RTEMS  5.1
Data Structures | Macros
struct  UsbhsDevdma
 UsbhsDevdma hardware registers. More...
struct  UsbhsHstdma
 UsbhsHstdma hardware registers. More...
struct  Usbhs
#define USBHSDEVDMA_NUMBER   7
 Usbhs hardware registers.
#define USBHSHSTDMA_NUMBER   7
#define USBHS_DEVCTRL_UADD_Pos   0
#define USBHS_DEVCTRL_UADD_Msk   (0x7fu << USBHS_DEVCTRL_UADD_Pos)
 (USBHS_DEVCTRL) USB Address
#define USBHS_DEVCTRL_UADD(value)   ((USBHS_DEVCTRL_UADD_Msk & ((value) << USBHS_DEVCTRL_UADD_Pos)))
#define USBHS_DEVCTRL_ADDEN   (0x1u << 7)
 (USBHS_DEVCTRL) Address Enable
#define USBHS_DEVCTRL_DETACH   (0x1u << 8)
 (USBHS_DEVCTRL) Detach
#define USBHS_DEVCTRL_RMWKUP   (0x1u << 9)
 (USBHS_DEVCTRL) Remote Wake-Up
#define USBHS_DEVCTRL_SPDCONF_Pos   10
#define USBHS_DEVCTRL_SPDCONF_Msk   (0x3u << USBHS_DEVCTRL_SPDCONF_Pos)
 (USBHS_DEVCTRL) Mode Configuration
#define USBHS_DEVCTRL_SPDCONF(value)   ((USBHS_DEVCTRL_SPDCONF_Msk & ((value) << USBHS_DEVCTRL_SPDCONF_Pos)))
#define USBHS_DEVCTRL_SPDCONF_NORMAL   (0x0u << 10)
 (USBHS_DEVCTRL) The peripheral starts in Full-speed mode and performs a high-speed reset to switch to High-speed mode if the host is high-speed-capable.
#define USBHS_DEVCTRL_SPDCONF_LOW_POWER   (0x1u << 10)
 (USBHS_DEVCTRL) For a better consumption, if high speed is not needed.
#define USBHS_DEVCTRL_SPDCONF_HIGH_SPEED   (0x2u << 10)
 (USBHS_DEVCTRL) Forced high speed.
#define USBHS_DEVCTRL_SPDCONF_FORCED_FS   (0x3u << 10)
 (USBHS_DEVCTRL) The peripheral remains in Full-speed mode whatever the host speed capability.
#define USBHS_DEVCTRL_LS   (0x1u << 12)
 (USBHS_DEVCTRL) Low-Speed Mode Force
#define USBHS_DEVCTRL_TSTJ   (0x1u << 13)
 (USBHS_DEVCTRL) Test mode J
#define USBHS_DEVCTRL_TSTK   (0x1u << 14)
 (USBHS_DEVCTRL) Test mode K
#define USBHS_DEVCTRL_TSTPCKT   (0x1u << 15)
 (USBHS_DEVCTRL) Test packet mode
#define USBHS_DEVCTRL_OPMODE2   (0x1u << 16)
 (USBHS_DEVCTRL) Specific Operational mode
#define USBHS_DEVISR_SUSP   (0x1u << 0)
 (USBHS_DEVISR) Suspend Interrupt
#define USBHS_DEVISR_MSOF   (0x1u << 1)
 (USBHS_DEVISR) Micro Start of Frame Interrupt
#define USBHS_DEVISR_SOF   (0x1u << 2)
 (USBHS_DEVISR) Start of Frame Interrupt
#define USBHS_DEVISR_EORST   (0x1u << 3)
 (USBHS_DEVISR) End of Reset Interrupt
#define USBHS_DEVISR_WAKEUP   (0x1u << 4)
 (USBHS_DEVISR) Wake-Up Interrupt
#define USBHS_DEVISR_EORSM   (0x1u << 5)
 (USBHS_DEVISR) End of Resume Interrupt
#define USBHS_DEVISR_UPRSM   (0x1u << 6)
 (USBHS_DEVISR) Upstream Resume Interrupt
#define USBHS_DEVISR_PEP_0   (0x1u << 12)
 (USBHS_DEVISR) Endpoint 0 Interrupt
#define USBHS_DEVISR_PEP_1   (0x1u << 13)
 (USBHS_DEVISR) Endpoint 1 Interrupt
#define USBHS_DEVISR_PEP_2   (0x1u << 14)
 (USBHS_DEVISR) Endpoint 2 Interrupt
#define USBHS_DEVISR_PEP_3   (0x1u << 15)
 (USBHS_DEVISR) Endpoint 3 Interrupt
#define USBHS_DEVISR_PEP_4   (0x1u << 16)
 (USBHS_DEVISR) Endpoint 4 Interrupt
#define USBHS_DEVISR_PEP_5   (0x1u << 17)
 (USBHS_DEVISR) Endpoint 5 Interrupt
#define USBHS_DEVISR_PEP_6   (0x1u << 18)
 (USBHS_DEVISR) Endpoint 6 Interrupt
#define USBHS_DEVISR_PEP_7   (0x1u << 19)
 (USBHS_DEVISR) Endpoint 7 Interrupt
#define USBHS_DEVISR_PEP_8   (0x1u << 20)
 (USBHS_DEVISR) Endpoint 8 Interrupt
#define USBHS_DEVISR_PEP_9   (0x1u << 21)
 (USBHS_DEVISR) Endpoint 9 Interrupt
#define USBHS_DEVISR_PEP_10   (0x1u << 22)
 (USBHS_DEVISR) Endpoint 10 Interrupt
#define USBHS_DEVISR_PEP_11   (0x1u << 23)
 (USBHS_DEVISR) Endpoint 11 Interrupt
#define USBHS_DEVISR_DMA_1   (0x1u << 25)
 (USBHS_DEVISR) DMA Channel 1 Interrupt
#define USBHS_DEVISR_DMA_2   (0x1u << 26)
 (USBHS_DEVISR) DMA Channel 2 Interrupt
#define USBHS_DEVISR_DMA_3   (0x1u << 27)
 (USBHS_DEVISR) DMA Channel 3 Interrupt
#define USBHS_DEVISR_DMA_4   (0x1u << 28)
 (USBHS_DEVISR) DMA Channel 4 Interrupt
#define USBHS_DEVISR_DMA_5   (0x1u << 29)
 (USBHS_DEVISR) DMA Channel 5 Interrupt
#define USBHS_DEVISR_DMA_6   (0x1u << 30)
 (USBHS_DEVISR) DMA Channel 6 Interrupt
#define USBHS_DEVISR_DMA_7   (0x1u << 31)
 (USBHS_DEVISR) DMA Channel 7 Interrupt
#define USBHS_DEVICR_SUSPC   (0x1u << 0)
 (USBHS_DEVICR) Suspend Interrupt Clear
#define USBHS_DEVICR_MSOFC   (0x1u << 1)
 (USBHS_DEVICR) Micro Start of Frame Interrupt Clear
#define USBHS_DEVICR_SOFC   (0x1u << 2)
 (USBHS_DEVICR) Start of Frame Interrupt Clear
#define USBHS_DEVICR_EORSTC   (0x1u << 3)
 (USBHS_DEVICR) End of Reset Interrupt Clear
#define USBHS_DEVICR_WAKEUPC   (0x1u << 4)
 (USBHS_DEVICR) Wake-Up Interrupt Clear
#define USBHS_DEVICR_EORSMC   (0x1u << 5)
 (USBHS_DEVICR) End of Resume Interrupt Clear
#define USBHS_DEVICR_UPRSMC   (0x1u << 6)
 (USBHS_DEVICR) Upstream Resume Interrupt Clear
#define USBHS_DEVIFR_SUSPS   (0x1u << 0)
 (USBHS_DEVIFR) Suspend Interrupt Set
#define USBHS_DEVIFR_MSOFS   (0x1u << 1)
 (USBHS_DEVIFR) Micro Start of Frame Interrupt Set
#define USBHS_DEVIFR_SOFS   (0x1u << 2)
 (USBHS_DEVIFR) Start of Frame Interrupt Set
#define USBHS_DEVIFR_EORSTS   (0x1u << 3)
 (USBHS_DEVIFR) End of Reset Interrupt Set
#define USBHS_DEVIFR_WAKEUPS   (0x1u << 4)
 (USBHS_DEVIFR) Wake-Up Interrupt Set
#define USBHS_DEVIFR_EORSMS   (0x1u << 5)
 (USBHS_DEVIFR) End of Resume Interrupt Set
#define USBHS_DEVIFR_UPRSMS   (0x1u << 6)
 (USBHS_DEVIFR) Upstream Resume Interrupt Set
#define USBHS_DEVIFR_DMA_1   (0x1u << 25)
 (USBHS_DEVIFR) DMA Channel 1 Interrupt Set
#define USBHS_DEVIFR_DMA_2   (0x1u << 26)
 (USBHS_DEVIFR) DMA Channel 2 Interrupt Set
#define USBHS_DEVIFR_DMA_3   (0x1u << 27)
 (USBHS_DEVIFR) DMA Channel 3 Interrupt Set
#define USBHS_DEVIFR_DMA_4   (0x1u << 28)
 (USBHS_DEVIFR) DMA Channel 4 Interrupt Set
#define USBHS_DEVIFR_DMA_5   (0x1u << 29)
 (USBHS_DEVIFR) DMA Channel 5 Interrupt Set
#define USBHS_DEVIFR_DMA_6   (0x1u << 30)
 (USBHS_DEVIFR) DMA Channel 6 Interrupt Set
#define USBHS_DEVIFR_DMA_7   (0x1u << 31)
 (USBHS_DEVIFR) DMA Channel 7 Interrupt Set
#define USBHS_DEVIMR_SUSPE   (0x1u << 0)
 (USBHS_DEVIMR) Suspend Interrupt Mask
#define USBHS_DEVIMR_MSOFE   (0x1u << 1)
 (USBHS_DEVIMR) Micro Start of Frame Interrupt Mask
#define USBHS_DEVIMR_SOFE   (0x1u << 2)
 (USBHS_DEVIMR) Start of Frame Interrupt Mask
#define USBHS_DEVIMR_EORSTE   (0x1u << 3)
 (USBHS_DEVIMR) End of Reset Interrupt Mask
#define USBHS_DEVIMR_WAKEUPE   (0x1u << 4)
 (USBHS_DEVIMR) Wake-Up Interrupt Mask
#define USBHS_DEVIMR_EORSME   (0x1u << 5)
 (USBHS_DEVIMR) End of Resume Interrupt Mask
#define USBHS_DEVIMR_UPRSME   (0x1u << 6)
 (USBHS_DEVIMR) Upstream Resume Interrupt Mask
#define USBHS_DEVIMR_PEP_0   (0x1u << 12)
 (USBHS_DEVIMR) Endpoint 0 Interrupt Mask
#define USBHS_DEVIMR_PEP_1   (0x1u << 13)
 (USBHS_DEVIMR) Endpoint 1 Interrupt Mask
#define USBHS_DEVIMR_PEP_2   (0x1u << 14)
 (USBHS_DEVIMR) Endpoint 2 Interrupt Mask
#define USBHS_DEVIMR_PEP_3   (0x1u << 15)
 (USBHS_DEVIMR) Endpoint 3 Interrupt Mask
#define USBHS_DEVIMR_PEP_4   (0x1u << 16)
 (USBHS_DEVIMR) Endpoint 4 Interrupt Mask
#define USBHS_DEVIMR_PEP_5   (0x1u << 17)
 (USBHS_DEVIMR) Endpoint 5 Interrupt Mask
#define USBHS_DEVIMR_PEP_6   (0x1u << 18)
 (USBHS_DEVIMR) Endpoint 6 Interrupt Mask
#define USBHS_DEVIMR_PEP_7   (0x1u << 19)
 (USBHS_DEVIMR) Endpoint 7 Interrupt Mask
#define USBHS_DEVIMR_PEP_8   (0x1u << 20)
 (USBHS_DEVIMR) Endpoint 8 Interrupt Mask
#define USBHS_DEVIMR_PEP_9   (0x1u << 21)
 (USBHS_DEVIMR) Endpoint 9 Interrupt Mask
#define USBHS_DEVIMR_PEP_10   (0x1u << 22)
 (USBHS_DEVIMR) Endpoint 10 Interrupt Mask
#define USBHS_DEVIMR_PEP_11   (0x1u << 23)
 (USBHS_DEVIMR) Endpoint 11 Interrupt Mask
#define USBHS_DEVIMR_DMA_1   (0x1u << 25)
 (USBHS_DEVIMR) DMA Channel 1 Interrupt Mask
#define USBHS_DEVIMR_DMA_2   (0x1u << 26)
 (USBHS_DEVIMR) DMA Channel 2 Interrupt Mask
#define USBHS_DEVIMR_DMA_3   (0x1u << 27)
 (USBHS_DEVIMR) DMA Channel 3 Interrupt Mask
#define USBHS_DEVIMR_DMA_4   (0x1u << 28)
 (USBHS_DEVIMR) DMA Channel 4 Interrupt Mask
#define USBHS_DEVIMR_DMA_5   (0x1u << 29)
 (USBHS_DEVIMR) DMA Channel 5 Interrupt Mask
#define USBHS_DEVIMR_DMA_6   (0x1u << 30)
 (USBHS_DEVIMR) DMA Channel 6 Interrupt Mask
#define USBHS_DEVIMR_DMA_7   (0x1u << 31)
 (USBHS_DEVIMR) DMA Channel 7 Interrupt Mask
#define USBHS_DEVIDR_SUSPEC   (0x1u << 0)
 (USBHS_DEVIDR) Suspend Interrupt Disable
