pUsbhs, uint8_t Pipe,
1590  uint8_t Err)
1591 {
1592  pUsbhs->USBHS_HSTPIPERR[Pipe] = Err;
1593 }
1594
1595
1596 __STATIC_INLINE uint8_t USBHS_GetInterruptPipeNum(void)
1597 {
1598  uint32_t status = USBHS->USBHS_HSTISR;
1599  uint32_t mask = USBHS->USBHS_HSTIMR;
1600  return ctz(((status & mask) >> 8) | (1 << USBHS_EPT_NUM));
1601 }
1602
1603 static inline uint8_t USBHS_GetInterruptPipeDmaNum(void)
1604 {
1605  uint32_t status = USBHS->USBHS_HSTISR;
1606  uint32_t mask = USBHS->USBHS_HSTIMR;
1607  return (ctz(((status & mask) >> 25) | (1 << (USBHS_EPT_NUM - 1))) + 1);
1608 }
1609 /*--------------------------------------------------------
1610 * =========== USB Host's pipe DMA functions =========
1611 *---------------------------------------------------------*/
1612
1618 __STATIC_INLINE void USBHS_SetHostDmaNDA(UsbhsHstdma *pUsbDma, uint32_t Desc)
1619 {
1620  pUsbDma->USBHS_HSTDMANXTDSC = Desc;
1621 }
1622
1628 __STATIC_INLINE uint32_t USBHS_GetHostDmaNDA(UsbhsHstdma *pUsbDma)
1629 {
1630  return (pUsbDma->USBHS_HSTDMANXTDSC);
1631 }
1632
1638 __STATIC_INLINE void USBHS_SetHostDmaBuffAdd(UsbhsHstdma *pUsbDma,
1639  uint32_t Addr)
1640 {
1641  pUsbDma->USBHS_HSTDMAADDRESS = Addr;
1642 }
1643
1644
1650 __STATIC_INLINE uint32_t USBHS_GetHostDmaBuffAdd(UsbhsHstdma *pUsbDma)
1651 {
1652  return (pUsbDma->USBHS_HSTDMAADDRESS);
1653 }
1654
1660 __STATIC_INLINE void USBHS_HostConfigureDma(UsbhsHstdma *pUsbDma, uint32_t Cfg)
1661 {
1662  pUsbDma->USBHS_HSTDMACONTROL |= Cfg;
1663 }
1664
1670 __STATIC_INLINE uint32_t USBHS_GetHostDmaConfiguration(UsbhsHstdma *pUsbDma)
1671 {
1672  return (pUsbDma->USBHS_HSTDMACONTROL);
1673 }
1674
1675
1681 __STATIC_INLINE void USBHS_SetHostPipeDmaStatus(UsbhsHstdma *pUsbDma,
1682  uint32_t Status)
1683 {
1684  pUsbDma->USBHS_HSTDMASTATUS = Status;
1685 }
1686
1687
1693 __STATIC_INLINE uint32_t USBHS_GetHostPipeDmaStatus(UsbhsHstdma *pUsbDma)
1694 {
1695  return (pUsbDma->USBHS_HSTDMASTATUS);
1696 }
1697
1699 #endif /* #ifndef USBHS_H */
__O uint32_t USBHS_HSTPIPICR[10]
(Usbhs Offset: 0x560) Host Pipe Clear Register (n = 0)
Definition: component_usbhs.h:101
Raise DMA interrupt for endpoint.
Definition: usbhs.h:442
Gets USB host interrupt status.
Definition: usbhs.h:1031
#define USBHS_DEVEPTCFG_EPBK_Msk
(USBHS_DEVEPTCFG[10]) Endpoint Banks
Definition: component_usbhs.h:301
Device or Host Mode.
Definition: usbhs.h:155
Get Dma Status.
Definition: usbhs.h:894
Raise interrupt for endpoint.
Definition: usbhs.h:183
Definition: usbhs.h:1290
Definition: usbhs.h:1559
#define USBHS_DEVCTRL_LS
(USBHS_DEVCTRL) Low-Speed Mode Force
Definition: component_usbhs.h:137
Definition: usbhs.h:1149
#define USBHS_DEVCTRL_SPDCONF_FORCED_FS
(USBHS_DEVCTRL) The peripheral remains in Full-speed mode whatever the host speed capability.
