RTEMS  5.1
twid.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _TWID_
31 #define _TWID_
32
33 /*----------------------------------------------------------------------------
34  * Headers
35  *----------------------------------------------------------------------------*/
36
37 #include "chip.h"
38
39 #include <stdint.h>
40
41 /*----------------------------------------------------------------------------
42  * Definition
43  *----------------------------------------------------------------------------*/
44
46 #define TWID_ERROR_BUSY 1
47
49 #define ASYNC_STATUS_PENDING 0xFF
50 #ifdef __cplusplus
51 extern "C" {
52 #endif
53
54 /*----------------------------------------------------------------------------
55  * Types
56  *----------------------------------------------------------------------------*/
57
58 /*----------------------------------------------------------------------------
59 * Type
60 *----------------------------------------------------------------------------*/
62 typedef struct _Async {
64  volatile uint32_t status;
66  void *callback;
68  uint8_t pStorage[9];
69 } Async;
70
72 typedef struct _Twid {
77 } Twid;
78
80 typedef struct {
81  uint8_t Twi_id;
86 } TwihsDma;
87
88 /*----------------------------------------------------------------------------
89  * Export functions
90  *----------------------------------------------------------------------------*/
91 extern void TWID_Initialize(Twid *pTwid, Twihs *pTwi);
92 extern void TWID_DmaInitialize(TwihsDma *pTwidma, Twihs *pTwi,
93  uint8_t bPolling);
94
95 extern void TWID_Handler(Twid *pTwid);
96
97 extern uint32_t ASYNC_IsFinished(Async *pAsync);
98
99 extern uint8_t TWID_Read(
100  Twid *pTwid,
101  uint8_t address,
102  uint32_t iaddress,
103  uint8_t isize,
104  uint8_t *pData,
105  uint32_t num,
106  Async *pAsync);
107
108 extern uint8_t TWID_Write(
109  Twid *pTwid,
110  uint8_t address,
111  uint32_t iaddress,
112  uint8_t isize,
113  uint8_t *pData,
114  uint32_t num,
115  Async *pAsync);
116
117 extern uint8_t TWID_DmaRead(
118  TwihsDma *pTwiXdma,
119  uint8_t address,
120  uint32_t iaddress,
121  uint8_t isize,
122  uint8_t *pData,
123  uint32_t num,
124  Async *pAsync);
125
126 extern uint8_t TWID_DmaWrite(
127  TwihsDma *pTwiXdma,
128  uint8_t address,
129  uint32_t iaddress,
130  uint8_t isize,
131  uint8_t *pData,
132  uint32_t num,
133  Async *pAsync);
134
135 #ifdef __cplusplus
136 }
137 #endif
138
139 #endif //#ifndef TWID_H
140
TWI driver structure. Holds the internal state of the driver.
Definition: twid.h:80
Async * pTransfer
Definition: twid.h:76
Definition: twid.h:64
Twihs * pTwi
Definition: twid.h:74
Asynchronous transfer descriptor.
Definition: twid.h:62
void * callback
Definition: twid.h:66
uint8_t pStorage[9]
Definition: twid.h:68
Twid * pTwid
Definition: twid.h:83
Twihs hardware registers.
Definition: component_twihs.h:41
sXdmad * pTwiDma
Definition: twid.h:85
Definition: xdmad.h:127
Definition: twid.h:72