#define USBHS_DEVIDR_MSOFEC   (0x1u << 1)
 (USBHS_DEVIDR) Micro Start of Frame Interrupt Disable
#define USBHS_DEVIDR_SOFEC   (0x1u << 2)
 (USBHS_DEVIDR) Start of Frame Interrupt Disable
#define USBHS_DEVIDR_EORSTEC   (0x1u << 3)
 (USBHS_DEVIDR) End of Reset Interrupt Disable
#define USBHS_DEVIDR_WAKEUPEC   (0x1u << 4)
 (USBHS_DEVIDR) Wake-Up Interrupt Disable
#define USBHS_DEVIDR_EORSMEC   (0x1u << 5)
 (USBHS_DEVIDR) End of Resume Interrupt Disable
#define USBHS_DEVIDR_UPRSMEC   (0x1u << 6)
 (USBHS_DEVIDR) Upstream Resume Interrupt Disable
#define USBHS_DEVIDR_PEP_0   (0x1u << 12)
 (USBHS_DEVIDR) Endpoint 0 Interrupt Disable
#define USBHS_DEVIDR_PEP_1   (0x1u << 13)
 (USBHS_DEVIDR) Endpoint 1 Interrupt Disable
#define USBHS_DEVIDR_PEP_2   (0x1u << 14)
 (USBHS_DEVIDR) Endpoint 2 Interrupt Disable
#define USBHS_DEVIDR_PEP_3   (0x1u << 15)
 (USBHS_DEVIDR) Endpoint 3 Interrupt Disable
#define USBHS_DEVIDR_PEP_4   (0x1u << 16)
 (USBHS_DEVIDR) Endpoint 4 Interrupt Disable
#define USBHS_DEVIDR_PEP_5   (0x1u << 17)
 (USBHS_DEVIDR) Endpoint 5 Interrupt Disable
#define USBHS_DEVIDR_PEP_6   (0x1u << 18)
 (USBHS_DEVIDR) Endpoint 6 Interrupt Disable
#define USBHS_DEVIDR_PEP_7   (0x1u << 19)
 (USBHS_DEVIDR) Endpoint 7 Interrupt Disable
#define USBHS_DEVIDR_PEP_8   (0x1u << 20)
 (USBHS_DEVIDR) Endpoint 8 Interrupt Disable
#define USBHS_DEVIDR_PEP_9   (0x1u << 21)
 (USBHS_DEVIDR) Endpoint 9 Interrupt Disable
#define USBHS_DEVIDR_PEP_10   (0x1u << 22)
 (USBHS_DEVIDR) Endpoint 10 Interrupt Disable
#define USBHS_DEVIDR_PEP_11   (0x1u << 23)
 (USBHS_DEVIDR) Endpoint 11 Interrupt Disable
#define USBHS_DEVIDR_DMA_1   (0x1u << 25)
 (USBHS_DEVIDR) DMA Channel 1 Interrupt Disable
#define USBHS_DEVIDR_DMA_2   (0x1u << 26)
 (USBHS_DEVIDR) DMA Channel 2 Interrupt Disable
#define USBHS_DEVIDR_DMA_3   (0x1u << 27)
 (USBHS_DEVIDR) DMA Channel 3 Interrupt Disable
#define USBHS_DEVIDR_DMA_4   (0x1u << 28)
 (USBHS_DEVIDR) DMA Channel 4 Interrupt Disable
#define USBHS_DEVIDR_DMA_5   (0x1u << 29)
 (USBHS_DEVIDR) DMA Channel 5 Interrupt Disable
#define USBHS_DEVIDR_DMA_6   (0x1u << 30)
 (USBHS_DEVIDR) DMA Channel 6 Interrupt Disable
#define USBHS_DEVIDR_DMA_7   (0x1u << 31)
 (USBHS_DEVIDR) DMA Channel 7 Interrupt Disable
#define USBHS_DEVIER_SUSPES   (0x1u << 0)
 (USBHS_DEVIER) Suspend Interrupt Enable
#define USBHS_DEVIER_MSOFES   (0x1u << 1)
 (USBHS_DEVIER) Micro Start of Frame Interrupt Enable
#define USBHS_DEVIER_SOFES   (0x1u << 2)
 (USBHS_DEVIER) Start of Frame Interrupt Enable
#define USBHS_DEVIER_EORSTES   (0x1u << 3)
 (USBHS_DEVIER) End of Reset Interrupt Enable
#define USBHS_DEVIER_WAKEUPES   (0x1u << 4)
 (USBHS_DEVIER) Wake-Up Interrupt Enable
#define USBHS_DEVIER_EORSMES   (0x1u << 5)
 (USBHS_DEVIER) End of Resume Interrupt Enable
#define USBHS_DEVIER_UPRSMES   (0x1u << 6)
 (USBHS_DEVIER) Upstream Resume Interrupt Enable
#define USBHS_DEVIER_PEP_0   (0x1u << 12)
 (USBHS_DEVIER) Endpoint 0 Interrupt Enable
#define USBHS_DEVIER_PEP_1   (0x1u << 13)
 (USBHS_DEVIER) Endpoint 1 Interrupt Enable
#define USBHS_DEVIER_PEP_2   (0x1u << 14)
 (USBHS_DEVIER) Endpoint 2 Interrupt Enable
#define USBHS_DEVIER_PEP_3   (0x1u << 15)
 (USBHS_DEVIER) Endpoint 3 Interrupt Enable
#define USBHS_DEVIER_PEP_4   (0x1u << 16)
 (USBHS_DEVIER) Endpoint 4 Interrupt Enable
#define USBHS_DEVIER_PEP_5   (0x1u << 17)
 (USBHS_DEVIER) Endpoint 5 Interrupt Enable
#define USBHS_DEVIER_PEP_6   (0x1u << 18)
 (USBHS_DEVIER) Endpoint 6 Interrupt Enable
#define USBHS_DEVIER_PEP_7   (0x1u << 19)
 (USBHS_DEVIER) Endpoint 7 Interrupt Enable
#define USBHS_DEVIER_PEP_8   (0x1u << 20)
 (USBHS_DEVIER) Endpoint 8 Interrupt Enable
#define USBHS_DEVIER_PEP_9   (0x1u << 21)
 (USBHS_DEVIER) Endpoint 9 Interrupt Enable
#define USBHS_DEVIER_PEP_10   (0x1u << 22)
 (USBHS_DEVIER) Endpoint 10 Interrupt Enable
#define USBHS_DEVIER_PEP_11   (0x1u << 23)
 (USBHS_DEVIER) Endpoint 11 Interrupt Enable
#define USBHS_DEVIER_DMA_1   (0x1u << 25)
 (USBHS_DEVIER) DMA Channel 1 Interrupt Enable
#define USBHS_DEVIER_DMA_2   (0x1u << 26)
 (USBHS_DEVIER) DMA Channel 2 Interrupt Enable
#define USBHS_DEVIER_DMA_3   (0x1u << 27)
 (USBHS_DEVIER) DMA Channel 3 Interrupt Enable
#define USBHS_DEVIER_DMA_4   (0x1u << 28)
 (USBHS_DEVIER) DMA Channel 4 Interrupt Enable
#define USBHS_DEVIER_DMA_5   (0x1u << 29)
 (USBHS_DEVIER) DMA Channel 5 Interrupt Enable
#define USBHS_DEVIER_DMA_6   (0x1u << 30)
 (USBHS_DEVIER) DMA Channel 6 Interrupt Enable
#define USBHS_DEVIER_DMA_7   (0x1u << 31)
 (USBHS_DEVIER) DMA Channel 7 Interrupt Enable
#define USBHS_DEVEPT_EPEN0   (0x1u << 0)
 (USBHS_DEVEPT) Endpoint 0 Enable
#define USBHS_DEVEPT_EPEN1   (0x1u << 1)
 (USBHS_DEVEPT) Endpoint 1 Enable
#define USBHS_DEVEPT_EPEN2   (0x1u << 2)
 (USBHS_DEVEPT) Endpoint 2 Enable
#define USBHS_DEVEPT_EPEN3   (0x1u << 3)
 (USBHS_DEVEPT) Endpoint 3 Enable
#define USBHS_DEVEPT_EPEN4   (0x1u << 4)
 (USBHS_DEVEPT) Endpoint 4 Enable
#define USBHS_DEVEPT_EPEN5   (0x1u << 5)
 (USBHS_DEVEPT) Endpoint 5 Enable
#define USBHS_DEVEPT_EPEN6   (0x1u << 6)
 (USBHS_DEVEPT) Endpoint 6 Enable
#define USBHS_DEVEPT_EPEN7   (0x1u << 7)
 (USBHS_DEVEPT) Endpoint 7 Enable
#define USBHS_DEVEPT_EPEN8   (0x1u << 8)
 (USBHS_DEVEPT) Endpoint 8 Enable
#define USBHS_DEVEPT_EPRST0   (0x1u << 16)
 (USBHS_DEVEPT) Endpoint 0 Reset
#define USBHS_DEVEPT_EPRST1   (0x1u << 17)
 (USBHS_DEVEPT) Endpoint 1 Reset
#define USBHS_DEVEPT_EPRST2   (0x1u << 18)
 (USBHS_DEVEPT) Endpoint 2 Reset
#define USBHS_DEVEPT_EPRST3   (0x1u << 19)
 (USBHS_DEVEPT) Endpoint 3 Reset
#define USBHS_DEVEPT_EPRST4   (0x1u << 20)
 (USBHS_DEVEPT) Endpoint 4 Reset
#define USBHS_DEVEPT_EPRST5   (0x1u << 21)
 (USBHS_DEVEPT) Endpoint 5 Reset
#define USBHS_DEVEPT_EPRST6   (0x1u << 22)
 (USBHS_DEVEPT) Endpoint 6 Reset
#define USBHS_DEVEPT_EPRST7   (0x1u << 23)
 (USBHS_DEVEPT) Endpoint 7 Reset
#define USBHS_DEVEPT_EPRST8   (0x1u << 24)
 (USBHS_DEVEPT) Endpoint 8 Reset
#define USBHS_DEVFNUM_MFNUM_Pos   0
#define USBHS_DEVFNUM_MFNUM_Msk   (0x7u << USBHS_DEVFNUM_MFNUM_Pos)
 (USBHS_DEVFNUM) Micro Frame Number
#define USBHS_DEVFNUM_FNUM_Pos   3
#define USBHS_DEVFNUM_FNUM_Msk   (0x7ffu << USBHS_DEVFNUM_FNUM_Pos)
 (USBHS_DEVFNUM) Frame Number
#define USBHS_DEVFNUM_FNCERR   (0x1u << 15)
 (USBHS_DEVFNUM) Frame Number CRC Error
#define USBHS_DEVEPTCFG_ALLOC   (0x1u << 1)
 (USBHS_DEVEPTCFG[10]) Endpoint Memory Allocate
#define USBHS_DEVEPTCFG_EPBK_Pos   2
#define USBHS_DEVEPTCFG_EPBK_Msk   (0x3u << USBHS_DEVEPTCFG_EPBK_Pos)
 (USBHS_DEVEPTCFG[10]) Endpoint Banks
#define USBHS_DEVEPTCFG_EPBK(value)   ((USBHS_DEVEPTCFG_EPBK_Msk & ((value) << USBHS_DEVEPTCFG_EPBK_Pos)))
#define USBHS_DEVEPTCFG_EPBK_1_BANK   (0x0u << 2)
 (USBHS_DEVEPTCFG[10]) Single-bank endpoint
#define USBHS_DEVEPTCFG_EPBK_2_BANK   (0x1u << 2)
 (USBHS_DEVEPTCFG[10]) Double-bank endpoint
#define USBHS_DEVEPTCFG_EPBK_3_BANK   (0x2u << 2)
 (USBHS_DEVEPTCFG[10]) Triple-bank endpoint
#define USBHS_DEVEPTCFG_EPSIZE_Pos   4
#define USBHS_DEVEPTCFG_EPSIZE_Msk   (0x7u << USBHS_DEVEPTCFG_EPSIZE_Pos)
 (USBHS_DEVEPTCFG[10]) Endpoint Size
#define USBHS_DEVEPTCFG_EPSIZE(value)   ((USBHS_DEVEPTCFG_EPSIZE_Msk & ((value) << USBHS_DEVEPTCFG_EPSIZE_Pos)))
#define USBHS_DEVEPTCFG_EPSIZE_8_BYTE   (0x0u << 4)
 (USBHS_DEVEPTCFG[10]) 8 bytes
#define USBHS_DEVEPTCFG_EPSIZE_16_BYTE   (0x1u << 4)
 (USBHS_DEVEPTCFG[10]) 16 bytes
#define USBHS_DEVEPTCFG_EPSIZE_32_BYTE   (0x2u << 4)
 (USBHS_DEVEPTCFG[10]) 32 bytes
#define USBHS_DEVEPTCFG_EPSIZE_64_BYTE   (0x3u << 4)
 (USBHS_DEVEPTCFG[10]) 64 bytes
#define USBHS_DEVEPTCFG_EPSIZE_128_BYTE   (0x4u << 4)
 (USBHS_DEVEPTCFG[10]) 128 bytes
#define USBHS_DEVEPTCFG_EPSIZE_256_BYTE   (0x5u << 4)
 (USBHS_DEVEPTCFG[10]) 256 bytes
#define USBHS_DEVEPTCFG_EPSIZE_512_BYTE   (0x6u << 4)
 (USBHS_DEVEPTCFG[10]) 512 bytes
#define USBHS_DEVEPTCFG_EPSIZE_1024_BYTE   (0x7u << 4)
 (USBHS_DEVEPTCFG[10]) 1024 bytes
#define USBHS_DEVEPTCFG_EPDIR   (0x1u << 8)
 (USBHS_DEVEPTCFG[10]) Endpoint Direction
#define USBHS_DEVEPTCFG_EPDIR_OUT   (0x0u << 8)
 (USBHS_DEVEPTCFG[10]) The endpoint direction is OUT.
#define USBHS_DEVEPTCFG_EPDIR_IN   (0x1u << 8)
 (USBHS_DEVEPTCFG[10]) The endpoint direction is IN (nor for control endpoints).