Definition: component_usbhs.h:136
__STATIC_INLINE void USBHS_HostClearErr(Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
Definition: usbhs.h:1589
#define USBHS_DEVCTRL_DETACH
(USBHS_DEVCTRL) Detach
Definition: component_usbhs.h:128
Sets USB host sends reste signal on USB Bus.
Definition: usbhs.h:977
#define USBHS_HSTPIPCFG_ALLOC
(USBHS_HSTPIPCFG[10]) Pipe Memory Allocate
Definition: component_usbhs.h:699
Sets USB host send Resume on USB bus.
Definition: usbhs.h:986
#define USBHS_HSTPIPISR_DTSEQ_Msk
(USBHS_HSTPIPISR[10]) Data Toggle Sequence
Definition: component_usbhs.h:751
Definition: usbhs.h:1256
check for interrupt of endpoint.
Definition: usbhs.h:454
Checks if Endpoint is enable.
Definition: usbhs.h:584
#define USBHS_DEVCTRL_SPDCONF_HIGH_SPEED
(USBHS_DEVCTRL) Forced high speed.
Definition: component_usbhs.h:135
Setup the USBHS DMA.
Definition: usbhs.h:1660
Definition: usbhs.h:735
#define USBHS_HSTPIP_PRST0
(USBHS_HSTPIP) Pipe 0 Reset
Definition: component_usbhs.h:646
#define USBHS_CTRL_UIMOD_DEVICE
(USBHS_CTRL) The module is in USB Device mode.
Definition: component_usbhs.h:889
Gets DMA next descriptor address.
Definition: usbhs.h:831
Sets USBHS's DMA Buffer addresse.
Definition: usbhs.h:841
Definition: usbhs.h:1410
__O uint32_t USBHS_DEVEPTIER[10]
(Usbhs Offset: 0x1F0) Device Endpoint Enable Register (n = 0)
Definition: component_usbhs.h:78
Definition: usbhs.h:432
Check if endpoint's interrupt is enabled for a given endpoint number.
Definition: usbhs.h:465
Definition: usbhs.h:1541
__I uint32_t USBHS_DEVIMR
(Usbhs Offset: 0x0010) Device Global Interrupt Mask Register
Definition: component_usbhs.h:62
Definition: usbhs.h:796
#define USBHS_HSTIDR_PEP_0
(USBHS_HSTIDR) Pipe 0 Interrupt Disable
Definition: component_usbhs.h:590
Definition: usbhs.h:968
Definition: usbhs.h:1021
#define USBHS_DEVCTRL_ADDEN
(USBHS_DEVCTRL) Address Enable
Definition: component_usbhs.h:127
__O uint32_t USBHS_DEVIDR
(Usbhs Offset: 0x0014) Device Global Interrupt Disable Register
Definition: component_usbhs.h:63
__STATIC_INLINE uint32_t USBHS_ReadEPStatus(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
Definition: usbhs.h:776
__IO uint32_t USBHS_HSTPIP
(Usbhs Offset: 0x0041C) Host Pipe Register
Definition: component_usbhs.h:91
Definition: usbhs.h:1335
__STATIC_INLINE void USBHS_ConfigureEPs(Usbhs *pUsbhs, const uint8_t Ep, const uint8_t Type, const uint8_t Dir, const uint8_t Size, const uint8_t Bank)
Definition: usbhs.h:629
Read status for an interrupt.
Definition: usbhs.h:388
Sets USB host Enable the Generation of Start of Frame.
