RTEMS  5.1
ti-tmp112.h
1 /*
2  * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org>
3  * All rights reserved.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /*
11  * TI TMP112
12  * http://www.ti.com/product/TMP112
13  */
14
15 #ifndef TI_TMP112_H
16 #define TI_TMP112_H
17
18 #include <dev/i2c/i2c.h>
19
20 /*
21  * Confirguration.
22  */
23 #define TI_TMP112_CR_0_25Hz (0 << 6)
24 #define TI_TMP112_CR_1Hz (1 << 6)
25 #define TI_TMP112_CR_4Hz (2 << 6) /* default */
26 #define TI_TMP112_CR_8Hz (3 << 6)
27 #define TI_TMP112_EM_NORMAL (0 << 4) /* default */
28 #define TI_TMP112_EM_EXTENDED (1 << 4)
29 #define TI_TMP112_SD_ON (0 << 8) /* default */
30 #define TI_TMP112_SD_SHUTDOWN (1 << 8)
31 #define TI_TMP112_TM_COMPARATOR (0 << 9) /* default */
32 #define TI_TMP112_TM_INTERRUPT (1 << 9)
33 #define TI_TMP112_POL_ALERT_LOW (0 << 10) /* default */
34 #define TI_TMP112_POL_ALERT_HIGH (1 << 10)
35 #define TI_TMP112_FQL_1 (0 << 11) /* default */
36 #define TI_TMP112_FQL_2 (1 << 11)
37 #define TI_TMP112_FQL_4 (2 << 11)
38 #define TI_TMP112_FQL_6 (3 << 11)
39
40 /*
41  * IO control interface.
42  */
43 #define TI_TMP112_GET_TEMP (I2C_DEV_IO_CONTROL + 0)
44 #define TI_TMP112_GET_TEMP_RAW (I2C_DEV_IO_CONTROL + 1)
45 #define TI_TMP112_SET_CONFIG (I2C_DEV_IO_CONTROL + 2)
46 #define TI_TMP112_SET_LOW_TEMP (I2C_DEV_IO_CONTROL + 3)
47 #define TI_TMP112_SET_HIGH_TEMP (I2C_DEV_IO_CONTROL + 4)
48
49 /*
50  * Register the device.
51  */
52 int i2c_dev_register_ti_tmp112(const char* bus_path,
53  const char* dev_path,
54  uint16_t address);
55
56 /*
57  * Get the temperature in degrees C x 10000. To print you would so:
58  *
59  * printf("Temperature is %3d.%04d\n", temp / 10000, temp % 10000);
60  *
61  * If the device is shutdown a single conversion is made waiting for the
62  * conversion to complete.
63  */
64 static inline int
65 ti_tmp112_get_temperature(int fd, int* temp)
66 {
67  return ioctl(fd, TI_TMP112_GET_TEMP, temp);
68 }
69
70 /*
71  * Get the temperature as the raw register value.
72  *
73  * If the device is shutdown a single conversion is made waiting for the
74  * conversion to complete.
75  */
76 static inline int
77 ti_tmp112_get_temperature_raw(int fd, unsigned int* temp)
78 {
79  return ioctl(fd, TI_TMP112_GET_TEMP_RAW, temp);
80 }
81
82 /*
83  * Set the configuration.
84  */
85 static inline int
86 ti_tmp112_adc_set_config(int fd, uint16_t config)
87 {
88  return ioctl(fd, TI_TMP112_SET_CONFIG, (void *)(uintptr_t) config);
89 }
90
91 /*
92  * Set the low temperature.
93  */
94 static inline int
95 ti_tmp112_set_low_temperator(int fd, uint16_t temp)
96 {
97  return ioctl(fd, TI_TMP112_SET_LOW_TEMP, (void *)(uintptr_t) temp);
98 }
99
100 /*
101  * Set the high temperature.
102  */
103 static inline int
104 ti_tmp112_adc_set_high_threshold(int fd, uint16_t level)
105 {
106  return ioctl(fd, TI_TMP112_SET_HIGH_TEMP, (void *)(uintptr_t) level);
107 }
108
109 #endif
Definition: deflate.c:115
Inter-Integrated Circuit (I2C) Driver API.