#define USBHS_DEVEPTCFG_AUTOSW   (0x1u << 9)
 (USBHS_DEVEPTCFG[10]) Automatic Switch
#define USBHS_DEVEPTCFG_EPTYPE_Pos   11
#define USBHS_DEVEPTCFG_EPTYPE_Msk   (0x3u << USBHS_DEVEPTCFG_EPTYPE_Pos)
 (USBHS_DEVEPTCFG[10]) Endpoint Type
#define USBHS_DEVEPTCFG_EPTYPE(value)   ((USBHS_DEVEPTCFG_EPTYPE_Msk & ((value) << USBHS_DEVEPTCFG_EPTYPE_Pos)))
#define USBHS_DEVEPTCFG_EPTYPE_CTRL   (0x0u << 11)
 (USBHS_DEVEPTCFG[10]) Control
#define USBHS_DEVEPTCFG_EPTYPE_ISO   (0x1u << 11)
 (USBHS_DEVEPTCFG[10]) Isochronous
#define USBHS_DEVEPTCFG_EPTYPE_BLK   (0x2u << 11)
 (USBHS_DEVEPTCFG[10]) Bulk
#define USBHS_DEVEPTCFG_EPTYPE_INTRPT   (0x3u << 11)
 (USBHS_DEVEPTCFG[10]) Interrupt
#define USBHS_DEVEPTCFG_NBTRANS_Pos   13
#define USBHS_DEVEPTCFG_NBTRANS_Msk   (0x3u << USBHS_DEVEPTCFG_NBTRANS_Pos)
 (USBHS_DEVEPTCFG[10]) Number of transactions per microframe for isochronous endpoint
#define USBHS_DEVEPTCFG_NBTRANS(value)   ((USBHS_DEVEPTCFG_NBTRANS_Msk & ((value) << USBHS_DEVEPTCFG_NBTRANS_Pos)))
#define USBHS_DEVEPTCFG_NBTRANS_0_TRANS   (0x0u << 13)
 (USBHS_DEVEPTCFG[10]) Reserved to endpoint that does not have the high-bandwidth isochronous capability.
#define USBHS_DEVEPTCFG_NBTRANS_1_TRANS   (0x1u << 13)
 (USBHS_DEVEPTCFG[10]) Default value: one transaction per microframe.
#define USBHS_DEVEPTCFG_NBTRANS_2_TRANS   (0x2u << 13)
 (USBHS_DEVEPTCFG[10]) Two transactions per microframe. This endpoint should be configured as double-bank.
#define USBHS_DEVEPTCFG_NBTRANS_3_TRANS   (0x3u << 13)
 (USBHS_DEVEPTCFG[10]) Three transactions per microframe. This endpoint should be configured as triple-bank.
#define USBHS_DEVEPTISR_TXINI   (0x1u << 0)
 (USBHS_DEVEPTISR[10]) Transmitted IN Data Interrupt
#define USBHS_DEVEPTISR_RXOUTI   (0x1u << 1)
 (USBHS_DEVEPTISR[10]) Received OUT Data Interrupt
#define USBHS_DEVEPTISR_RXSTPI   (0x1u << 2)
 (USBHS_DEVEPTISR[10]) Received SETUP Interrupt
#define USBHS_DEVEPTISR_NAKOUTI   (0x1u << 3)
 (USBHS_DEVEPTISR[10]) NAKed OUT Interrupt
#define USBHS_DEVEPTISR_NAKINI   (0x1u << 4)
 (USBHS_DEVEPTISR[10]) NAKed IN Interrupt
#define USBHS_DEVEPTISR_OVERFI   (0x1u << 5)
 (USBHS_DEVEPTISR[10]) Overflow Interrupt
#define USBHS_DEVEPTISR_STALLEDI   (0x1u << 6)
 (USBHS_DEVEPTISR[10]) STALLed Interrupt
#define USBHS_DEVEPTISR_SHORTPACKET   (0x1u << 7)
 (USBHS_DEVEPTISR[10]) Short Packet Interrupt
#define USBHS_DEVEPTISR_DTSEQ_Pos   8
#define USBHS_DEVEPTISR_DTSEQ_Msk   (0x3u << USBHS_DEVEPTISR_DTSEQ_Pos)
 (USBHS_DEVEPTISR[10]) Data Toggle Sequence
#define USBHS_DEVEPTISR_DTSEQ_DATA0   (0x0u << 8)
 (USBHS_DEVEPTISR[10]) Data0 toggle sequence
#define USBHS_DEVEPTISR_DTSEQ_DATA1   (0x1u << 8)
 (USBHS_DEVEPTISR[10]) Data1 toggle sequence
#define USBHS_DEVEPTISR_DTSEQ_DATA2   (0x2u << 8)
 (USBHS_DEVEPTISR[10]) Reserved for high-bandwidth isochronous endpoint
#define USBHS_DEVEPTISR_DTSEQ_MDATA   (0x3u << 8)
#define USBHS_DEVEPTISR_NBUSYBK_Pos   12
#define USBHS_DEVEPTISR_NBUSYBK_Msk   (0x3u << USBHS_DEVEPTISR_NBUSYBK_Pos)
 (USBHS_DEVEPTISR[10]) Number of Busy Banks
#define USBHS_DEVEPTISR_NBUSYBK_0_BUSY   (0x0u << 12)
 (USBHS_DEVEPTISR[10]) 0 busy bank (all banks free)
#define USBHS_DEVEPTISR_NBUSYBK_1_BUSY   (0x1u << 12)
 (USBHS_DEVEPTISR[10]) 1 busy bank
#define USBHS_DEVEPTISR_NBUSYBK_2_BUSY   (0x2u << 12)
 (USBHS_DEVEPTISR[10]) 2 busy banks
#define USBHS_DEVEPTISR_NBUSYBK_3_BUSY   (0x3u << 12)
 (USBHS_DEVEPTISR[10]) 3 busy banks
#define USBHS_DEVEPTISR_CURRBK_Pos   14
#define USBHS_DEVEPTISR_CURRBK_Msk   (0x3u << USBHS_DEVEPTISR_CURRBK_Pos)
 (USBHS_DEVEPTISR[10]) Current Bank
#define USBHS_DEVEPTISR_CURRBK_BANK0   (0x0u << 14)
 (USBHS_DEVEPTISR[10]) Current bank is bank0
#define USBHS_DEVEPTISR_CURRBK_BANK1   (0x1u << 14)
 (USBHS_DEVEPTISR[10]) Current bank is bank1
#define USBHS_DEVEPTISR_CURRBK_BANK2   (0x2u << 14)
 (USBHS_DEVEPTISR[10]) Current bank is bank2
#define USBHS_DEVEPTISR_RWALL   (0x1u << 16)
 (USBHS_DEVEPTISR[10]) Read/Write Allowed
#define USBHS_DEVEPTISR_CTRLDIR   (0x1u << 17)
 (USBHS_DEVEPTISR[10]) Control Direction
#define USBHS_DEVEPTISR_CFGOK   (0x1u << 18)
 (USBHS_DEVEPTISR[10]) Configuration OK Status
#define USBHS_DEVEPTISR_BYCT_Pos   20
#define USBHS_DEVEPTISR_BYCT_Msk   (0x7ffu << USBHS_DEVEPTISR_BYCT_Pos)
 (USBHS_DEVEPTISR[10]) Byte Count
#define USBHS_DEVEPTISR_UNDERFI   (0x1u << 2)
 (USBHS_DEVEPTISR[10]) Underflow Interrupt
#define USBHS_DEVEPTISR_HBISOINERRI   (0x1u << 3)
 (USBHS_DEVEPTISR[10]) High Bandwidth Isochronous IN Underflow Error Interrupt
#define USBHS_DEVEPTISR_HBISOFLUSHI   (0x1u << 4)
 (USBHS_DEVEPTISR[10]) High Bandwidth Isochronous IN Flush Interrupt
#define USBHS_DEVEPTISR_CRCERRI   (0x1u << 6)
 (USBHS_DEVEPTISR[10]) CRC Error Interrupt
#define USBHS_DEVEPTISR_ERRORTRANS   (0x1u << 10)
 (USBHS_DEVEPTISR[10]) High-bandwidth Isochronous OUT Endpoint Transaction Error Interrupt
#define USBHS_DEVEPTICR_TXINIC   (0x1u << 0)
 (USBHS_DEVEPTICR[10]) Transmitted IN Data Interrupt Clear
#define USBHS_DEVEPTICR_RXOUTIC   (0x1u << 1)
 (USBHS_DEVEPTICR[10]) Received OUT Data Interrupt Clear
#define USBHS_DEVEPTICR_RXSTPIC   (0x1u << 2)
 (USBHS_DEVEPTICR[10]) Received SETUP Interrupt Clear
#define USBHS_DEVEPTICR_NAKOUTIC   (0x1u << 3)
 (USBHS_DEVEPTICR[10]) NAKed OUT Interrupt Clear
#define USBHS_DEVEPTICR_NAKINIC   (0x1u << 4)
 (USBHS_DEVEPTICR[10]) NAKed IN Interrupt Clear
#define USBHS_DEVEPTICR_OVERFIC   (0x1u << 5)
 (USBHS_DEVEPTICR[10]) Overflow Interrupt Clear
#define USBHS_DEVEPTICR_STALLEDIC   (0x1u << 6)
 (USBHS_DEVEPTICR[10]) STALLed Interrupt Clear
#define USBHS_DEVEPTICR_SHORTPACKETC   (0x1u << 7)
 (USBHS_DEVEPTICR[10]) Short Packet Interrupt Clear
#define USBHS_DEVEPTICR_UNDERFIC   (0x1u << 2)
 (USBHS_DEVEPTICR[10]) Underflow Interrupt Clear
#define USBHS_DEVEPTICR_HBISOINERRIC   (0x1u << 3)
 (USBHS_DEVEPTICR[10]) High Bandwidth Isochronous IN Underflow Error Interrupt Clear
#define USBHS_DEVEPTICR_HBISOFLUSHIC   (0x1u << 4)
 (USBHS_DEVEPTICR[10]) High Bandwidth Isochronous IN Flush Interrupt Clear
#define USBHS_DEVEPTICR_CRCERRIC   (0x1u << 6)
 (USBHS_DEVEPTICR[10]) CRC Error Interrupt Clear
#define USBHS_DEVEPTIFR_TXINIS   (0x1u << 0)
 (USBHS_DEVEPTIFR[10]) Transmitted IN Data Interrupt Set
#define USBHS_DEVEPTIFR_RXOUTIS   (0x1u << 1)
 (USBHS_DEVEPTIFR[10]) Received OUT Data Interrupt Set
#define USBHS_DEVEPTIFR_RXSTPIS   (0x1u << 2)
 (USBHS_DEVEPTIFR[10]) Received SETUP Interrupt Set
#define USBHS_DEVEPTIFR_NAKOUTIS   (0x1u << 3)
 (USBHS_DEVEPTIFR[10]) NAKed OUT Interrupt Set
#define USBHS_DEVEPTIFR_NAKINIS   (0x1u << 4)
 (USBHS_DEVEPTIFR[10]) NAKed IN Interrupt Set
#define USBHS_DEVEPTIFR_OVERFIS   (0x1u << 5)
 (USBHS_DEVEPTIFR[10]) Overflow Interrupt Set
#define USBHS_DEVEPTIFR_STALLEDIS   (0x1u << 6)
 (USBHS_DEVEPTIFR[10]) STALLed Interrupt Set
#define USBHS_DEVEPTIFR_SHORTPACKETS   (0x1u << 7)
 (USBHS_DEVEPTIFR[10]) Short Packet Interrupt Set
#define USBHS_DEVEPTIFR_NBUSYBKS   (0x1u << 12)
 (USBHS_DEVEPTIFR[10]) Number of Busy Banks Interrupt Set
#define USBHS_DEVEPTIFR_UNDERFIS   (0x1u << 2)
 (USBHS_DEVEPTIFR[10]) Underflow Interrupt Set
#define USBHS_DEVEPTIFR_HBISOINERRIS   (0x1u << 3)
 (USBHS_DEVEPTIFR[10]) High Bandwidth Isochronous IN Underflow Error Interrupt Set
#define USBHS_DEVEPTIFR_HBISOFLUSHIS   (0x1u << 4)
 (USBHS_DEVEPTIFR[10]) High Bandwidth Isochronous IN Flush Interrupt Set
#define USBHS_DEVEPTIFR_CRCERRIS   (0x1u << 6)
 (USBHS_DEVEPTIFR[10]) CRC Error Interrupt Set
#define USBHS_DEVEPTIMR_TXINE   (0x1u << 0)
 (USBHS_DEVEPTIMR[10]) Transmitted IN Data Interrupt
#define USBHS_DEVEPTIMR_RXOUTE   (0x1u << 1)
 (USBHS_DEVEPTIMR[10]) Received OUT Data Interrupt
#define USBHS_DEVEPTIMR_RXSTPE   (0x1u << 2)
 (USBHS_DEVEPTIMR[10]) Received SETUP Interrupt
#define USBHS_DEVEPTIMR_NAKOUTE   (0x1u << 3)
 (USBHS_DEVEPTIMR[10]) NAKed OUT Interrupt
#define USBHS_DEVEPTIMR_NAKINE   (0x1u << 4)
 (USBHS_DEVEPTIMR[10]) NAKed IN Interrupt
#define USBHS_DEVEPTIMR_OVERFE   (0x1u << 5)
 (USBHS_DEVEPTIMR[10]) Overflow Interrupt
#define USBHS_DEVEPTIMR_STALLEDE   (0x1u << 6)
 (USBHS_DEVEPTIMR[10]) STALLed Interrupt
#define USBHS_DEVEPTIMR_SHORTPACKETE   (0x1u << 7)
 (USBHS_DEVEPTIMR[10]) Short Packet Interrupt
#define USBHS_DEVEPTIMR_NBUSYBKE   (0x1u << 12)
 (USBHS_DEVEPTIMR[10]) Number of Busy Banks Interrupt
#define USBHS_DEVEPTIMR_KILLBK   (0x1u << 13)
 (USBHS_DEVEPTIMR[10]) Kill IN Bank
#define USBHS_DEVEPTIMR_FIFOCON   (0x1u << 14)
 (USBHS_DEVEPTIMR[10]) FIFO Control
#define USBHS_DEVEPTIMR_EPDISHDMA   (0x1u << 16)
 (USBHS_DEVEPTIMR[10]) Endpoint Interrupts Disable HDMA Request
#define USBHS_DEVEPTIMR_NYETDIS   (0x1u << 17)
 (USBHS_DEVEPTIMR[10]) NYET Token Disable
#define USBHS_DEVEPTIMR_RSTDT   (0x1u << 18)
 (USBHS_DEVEPTIMR[10]) Reset Data Toggle
#define USBHS_DEVEPTIMR_STALLRQ   (0x1u << 19)