Definition: usbhs.h:995
#define USBHS_DEVIFR_DMA_1
(USBHS_DEVIFR) DMA Channel 1 Interrupt Set
Definition: component_usbhs.h:185
Definition: usbhs.h:1431
__O uint32_t USBHS_DEVEPTICR[10]
(Usbhs Offset: 0x160) Device Endpoint Clear Register (n = 0)
Definition: component_usbhs.h:72
__IO uint32_t USBHS_HSTADDR2
(Usbhs Offset: 0x0428) Host Address 2 Register
Definition: component_usbhs.h:94
__STATIC_INLINE uint32_t USBHS_GetHostDmaPipeStatus(Usbhs *pUsbhs, uint8_t PipeInt)
Definition: usbhs.h:1042
Definition: usbhs.h:862
#define USBHS_HSTPIPINRQ_INMODE
(USBHS_HSTPIPINRQ[10]) IN Request Mode
Definition: component_usbhs.h:843
#define USBHS_HSTFNUM_MFNUM_Msk
(USBHS_HSTFNUM) Micro Frame Number
Definition: component_usbhs.h:657
Enable or disable USB address.
Definition: usbhs.h:194
Definition: usbhs.h:273
__STATIC_INLINE void USBHS_HostSetPipeType(Usbhs *pUsbhs, uint8_t Pipe, uint8_t PipeType)
Definition: usbhs.h:1346
Definition: usbhs.h:743
__IO uint32_t USBHS_HSTPIPCFG[10]
(Usbhs Offset: 0x500) Host Pipe Configuration Register (n = 0)
Definition: component_usbhs.h:97
__IO uint32_t USBHS_HSTDMANXTDSC
(UsbhsHstdma Offset: 0x0) Host DMA Channel Next Descriptor Address Register
Definition: component_usbhs.h:49
Definition: usbhs.h:806
#define USBHS_HSTCTRL_SPDCONF_Msk
(USBHS_HSTCTRL) Mode Configuration
Definition: component_usbhs.h:499
__O uint32_t USBHS_SCR
(Usbhs Offset: 0x0808) General Status Clear Register
Definition: component_usbhs.h:119
__STATIC_INLINE uint32_t USBHS_IsHostDmaIntEnable(Usbhs *pUsbhs, uint8_t PipeInt)
Definition: usbhs.h:1104
Sets USB host disable the Generation of Start of Frame.
Definition: usbhs.h:1012
Definition: usbhs.h:1004
#define USBHS_SR_SPEED_LOW_SPEED
(USBHS_SR) Low-Speed mode
Definition: component_usbhs.h:897
#define USBHS_DEVFNUM_FNCERR
(USBHS_DEVFNUM) Frame Number CRC Error
Definition: component_usbhs.h:297
Get DMA configuration.
Definition: usbhs.h:1670
Sets USB host's speed to forced Full speed.
Definition: usbhs.h:958
__O uint32_t USBHS_HSTIDR
(Usbhs Offset: 0x0414) Host Global Interrupt Disable Register
#define USBHS_HSTPIPCFG_PTOKEN_Msk
(USBHS_HSTPIPCFG[10]) Pipe Token
Definition: component_usbhs.h:718
#define USBHS_HSTIER_PEP_0
(USBHS_HSTIER) Pipe 0 Interrupt Enable
Definition: component_usbhs.h:617
#define USBHS_DEVFNUM_FNUM_Msk
Definition: component_usbhs.h:296
__STATIC_INLINE void USBHS_HostSetIntFreq(Usbhs *pUsbhs, uint8_t Pipe, uint8_t Freq)
Definition: usbhs.h:1399
#define USBHS_DEVEPTIMR_KILLBK
(USBHS_DEVEPTIMR[10]) Kill IN Bank
Definition: component_usbhs.h:408
Definition: usbhs.h:1569
Sets DMA next descriptor address.
Definition: usbhs.h:1618
Definition: usbhs.h:821
#define USBHS_DEVIMR_PEP_0
(USBHS_DEVIMR) Endpoint 0 Interrupt Mask
Definition: component_usbhs.h:200
Check if clock is usable or not.
Definition: usbhs.h:171
Sets USB host's speed to Normal , it sets to HS from FS.
Definition: usbhs.h:938
Read status for a DMA Endpoint.