 (USBHS_DEVEPTIMR[10]) STALL Request
#define USBHS_DEVEPTIMR_UNDERFE   (0x1u << 2)
 (USBHS_DEVEPTIMR[10]) Underflow Interrupt
#define USBHS_DEVEPTIMR_HBISOINERRE   (0x1u << 3)
 (USBHS_DEVEPTIMR[10]) High Bandwidth Isochronous IN Error Interrupt
#define USBHS_DEVEPTIMR_HBISOFLUSHE   (0x1u << 4)
 (USBHS_DEVEPTIMR[10]) High Bandwidth Isochronous IN Flush Interrupt
#define USBHS_DEVEPTIMR_CRCERRE   (0x1u << 6)
 (USBHS_DEVEPTIMR[10]) CRC Error Interrupt
#define USBHS_DEVEPTIMR_MDATAE   (0x1u << 8)
 (USBHS_DEVEPTIMR[10]) MData Interrupt
#define USBHS_DEVEPTIMR_DATAXE   (0x1u << 9)
 (USBHS_DEVEPTIMR[10]) DataX Interrupt
#define USBHS_DEVEPTIMR_ERRORTRANSE   (0x1u << 10)
 (USBHS_DEVEPTIMR[10]) Transaction Error Interrupt
#define USBHS_DEVEPTIER_TXINES   (0x1u << 0)
 (USBHS_DEVEPTIER[10]) Transmitted IN Data Interrupt Enable
#define USBHS_DEVEPTIER_RXOUTES   (0x1u << 1)
 (USBHS_DEVEPTIER[10]) Received OUT Data Interrupt Enable
#define USBHS_DEVEPTIER_RXSTPES   (0x1u << 2)
 (USBHS_DEVEPTIER[10]) Received SETUP Interrupt Enable
#define USBHS_DEVEPTIER_NAKOUTES   (0x1u << 3)
 (USBHS_DEVEPTIER[10]) NAKed OUT Interrupt Enable
#define USBHS_DEVEPTIER_NAKINES   (0x1u << 4)
 (USBHS_DEVEPTIER[10]) NAKed IN Interrupt Enable
#define USBHS_DEVEPTIER_OVERFES   (0x1u << 5)
 (USBHS_DEVEPTIER[10]) Overflow Interrupt Enable
#define USBHS_DEVEPTIER_STALLEDES   (0x1u << 6)
 (USBHS_DEVEPTIER[10]) STALLed Interrupt Enable
#define USBHS_DEVEPTIER_SHORTPACKETES   (0x1u << 7)
 (USBHS_DEVEPTIER[10]) Short Packet Interrupt Enable
#define USBHS_DEVEPTIER_NBUSYBKES   (0x1u << 12)
 (USBHS_DEVEPTIER[10]) Number of Busy Banks Interrupt Enable
#define USBHS_DEVEPTIER_KILLBKS   (0x1u << 13)
 (USBHS_DEVEPTIER[10]) Kill IN Bank
#define USBHS_DEVEPTIER_FIFOCONS   (0x1u << 14)
 (USBHS_DEVEPTIER[10]) FIFO Control
#define USBHS_DEVEPTIER_EPDISHDMAS   (0x1u << 16)
 (USBHS_DEVEPTIER[10]) Endpoint Interrupts Disable HDMA Request Enable
#define USBHS_DEVEPTIER_NYETDISS   (0x1u << 17)
 (USBHS_DEVEPTIER[10]) NYET Token Disable Enable
#define USBHS_DEVEPTIER_RSTDTS   (0x1u << 18)
 (USBHS_DEVEPTIER[10]) Reset Data Toggle Enable
#define USBHS_DEVEPTIER_STALLRQS   (0x1u << 19)
 (USBHS_DEVEPTIER[10]) STALL Request Enable
#define USBHS_DEVEPTIER_UNDERFES   (0x1u << 2)
 (USBHS_DEVEPTIER[10]) Underflow Interrupt Enable
#define USBHS_DEVEPTIER_HBISOINERRES   (0x1u << 3)
 (USBHS_DEVEPTIER[10]) High Bandwidth Isochronous IN Error Interrupt Enable
#define USBHS_DEVEPTIER_HBISOFLUSHES   (0x1u << 4)
 (USBHS_DEVEPTIER[10]) High Bandwidth Isochronous IN Flush Interrupt Enable
#define USBHS_DEVEPTIER_CRCERRES   (0x1u << 6)
 (USBHS_DEVEPTIER[10]) CRC Error Interrupt Enable
#define USBHS_DEVEPTIER_MDATAES   (0x1u << 8)
 (USBHS_DEVEPTIER[10]) MData Interrupt Enable
#define USBHS_DEVEPTIER_DATAXES   (0x1u << 9)
 (USBHS_DEVEPTIER[10]) DataX Interrupt Enable
#define USBHS_DEVEPTIER_ERRORTRANSES   (0x1u << 10)
 (USBHS_DEVEPTIER[10]) Transaction Error Interrupt Enable
#define USBHS_DEVEPTIDR_TXINEC   (0x1u << 0)
 (USBHS_DEVEPTIDR[10]) Transmitted IN Interrupt Clear
#define USBHS_DEVEPTIDR_RXOUTEC   (0x1u << 1)
 (USBHS_DEVEPTIDR[10]) Received OUT Data Interrupt Clear
#define USBHS_DEVEPTIDR_RXSTPEC   (0x1u << 2)
 (USBHS_DEVEPTIDR[10]) Received SETUP Interrupt Clear
#define USBHS_DEVEPTIDR_NAKOUTEC   (0x1u << 3)
 (USBHS_DEVEPTIDR[10]) NAKed OUT Interrupt Clear
#define USBHS_DEVEPTIDR_NAKINEC   (0x1u << 4)
 (USBHS_DEVEPTIDR[10]) NAKed IN Interrupt Clear
#define USBHS_DEVEPTIDR_OVERFEC   (0x1u << 5)
 (USBHS_DEVEPTIDR[10]) Overflow Interrupt Clear
#define USBHS_DEVEPTIDR_STALLEDEC   (0x1u << 6)
 (USBHS_DEVEPTIDR[10]) STALLed Interrupt Clear
#define USBHS_DEVEPTIDR_SHORTPACKETEC   (0x1u << 7)
 (USBHS_DEVEPTIDR[10]) Shortpacket Interrupt Clear
#define USBHS_DEVEPTIDR_NBUSYBKEC   (0x1u << 12)
 (USBHS_DEVEPTIDR[10]) Number of Busy Banks Interrupt Clear
#define USBHS_DEVEPTIDR_FIFOCONC   (0x1u << 14)
 (USBHS_DEVEPTIDR[10]) FIFO Control Clear
#define USBHS_DEVEPTIDR_EPDISHDMAC   (0x1u << 16)
 (USBHS_DEVEPTIDR[10]) Endpoint Interrupts Disable HDMA Request Clear
#define USBHS_DEVEPTIDR_NYETDISC   (0x1u << 17)
 (USBHS_DEVEPTIDR[10]) NYET Token Disable Clear
#define USBHS_DEVEPTIDR_STALLRQC   (0x1u << 19)
 (USBHS_DEVEPTIDR[10]) STALL Request Clear
#define USBHS_DEVEPTIDR_UNDERFEC   (0x1u << 2)
 (USBHS_DEVEPTIDR[10]) Underflow Interrupt Clear
#define USBHS_DEVEPTIDR_HBISOINERREC   (0x1u << 3)
 (USBHS_DEVEPTIDR[10]) High Bandwidth Isochronous IN Error Interrupt Clear
#define USBHS_DEVEPTIDR_HBISOFLUSHEC   (0x1u << 4)
 (USBHS_DEVEPTIDR[10]) High Bandwidth Isochronous IN Flush Interrupt Clear
#define USBHS_DEVEPTIDR_CRCERREC   (0x1u << 6)
 (USBHS_DEVEPTIDR[10]) CRC Error Interrupt Clear
#define USBHS_DEVEPTIDR_MDATEC   (0x1u << 8)
 (USBHS_DEVEPTIDR[10]) MData Interrupt Clear
#define USBHS_DEVEPTIDR_DATAXEC   (0x1u << 9)
 (USBHS_DEVEPTIDR[10]) DataX Interrupt Clear
#define USBHS_DEVEPTIDR_ERRORTRANSEC   (0x1u << 10)
 (USBHS_DEVEPTIDR[10]) Transaction Error Interrupt Clear
#define USBHS_DEVDMANXTDSC_NXT_DSC_ADD_Pos   0
#define USBHS_DEVDMANXTDSC_NXT_DSC_ADD_Msk   (0xffffffffu << USBHS_DEVDMANXTDSC_NXT_DSC_ADD_Pos)
 (USBHS_DEVDMANXTDSC) Next Descriptor Address
#define USBHS_DEVDMANXTDSC_NXT_DSC_ADD(value)   ((USBHS_DEVDMANXTDSC_NXT_DSC_ADD_Msk & ((value) << USBHS_DEVDMANXTDSC_NXT_DSC_ADD_Pos)))
#define USBHS_DEVDMAADDRESS_BUFF_ADD_Pos   0
#define USBHS_DEVDMAADDRESS_BUFF_ADD_Msk   (0xffffffffu << USBHS_DEVDMAADDRESS_BUFF_ADD_Pos)
 (USBHS_DEVDMAADDRESS) Buffer Address
#define USBHS_DEVDMAADDRESS_BUFF_ADD(value)   ((USBHS_DEVDMAADDRESS_BUFF_ADD_Msk & ((value) << USBHS_DEVDMAADDRESS_BUFF_ADD_Pos)))
#define USBHS_DEVDMACONTROL_CHANN_ENB   (0x1u << 0)
 (USBHS_DEVDMACONTROL) Channel Enable Command
#define USBHS_DEVDMACONTROL_LDNXT_DSC   (0x1u << 1)
 (USBHS_DEVDMACONTROL) Load Next Channel Transfer Descriptor Enable Command
#define USBHS_DEVDMACONTROL_END_TR_EN   (0x1u << 2)
 (USBHS_DEVDMACONTROL) End of Transfer Enable Control (OUT transfers only)
#define USBHS_DEVDMACONTROL_END_B_EN   (0x1u << 3)
 (USBHS_DEVDMACONTROL) End of Buffer Enable Control
#define USBHS_DEVDMACONTROL_END_TR_IT   (0x1u << 4)
 (USBHS_DEVDMACONTROL) End of Transfer Interrupt Enable
#define USBHS_DEVDMACONTROL_END_BUFFIT   (0x1u << 5)
 (USBHS_DEVDMACONTROL) End of Buffer Interrupt Enable
#define USBHS_DEVDMACONTROL_DESC_LD_IT   (0x1u << 6)
 (USBHS_DEVDMACONTROL) Descriptor Loaded Interrupt Enable
#define USBHS_DEVDMACONTROL_BURST_LCK   (0x1u << 7)
 (USBHS_DEVDMACONTROL) Burst Lock Enable
#define USBHS_DEVDMACONTROL_BUFF_LENGTH_Pos   16
#define USBHS_DEVDMACONTROL_BUFF_LENGTH_Msk   (0xffffu << USBHS_DEVDMACONTROL_BUFF_LENGTH_Pos)
 (USBHS_DEVDMACONTROL) Buffer Byte Length (Write-only)
#define USBHS_DEVDMACONTROL_BUFF_LENGTH(value)   ((USBHS_DEVDMACONTROL_BUFF_LENGTH_Msk & ((value) << USBHS_DEVDMACONTROL_BUFF_LENGTH_Pos)))
#define USBHS_DEVDMASTATUS_CHANN_ENB   (0x1u << 0)
 (USBHS_DEVDMASTATUS) Channel Enable Status
#define USBHS_DEVDMASTATUS_CHANN_ACT   (0x1u << 1)
 (USBHS_DEVDMASTATUS) Channel Active Status
#define USBHS_DEVDMASTATUS_END_TR_ST   (0x1u << 4)
 (USBHS_DEVDMASTATUS) End of Channel Transfer Status
#define USBHS_DEVDMASTATUS_END_BF_ST   (0x1u << 5)
 (USBHS_DEVDMASTATUS) End of Channel Buffer Status
#define USBHS_DEVDMASTATUS_DESC_LDST   (0x1u << 6)
 (USBHS_DEVDMASTATUS) Descriptor Loaded Status
#define USBHS_DEVDMASTATUS_BUFF_COUNT_Pos   16
#define USBHS_DEVDMASTATUS_BUFF_COUNT_Msk   (0xffffu << USBHS_DEVDMASTATUS_BUFF_COUNT_Pos)
 (USBHS_DEVDMASTATUS) Buffer Byte Count
#define USBHS_DEVDMASTATUS_BUFF_COUNT(value)   ((USBHS_DEVDMASTATUS_BUFF_COUNT_Msk & ((value) << USBHS_DEVDMASTATUS_BUFF_COUNT_Pos)))
#define USBHS_HSTCTRL_SOFE   (0x1u << 8)
 (USBHS_HSTCTRL) Start of Frame Generation Enable
#define USBHS_HSTCTRL_RESET   (0x1u << 9)
 (USBHS_HSTCTRL) Send USB Reset
#define USBHS_HSTCTRL_RESUME   (0x1u << 10)
 (USBHS_HSTCTRL) Send USB Resume
#define USBHS_HSTCTRL_SPDCONF_Pos   12
#define USBHS_HSTCTRL_SPDCONF_Msk   (0x3u << USBHS_HSTCTRL_SPDCONF_Pos)
 (USBHS_HSTCTRL) Mode Configuration
#define USBHS_HSTCTRL_SPDCONF(value)   ((USBHS_HSTCTRL_SPDCONF_Msk & ((value) << USBHS_HSTCTRL_SPDCONF_Pos)))
#define USBHS_HSTCTRL_SPDCONF_NORMAL   (0x0u << 12)
 (USBHS_HSTCTRL) The host starts in Full-speed mode and performs a high-speed reset to switch to High-speed mode if the downstream peripheral is high-speed capable.
#define USBHS_HSTCTRL_SPDCONF_LOW_POWER   (0x1u << 12)
 (USBHS_HSTCTRL) For a better consumption, if high speed is not needed.
#define USBHS_HSTCTRL_SPDCONF_HIGH_SPEED   (0x2u << 12)
 (USBHS_HSTCTRL) Forced high speed.
#define USBHS_HSTCTRL_SPDCONF_FORCED_FS   (0x3u << 12)
 (USBHS_HSTCTRL) The host remains in Full-speed mode whatever the peripheral speed capability.
#define USBHS_HSTISR_DCONNI   (0x1u << 0)
 (USBHS_HSTISR) Device Connection Interrupt
#define USBHS_HSTISR_DDISCI   (0x1u << 1)
 (USBHS_HSTISR) Device Disconnection Interrupt
#define USBHS_HSTISR_RSTI   (0x1u << 2)
 (USBHS_HSTISR) USB Reset Sent Interrupt
#define USBHS_HSTISR_RSMEDI   (0x1u << 3)
 (USBHS_HSTISR) Downstream Resume Sent Interrupt
#define USBHS_HSTISR_RXRSMI   (0x1u << 4)
 (USBHS_HSTISR) Upstream Resume Received Interrupt
#define USBHS_HSTISR_HSOFI   (0x1u << 5)
 (USBHS_HSTISR) Host Start of Frame Interrupt
#define USBHS_HSTISR_HWUPI   (0x1u << 6)
 (USBHS_HSTISR) Host Wake-Up Interrupt
#define USBHS_HSTISR_PEP_0   (0x1u << 8)
 (USBHS_HSTISR) Pipe 0 Interrupt
#define USBHS_HSTISR_PEP_1   (0x1u << 9)
 (USBHS_HSTISR) Pipe 1 Interrupt
#define USBHS_HSTISR_PEP_2   (0x1u << 10)
 (USBHS_HSTISR) Pipe 2 Interrupt
#define USBHS_HSTISR_PEP_3   (0x1u << 11)
 (USBHS_HSTISR) Pipe 3 Interrupt
#define USBHS_HSTISR_PEP_4   (0x1u << 12)
 (USBHS_HSTISR) Pipe 4 Interrupt
#define USBHS_HSTISR_PEP_5   (0x1u << 13)
 (USBHS_HSTISR) Pipe 5 Interrupt
#define USBHS_HSTISR_PEP_6   (0x1u << 14)
 (USBHS_HSTISR) Pipe 6 Interrupt
#define USBHS_HSTISR_PEP_7   (0x1u << 15)
 (USBHS_HSTISR) Pipe 7 Interrupt
#define USBHS_HSTISR_PEP_8   (0x1u << 16)
 (USBHS_HSTISR) Pipe 8 Interrupt
#define USBHS_HSTISR_PEP_9   (0x1u << 17)
 (USBHS_HSTISR) Pipe 9 Interrupt
#define USBHS_HSTISR_PEP_10   (0x1u << 18)
 (USBHS_HSTISR) Pipe 10 Interrupt
#define USBHS_HSTISR_PEP_11   (0x1u << 19)
 (USBHS_HSTISR) Pipe 11 Interrupt
#define USBHS_HSTISR_DMA_1   (0x1u << 25)
 (USBHS_HSTISR) DMA Channel 1 Interrupt
#define USBHS_HSTISR_DMA_2   (0x1u << 26)
 (USBHS_HSTISR) DMA Channel 2 Interrupt
#define USBHS_HSTISR_DMA_3   (0x1u << 27)
 (USBHS_HSTISR) DMA Channel 3 Interrupt
#define USBHS_HSTISR_DMA_4   (0x1u << 28)
 (USBHS_HSTISR) DMA Channel 4 Interrupt
#define USBHS_HSTISR_DMA_5   (0x1u << 29)
 (USBHS_HSTISR) DMA Channel 5 Interrupt
#define USBHS_HSTISR_DMA_6   (0x1u << 30)
 (USBHS_HSTISR) DMA Channel 6 Interrupt
#define USBHS_HSTISR_DMA_7   (0x1u << 31)
 (USBHS_HSTISR) DMA Channel 7 Interrupt
#define USBHS_HSTICR_DCONNIC   (0x1u << 0)
 (USBHS_HSTICR) Device Connection Interrupt Clear
#define USBHS_HSTICR_DDISCIC   (0x1u << 1)
 (USBHS_HSTICR) Device Disconnection Interrupt Clear
#define USBHS_HSTICR_RSTIC   (0x1u << 2)
 (USBHS_HSTICR) USB Reset Sent Interrupt Clear
#define USBHS_HSTICR_RSMEDIC   (0x1u << 3)
 (USBHS_HSTICR) Downstream Resume Sent Interrupt Clear
#define USBHS_HSTICR_RXRSMIC   (0x1u << 4)
 (USBHS_HSTICR) Upstream Resume Received Interrupt Clear
#define USBHS_HSTICR_HSOFIC   (0x1u << 5)
 (USBHS_HSTICR) Host Start of Frame Interrupt Clear
#define USBHS_HSTICR_HWUPIC   (0x1u << 6)
 (USBHS_HSTICR) Host Wake-Up Interrupt Clear
#define USBHS_HSTIFR_DCONNIS   (0x1u << 0)
 (USBHS_HSTIFR) Device Connection Interrupt Set
#define USBHS_HSTIFR_DDISCIS   (0x1u << 1)
 (USBHS_HSTIFR) Device Disconnection Interrupt Set
#define USBHS_HSTIFR_RSTIS   (0x1u << 2)
 (USBHS_HSTIFR) USB Reset Sent Interrupt Set
#define USBHS_HSTIFR_RSMEDIS   (0x1u << 3)
 (USBHS_HSTIFR) Downstream Resume Sent Interrupt Set
#define USBHS_HSTIFR_RXRSMIS   (0x1u << 4)
 (USBHS_HSTIFR) Upstream Resume Received Interrupt Set
#define USBHS_HSTIFR_HSOFIS   (0x1u << 5)
 (USBHS_HSTIFR) Host Start of Frame Interrupt Set
#define USBHS_HSTIFR_HWUPIS   (0x1u << 6)
 (USBHS_HSTIFR) Host Wake-Up Interrupt Set
#define USBHS_HSTIFR_DMA_1   (0x1u << 25)
 (USBHS_HSTIFR) DMA Channel 1 Interrupt Set
#define USBHS_HSTIFR_DMA_2   (0x1u << 26)
 (USBHS_HSTIFR) DMA Channel 2 Interrupt Set
#define USBHS_HSTIFR_DMA_3   (0x1u << 27)
 (USBHS_HSTIFR) DMA Channel 3 Interrupt Set
#define USBHS_HSTIFR_DMA_4   (0x1u << 28)
 (USBHS_HSTIFR) DMA Channel 4 Interrupt Set
#define USBHS_HSTIFR_DMA_5   (0x1u << 29)
 (USBHS_HSTIFR) DMA Channel 5 Interrupt Set
#define USBHS_HSTIFR_DMA_6   (0x1u << 30)
 (USBHS_HSTIFR) DMA Channel 6 Interrupt Set
#define USBHS_HSTIFR_DMA_7   (0x1u << 31)
 (USBHS_HSTIFR) DMA Channel 7 Interrupt Set
#define USBHS_HSTIMR_DCONNIE   (0x1u << 0)
 (USBHS_HSTIMR) Device Connection Interrupt Enable
#define USBHS_HSTIMR_DDISCIE   (0x1u << 1)
 (USBHS_HSTIMR) Device Disconnection Interrupt Enable
#define USBHS_HSTIMR_RSTIE   (0x1u << 2)
 (USBHS_HSTIMR) USB Reset Sent Interrupt Enable
#define USBHS_HSTIMR_RSMEDIE   (0x1u << 3)
 (USBHS_HSTIMR) Downstream Resume Sent Interrupt Enable
#define USBHS_HSTIMR_RXRSMIE   (0x1u << 4)
 (USBHS_HSTIMR) Upstream Resume Received Interrupt Enable
#define USBHS_HSTIMR_HSOFIE   (0x1u << 5)
 (USBHS_HSTIMR) Host Start of Frame Interrupt Enable
#define USBHS_HSTIMR_HWUPIE   (0x1u << 6)
 (USBHS_HSTIMR) Host Wake-Up Interrupt Enable
#define USBHS_HSTIMR_PEP_0   (0x1u << 8)
 (USBHS_HSTIMR) Pipe 0 Interrupt Enable
#define USBHS_HSTIMR_PEP_1   (0x1u << 9)
 (USBHS_HSTIMR) Pipe 1 Interrupt Enable
#define USBHS_HSTIMR_PEP_2   (0x1u << 10)
 (USBHS_HSTIMR) Pipe 2 Interrupt Enable
#define USBHS_HSTIMR_PEP_3   (0x1u << 11)
 (USBHS_HSTIMR) Pipe 3 Interrupt Enable
#define USBHS_HSTIMR_PEP_4   (0x1u << 12)
 (USBHS_HSTIMR) Pipe 4 Interrupt Enable
#define USBHS_HSTIMR_PEP_5   (0x1u << 13)
 (USBHS_HSTIMR) Pipe 5 Interrupt Enable
#define USBHS_HSTIMR_PEP_6   (0x1u << 14)
 (USBHS_HSTIMR) Pipe 6 Interrupt Enable
#define USBHS_HSTIMR_PEP_7   (0x1u << 15)
 (USBHS_HSTIMR) Pipe 7 Interrupt Enable
#define USBHS_HSTIMR_PEP_8   (0x1u << 16)
 (USBHS_HSTIMR) Pipe 8 Interrupt Enable
#define USBHS_HSTIMR_PEP_9   (0x1u << 17)
 (USBHS_HSTIMR) Pipe 9 Interrupt Enable
#define USBHS_HSTIMR_PEP_10   (0x1u << 18)
 (USBHS_HSTIMR) Pipe 10 Interrupt Enable
#define USBHS_HSTIMR_PEP_11   (0x1u << 19)
 (USBHS_HSTIMR) Pipe 11 Interrupt Enable
#define USBHS_HSTIMR_DMA_1   (0x1u << 25)
 (USBHS_HSTIMR) DMA Channel 1 Interrupt Enable
#define USBHS_HSTIMR_DMA_2   (0x1u << 26)
 (USBHS_HSTIMR) DMA Channel 2 Interrupt Enable
#define USBHS_HSTIMR_DMA_3   (0x1u << 27)
 (USBHS_HSTIMR) DMA Channel 3 Interrupt Enable
#define USBHS_HSTIMR_DMA_4   (0x1u << 28)
 (USBHS_HSTIMR) DMA Channel 4 Interrupt Enable
#define USBHS_HSTIMR_DMA_5   (0x1u << 29)
 (USBHS_HSTIMR) DMA Channel 5 Interrupt Enable
#define USBHS_HSTIMR_DMA_6   (0x1u << 30)
 (USBHS_HSTIMR) DMA Channel 6 Interrupt Enable
#define USBHS_HSTIMR_DMA_7   (0x1u << 31)
 (USBHS_HSTIMR) DMA Channel 7 Interrupt Enable
#define USBHS_HSTIDR_DCONNIEC   (0x1u << 0)
 (USBHS_HSTIDR) Device Connection Interrupt Disable
#define USBHS_HSTIDR_DDISCIEC   (0x1u << 1)
 (USBHS_HSTIDR) Device Disconnection Interrupt Disable
#define USBHS_HSTIDR_RSTIEC   (0x1u << 2)
 (USBHS_HSTIDR) USB Reset Sent Interrupt Disable
#define USBHS_HSTIDR_RSMEDIEC   (0x1u << 3)
 (USBHS_HSTIDR) Downstream Resume Sent Interrupt Disable
#define USBHS_HSTIDR_RXRSMIEC   (0x1u << 4)
 (USBHS_HSTIDR) Upstream Resume Received Interrupt Disable
#define USBHS_HSTIDR_HSOFIEC   (0x1u << 5)
 (USBHS_HSTIDR) Host Start of Frame Interrupt Disable
#define USBHS_HSTIDR_HWUPIEC   (0x1u << 6)
 (USBHS_HSTIDR) Host Wake-Up Interrupt Disable
#define USBHS_HSTIDR_PEP_0   (0x1u << 8)
 (USBHS_HSTIDR) Pipe 0 Interrupt Disable
#define USBHS_HSTIDR_PEP_1   (0x1u << 9)
 (USBHS_HSTIDR) Pipe 1 Interrupt Disable
#define USBHS_HSTIDR_PEP_2   (0x1u << 10)
 (USBHS_HSTIDR) Pipe 2 Interrupt Disable
#define USBHS_HSTIDR_PEP_3   (0x1u << 11)
 (USBHS_HSTIDR) Pipe 3 Interrupt Disable
#define USBHS_HSTIDR_PEP_4   (0x1u << 12)
 (USBHS_HSTIDR) Pipe 4 Interrupt Disable
#define USBHS_HSTIDR_PEP_5   (0x1u << 13)
 (USBHS_HSTIDR) Pipe 5 Interrupt Disable
#define USBHS_HSTIDR_PEP_6   (0x1u << 14)
 (USBHS_HSTIDR) Pipe 6 Interrupt Disable
#define USBHS_HSTIDR_PEP_7   (0x1u << 15)
 (USBHS_HSTIDR) Pipe 7 Interrupt Disable
#define USBHS_HSTIDR_PEP_8   (0x1u << 16)
 (USBHS_HSTIDR) Pipe 8 Interrupt Disable
#define USBHS_HSTIDR_PEP_9   (0x1u << 17)
 (USBHS_HSTIDR) Pipe 9 Interrupt Disable
#define USBHS_HSTIDR_PEP_10   (0x1u << 18)
 (USBHS_HSTIDR) Pipe 10 Interrupt Disable
#define USBHS_HSTIDR_PEP_11   (0x1u << 19)
 (USBHS_HSTIDR) Pipe 11 Interrupt Disable
#define USBHS_HSTIDR_DMA_1   (0x1u << 25)
 (USBHS_HSTIDR) DMA Channel 1 Interrupt Disable
#define USBHS_HSTIDR_DMA_2   (0x1u << 26)
 (USBHS_HSTIDR) DMA Channel 2 Interrupt Disable
#define USBHS_HSTIDR_DMA_3   (0x1u << 27)
 (USBHS_HSTIDR) DMA Channel 3 Interrupt Disable
#define USBHS_HSTIDR_DMA_4   (0x1u << 28)
 (USBHS_HSTIDR) DMA Channel 4 Interrupt Disable