Definition: usbhs.h:409
Definition: usbhs.h:661
Definition: usbhs.h:1168
#define USBHS_CTRL_USBE
(USBHS_CTRL) USBHS Enable
Definition: component_usbhs.h:886
__I uint32_t USBHS_DEVEPTIMR[10]
(Usbhs Offset: 0x1C0) Device Endpoint Mask Register (n = 0)
Definition: component_usbhs.h:76
__IO uint32_t USBHS_CTRL
(Usbhs Offset: 0x0800) General Control Register
Definition: component_usbhs.h:117
__STATIC_INLINE void USBHS_AutoSwitchBankEnable(Usbhs *pUsbhs, uint8_t Ep, uint8_t Enable)
Definition: usbhs.h:648
__I uint32_t USBHS_HSTPIPISR[10]
(Usbhs Offset: 0x530) Host Pipe Status Register (n = 0)
Definition: component_usbhs.h:99
__STATIC_INLINE void USBHS_HostSetToken(Usbhs *pUsbhs, uint8_t Pipe, uint32_t Token)
Definition: usbhs.h:1322
__O uint32_t USBHS_DEVEPTIFR[10]
(Usbhs Offset: 0x190) Device Endpoint Set Register (n = 0)
Definition: component_usbhs.h:74
__IO uint32_t USBHS_DEVEPT
(Usbhs Offset: 0x001C) Device Endpoint Register
__I uint32_t USBHS_DEVFNUM
(Usbhs Offset: 0x0020) Device Frame Number Register
Definition: component_usbhs.h:66
__IO uint32_t USBHS_HSTDMASTATUS
(UsbhsHstdma Offset: 0xC) Host DMA Channel Status Register
Definition: component_usbhs.h:52
#define USBHS_HSTPIPISR_NBUSYBK_Msk
(USBHS_HSTPIPISR[10]) Number of Busy Banks
Definition: component_usbhs.h:755
Enables or disables USB.
Definition: usbhs.h:140
Sets USB host's speed to Low speed.
Definition: usbhs.h:948
#define USBHS_HSTPIPCFG_AUTOSW
(USBHS_HSTPIPCFG[10]) Automatic Switch
Definition: component_usbhs.h:723
#define USBHS_DEVCTRL_UADD_Msk
(USBHS_DEVCTRL) USB Address
Definition: component_usbhs.h:125
Definition: usbhs.h:1463
__O uint32_t USBHS_HSTIER
(Usbhs Offset: 0x0418) Host Global Interrupt Enable Register
Definition: component_usbhs.h:90
#define USBHS_SR_SPEED_FULL_SPEED
(USBHS_SR) Full-Speed mode
Definition: component_usbhs.h:895
Definition: usbhs.h:1117
#define USBHS_HSTCTRL_SOFE
(USBHS_HSTCTRL) Start of Frame Generation Enable
Definition: component_usbhs.h:495
__O uint32_t USBHS_HSTIFR
(Usbhs Offset: 0x040C) Host Global Interrupt Set Register
Definition: component_usbhs.h:87
__STATIC_INLINE void USBHS_HostAckPipeIntType(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1482
__IO uint32_t USBHS_DEVDMASTATUS
(UsbhsDevdma Offset: 0xC) Device DMA Channel Status Register
Definition: component_usbhs.h:45
#define USBHS_HSTFNUM_FLENHIGH_Msk
(USBHS_HSTFNUM) Frame Length
Definition: component_usbhs.h:663
__STATIC_INLINE void USBHS_HostDisablePipeIntType(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1512
Definition: usbhs.h:1442
__IO uint32_t USBHS_DEVDMAADDRESS
(UsbhsDevdma Offset: 0x4) Device DMA Channel Address Register
Definition: component_usbhs.h:43
Definition: usbhs.h:1054
Definition: usbhs.h:1300
Definition: usbhs.h:1390
Enables DMA interrupt for a given endpoint.
Definition: usbhs.h:510
Definition: usbhs.h:1063
#define USBHS_HSTCTRL_SPDCONF_NORMAL
(USBHS_HSTCTRL) The host starts in Full-speed mode and performs a high-speed reset to switch to High-...
Definition: component_usbhs.h:501
__STATIC_INLINE uint8_t USBHS_HostGetErr(Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
Definition: usbhs.h:1578
#define USBHS_HSTPIPISR_PBYCT_Msk
(USBHS_HSTPIPISR[10]) Pipe Byte Count
Definition: component_usbhs.h:768
__O uint32_t USBHS_HSTPIPIER[10]
(Usbhs Offset: 0x5F0) Host Pipe Enable Register (n = 0)
Definition: component_usbhs.h:107
#define USBHS_HSTCTRL_SPDCONF_FORCED_FS
(USBHS_HSTCTRL) The host remains in Full-speed mode whatever the peripheral speed capability.