#define USBHS_HSTIDR_DMA_5   (0x1u << 29)
 (USBHS_HSTIDR) DMA Channel 5 Interrupt Disable
#define USBHS_HSTIDR_DMA_6   (0x1u << 30)
 (USBHS_HSTIDR) DMA Channel 6 Interrupt Disable
#define USBHS_HSTIDR_DMA_7   (0x1u << 31)
 (USBHS_HSTIDR) DMA Channel 7 Interrupt Disable
#define USBHS_HSTIER_DCONNIES   (0x1u << 0)
 (USBHS_HSTIER) Device Connection Interrupt Enable
#define USBHS_HSTIER_DDISCIES   (0x1u << 1)
 (USBHS_HSTIER) Device Disconnection Interrupt Enable
#define USBHS_HSTIER_RSTIES   (0x1u << 2)
 (USBHS_HSTIER) USB Reset Sent Interrupt Enable
#define USBHS_HSTIER_RSMEDIES   (0x1u << 3)
 (USBHS_HSTIER) Downstream Resume Sent Interrupt Enable
#define USBHS_HSTIER_RXRSMIES   (0x1u << 4)
 (USBHS_HSTIER) Upstream Resume Received Interrupt Enable
#define USBHS_HSTIER_HSOFIES   (0x1u << 5)
 (USBHS_HSTIER) Host Start of Frame Interrupt Enable
#define USBHS_HSTIER_HWUPIES   (0x1u << 6)
 (USBHS_HSTIER) Host Wake-Up Interrupt Enable
#define USBHS_HSTIER_PEP_0   (0x1u << 8)
 (USBHS_HSTIER) Pipe 0 Interrupt Enable
#define USBHS_HSTIER_PEP_1   (0x1u << 9)
 (USBHS_HSTIER) Pipe 1 Interrupt Enable
#define USBHS_HSTIER_PEP_2   (0x1u << 10)
 (USBHS_HSTIER) Pipe 2 Interrupt Enable
#define USBHS_HSTIER_PEP_3   (0x1u << 11)
 (USBHS_HSTIER) Pipe 3 Interrupt Enable
#define USBHS_HSTIER_PEP_4   (0x1u << 12)
 (USBHS_HSTIER) Pipe 4 Interrupt Enable
#define USBHS_HSTIER_PEP_5   (0x1u << 13)
 (USBHS_HSTIER) Pipe 5 Interrupt Enable
#define USBHS_HSTIER_PEP_6   (0x1u << 14)
 (USBHS_HSTIER) Pipe 6 Interrupt Enable
#define USBHS_HSTIER_PEP_7   (0x1u << 15)
 (USBHS_HSTIER) Pipe 7 Interrupt Enable
#define USBHS_HSTIER_PEP_8   (0x1u << 16)
 (USBHS_HSTIER) Pipe 8 Interrupt Enable
#define USBHS_HSTIER_PEP_9   (0x1u << 17)
 (USBHS_HSTIER) Pipe 9 Interrupt Enable
#define USBHS_HSTIER_PEP_10   (0x1u << 18)
 (USBHS_HSTIER) Pipe 10 Interrupt Enable
#define USBHS_HSTIER_PEP_11   (0x1u << 19)
 (USBHS_HSTIER) Pipe 11 Interrupt Enable
#define USBHS_HSTIER_DMA_1   (0x1u << 25)
 (USBHS_HSTIER) DMA Channel 1 Interrupt Enable
#define USBHS_HSTIER_DMA_2   (0x1u << 26)
 (USBHS_HSTIER) DMA Channel 2 Interrupt Enable
#define USBHS_HSTIER_DMA_3   (0x1u << 27)
 (USBHS_HSTIER) DMA Channel 3 Interrupt Enable
#define USBHS_HSTIER_DMA_4   (0x1u << 28)
 (USBHS_HSTIER) DMA Channel 4 Interrupt Enable
#define USBHS_HSTIER_DMA_5   (0x1u << 29)
 (USBHS_HSTIER) DMA Channel 5 Interrupt Enable
#define USBHS_HSTIER_DMA_6   (0x1u << 30)
 (USBHS_HSTIER) DMA Channel 6 Interrupt Enable
#define USBHS_HSTIER_DMA_7   (0x1u << 31)
 (USBHS_HSTIER) DMA Channel 7 Interrupt Enable
#define USBHS_HSTPIP_PEN0   (0x1u << 0)
 (USBHS_HSTPIP) Pipe 0 Enable
#define USBHS_HSTPIP_PEN1   (0x1u << 1)
 (USBHS_HSTPIP) Pipe 1 Enable
#define USBHS_HSTPIP_PEN2   (0x1u << 2)
 (USBHS_HSTPIP) Pipe 2 Enable
#define USBHS_HSTPIP_PEN3   (0x1u << 3)
 (USBHS_HSTPIP) Pipe 3 Enable
#define USBHS_HSTPIP_PEN4   (0x1u << 4)
 (USBHS_HSTPIP) Pipe 4 Enable
#define USBHS_HSTPIP_PEN5   (0x1u << 5)
 (USBHS_HSTPIP) Pipe 5 Enable
#define USBHS_HSTPIP_PEN6   (0x1u << 6)
 (USBHS_HSTPIP) Pipe 6 Enable
#define USBHS_HSTPIP_PEN7   (0x1u << 7)
 (USBHS_HSTPIP) Pipe 7 Enable
#define USBHS_HSTPIP_PEN8   (0x1u << 8)
 (USBHS_HSTPIP) Pipe 8 Enable
#define USBHS_HSTPIP_PRST0   (0x1u << 16)
 (USBHS_HSTPIP) Pipe 0 Reset
#define USBHS_HSTPIP_PRST1   (0x1u << 17)
 (USBHS_HSTPIP) Pipe 1 Reset
#define USBHS_HSTPIP_PRST2   (0x1u << 18)
 (USBHS_HSTPIP) Pipe 2 Reset
#define USBHS_HSTPIP_PRST3   (0x1u << 19)
 (USBHS_HSTPIP) Pipe 3 Reset
#define USBHS_HSTPIP_PRST4   (0x1u << 20)
 (USBHS_HSTPIP) Pipe 4 Reset
#define USBHS_HSTPIP_PRST5   (0x1u << 21)
 (USBHS_HSTPIP) Pipe 5 Reset
#define USBHS_HSTPIP_PRST6   (0x1u << 22)
 (USBHS_HSTPIP) Pipe 6 Reset
#define USBHS_HSTPIP_PRST7   (0x1u << 23)
 (USBHS_HSTPIP) Pipe 7 Reset
#define USBHS_HSTPIP_PRST8   (0x1u << 24)
 (USBHS_HSTPIP) Pipe 8 Reset
#define USBHS_HSTFNUM_MFNUM_Pos   0
#define USBHS_HSTFNUM_MFNUM_Msk   (0x7u << USBHS_HSTFNUM_MFNUM_Pos)
 (USBHS_HSTFNUM) Micro Frame Number
#define USBHS_HSTFNUM_MFNUM(value)   ((USBHS_HSTFNUM_MFNUM_Msk & ((value) << USBHS_HSTFNUM_MFNUM_Pos)))
#define USBHS_HSTFNUM_FNUM_Pos   3
#define USBHS_HSTFNUM_FNUM_Msk   (0x7ffu << USBHS_HSTFNUM_FNUM_Pos)
 (USBHS_HSTFNUM) Frame Number
#define USBHS_HSTFNUM_FNUM(value)   ((USBHS_HSTFNUM_FNUM_Msk & ((value) << USBHS_HSTFNUM_FNUM_Pos)))
#define USBHS_HSTFNUM_FLENHIGH_Pos   16
#define USBHS_HSTFNUM_FLENHIGH_Msk   (0xffu << USBHS_HSTFNUM_FLENHIGH_Pos)
 (USBHS_HSTFNUM) Frame Length
#define USBHS_HSTFNUM_FLENHIGH(value)   ((USBHS_HSTFNUM_FLENHIGH_Msk & ((value) << USBHS_HSTFNUM_FLENHIGH_Pos)))
#define USBHS_HSTADDR1_HSTADDRP0_Pos   0
#define USBHS_HSTADDR1_HSTADDRP0_Msk   (0x7fu << USBHS_HSTADDR1_HSTADDRP0_Pos)
 (USBHS_HSTADDR1) USB Host Address
#define USBHS_HSTADDR1_HSTADDRP0(value)   ((USBHS_HSTADDR1_HSTADDRP0_Msk & ((value) << USBHS_HSTADDR1_HSTADDRP0_Pos)))
#define USBHS_HSTADDR1_HSTADDRP1_Pos   8
#define USBHS_HSTADDR1_HSTADDRP1_Msk   (0x7fu << USBHS_HSTADDR1_HSTADDRP1_Pos)
#define USBHS_HSTADDR1_HSTADDRP1(value)   ((USBHS_HSTADDR1_HSTADDRP1_Msk & ((value) << USBHS_HSTADDR1_HSTADDRP1_Pos)))
#define USBHS_HSTADDR1_HSTADDRP2_Pos   16
#define USBHS_HSTADDR1_HSTADDRP2_Msk   (0x7fu << USBHS_HSTADDR1_HSTADDRP2_Pos)
#define USBHS_HSTADDR1_HSTADDRP2(value)   ((USBHS_HSTADDR1_HSTADDRP2_Msk & ((value) << USBHS_HSTADDR1_HSTADDRP2_Pos)))
#define USBHS_HSTADDR1_HSTADDRP3_Pos   24
#define USBHS_HSTADDR1_HSTADDRP3_Msk   (0x7fu << USBHS_HSTADDR1_HSTADDRP3_Pos)
#define USBHS_HSTADDR1_HSTADDRP3(value)   ((USBHS_HSTADDR1_HSTADDRP3_Msk & ((value) << USBHS_HSTADDR1_HSTADDRP3_Pos)))
#define USBHS_HSTADDR2_HSTADDRP4_Pos   0
#define USBHS_HSTADDR2_HSTADDRP4_Msk   (0x7fu << USBHS_HSTADDR2_HSTADDRP4_Pos)
 (USBHS_HSTADDR2) USB Host Address
#define USBHS_HSTADDR2_HSTADDRP4(value)   ((USBHS_HSTADDR2_HSTADDRP4_Msk & ((value) << USBHS_HSTADDR2_HSTADDRP4_Pos)))
#define USBHS_HSTADDR2_HSTADDRP5_Pos   8
#define USBHS_HSTADDR2_HSTADDRP5_Msk   (0x7fu << USBHS_HSTADDR2_HSTADDRP5_Pos)
#define USBHS_HSTADDR2_HSTADDRP5(value)   ((USBHS_HSTADDR2_HSTADDRP5_Msk & ((value) << USBHS_HSTADDR2_HSTADDRP5_Pos)))
#define USBHS_HSTADDR2_HSTADDRP6_Pos   16
#define USBHS_HSTADDR2_HSTADDRP6_Msk   (0x7fu << USBHS_HSTADDR2_HSTADDRP6_Pos)
#define USBHS_HSTADDR2_HSTADDRP6(value)   ((USBHS_HSTADDR2_HSTADDRP6_Msk & ((value) << USBHS_HSTADDR2_HSTADDRP6_Pos)))
#define USBHS_HSTADDR2_HSTADDRP7_Pos   24
#define USBHS_HSTADDR2_HSTADDRP7_Msk   (0x7fu << USBHS_HSTADDR2_HSTADDRP7_Pos)
#define USBHS_HSTADDR2_HSTADDRP7(value)   ((USBHS_HSTADDR2_HSTADDRP7_Msk & ((value) << USBHS_HSTADDR2_HSTADDRP7_Pos)))
#define USBHS_HSTADDR3_HSTADDRP8_Pos   0
#define USBHS_HSTADDR3_HSTADDRP8_Msk   (0x7fu << USBHS_HSTADDR3_HSTADDRP8_Pos)
 (USBHS_HSTADDR3) USB Host Address
#define USBHS_HSTADDR3_HSTADDRP8(value)   ((USBHS_HSTADDR3_HSTADDRP8_Msk & ((value) << USBHS_HSTADDR3_HSTADDRP8_Pos)))
#define USBHS_HSTADDR3_HSTADDRP9_Pos   8
#define USBHS_HSTADDR3_HSTADDRP9_Msk   (0x7fu << USBHS_HSTADDR3_HSTADDRP9_Pos)
#define USBHS_HSTADDR3_HSTADDRP9(value)   ((USBHS_HSTADDR3_HSTADDRP9_Msk & ((value) << USBHS_HSTADDR3_HSTADDRP9_Pos)))
#define USBHS_HSTPIPCFG_ALLOC   (0x1u << 1)
 (USBHS_HSTPIPCFG[10]) Pipe Memory Allocate
#define USBHS_HSTPIPCFG_PBK_Pos   2
#define USBHS_HSTPIPCFG_PBK_Msk   (0x3u << USBHS_HSTPIPCFG_PBK_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Banks
#define USBHS_HSTPIPCFG_PBK(value)   ((USBHS_HSTPIPCFG_PBK_Msk & ((value) << USBHS_HSTPIPCFG_PBK_Pos)))
#define USBHS_HSTPIPCFG_PBK_1_BANK   (0x0u << 2)
 (USBHS_HSTPIPCFG[10]) Single-bank pipe
#define USBHS_HSTPIPCFG_PBK_2_BANK   (0x1u << 2)
 (USBHS_HSTPIPCFG[10]) Double-bank pipe
#define USBHS_HSTPIPCFG_PBK_3_BANK   (0x2u << 2)
 (USBHS_HSTPIPCFG[10]) Triple-bank pipe
#define USBHS_HSTPIPCFG_PSIZE_Pos   4
#define USBHS_HSTPIPCFG_PSIZE_Msk   (0x7u << USBHS_HSTPIPCFG_PSIZE_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Size
#define USBHS_HSTPIPCFG_PSIZE(value)   ((USBHS_HSTPIPCFG_PSIZE_Msk & ((value) << USBHS_HSTPIPCFG_PSIZE_Pos)))
#define USBHS_HSTPIPCFG_PSIZE_8_BYTE   (0x0u << 4)
 (USBHS_HSTPIPCFG[10]) 8 bytes
#define USBHS_HSTPIPCFG_PSIZE_16_BYTE   (0x1u << 4)
 (USBHS_HSTPIPCFG[10]) 16 bytes
#define USBHS_HSTPIPCFG_PSIZE_32_BYTE   (0x2u << 4)
 (USBHS_HSTPIPCFG[10]) 32 bytes
#define USBHS_HSTPIPCFG_PSIZE_64_BYTE   (0x3u << 4)
 (USBHS_HSTPIPCFG[10]) 64 bytes
#define USBHS_HSTPIPCFG_PSIZE_128_BYTE   (0x4u << 4)
 (USBHS_HSTPIPCFG[10]) 128 bytes
#define USBHS_HSTPIPCFG_PSIZE_256_BYTE   (0x5u << 4)
 (USBHS_HSTPIPCFG[10]) 256 bytes
#define USBHS_HSTPIPCFG_PSIZE_512_BYTE   (0x6u << 4)
 (USBHS_HSTPIPCFG[10]) 512 bytes
#define USBHS_HSTPIPCFG_PSIZE_1024_BYTE   (0x7u << 4)
 (USBHS_HSTPIPCFG[10]) 1024 bytes
#define USBHS_HSTPIPCFG_PTOKEN_Pos   8
#define USBHS_HSTPIPCFG_PTOKEN_Msk   (0x3u << USBHS_HSTPIPCFG_PTOKEN_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Token
#define USBHS_HSTPIPCFG_PTOKEN(value)   ((USBHS_HSTPIPCFG_PTOKEN_Msk & ((value) << USBHS_HSTPIPCFG_PTOKEN_Pos)))
#define USBHS_HSTPIPCFG_PTOKEN_SETUP   (0x0u << 8)
 (USBHS_HSTPIPCFG[10]) SETUP
#define USBHS_HSTPIPCFG_PTOKEN_IN   (0x1u << 8)
 (USBHS_HSTPIPCFG[10]) IN
#define USBHS_HSTPIPCFG_PTOKEN_OUT   (0x2u << 8)
 (USBHS_HSTPIPCFG[10]) OUT
#define USBHS_HSTPIPCFG_AUTOSW   (0x1u << 10)
 (USBHS_HSTPIPCFG[10]) Automatic Switch
#define USBHS_HSTPIPCFG_PTYPE_Pos   12
#define USBHS_HSTPIPCFG_PTYPE_Msk   (0x3u << USBHS_HSTPIPCFG_PTYPE_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Type
#define USBHS_HSTPIPCFG_PTYPE(value)   ((USBHS_HSTPIPCFG_PTYPE_Msk & ((value) << USBHS_HSTPIPCFG_PTYPE_Pos)))
#define USBHS_HSTPIPCFG_PTYPE_CTRL   (0x0u << 12)
 (USBHS_HSTPIPCFG[10]) Control
#define USBHS_HSTPIPCFG_PTYPE_ISO   (0x1u << 12)
 (USBHS_HSTPIPCFG[10]) Isochronous
#define USBHS_HSTPIPCFG_PTYPE_BLK   (0x2u << 12)
 (USBHS_HSTPIPCFG[10]) Bulk
#define USBHS_HSTPIPCFG_PTYPE_INTRPT   (0x3u << 12)
 (USBHS_HSTPIPCFG[10]) Interrupt
#define USBHS_HSTPIPCFG_PEPNUM_Pos   16
#define USBHS_HSTPIPCFG_PEPNUM_Msk   (0xfu << USBHS_HSTPIPCFG_PEPNUM_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Endpoint Number
#define USBHS_HSTPIPCFG_PEPNUM(value)   ((USBHS_HSTPIPCFG_PEPNUM_Msk & ((value) << USBHS_HSTPIPCFG_PEPNUM_Pos)))
#define USBHS_HSTPIPCFG_INTFRQ_Pos   24
#define USBHS_HSTPIPCFG_INTFRQ_Msk   (0xffu << USBHS_HSTPIPCFG_INTFRQ_Pos)
 (USBHS_HSTPIPCFG[10]) Pipe Interrupt Request Frequency
#define USBHS_HSTPIPCFG_INTFRQ(value)   ((USBHS_HSTPIPCFG_INTFRQ_Msk & ((value) << USBHS_HSTPIPCFG_INTFRQ_Pos)))
#define USBHS_HSTPIPCFG_PINGEN   (0x1u << 20)
 (USBHS_HSTPIPCFG[10]) Ping Enable
#define USBHS_HSTPIPCFG_BINTERVAL_Pos   24
#define USBHS_HSTPIPCFG_BINTERVAL_Msk   (0xffu << USBHS_HSTPIPCFG_BINTERVAL_Pos)
 (USBHS_HSTPIPCFG[10]) Binterval Parameter for the Bulk-Out/Ping Transaction
#define USBHS_HSTPIPCFG_BINTERVAL(value)   ((USBHS_HSTPIPCFG_BINTERVAL_Msk & ((value) << USBHS_HSTPIPCFG_BINTERVAL_Pos)))
#define USBHS_HSTPIPISR_RXINI   (0x1u << 0)
 (USBHS_HSTPIPISR[10]) Received IN Data Interrupt
#define USBHS_HSTPIPISR_TXOUTI   (0x1u << 1)
 (USBHS_HSTPIPISR[10]) Transmitted OUT Data Interrupt
#define USBHS_HSTPIPISR_TXSTPI   (0x1u << 2)
 (USBHS_HSTPIPISR[10]) Transmitted SETUP Interrupt
#define USBHS_HSTPIPISR_PERRI   (0x1u << 3)
 (USBHS_HSTPIPISR[10]) Pipe Error Interrupt
#define USBHS_HSTPIPISR_NAKEDI   (0x1u << 4)
 (USBHS_HSTPIPISR[10]) NAKed Interrupt
#define USBHS_HSTPIPISR_OVERFI   (0x1u << 5)
 (USBHS_HSTPIPISR[10]) Overflow Interrupt
#define USBHS_HSTPIPISR_RXSTALLDI   (0x1u << 6)
 (USBHS_HSTPIPISR[10]) Received STALLed Interrupt
#define USBHS_HSTPIPISR_SHORTPACKETI   (0x1u << 7)
 (USBHS_HSTPIPISR[10]) Short Packet Interrupt
#define USBHS_HSTPIPISR_DTSEQ_Pos   8
#define USBHS_HSTPIPISR_DTSEQ_Msk   (0x3u << USBHS_HSTPIPISR_DTSEQ_Pos)
 (USBHS_HSTPIPISR[10]) Data Toggle Sequence
#define USBHS_HSTPIPISR_DTSEQ_DATA0   (0x0u << 8)
 (USBHS_HSTPIPISR[10]) Data0 toggle sequence
#define USBHS_HSTPIPISR_DTSEQ_DATA1   (0x1u << 8)
 (USBHS_HSTPIPISR[10]) Data1 toggle sequence
#define USBHS_HSTPIPISR_NBUSYBK_Pos   12
#define USBHS_HSTPIPISR_NBUSYBK_Msk   (0x3u << USBHS_HSTPIPISR_NBUSYBK_Pos)
 (USBHS_HSTPIPISR[10]) Number of Busy Banks
#define USBHS_HSTPIPISR_NBUSYBK_0_BUSY   (0x0u << 12)
 (USBHS_HSTPIPISR[10]) 0 busy bank (all banks free)
#define USBHS_HSTPIPISR_NBUSYBK_1_BUSY   (0x1u << 12)
 (USBHS_HSTPIPISR[10]) 1 busy bank
#define USBHS_HSTPIPISR_NBUSYBK_2_BUSY   (0x2u << 12)
 (USBHS_HSTPIPISR[10]) 2 busy banks
#define USBHS_HSTPIPISR_NBUSYBK_3_BUSY   (0x3u << 12)
 (USBHS_HSTPIPISR[10]) 3 busy banks
#define USBHS_HSTPIPISR_CURRBK_Pos   14
#define USBHS_HSTPIPISR_CURRBK_Msk   (0x3u << USBHS_HSTPIPISR_CURRBK_Pos)
 (USBHS_HSTPIPISR[10]) Current Bank
#define USBHS_HSTPIPISR_CURRBK_BANK0   (0x0u << 14)
 (USBHS_HSTPIPISR[10]) Current bank is bank0
#define USBHS_HSTPIPISR_CURRBK_BANK1   (0x1u << 14)
 (USBHS_HSTPIPISR[10]) Current bank is bank1
#define USBHS_HSTPIPISR_CURRBK_BANK2   (0x2u << 14)
 (USBHS_HSTPIPISR[10]) Current bank is bank2
#define USBHS_HSTPIPISR_RWALL   (0x1u << 16)
 (USBHS_HSTPIPISR[10]) Read/Write Allowed
#define USBHS_HSTPIPISR_CFGOK   (0x1u << 18)
 (USBHS_HSTPIPISR[10]) Configuration OK Status
#define USBHS_HSTPIPISR_PBYCT_Pos   20
#define USBHS_HSTPIPISR_PBYCT_Msk   (0x7ffu << USBHS_HSTPIPISR_PBYCT_Pos)
 (USBHS_HSTPIPISR[10]) Pipe Byte Count
#define USBHS_HSTPIPISR_UNDERFI   (0x1u << 2)
 (USBHS_HSTPIPISR[10]) Underflow Interrupt
#define USBHS_HSTPIPISR_CRCERRI   (0x1u << 6)
 (USBHS_HSTPIPISR[10]) CRC Error Interrupt
#define USBHS_HSTPIPICR_RXINIC   (0x1u << 0)
 (USBHS_HSTPIPICR[10]) Received IN Data Interrupt Clear
#define USBHS_HSTPIPICR_TXOUTIC   (0x1u << 1)
 (USBHS_HSTPIPICR[10]) Transmitted OUT Data Interrupt Clear
#define USBHS_HSTPIPICR_TXSTPIC   (0x1u << 2)
 (USBHS_HSTPIPICR[10]) Transmitted SETUP Interrupt Clear
#define USBHS_HSTPIPICR_NAKEDIC   (0x1u << 4)
 (USBHS_HSTPIPICR[10]) NAKed Interrupt Clear
#define USBHS_HSTPIPICR_OVERFIC   (0x1u << 5)
 (USBHS_HSTPIPICR[10]) Overflow Interrupt Clear
#define USBHS_HSTPIPICR_RXSTALLDIC   (0x1u << 6)
 (USBHS_HSTPIPICR[10]) Received STALLed Interrupt Clear
#define USBHS_HSTPIPICR_SHORTPACKETIC   (0x1u << 7)
 (USBHS_HSTPIPICR[10]) Short Packet Interrupt Clear
#define USBHS_HSTPIPICR_UNDERFIC   (0x1u << 2)
 (USBHS_HSTPIPICR[10]) Underflow Interrupt Clear
#define USBHS_HSTPIPICR_CRCERRIC   (0x1u << 6)
 (USBHS_HSTPIPICR[10]) CRC Error Interrupt Clear
#define USBHS_HSTPIPIFR_RXINIS   (0x1u << 0)
 (USBHS_HSTPIPIFR[10]) Received IN Data Interrupt Set
#define USBHS_HSTPIPIFR_TXOUTIS   (0x1u << 1)
 (USBHS_HSTPIPIFR[10]) Transmitted OUT Data Interrupt Set
#define USBHS_HSTPIPIFR_TXSTPIS   (0x1u << 2)
 (USBHS_HSTPIPIFR[10]) Transmitted SETUP Interrupt Set
#define USBHS_HSTPIPIFR_PERRIS   (0x1u << 3)
 (USBHS_HSTPIPIFR[10]) Pipe Error Interrupt Set
#define USBHS_HSTPIPIFR_NAKEDIS   (0x1u << 4)
 (USBHS_HSTPIPIFR[10]) NAKed Interrupt Set
#define USBHS_HSTPIPIFR_OVERFIS   (0x1u << 5)
 (USBHS_HSTPIPIFR[10]) Overflow Interrupt Set
#define USBHS_HSTPIPIFR_RXSTALLDIS   (0x1u << 6)
 (USBHS_HSTPIPIFR[10]) Received STALLed Interrupt Set
#define USBHS_HSTPIPIFR_SHORTPACKETIS   (0x1u << 7)
 (USBHS_HSTPIPIFR[10]) Short Packet Interrupt Set
#define USBHS_HSTPIPIFR_NBUSYBKS   (0x1u << 12)
 (USBHS_HSTPIPIFR[10]) Number of Busy Banks Set
#define USBHS_HSTPIPIFR_UNDERFIS   (0x1u << 2)
 (USBHS_HSTPIPIFR[10]) Underflow Interrupt Set
#define USBHS_HSTPIPIFR_CRCERRIS   (0x1u << 6)
 (USBHS_HSTPIPIFR[10]) CRC Error Interrupt Set
#define USBHS_HSTPIPIMR_RXINE   (0x1u << 0)
 (USBHS_HSTPIPIMR[10]) Received IN Data Interrupt Enable
#define USBHS_HSTPIPIMR_TXOUTE   (0x1u << 1)
 (USBHS_HSTPIPIMR[10]) Transmitted OUT Data Interrupt Enable
#define USBHS_HSTPIPIMR_TXSTPE   (0x1u << 2)
 (USBHS_HSTPIPIMR[10]) Transmitted SETUP Interrupt Enable
#define USBHS_HSTPIPIMR_PERRE   (0x1u << 3)
 (USBHS_HSTPIPIMR[10]) Pipe Error Interrupt Enable
#define USBHS_HSTPIPIMR_NAKEDE   (0x1u << 4)
 (USBHS_HSTPIPIMR[10]) NAKed Interrupt Enable
#define USBHS_HSTPIPIMR_OVERFIE   (0x1u << 5)
 (USBHS_HSTPIPIMR[10]) Overflow Interrupt Enable
#define USBHS_HSTPIPIMR_RXSTALLDE   (0x1u << 6)
 (USBHS_HSTPIPIMR[10]) Received STALLed Interrupt Enable
#define USBHS_HSTPIPIMR_SHORTPACKETIE   (0x1u << 7)
 (USBHS_HSTPIPIMR[10]) Short Packet Interrupt Enable
#define USBHS_HSTPIPIMR_NBUSYBKE   (0x1u << 12)
 (USBHS_HSTPIPIMR[10]) Number of Busy Banks Interrupt Enable
#define USBHS_HSTPIPIMR_FIFOCON   (0x1u << 14)
 (USBHS_HSTPIPIMR[10]) FIFO Control
#define USBHS_HSTPIPIMR_PDISHDMA   (0x1u << 16)
 (USBHS_HSTPIPIMR[10]) Pipe Interrupts Disable HDMA Request Enable
#define USBHS_HSTPIPIMR_PFREEZE   (0x1u << 17)
 (USBHS_HSTPIPIMR[10]) Pipe Freeze
#define USBHS_HSTPIPIMR_RSTDT   (0x1u << 18)