Definition: component_usbhs.h:504
#define USBHS_HSTIFR_DMA_1
(USBHS_HSTIFR) DMA Channel 1 Interrupt Set
Definition: component_usbhs.h:548
#define USBHS_DEVIDR_DMA_1
(USBHS_DEVIDR) DMA Channel 1 Interrupt Disable
Definition: component_usbhs.h:239
#define USBHS_HSTPIPCFG_PINGEN
(USBHS_HSTPIPCFG[10]) Ping Enable
Definition: component_usbhs.h:737
#define USBHS
(USBHS ) Base Address
Definition: same70j19.h:513
Gets USBHS's DMA Buffer addresse.
Definition: usbhs.h:1650
Set Remote WakeUp mode.
Definition: usbhs.h:355
Disables interrupt for endpoint.
Definition: usbhs.h:522
#define USBHS_SR_CLKUSABLE
(USBHS_SR) UTMI Clock Usable
Definition: component_usbhs.h:898
Read status for an Endpoint.
Definition: usbhs.h:399
__IO uint32_t USBHS_HSTPIPERR[10]
(Usbhs Offset: 0x680) Host Pipe Error Register (n = 0)
Definition: component_usbhs.h:113
Definition: usbhs.h:1453
#define USBHS_DEVEPTCFG_AUTOSW
(USBHS_DEVEPTCFG[10]) Automatic Switch
Definition: component_usbhs.h:320
Enables Interrupt.
Definition: usbhs.h:489
__STATIC_INLINE void USBHS_HostConfigure(Usbhs *pUsbhs, uint8_t Pipe, uint32_t pipeBank, uint8_t pipeSize, uint32_t pipeType, uint32_t pipeToken, uint8_t pipeEpNum, uint8_t PipeIntFreq)
Definition: usbhs.h:1276
__O uint32_t USBHS_DEVIFR
(Usbhs Offset: 0x000C) Device Global Interrupt Set Register
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntEnable(Usbhs *pUsbhs, uint8_t PipeInt)
Definition: usbhs.h:1093
#define USBHS_SR_SPEED_Msk
(USBHS_SR) Speed Status (Device mode only)
Definition: component_usbhs.h:894
Get DMA buffer's count.
Definition: usbhs.h:905
Definition: component_usbhs.h:57
__STATIC_INLINE void USBHS_SetHostDmaBuffAdd(UsbhsHstdma *pUsbDma, uint32_t Addr)
Definition: usbhs.h:1638
Disables DMA interrupt for endpoint.
Definition: usbhs.h:543
#define USBHS_HSTPIPCFG_PEPNUM_Msk
(USBHS_HSTPIPCFG[10]) Pipe Endpoint Number
Definition: component_usbhs.h:732
Definition: usbhs.h:872
#define USBHS_DEVISR_DMA_1
(USBHS_DEVISR) DMA Channel 1 Interrupt
Definition: component_usbhs.h:162
Definition: usbhs.h:533
Definition: usbhs.h:1188
Definition: usbhs.h:852
Definition: usbhs.h:244
Definition: usbhs.h:1311
__I uint32_t USBHS_HSTISR
(Usbhs Offset: 0x0404) Host Global Interrupt Status Register
Definition: component_usbhs.h:85
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntTypeEnable(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1502
__IO uint32_t USBHS_DEVEPTCFG[10]
(Usbhs Offset: 0x100) Device Endpoint Configuration Register (n = 0)
Definition: component_usbhs.h:68
#define USBHS_DEVISR_PEP_0
(USBHS_DEVISR) Endpoint 0 Interrupt
Definition: component_usbhs.h:150
__I uint32_t USBHS_HSTIMR
(Usbhs Offset: 0x0410) Host Global Interrupt Mask Register
Definition: usbhs.h:1158
#define USBHS_DEVEPTCFG_EPSIZE_Msk
(USBHS_DEVEPTCFG[10]) Endpoint Size
Definition: component_usbhs.h:307
Get Dma Status.