 (USBHS_HSTPIPIMR[10]) Reset Data Toggle
#define USBHS_HSTPIPIMR_UNDERFIE   (0x1u << 2)
 (USBHS_HSTPIPIMR[10]) Underflow Interrupt Enable
#define USBHS_HSTPIPIMR_CRCERRE   (0x1u << 6)
 (USBHS_HSTPIPIMR[10]) CRC Error Interrupt Enable
#define USBHS_HSTPIPIER_RXINES   (0x1u << 0)
 (USBHS_HSTPIPIER[10]) Received IN Data Interrupt Enable
#define USBHS_HSTPIPIER_TXOUTES   (0x1u << 1)
 (USBHS_HSTPIPIER[10]) Transmitted OUT Data Interrupt Enable
#define USBHS_HSTPIPIER_TXSTPES   (0x1u << 2)
 (USBHS_HSTPIPIER[10]) Transmitted SETUP Interrupt Enable
#define USBHS_HSTPIPIER_PERRES   (0x1u << 3)
 (USBHS_HSTPIPIER[10]) Pipe Error Interrupt Enable
#define USBHS_HSTPIPIER_NAKEDES   (0x1u << 4)
 (USBHS_HSTPIPIER[10]) NAKed Interrupt Enable
#define USBHS_HSTPIPIER_OVERFIES   (0x1u << 5)
 (USBHS_HSTPIPIER[10]) Overflow Interrupt Enable
#define USBHS_HSTPIPIER_RXSTALLDES   (0x1u << 6)
 (USBHS_HSTPIPIER[10]) Received STALLed Interrupt Enable
#define USBHS_HSTPIPIER_SHORTPACKETIES   (0x1u << 7)
 (USBHS_HSTPIPIER[10]) Short Packet Interrupt Enable
#define USBHS_HSTPIPIER_NBUSYBKES   (0x1u << 12)
 (USBHS_HSTPIPIER[10]) Number of Busy Banks Enable
#define USBHS_HSTPIPIER_PDISHDMAS   (0x1u << 16)
 (USBHS_HSTPIPIER[10]) Pipe Interrupts Disable HDMA Request Enable
#define USBHS_HSTPIPIER_PFREEZES   (0x1u << 17)
 (USBHS_HSTPIPIER[10]) Pipe Freeze Enable
#define USBHS_HSTPIPIER_RSTDTS   (0x1u << 18)
 (USBHS_HSTPIPIER[10]) Reset Data Toggle Enable
#define USBHS_HSTPIPIER_UNDERFIES   (0x1u << 2)
 (USBHS_HSTPIPIER[10]) Underflow Interrupt Enable
#define USBHS_HSTPIPIER_CRCERRES   (0x1u << 6)
 (USBHS_HSTPIPIER[10]) CRC Error Interrupt Enable
#define USBHS_HSTPIPIDR_RXINEC   (0x1u << 0)
 (USBHS_HSTPIPIDR[10]) Received IN Data Interrupt Disable
#define USBHS_HSTPIPIDR_TXOUTEC   (0x1u << 1)
 (USBHS_HSTPIPIDR[10]) Transmitted OUT Data Interrupt Disable
#define USBHS_HSTPIPIDR_TXSTPEC   (0x1u << 2)
 (USBHS_HSTPIPIDR[10]) Transmitted SETUP Interrupt Disable
#define USBHS_HSTPIPIDR_PERREC   (0x1u << 3)
 (USBHS_HSTPIPIDR[10]) Pipe Error Interrupt Disable
#define USBHS_HSTPIPIDR_NAKEDEC   (0x1u << 4)
 (USBHS_HSTPIPIDR[10]) NAKed Interrupt Disable
#define USBHS_HSTPIPIDR_OVERFIEC   (0x1u << 5)
 (USBHS_HSTPIPIDR[10]) Overflow Interrupt Disable
#define USBHS_HSTPIPIDR_RXSTALLDEC   (0x1u << 6)
 (USBHS_HSTPIPIDR[10]) Received STALLed Interrupt Disable
#define USBHS_HSTPIPIDR_SHORTPACKETIEC   (0x1u << 7)
 (USBHS_HSTPIPIDR[10]) Short Packet Interrupt Disable
#define USBHS_HSTPIPIDR_NBUSYBKEC   (0x1u << 12)
 (USBHS_HSTPIPIDR[10]) Number of Busy Banks Disable
#define USBHS_HSTPIPIDR_FIFOCONC   (0x1u << 14)
 (USBHS_HSTPIPIDR[10]) FIFO Control Disable
#define USBHS_HSTPIPIDR_PDISHDMAC   (0x1u << 16)
 (USBHS_HSTPIPIDR[10]) Pipe Interrupts Disable HDMA Request Disable
#define USBHS_HSTPIPIDR_PFREEZEC   (0x1u << 17)
 (USBHS_HSTPIPIDR[10]) Pipe Freeze Disable
#define USBHS_HSTPIPIDR_UNDERFIEC   (0x1u << 2)
 (USBHS_HSTPIPIDR[10]) Underflow Interrupt Disable
#define USBHS_HSTPIPIDR_CRCERREC   (0x1u << 6)
 (USBHS_HSTPIPIDR[10]) CRC Error Interrupt Disable
#define USBHS_HSTPIPINRQ_INRQ_Pos   0
#define USBHS_HSTPIPINRQ_INRQ_Msk   (0xffu << USBHS_HSTPIPINRQ_INRQ_Pos)
 (USBHS_HSTPIPINRQ[10]) IN Request Number before Freeze
#define USBHS_HSTPIPINRQ_INRQ(value)   ((USBHS_HSTPIPINRQ_INRQ_Msk & ((value) << USBHS_HSTPIPINRQ_INRQ_Pos)))
#define USBHS_HSTPIPINRQ_INMODE   (0x1u << 8)
 (USBHS_HSTPIPINRQ[10]) IN Request Mode
#define USBHS_HSTPIPERR_DATATGL   (0x1u << 0)
 (USBHS_HSTPIPERR[10]) Data Toggle Error
#define USBHS_HSTPIPERR_DATAPID   (0x1u << 1)
 (USBHS_HSTPIPERR[10]) Data PID Error
#define USBHS_HSTPIPERR_PID   (0x1u << 2)
#define USBHS_HSTPIPERR_TIMEOUT   (0x1u << 3)
 (USBHS_HSTPIPERR[10]) Time-Out Error
#define USBHS_HSTPIPERR_CRC16   (0x1u << 4)
 (USBHS_HSTPIPERR[10]) CRC16 Error
#define USBHS_HSTPIPERR_COUNTER_Pos   5
#define USBHS_HSTPIPERR_COUNTER_Msk   (0x3u << USBHS_HSTPIPERR_COUNTER_Pos)
 (USBHS_HSTPIPERR[10]) Error Counter
#define USBHS_HSTPIPERR_COUNTER(value)   ((USBHS_HSTPIPERR_COUNTER_Msk & ((value) << USBHS_HSTPIPERR_COUNTER_Pos)))
#define USBHS_HSTDMANXTDSC_NXT_DSC_ADD_Pos   0
#define USBHS_HSTDMANXTDSC_NXT_DSC_ADD_Msk   (0xffffffffu << USBHS_HSTDMANXTDSC_NXT_DSC_ADD_Pos)
 (USBHS_HSTDMANXTDSC) Next Descriptor Address
#define USBHS_HSTDMANXTDSC_NXT_DSC_ADD(value)   ((USBHS_HSTDMANXTDSC_NXT_DSC_ADD_Msk & ((value) << USBHS_HSTDMANXTDSC_NXT_DSC_ADD_Pos)))
#define USBHS_HSTDMAADDRESS_BUFF_ADD_Pos   0
#define USBHS_HSTDMAADDRESS_BUFF_ADD_Msk   (0xffffffffu << USBHS_HSTDMAADDRESS_BUFF_ADD_Pos)
 (USBHS_HSTDMAADDRESS) Buffer Address
#define USBHS_HSTDMAADDRESS_BUFF_ADD(value)   ((USBHS_HSTDMAADDRESS_BUFF_ADD_Msk & ((value) << USBHS_HSTDMAADDRESS_BUFF_ADD_Pos)))
#define USBHS_HSTDMACONTROL_CHANN_ENB   (0x1u << 0)
 (USBHS_HSTDMACONTROL) Channel Enable Command
#define USBHS_HSTDMACONTROL_LDNXT_DSC   (0x1u << 1)
 (USBHS_HSTDMACONTROL) Load Next Channel Transfer Descriptor Enable Command
#define USBHS_HSTDMACONTROL_END_TR_EN   (0x1u << 2)
 (USBHS_HSTDMACONTROL) End of Transfer Enable Control (OUT transfers only)
#define USBHS_HSTDMACONTROL_END_B_EN   (0x1u << 3)
 (USBHS_HSTDMACONTROL) End of Buffer Enable Control
#define USBHS_HSTDMACONTROL_END_TR_IT   (0x1u << 4)
 (USBHS_HSTDMACONTROL) End of Transfer Interrupt Enable
#define USBHS_HSTDMACONTROL_END_BUFFIT   (0x1u << 5)
 (USBHS_HSTDMACONTROL) End of Buffer Interrupt Enable
#define USBHS_HSTDMACONTROL_DESC_LD_IT   (0x1u << 6)
 (USBHS_HSTDMACONTROL) Descriptor Loaded Interrupt Enable
#define USBHS_HSTDMACONTROL_BURST_LCK   (0x1u << 7)
 (USBHS_HSTDMACONTROL) Burst Lock Enable
#define USBHS_HSTDMACONTROL_BUFF_LENGTH_Pos   16
#define USBHS_HSTDMACONTROL_BUFF_LENGTH_Msk   (0xffffu << USBHS_HSTDMACONTROL_BUFF_LENGTH_Pos)
 (USBHS_HSTDMACONTROL) Buffer Byte Length (Write-only)
#define USBHS_HSTDMACONTROL_BUFF_LENGTH(value)   ((USBHS_HSTDMACONTROL_BUFF_LENGTH_Msk & ((value) << USBHS_HSTDMACONTROL_BUFF_LENGTH_Pos)))
#define USBHS_HSTDMASTATUS_CHANN_ENB   (0x1u << 0)
 (USBHS_HSTDMASTATUS) Channel Enable Status
#define USBHS_HSTDMASTATUS_CHANN_ACT   (0x1u << 1)
 (USBHS_HSTDMASTATUS) Channel Active Status
#define USBHS_HSTDMASTATUS_END_TR_ST   (0x1u << 4)
 (USBHS_HSTDMASTATUS) End of Channel Transfer Status
#define USBHS_HSTDMASTATUS_END_BF_ST   (0x1u << 5)
 (USBHS_HSTDMASTATUS) End of Channel Buffer Status
#define USBHS_HSTDMASTATUS_DESC_LDST   (0x1u << 6)
 (USBHS_HSTDMASTATUS) Descriptor Loaded Status
#define USBHS_HSTDMASTATUS_BUFF_COUNT_Pos   16
#define USBHS_HSTDMASTATUS_BUFF_COUNT_Msk   (0xffffu << USBHS_HSTDMASTATUS_BUFF_COUNT_Pos)
 (USBHS_HSTDMASTATUS) Buffer Byte Count
#define USBHS_HSTDMASTATUS_BUFF_COUNT(value)   ((USBHS_HSTDMASTATUS_BUFF_COUNT_Msk & ((value) << USBHS_HSTDMASTATUS_BUFF_COUNT_Pos)))
#define USBHS_CTRL_RDERRE   (0x1u << 4)
 (USBHS_CTRL) Remote Device Connection Error Interrupt Enable
#define USBHS_CTRL_VBUSHWC   (0x1u << 8)
 (USBHS_CTRL) VBUS Hardware Control
#define USBHS_CTRL_FRZCLK   (0x1u << 14)
 (USBHS_CTRL) Freeze USB Clock
#define USBHS_CTRL_USBE   (0x1u << 15)
 (USBHS_CTRL) USBHS Enable
#define USBHS_CTRL_UIMOD   (0x1u << 25)
 (USBHS_CTRL) USBHS Mode
#define USBHS_CTRL_UIMOD_HOST   (0x0u << 25)
 (USBHS_CTRL) The module is in USB Host mode.
#define USBHS_CTRL_UIMOD_DEVICE   (0x1u << 25)
 (USBHS_CTRL) The module is in USB Device mode.
#define USBHS_SR_RDERRI   (0x1u << 4)
 (USBHS_SR) Remote Device Connection Error Interrupt (Host mode only)
#define USBHS_SR_VBUSRQ   (0x1u << 9)
 (USBHS_SR) VBUS Request (Host mode only)
#define USBHS_SR_SPEED_Pos   12
#define USBHS_SR_SPEED_Msk   (0x3u << USBHS_SR_SPEED_Pos)
 (USBHS_SR) Speed Status (Device mode only)
#define USBHS_SR_SPEED_FULL_SPEED   (0x0u << 12)
 (USBHS_SR) Full-Speed mode
#define USBHS_SR_SPEED_HIGH_SPEED   (0x1u << 12)
 (USBHS_SR) High-Speed mode
#define USBHS_SR_SPEED_LOW_SPEED   (0x2u << 12)
 (USBHS_SR) Low-Speed mode
#define USBHS_SR_CLKUSABLE   (0x1u << 14)
 (USBHS_SR) UTMI Clock Usable
#define USBHS_SCR_RDERRIC   (0x1u << 4)
 (USBHS_SCR) Remote Device Connection Error Interrupt Clear
#define USBHS_SCR_VBUSRQC   (0x1u << 9)
 (USBHS_SCR) VBUS Request Clear
#define USBHS_SFR_RDERRIS   (0x1u << 4)
 (USBHS_SFR) Remote Device Connection Error Interrupt Set
#define USBHS_SFR_VBUSRQS   (0x1u << 9)
 (USBHS_SFR) VBUS Request Set
SOFTWARE API DEFINITION FOR USB High-Speed Interface