Definition: usbhs.h:1693
__O uint32_t USBHS_DEVICR
(Usbhs Offset: 0x0008) Device Global Interrupt Clear Register
Definition: component_usbhs.h:60
__O uint32_t USBHS_SFR
(Usbhs Offset: 0x080C) General Status Set Register
Definition: component_usbhs.h:120
Definition: usbhs.h:1136
Definition: usbhs.h:1550
__IO uint32_t USBHS_HSTDMAADDRESS
(UsbhsHstdma Offset: 0x4) Host DMA Channel Address Register
Definition: usbhs.h:670
__O uint32_t USBHS_DEVEPTIDR[10]
(Usbhs Offset: 0x220) Device Endpoint Disable Register (n = 0)
Definition: component_usbhs.h:80
Disable/Enables Test mode.
Definition: usbhs.h:366
#define USBHS_DEVEPTISR_NBUSYBK_Msk
(USBHS_DEVEPTISR[10]) Number of Busy Banks
Definition: component_usbhs.h:351
Get Frame number CRC error.
Definition: usbhs.h:616
Definition: usbhs.h:1532
#define USBHS_DEVCTRL_RMWKUP
(USBHS_DEVCTRL) Remote Wake-Up
Definition: component_usbhs.h:129
#define USBHS_DEVIDR_PEP_0
(USBHS_DEVIDR) Endpoint 0 Interrupt Disable
Definition: component_usbhs.h:227
Disable/Enables High Speed mode.
Definition: usbhs.h:338
#define USBHS_HSTPIP_PEN0
(USBHS_HSTPIP) Pipe 0 Enable
Definition: component_usbhs.h:637
Rests Endpoint.
Definition: usbhs.h:572
Definition: usbhs.h:688
__STATIC_INLINE uint32_t USBHS_IsEpIntEnable(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpIntType)
Definition: usbhs.h:716
__STATIC_INLINE uint32_t USBHS_HostGetIntTypeStatus(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1472
#define USBHS_CTRL_FRZCLK
(USBHS_CTRL) Freeze USB Clock
Definition: component_usbhs.h:885
Definition: usbhs.h:1265
Acknowledge interrupt for endpoint.
Definition: usbhs.h:420
__IO uint32_t USBHS_HSTCTRL
(Usbhs Offset: 0x0400) Host General Control Register
#define USBHS_HSTISR_PEP_0
(USBHS_HSTISR) Pipe 0 Interrupt
Definition: component_usbhs.h:513
Set DMA status.
Definition: usbhs.h:883
__STATIC_INLINE void USBHS_AckEpInterrupt(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
Definition: usbhs.h:759
__STATIC_INLINE void USBHS_SetIsoTrans(Usbhs *pUsbhs, uint8_t Ep, uint8_t nbTrans)
Definition: usbhs.h:707
#define USBHS_HSTPIPCFG_PTYPE_Msk
(USBHS_HSTPIPCFG[10]) Pipe Type
Definition: component_usbhs.h:725
Configure USB address and enable or disable it.
Definition: usbhs.h:287
Definition: usbhs.h:257
#define USBHS_DEVEPTIER_KILLBKS
(USBHS_DEVEPTIER[10]) Kill IN Bank
Definition: component_usbhs.h:431
#define USBHS_DEVFNUM_MFNUM_Msk
(USBHS_DEVFNUM) Micro Frame Number
Definition: component_usbhs.h:294
__IO uint32_t USBHS_HSTADDR1
(Usbhs Offset: 0x0424) Host Address 1 Register
Definition: component_usbhs.h:93
Definition: usbhs.h:1072
Freeze or unfreeze USB clock.
__IO uint32_t USBHS_DEVDMANXTDSC
(UsbhsDevdma Offset: 0x0) Device DMA Channel Next Descriptor Address Register
Definition: component_usbhs.h:42
__STATIC_INLINE void USBHS_HostSetPipeIntType(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1492
#define USBHS_HSTIDR_DMA_1
(USBHS_HSTIDR) DMA Channel 1 Interrupt Disable
Definition: component_usbhs.h:602
#define USBHS_DEVEPT_EPEN0
(USBHS_DEVEPT) Endpoint 0 Enable
Definition: component_usbhs.h:274
__O uint32_t USBHS_HSTPIPIFR[10]
(Usbhs Offset: 0x590) Host Pipe Set Register (n = 0)
Definition: component_usbhs.h:103
#define USBHS_HSTFNUM_FNUM_Msk
(USBHS_HSTFNUM) Frame Number
Definition: component_usbhs.h:660
__IO uint32_t USBHS_HSTADDR3
(Usbhs Offset: 0x042C) Host Address 3 Register
Definition: component_usbhs.h:95
Attach or detach USB.
Definition: usbhs.h:309
Check if endpoint's DMA interrupt is enabled for a given endpoint DMA number.
Definition: usbhs.h:478
Definition: usbhs.h:919
Enables interrupt for a given endpoint.
Definition: usbhs.h:499
#define USBHS_DEVEPTCFG_ALLOC
(USBHS_DEVEPTCFG[10]) Endpoint Memory Allocate
Definition: component_usbhs.h:299
Definition: usbhs.h:917
Definition: usbhs.h:1628
UsbhsHstdma hardware registers.
Definition: component_usbhs.h:48
#define USBHS_SR_SPEED_HIGH_SPEED
(USBHS_SR) High-Speed mode
Definition: component_usbhs.h:896
Enables or disables endpoint.
Definition: usbhs.h:556
Definition: usbhs.h:1420
#define USBHS_HSTISR_DMA_1
(USBHS_HSTISR) DMA Channel 1 Interrupt
Definition: component_usbhs.h:525
__STATIC_INLINE void USBHS_EnableEPIntType(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
Definition: usbhs.h:726
__O uint32_t USBHS_HSTICR
(Usbhs Offset: 0x0408) Host Global Interrupt Clear Register
Definition: component_usbhs.h:86
#define USBHS_DEVEPT_EPRST0
(USBHS_DEVEPT) Endpoint 0 Reset
Definition: component_usbhs.h:283
#define USBHS_HSTCTRL_RESUME
(USBHS_HSTCTRL) Send USB Resume
Definition: component_usbhs.h:497
#define USBHS_DEVEPTISR_CFGOK
(USBHS_DEVEPTISR[10]) Configuration OK Status
Definition: component_usbhs.h:363
#define ctz(u)
Counts the trailing zero bits of the given value considered as a 32-bit integer.
Definition: compiler.h:440
#define USBHS_DEVIMR_DMA_1
(USBHS_DEVIMR) DMA Channel 1 Interrupt Mask
Definition: component_usbhs.h:212
__I uint32_t USBHS_DEVEPTISR[10]
(Usbhs Offset: 0x130) Device Endpoint Status Register (n = 0)
Definition: component_usbhs.h:70
__O uint32_t USBHS_DEVIER
(Usbhs Offset: 0x0018) Device Global Interrupt Enable Register
#define USBHS_HSTCTRL_RESET
(USBHS_HSTCTRL) Send USB Reset
Definition: component_usbhs.h:496
__IO uint32_t USBHS_HSTDMACONTROL
(UsbhsHstdma Offset: 0x8) Host DMA Channel Control Register
__I uint32_t USBHS_DEVISR
(Usbhs Offset: 0x0004) Device Global Interrupt Status Register
Definition: usbhs.h:1084
#define USBHS_DEVEPTCFG_EPTYPE_Msk
(USBHS_DEVEPTCFG[10]) Endpoint Type
Definition: component_usbhs.h:322
__STATIC_INLINE void USBHS_SetHostPipeDmaStatus(UsbhsHstdma *pUsbDma, uint32_t Status)
Set DMA status.
Definition: usbhs.h:1681
__STATIC_INLINE uint32_t USBHS_GetConfigureEPs(Usbhs *pUsbhs, uint8_t Ep, uint32_t IntType)
Definition: usbhs.h:679
__STATIC_INLINE void USBHS_HostEnablePipeIntType(Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
Definition: usbhs.h:1522
#define USBHS_HSTPIPISR_CURRBK_Msk
(USBHS_HSTPIPISR[10]) Current Bank
Definition: component_usbhs.h:761
Definition: usbhs.h:1126
#define USBHS_DEVEPTCFG_EPDIR
(USBHS_DEVEPTCFG[10]) Endpoint Direction
Definition: component_usbhs.h:317
#define USBHS_DEVIER_PEP_0
(USBHS_DEVIER) Endpoint 0 Interrupt Enable
Definition: component_usbhs.h:254
#define USBHS_HSTCTRL_SPDCONF_LOW_POWER
(USBHS_HSTCTRL) For a better consumption, if high speed is not needed.
Definition: component_usbhs.h:502
Definition: usbhs.h:1381
Definition: usbhs.h:231
Disable/Enables HS Test mode.
Definition: usbhs.h:377
Definition: usbhs.h:1246
#define USBHS_DEVCTRL_SPDCONF_Msk
(USBHS_DEVCTRL) Mode Configuration
Definition: component_usbhs.h:131
#define USBHS_HSTPIPCFG_PTOKEN_IN
(USBHS_HSTPIPCFG[10]) IN
Definition: component_usbhs.h:721
__I uint32_t USBHS_HSTPIPIMR[10]
(Usbhs Offset: 0x5C0) Host Pipe Mask Register (n = 0)
Definition: component_usbhs.h:105
Definition: usbhs.h:1358
#define USBHS_HSTIMR_PEP_0
(USBHS_HSTIMR) Pipe 0 Interrupt Enable
Definition: component_usbhs.h:563
#define USBHSDEVDMA_NUMBER
Usbhs hardware registers.
Definition: component_usbhs.h:55
#define USBHS_HSTIMR_DMA_1
(USBHS_HSTIMR) DMA Channel 1 Interrupt Enable
Definition: component_usbhs.h:575
#define USBHS_DEVDMASTATUS_BUFF_COUNT_Msk
(USBHS_DEVDMASTATUS) Buffer Byte Count
Definition: component_usbhs.h:492
Get USB address.
Definition: usbhs.h:298
Force Low Speed mode.
Definition: usbhs.h:324
__IO uint32_t USBHS_DEVCTRL
(Usbhs Offset: 0x0000) Device General Control Register
Definition: component_usbhs.h:58
Definition: usbhs.h:1236
#define USBHS_DEVIER_DMA_1
(USBHS_DEVIER) DMA Channel 1 Interrupt Enable
Definition: component_usbhs.h:266
Definition: usbhs.h:785
#define USBHS_HSTPIPCFG_PSIZE_Msk
(USBHS_HSTPIPCFG[10]) Pipe Size
Definition: component_usbhs.h:707
Definition: usbhs.h:1178
__O uint32_t USBHS_HSTPIPIDR[10]
(Usbhs Offset: 0x620) Host Pipe Disable Register (n = 0)
Definition: component_usbhs.h:109
__I uint32_t USBHS_SR
(Usbhs Offset: 0x0804) General Status Register
Definition: component_usbhs.h:118
Definition: usbhs.h:1199
#define USBHS_DEVEPTISR_BYCT_Msk
(USBHS_DEVEPTISR[10]) Byte Count
Definition: component_usbhs.h:365
__IO uint32_t USBHS_HSTPIPINRQ[10]
(Usbhs Offset: 0x650) Host Pipe IN Request Register (n = 0)
Definition: component_usbhs.h:111
__IO uint32_t USBHS_DEVDMACONTROL
(UsbhsDevdma Offset: 0x8) Device DMA Channel Control Register
Definition: component_usbhs.h:44
Get Frame number.
Definition: usbhs.h:605
Definition: usbhs.h:206
__STATIC_INLINE void USBHS_DisableEPIntType(Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
Definition: usbhs.h:750
Get MicrFrame number.
Definition: usbhs.h:594
#define USBHS_HSTIER_DMA_1
(USBHS_HSTIER) DMA Channel 1 Interrupt Enable
Definition: component_usbhs.h:629
Definition: usbhs.h:697
UsbhsDevdma hardware registers.
Definition: component_usbhs.h:41
Definition: usbhs.h:768
Definition: usbhs.h:219
